- To:
- Subject: Re: [cgal-discuss] Apollonius Graph -- Segmentation fault
- Date: Fri, 11 Oct 2013 00:18:34 +0200
On Thu, 2013-10-10 at 22:54 +0200, Stefan Salewski wrote:
> May the problem be simple that the output loop fails when we have only
> one visible site?
After reading (again) some documentation about CGAL's circulators, I
really guess that there is a bug.
It is clear that I have to test for empty graph, maybe something like
circ == NULL (I read about tests for empty ranges, but I guess that will
not work well for hulls.)
But ++circ should never give invalid values for circulators, from my
understanding of the documentation. But segmentation fault indicates
that there is an undefined value.
So it seems that I really have to handle the case with only one visible
side separately, which makes my code a bit ugly.
- [cgal-discuss] Apollonius Graph -- Segmentation fault, Stefan Salewski, 10/10/2013
- Re: [cgal-discuss] Apollonius Graph -- Segmentation fault, Stefan Salewski, 10/10/2013
- Re: [cgal-discuss] Apollonius Graph -- Segmentation fault, Stefan Salewski, 10/11/2013
- Re: [cgal-discuss] Apollonius Graph -- Segmentation fault, Menelaos Karavelas, 10/11/2013
