- To:
- Subject: Re: [cgal-discuss] Tiangulation with holes
- Date: Sun, 6 Oct 2013 13:26:22 +0300
Perhaps you should try to reduce your problem to the plane.
Triangulating a polygon with holes (in the plane) can be done in several ways. You can even use 2D arrangements to create a vertical decomposition (into pseudo trapezoids) and then split the quadrangles. ____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On Wed, Oct 2, 2013 at 11:30 AM, Sebastien Loriot (GeometryFactory) <> wrote:
IIUC, you have a set of 3D polylines in parallel planes and you'd like
to construct a 3D mesh out of this.
We have a prototype implementing [1] but for now it only produces
surface triangulation and it is not ready for public distribution.
Outside of CGAL there is this:
http://www.cse.wustl.edu/~taoju/lliu/paper/ctr2suf/program.html
I have never tried it and don't know how it performs.
Sebastien.
[1] http://hal.inria.fr/inria-00076934--
On 10/02/2013 10:09 AM, khaldon hmesheh wrote:
Hello,
I have some plate which are defined in 2D plane as in the attached file.
I want to get a 3D triangulation of this plate.The outer contour of the
plate, the contours of the holes inside the plate and plate's thickness
are the given information.And my question is how to generate a 3D
triangulation of this 2D plate in CGAL?
regards
Sniper
- [cgal-discuss] Tiangulation with holes, khaldon hmesheh, 10/02/2013
- Re: [cgal-discuss] Tiangulation with holes, Sebastien Loriot (GeometryFactory), 10/02/2013
- Re: [cgal-discuss] Tiangulation with holes, Efi Fogel, 10/06/2013
- Re: [cgal-discuss] Tiangulation with holes, khaldon hmesheh, 10/06/2013
