cgal-discuss - Re: [cgal-discuss] get Primitive in AABB tree by id
  • To:
  • Subject: Re: [cgal-discuss] get Primitive in AABB tree by id
  • Date: Thu, 19 Sep 2013 17:11:21 +0200
This is not the right list for posting, you should use
http://groups.google.com/group/cgal-bindings-discuss
The integer should be the position of the segment in the input list.
Sebastien.
On 09/19/2013 04:01 PM, 0oo1l0 wrote:
Hi, I'm trying to solve a problem that I've researched here but havent'
been able to totally figure out from previous posts. My query is directed
to the python-bindings of cgal but if anyone can give me hints via the cpp
that would also be appreciated.
I have an AABB tree built with a list of segments (tree), a segment query
(sa) and a python list (s) that can take iterator output.
I run:
tree.do_intersect(sa)
tree.any_intersected_primitive(sa,s)
and then I get an intersection out of the function (whose .value() is a
Point_3) and the primitive id, which in this case is an integer, in s.
How can I use the id to return the segment in the AABB tree that generated
the intersection? If it can't be done with the lists of Segment_3s, how
could I change the methodology (--should they be Line_3s?--) so that I can
find the point of intersection and the primitive that intersects with the
query? I understand that in some AABB trees the Id is a handler but I don't
know how to point that to the AABB.tree primitive. And, anyway, in this
case (Segment_3 list and with a Segment_3 query) the Id is just an integer!
Thanks for any help.
(Also, great tool this library is!)
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/get-Primitive-in-AABB-tree-by-id-tp4658059.html
