- To:
- Subject: Re: [cgal-discuss] Surface mesh from a labelled image
- Date: Tue, 01 Oct 2013 11:58:58 +0200
Le lundi 30 septembre 2013 23:10:50 Ramón Casero Cañas a écrit :
> Replying to myself, I had got confused, as
> the CGAL::Labeled_image_mesh_domain_3 is for volumetric meshes, not
> surfaces meshes.
> In the end, I managed to make it work following the example more closely,
> with a CGAL::Gray_level_image_3 and CGAL::Implicit_surface_3.
> The code is here in case it's useful for somebody else (it's a Matlab MEX
> wrapper around CGAL::make_surface_mesh)
> https://code.google.com/p/gerardus/source/browse/trunk/matlab/CgalToolbox/Cg
> alMeshSegmentation.cpp
Thanks for letting us know.
I am sorry you had not got any answer to your first message. Myself I am very
busy for more than a week (both preparing the next release of CGAL, as the
Release Manager, and in the other tasks of my job).
Laurent Rineau, PhD
- Re: [cgal-discuss] Surface mesh from a labelled image, Ramón Casero Cañas, 10/01/2013
- Re: [cgal-discuss] Surface mesh from a labelled image, Laurent Rineau (CGAL/GeometryFactory), 10/01/2013
