cgal-discuss - Re: [cgal-discuss] failing to compile Mesh_3 demo on Mac, due to GLEW?
  • To:
  • Subject: Re: [cgal-discuss] failing to compile Mesh_3 demo on Mac, due to GLEW?
  • Date: Tue, 10 Sep 2013 09:24:12 +0200
On 09/10/2013 09:19 AM, Marc Pouget wrote:
Hi,
I use a homebrew install of many things including cgal 4.2 and GLEW, and I'm
trying to compile the Mesh_3 demo of CGAL-4.3-beta1.
GLEW is not found by cmake so I used
cmake -DGLEW_INCLUDE_DIR=/usr/local/Cellar/glew/1.10.0/include/GL
-DGLEW_GLEW_LIBRARY=/usr/local/Cellar/glew/1.10.0/lib/libGLEW.dylib .
I think it should be
-DGLEW_LIBRARY=/usr/local/Cellar/glew/1.10.0/lib/libGLEW.dylib
Sebastien.
but libmesh_3_demo_volume_planes_plugin fails to link:
Linking CXX shared module libmesh_3_demo_volume_planes_plugin.so
ld: warning: duplicate dylib /usr/local/lib/libboost_thread-mt.dylib
ld: warning: duplicate dylib /usr/local/lib/libboost_system-mt.dylib
ld: warning: duplicate dylib /usr/local/Cellar/cgal/4.2/lib/libCGAL_Qt4.dylib
/usr/local/Cellar/cgal/4.2/lib/libCGAL_ImageIO.dylib
ld: warning: duplicate dylib /usr/local/Cellar/cgal/4.2/lib/libCGAL.dylib
ld: warning: duplicate dylib /usr/lib/libz.dylib
Undefined symbols:
"typeinfo for MainWindow", referenced from:
Volume_plane_plugin::init(QMainWindow*, Scene_interface*) in
Volume_planes_plugin.cpp.o
ld: symbol(s) not found
Note that without glew, this lib is not build and the others are compiling
fine. I also tried to compile and use the lib from CGAL-4.3-beta1 and got the
same error.
Any ideas welcome,
best,
Marc
More logs:
make VERBOSE=1 mesh_3_demo_volume_planes_plugin gives:
/usr/local/Cellar/cmake/2.8.11.2/bin/cmake
-H/Users/pougetma/Library/CGAL-4.3-beta1/demo/Mesh_3
-B/Users/pougetma/Library/CGAL-4.3-beta1/demo/Mesh_3 --check-build-system
CMakeFiles/Makefile.cmake 0
Re-run cmake file: Makefile older than: CMakeCache.txt
-- Build type: Debug
-- USING CXXFLAGS = ' -frounding-math -fno-strict-aliasing -g'
-- USING EXEFLAGS = '
-Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
-- Targetting Unix Makefiles
-- Using /usr/bin/g++ compiler.
-- DARWIN_VERSION=10
-- Mac Leopard detected
-- Requested component: Qt4
-- Found Qt4: /usr/local/bin/qmake (found version "4.8.5")
-- Requested component: ImageIO
-- Requested component: MPFR
-- Requested component: GMP
-- Found Glew: /usr/local/Cellar/glew/1.10.0/lib/libGLEW.dylib;-framework
Cocoa
-- Boost version: 1.54.0
-- Found the following Boost libraries:
-- thread
-- system
-- Found QGLViewer: /usr/lib/qglviewer.framework
-- Configuring done
-- Generating done
-- Build files have been written to:
make -f CMakeFiles/Makefile2 mesh_3_demo_volume_planes_plugin
/usr/local/Cellar/cmake/2.8.11.2/bin/cmake -E cmake_progress_start
/Users/pougetma/Library/CGAL-4.3-beta1/demo/Mesh_3/CMakeFiles 18
CMakeFiles/mesh_3_demo_volume_planes_plugin.dir/all
make -f CMakeFiles/mesh_3_demo_viewer.dir/build.make
CMakeFiles/mesh_3_demo_viewer.dir/depend
cd /Users/pougetma/Library/CGAL-4.3-beta1/demo/Mesh_3&&
/usr/local/Cellar/cmake/2.8.11.2/bin/cmake -E cmake_depends "Unix Makefiles"
/Users/pougetma/Library/CGAL-4.3-beta1/demo/Mesh_3/CMakeFiles/mesh_3_demo_viewer.dir/DependInfo.cmake
--color=
make[3]: Nothing to be done for `CMakeFiles/mesh_3_demo_viewer.dir/build'.
