- To: <>
- Subject: RE: [cgal-discuss] [Solved] CGAL 4.1: Cmake configuration for Boost on Windows
- Date: Sat, 7 Sep 2013 18:05:15 +0100
Andreas, thanks for your help, greatly appreciated.
-----Original Message-----
[mailto:]
On Behalf Of Andreas Fabri
Sent: 07 September 2013 17:33
To:
Subject: Re: [cgal-discuss] [Solved] CGAL 4.1: Cmake configuration for Boost
on Windows
On 07/09/2013 18:05,
wrote:
> Ended up rebuilding Boost with the following:
> bjam.exe toolset=msvc --build-dir=u:\pkg\boost\build --with-test
> --with-system --with-wave --with-filesystem --with-program_options
> --with-date_time --with-thread variant=release,debug threading=multi
> link=shared runtime-link=shared install --prefix=u:\pkg\boost
> i.e. CGAL expects all boost libraries to be packaged as DLL files on
> Windows.
> Need to find out how to configure CGAL to expect static boost
> libraries and MSVC runtimes ....
In cmake-gui select Advanced
The variable is CGAL_Boost_USE_STATIC_LIBS
andreas
- RE: [cgal-discuss] [Solved] CGAL 4.1: Cmake configuration for Boost on Windows, g4, 09/07/2013
- Re: [cgal-discuss] [Solved] CGAL 4.1: Cmake configuration for Boost on Windows, Andreas Fabri, 09/07/2013
