cgal-discuss - [cgal-discuss] Bug in triangulate_polyhedron.h?
  • To:
  • Subject: [cgal-discuss] Bug in triangulate_polyhedron.h?
  • Date: Fri, 18 Oct 2013 20:56:10 +0100
Hi all,
I have a triangular mesh (attached as x.csv for vertices and tri.csv for triangles) with some holes, and I'm using CGAL to fill the holes and then triangulate the polygons that cover the holes. To triangulate the hole I'm using
CGAL-4.2/demo/Polyhedron/include/CGAL/triangulate_polyhedron.h
This is where the bug is, I believe.
Full code of the program is here
https://code.google.com/p/gerardus/source/browse/trunk/matlab/CgalToolbox/CgalTriFillHoles.cpp
but I highlight the parts of interest.
/* CGAL headers */
#include <CGAL/Subdivision_method_3.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/triangulate_polyhedron.h>
#include "PolyhedronBuilder.h"
typedef CGAL::Exact_predicates_inexact_constructions_kernel  Kernel;
typedef CGAL::Polyhedron_3<Kernel>                           Polyhedron;
typedef CGAL::Point_3<Kernel>                                Point;
typedef Polyhedron::Facet                                    Facet;
typedef Polyhedron::Facet_iterator                           Facet_iterator;
typedef Polyhedron::Vertex_handle                            Vertex_handle;
typedef Polyhedron::Vertex_iterator                          Vertex_iterator;
typedef Polyhedron::Halfedge_around_facet_circulator         Halfedge_around_facet_circulator;
I read the mesh from Matlab into a CGAL::Polyhedron_3
  // polyhedron to contain the input mesh
  Polyhedron mesh;
  PolyhedronBuilder<Polyhedron> builder(matlabImport, inTRI, inX);
  mesh.delegate(builder);
https://code.google.com/p/gerardus/source/browse/trunk/matlab/CgalToolbox/PolyhedronBuilder.h
Then the holes get filled with
  // sort halfedges such that the non-border edges precede the
  // border edges. We need to do this before any halfedge iterator
  // operations are valid
  mesh.normalize_border();
  // number of holes we have filled
  mwIndex n = 0;
  // a closed mesh with no holes will have no border edges. What we do
  // is grab a border halfedge and close the associated hole. This
  // makes the rest of the iterators invalid, so we have to normalize
  // the mesh again. Then we iterate, looking for a new border
  // halfedge, filling the hole, etc.
  // Note that confusingly, mesh.border_halfedges_begin() gives a
  // pointer to the halfedge that is NOT a border in a border
  // edge. The border halfedge is instead
  // mesh.border_halfedges_begin()->opposite()
  while (!mesh.is_closed()) {
    // exit if user pressed Ctrl+C
    ctrlcCheckPoint(__FILE__, __LINE__);
    // get the first hole we can find, and close it
    mesh.fill_hole(mesh.border_halfedges_begin()->opposite());
    // increase the counter of number of holes we have filled
    n++;
    // renormalize mesh so that halfedge iterators are again valid
Finally, we want to triangulate all the facets in the mesh, and this is where the segfault happens
  // Split all facets to triangles
  CGAL::triangulate_polyhedron<Polyhedron>(mesh);
This calls the class here
https://code.google.com/p/gerardus/source/browse/trunk/cpp/src/third-party/CGAL-4.2/demo/Polyhedron/include/CGAL/triangulate_polyhedron.h
This is not the main point, but note that I had to change
typedef CGAL::No_intersection_tag                                    Itag;
to
typedef CGAL::Exact_predicates_tag                                   Itag;
Otherwise, I get an error
 sorry, this triangulation does not deal with
 intersecting constraints
The segfault happens exactly in the "// then modify the polyhedron" block. There's a hole with 15 vertices (facet with index 9127) with coordinates
0.015412 0.012213 0.01467
0.015387 0.012213 0.01467
0.015387 0.012213 0.014646
0.015387 0.012213 0.014621
0.01493 0.012264 0.014841
0.014422 0.012416 0.014914
0.014244 0.012467 0.015061
0.014219 0.012467 0.015085
0.014143 0.012467 0.015134
0.01493 0.012289 0.01489
0.014981 0.012264 0.01489
0.015006 0.012264 0.01489
0.015031 0.012264 0.01489
0.015057 0.012264 0.01489
0.015412 0.012213 0.014694
that has been filled with a polygon, and when the polygon modification is in its 18th iteration in the triangulation function, it has acquired the vertices:
        const typename CDT::Vertex_handle va = fh->vertex(cdt. cw(index));
        const typename CDT::Vertex_handle vb = fh->vertex(cdt.ccw(index));
It finds that this is an strictly internal edge, and tries to do
          decorator.set_vertex(h, va->info()->vertex());
          decorator.set_vertex(h->opposite(), vb->info()->vertex());
However, va->info() == NULL at this point, so va->info()->vertex() throws a segfault.
