cgal-discuss - Re: [cgal-discuss] ruby c extensions and straight skeletons
  • To:
  • Subject: Re: [cgal-discuss] ruby c extensions and straight skeletons
  • Date: Wed, 9 Oct 2013 01:09:40 +0200
I can't believe it was that easy.  Thanks Marc, easy when you know what you're doing.  Having other problems now but they are more palatable.  Cheers
2013/10/8 Noel Warren <>
I've never written a macro so I wouldn't know.  I'm guessing ruby has a macro called access, maybe I'll try and change that.  Thanks Marc.  I'll let you know if it worked.
2013/10/8 Marc Glisse <>
On Tue, 8 Oct 2013, Noel Warren wrote:
There is obviously something "big" I'm doing wrong but I can't see what it
is from the output.  Any help will be greatly appreciated.
C:/CGAL-4.2/include/CGAL/Straight_skeleton_vertex_base_2.h:40:58: error:
macro "access" requires 2 arguments, but only 1 given
You have a macro called access. That's bad. Macros should be avoided, and when they are necessary they should be given ugly names. You should find where this macro is coming from and kill it.
Marc Glisse
