cgal-discuss - Re: [cgal-discuss] Assertion converting Polyhedron_3 to Nef_polyhedron_3 / Nef_polyhedron VERY slow with extended kernel
  • To:
  • Subject: Re: [cgal-discuss] Assertion converting Polyhedron_3 to Nef_polyhedron_3 / Nef_polyhedron VERY slow with extended kernel
  • Date: Fri, 27 Sep 2013 16:58:09 +0200
  • Organization: Fraunhofer ITWM
On 09/27/2013 07:20 AM, Sebastien Loriot (GeometryFactory) wrote:
> In the non-triangulated version, your polyhedron has some facets with
> its points not being exactly in a plane. Nef does not like that.
Yes, that's what I guessed might be the problem. Hence trying to
triangulate the polyhedron faces by simply adding some diagonals.
> In the triangulated version, your polyhedron has some self-intersections
> which I suspect to be the reason why Nef is not happy.
I did not realize the polyhedron is degenerated. I will have to further
investigate how I could come up with this degenerate polyhedron in the
first place.
> The following is working:
> istringstream off(polyhedronOffStr);
> Nef_polyhedron NP;
> CGAL::OFF_to_nef_3(off, NP);
Thanks, this works.
Is there a way to directly construct the Nef polyhedron without first
serializing to/from an OFF string? (My data is not in OFF format,
I just used the output operator of Polyhedron_3 for this to create
example data).
Best regards,
Andre
Dipl.-Inf. Andre Schmeißer
Department of Transport Processes
Fraunhofer Institute for Industrial Mathematics ITWM
Fraunhofer-Platz 1, D-67663 Kaiserslautern
Internet: www.itwm.fraunhofer.de
