cgal-discuss - [cgal-discuss] Voronoi adapter edge rejector
  • To:
  • Subject: [cgal-discuss] Voronoi adapter edge rejector
  • Date: Tue, 8 Oct 2013 10:41:58 +0100
Dear CGAL community,
I am using the following setup to generate a Voronoi diagram:
typedef CGAL::Delaunay_triangulation_2< K, Tds> Delaunay;
typedef CGAL::Delaunay_triangulation_adaptation_traits_2< Delaunay> AT;
typedef CGAL::Delaunay_triangulation_caching_degeneracy_removal_policy_2<
Delaunay> AP;
typedef CGAL::Voronoi_diagram_2< Delaunay, AT, AP> VD;
which successfully removes degenerate edges from the Voronoi. In part
for my code I iterate over all Delaunay edges and call
voronoi.dual(delaunayEdge)
but this causes assertions because some of the edges are rejected. Is
there a way to check if the Delaunay edge corresponds to a rejected
dual? Or with this setup am I only 'allowed' to go from Voronoi edges
to Delaunay edges and not the other way around?
At the moment I'm using:
if(!voronoi.edge_rejector()(delaunay, delaunayEdge))
but it seems quite clear from the source that edge_rejector(...) is
not API facing code.
Many thanks,
-Martin
Martin Uhrin Tel: +44
207 679 3466
Department of Physics & Astronomy Fax:+44 207 679 0595
University College London
Gower St, London, WC1E 6BT, U.K. http://www.cmmp.ucl.ac.uk
  • [cgal-discuss] Voronoi adapter edge rejector, Martin Uhrin, 10/08/2013
