Re: [cgal-discuss] Questions about surface reconstruction from point sets in CGAL
- To:
- Subject: Re: [cgal-discuss] Questions about surface reconstruction from point sets in CGAL
- Date: Mon, 30 Sep 2013 09:52:26 +0200
Hi Jogging Song,From the User Manual http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_reconstruction_points_3/Chapter_main.html: The computed implicit functions can be iso-contoured to reconstruct a surface by using the Cgal surface mesh generator [RY07, BO05]: CGAL::make_surface_mesh [RY07] Laurent Rineau and Mariette Yvinec. A generic software design for Delaunay refinement meshing. Comput. Geom. Theory Appl., 38:100-110, 2007. [BO05] Jean-Daniel Boissonnat and Steve Oudot. Provably good sampling and meshing of surfaces. Graphical Models, 67:405-451, 2005 Then you have to search for these articles in Google Scholar. Best regards, Laurent Saboret Le 30/09/2013 04:28, Jogging Song a
écrit :
Hi, Jesse Thanks for your reply. From the example code, poisson reconstruction algorithm is one kind of implicit function based method. Usually marching cube method is applied to the implicit function to get the triangle mesh. I am curious about how the Delaunay triangulation method is applied to the implicit function. I am not an expert on computational geometry. Delaunay triangulation algorithm takes one point cloud as the input. The document says "Cgal implements a variant of this algorithm which solves for a piecewise linear function on a 3D Delaunay triangulation instead of an adaptive octree." I don't understand what it means. To understand it, I download the source code but it is hard to read it. Thanks. Regards Jogging Song Jesse Louis-Rosenberg wrote Hi Jogging Song, I think your understanding is mistaken. The point cloud is not directly triangulated. Instead Poisson reconstruction generates an implicit function which estimates the surface from the point cloud. Surface mesh triangulation takes an implicit function (which is now independent from you point cloud) and generates a triangle mesh using Delaunay refinement. Best, Jesse Louis-Rosenberg Nervous System On Thu, Sep 26, 2013 at 1:16 AM, Jogging Song < joggingsong@ > wrote:Hi, all Currently I hope to use CGAL to obtain one adaptive non-manifold mesh from my input point cloud. I try to learn more about poisson reconstruction in CGAL. From the following link: http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_reconstruction_points_3/Chapter_main.html /"Cgal implements a variant of this algorithm which solves for a piecewise linear function on a 3D Delaunay triangulation instead of an adaptive octree. The algorithm takes as input a set of 3D oriented points. It builds a 3D Delaunay triangulation from these points and refines it by Delaunay refinement so as to remove all badly shaped (non isotropic) tetrahedra and to tessellate a loose bounding box of the input oriented points. The normal of each Steiner point added during refinement is set to zero. It then solves for a scalar indicator function f represented as a piecewise linear function over the refined triangulation. More specifically, it solves for the Poisson equation Δf = div(n) at each vertex of the triangulation using a sparse linear solver. Eventually, the Cgal surface mesh generator extracts an isosurface with function value set by default to be the median value of f at all input points. "/ From my understanding of the above description, for the oriented point cloud I provide, Delaunay triangulation is employed to obtain one triangle mesh, and Delaunay refinement will be applied to resultant triangle mesh. Poisson reconstruction will use the new mesh as the input. In the demo code poisson_reconstruction_example.cpp, the input oriented point cloud is input to poisson reconstruction and the implicit function is got. The function named make_surface_mesh is called to generate the triangle mesh, and I find that the argument lists doesn't contain the information about point cloud. Is my understand correct? Where is Delaunay triangulation applied? Thanks. Regards Jogging Song -- View this message in context: http://cgal-discuss.949826.n4.nabble.com/Questions-about-surface-reconstruction-from-point-sets-in-CGAL-tp4658080.html Sent from the cgal-discuss mailing list archive at Nabble.com. -- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://sympa.inria.fr/sympa/info/cgal-discuss-- Jesse Louis-Rosenberg Nervous System http://n-e-r-v-o-u-s.com -- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://sympa.inria.fr/sympa/info/cgal-discuss -- View this message in context: http://cgal-discuss.949826.n4.nabble.com/Questions-about-surface-reconstruction-from-point-sets-in-CGAL-tp4658080p4658102.html Sent from the cgal-discuss mailing list archive at Nabble.com. |
- [cgal-discuss] Questions about surface reconstruction from point sets in CGAL, Jogging Song, 09/26/2013
- Re: [cgal-discuss] Questions about surface reconstruction from point sets in CGAL, Laurent Saboret, 09/27/2013
- Re: [cgal-discuss] Questions about surface reconstruction from point sets in CGAL, Jesse Louis-Rosenberg, 09/27/2013
- Re: [cgal-discuss] Questions about surface reconstruction from point sets in CGAL, Jogging Song, 09/30/2013
- Re: [cgal-discuss] Questions about surface reconstruction from point sets in CGAL, Laurent Saboret, 09/30/2013
