cgal-discuss - RE: [cgal-discuss] QT3 -> Qt4 conversion
  • To: <>
  • Subject: RE: [cgal-discuss] QT3 -> Qt4 conversion
  • Date: Sun, 8 Sep 2013 17:00:37 +0100
Plugins were missing libgmp and libmpfr DLL files. All working now ...
-----Original Message-----
[mailto:]
On Behalf Of
Sent: 08 September 2013 16:48
To:
Hi Andrea, thanks for the heads-up. I've encountered a number of problems
getting this project to build and run:
Using Boost 1.52 /CGAL 4.3B1 / QT4 with VS2012 Pro SP1. CGAL installed with
precompiled TAUCS packages.
1. A number of the plug-ins (PCA and jet-fitting for example) refuse to link
with lots of
liblapack.lib(dgelss.o) : error LNK2026: module unsafe for SAFESEH image.
These can obviously be 'fixed' by setting the linker options to /SAFESEH:No
but it's a pain ....
2. Next issue is that in debug mode these refuse to link with due to
something (not sure which yet) using the release mode MSVCRT libs ...
3. When I run Polyhedron the QT UI comes up but there are a slew of console
errors, examples of which are:
### Loading "nef_io_plugin.dll"...
Error loading "nef_io_plugin.dll": Cannot load library
U:/bin/cgal/demo/polyhedron/Debug/nef_io_plugin.dll: The specified module
could not be found.
### Loading "nef_plugin.dll"...
Error loading "nef_plugin.dll": Cannot load library
U:/bin/cgal/demo/polyhedron/Debug/nef_plugin.dll: The specified module could
not be found.
### Loading "off_plugin.dll"...
Error loading "off_plugin.dll": Cannot load library
U:/bin/cgal/demo/polyhedron/Debug/off_plugin.dll: The specified module could
not be found.
The DLL files *are* in the main solution output folder - so I'm not sure if
this error message is simply misleading and in fact means the DLLs cannot be
loaded because they have some missing dependencies. Having just stepped
through the QT code it is actually hard to tell.
I will investigate this but am asking here just in case this is some weird
but known issue.
Also does anyone have a precompiled version of Polyhedron for Windows which
does load .OFF files? I am indeed especially interested in seeing the
Boolean operations at work.
Thanks.
Jerry.
[mailto:]
On Behalf Of Andreas Fabri
Sent: 07 September 2013 20:23
To:
Subject: Re: [cgal-discuss] QT3 -> Qt4 conversion
On 07/09/2013 19:30,
wrote:
> Before I start hacking about . I'm looking at the NEF3 demo which
> includes the QT3 based file viewer etc. QT3 for Windows is unavailable
> so I'm seeing what is required to update it to QT4. The cmakelists
> file is the obvious place to start. Can I simply replace the QT3
> references with QT4 and copy the main used in the QT4 based
> GraphicsView
demo?
> Cheers.
> *QT3 was never made available as a free download for Windows (or is no
> longer in the QT archives).
Note that the Boolean operations are integrated in the Polyhedron demo.
andreas
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