/usr/local/Cellar/cmake/2.8.11.2/bin/cmake -E cmake_progress_report
/Users/pougetma/Library/CGAL-4.3-beta1/demo/Mesh_3/CMakeFiles 56 57 58
[ 16%] Built target mesh_3_demo_viewer
make -f CMakeFiles/mesh_3_demo_scene_item.dir/build.make
CMakeFiles/mesh_3_demo_scene_item.dir/depend
/Users/pougetma/Library/CGAL-4.3-beta1/demo/Mesh_3/CMakeFiles/mesh_3_demo_scene_item.dir/DependInfo.cmake
--color=
make[3]: Nothing to be done for `CMakeFiles/mesh_3_demo_scene_item.dir/build'.
/Users/pougetma/Library/CGAL-4.3-beta1/demo/Mesh_3/CMakeFiles 47 48 49 50 51
[ 44%] Built target mesh_3_demo_scene_item
make -f CMakeFiles/mesh_3_demo_scene_segmented_image_item.dir/build.make
CMakeFiles/mesh_3_demo_scene_segmented_image_item.dir/depend
/Users/pougetma/Library/CGAL-4.3-beta1/demo/Mesh_3/CMakeFiles/mesh_3_demo_scene_segmented_image_item.dir/DependInfo.cmake
--color=
`CMakeFiles/mesh_3_demo_scene_segmented_image_item.dir/build'.
/Users/pougetma/Library/CGAL-4.3-beta1/demo/Mesh_3/CMakeFiles 54 55
[ 55%] Built target mesh_3_demo_scene_segmented_image_item
make -f CMakeFiles/mesh_3_demo_volume_planes_plugin.dir/build.make
CMakeFiles/mesh_3_demo_volume_planes_plugin.dir/depend
/Users/pougetma/Library/CGAL-4.3-beta1/demo/Mesh_3/CMakeFiles/mesh_3_demo_volume_planes_plugin.dir/DependInfo.cmake
--color=
/usr/local/Cellar/cmake/2.8.11.2/bin/cmake -E cmake_link_script
CMakeFiles/mesh_3_demo_volume_planes_plugin.dir/link.txt --verbose=1
/usr/bin/g++ -frounding-math -fno-strict-aliasing -g -bundle
-Wl,-headerpad_max_install_names
-o libmesh_3_demo_volume_planes_plugin.so
CMakeFiles/mesh_3_demo_volume_planes_plugin.dir/Volume_planes_plugin.cpp.o
CMakeFiles/mesh_3_demo_volume_planes_plugin.dir/moc_Volume_plane_thread.cxx.o
CMakeFiles/mesh_3_demo_volume_planes_plugin.dir/moc_Volume_plane_interface.cxx.o
CMakeFiles/mesh_3_demo_volume_planes_plugin.dir/Volume_plane_intersection.cpp.o
-F/usr/local/Cellar/qt/4.8.5/lib -F/usr/lib
-L/usr/local/Cellar/cgal/4.2/lib -L/usr/local/lib
/usr/local/lib/libmpfr.dylib /usr/local/lib/libgmp.dylib
/usr/local/lib/libboost_thread-mt.dylib /usr/local/lib/libboost_system-mt
.dylib -framework QtOpenGL -framework QtGui -framework QtCore -framework AGL
-framework OpenGL -framework AGL -framework OpenGL /usr/lib/libz.dylib
-framework QtOpenGL -framework QtScript -framework QtGui -framework QtXml
-framework QtCore libmesh_3_demo_scene_item.dylib
/usr/local/lib/libboost_system-mt.dylib -framework QtOpenGL -framework QtGui
-framework QtCore -framework AGL -framework OpenGL -framework AGL -framework
OpenGL /usr/lib/libz.dylib libmesh_3_demo_scene_segmented_image_item.dylib
libmesh_3_demo_viewer.dylib libmesh_3_demo_scene_item.dylib
/usr/local/Cellar/glew/1.10.0/lib/libGLEW.dylib -framework Cocoa
lib/libCGAL.dylib /usr/local/lib/libboost_thread-mt.dylib
/usr/local/lib/libboost_system-mt.dylib -framework qglviewer -framework
QtOpenGL -framework QtScript -framework QtGui -framework QtXml -framework
QtCore -framework AGL -framework OpenGL -framework AGL -framework OpenGL
/usr/lib/libz.dylib
Undefined symbols:
collect2: ld returned 1 exit status
make[3]: *** [libmesh_3_demo_volume_planes_plugin.so] Error 1
make[2]: *** [CMakeFiles/mesh_3_demo_volume_planes_plugin.dir/all] Error 2
make[1]: *** [CMakeFiles/mesh_3_demo_volume_planes_plugin.dir/rule] Error 2
make: *** [mesh_3_demo_volume_planes_plugin] Error 2
