cgal-discuss - Re: [cgal-discuss] Convex hull of circles, disk, circular arcs in 2D
  • To:
  • Subject: Re: [cgal-discuss] Convex hull of circles, disk, circular arcs in 2D
  • Date: Fri, 04 Oct 2013 13:42:17 +0200
Have a look at the Apollonius Graph
http://doc.cgal.org/latest/Apollonius_graph_2/index.html#Chapter_2D_Apollonius_Graphs
andreas
On 04/10/2013 13:25, Stefan Salewski wrote:
I have a set of circles in 2d, they differ much in size and may partly
or fully overlap. I need to identify the ones which touch the convex
hull of the set, so that I can drop the inner ones.
I have experimented with some sort of graham scan, after circular
sorting and calculation tangents. While that seemed to work for most
cases, I noted that it still may fail for special cases, i.e when there
is a very big difference in size.
Yesterday I found this paper
On Computing the Convex Hull of (Piecewise) Curved Objects by Franz
Aurenhammer and Bert JÜttler
www.igi.tugraz.at/auren/psfiles/aj-cchpco-12.pdf
For me that is a very abstract theoretical description.
Is there a chance to convert that paper into real code?
Or any other suggestions?
Best regards,
Stefan Salewski
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
