- To: <>
- Subject: RE: [cgal-discuss] surface point insertion
- Date: Thu, 5 Sep 2013 12:02:32 +0000
- Accept-language: fr-CH, de-CH, en-US
Hi Mariette, Thanks a lot for the help,
I want to keep connectivity between the points (edges) as well. I tried c3t3.triangulatiun().insert() but only the points were inserted and their connection (edges) are not preserved.
I have a mesh c3t3. I have another surface (polyhedron) covering this mesh (with no intersection, good point). I want to add the covered surface points and its edges as well.
I used add feature function but there are many edges to be preserved.
I wanted to know if there is another way to insert the surface points with the connectivity?
Do you think this is possible if I insert the surface points and then I play over the mesh criteria (in the remesh step) in order to keep the connections?
On Behalf Of Mariette Yvinec
Hi Laurent,I am looking for an example using the following function,But before I want to know if this preserves the surface connectivity as well?c3t3.insert_surface_points(...))I tried also to add a contour (as a feature) from the respective surface using:domain.add_features(polylines.begin(), polylines.end());this works perfectly but when I added all edges from the surface, I was not successful.-----Original Message-----From: [mailto:] On Behalf Of Laurent Rineau (CGAL/GeometryFactory)Sent: Tuesday, September 03, 2013 5:42 PMTo:Subject: Re: [cgal-discuss] surface point insertionLe mardi 03 septembre 2013 15:37:17 a écrit :Is there any example for inserting surface points (with connectivity)into a volumetric mesh?Please be more explicit. What do you call a volumetric mesh? The 'c3t3'created by the CGAL 3D mesh generator?What you want is probably quite difficult to implement without knowing a lot of the internal of the CGAL 3D mesh generator.--Laurent Rineau, PhDR&D Engineer at GeometryFactory http://www.geometryfactory.com/Release Manager of the CGAL Project http://www.cgal.org/
-- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] surface point insertion, kamal.shahim, 09/03/2013
- Re: [cgal-discuss] surface point insertion, Laurent Rineau (CGAL/GeometryFactory), 09/03/2013
- RE: [cgal-discuss] surface point insertion, kamal.shahim, 09/03/2013
- Re: [cgal-discuss] surface point insertion, Mariette Yvinec, 09/05/2013
- RE: [cgal-discuss] surface point insertion, kamal.shahim, 09/05/2013