Best regards,
Ramon.
Dr. Ramón Casero Cañas
Oxford e-Research Centre (OeRC)
University of Oxford
7 Keble Rd
Oxford OX1 3QG
tlf     +44 (0) 1865 610739
web     http://www.cs.ox.ac.uk/people/Ramon.CaseroCanas
photos  http://www.flickr.com/photos/rcasero/
0.017113,0.011375,0.0024894
0.017113,0.011401,0.0024894
0.017113,0.011426,0.0024894
0.017139,0.011375,0.0024894
0.017139,0.011401,0.0024894
0.017139,0.011426,0.0024894
0.017139,0.011451,0.0024894
0.017139,0.011477,0.0024894
0.017164,0.011401,0.0024894
0.017164,0.011426,0.0024894
0.017164,0.011451,0.0024894
0.017164,0.011477,0.0024894
0.017088,0.011401,0.0025138
0.017088,0.011426,0.0025138
0.017164,0.011375,0.0025138
0.017189,0.011426,0.0025138
0.017189,0.011451,0.0025138
0.017164,0.01135,0.0025382
0.017012,0.011223,0.0025871
0.017012,0.01135,0.0025871
0.016986,0.011375,0.0026115
0.016936,0.011197,0.0026359
0.016834,0.010918,0.0027335
0.016859,0.010918,0.0027335
0.016936,0.011959,0.0027335
0.016936,0.011985,0.0027335
0.016961,0.011985,0.0027335
0.01691,0.011934,0.0027579
0.01691,0.011959,0.0027579
0.01691,0.011985,0.0027579
0.016986,0.011959,0.0027579
0.017012,0.011908,0.0027579
0.01724,0.011502,0.0027579
0.017012,0.011934,0.0027823
0.01724,0.011528,0.0027823
0.016656,0.011045,0.0028067
0.016605,0.01102,0.0028312
0.017012,0.011959,0.0028312
0.01691,0.012086,0.0028556
0.016936,0.012086,0.0028556
0.016504,0.011172,0.00288
0.016479,0.011147,0.0029044
0.016479,0.011172,0.0029044
0.016605,0.01135,0.0029044
0.016859,0.012111,0.0029044
0.016859,0.012137,0.0029288
0.017012,0.01201,0.0029288
0.016555,0.011375,0.0029532
0.016859,0.012162,0.0029532
0.016605,0.011528,0.003002
0.016834,0.012188,0.003002
0.016859,0.012188,0.003002
0.017316,0.011528,0.0030264
0.017367,0.011401,0.0030264
0.016732,0.012162,0.0030508
0.017316,0.011528,0.0030508
0.016326,0.01074,0.0030753
0.016352,0.01074,0.0030753
0.016732,0.012188,0.0030753
0.016301,0.010715,0.0030997
0.016326,0.010715,0.0030997
0.016732,0.012213,0.0030997
0.016986,0.012137,0.0030997
0.016732,0.012238,0.0031241
0.017494,0.011197,0.0031485
0.017494,0.011223,0.0031485
0.016758,0.012289,0.0031729
0.016783,0.012289,0.0031729
0.017469,0.011172,0.0031729
0.016986,0.012213,0.0031973
0.016123,0.010893,0.0032217
0.016148,0.010639,0.0032217
0.016199,0.010639,0.0032217
0.01752,0.011223,0.0032217
0.01752,0.011248,0.0032217
0.016098,0.010893,0.0032461
0.016123,0.010639,0.0032461
0.016148,0.010613,0.0032461
0.016174,0.01102,0.0032461
0.016758,0.01234,0.0032461
0.016783,0.01234,0.0032461
0.016986,0.012238,0.0032461
0.01752,0.011223,0.0032461
0.01752,0.011248,0.0032461
0.016072,0.010893,0.0032705
0.016098,0.010639,0.0032705
0.017494,0.011172,0.0032705
0.01752,0.011223,0.0032705
0.01752,0.011248,0.0032705
0.016986,0.012264,0.0032949
0.017494,0.011172,0.0032949
0.017494,0.011172,0.0033194
0.016072,0.010613,0.0033438
0.016326,0.011883,0.0033438
0.016326,0.011908,0.0033438
0.017494,0.011172,0.0033438
0.016047,0.010613,0.0033682
0.016301,0.011908,0.0033682
0.016301,0.011934,0.0033682
0.016682,0.012416,0.0033682
0.016275,0.011934,0.0033926
0.016275,0.011959,0.0033926
0.016682,0.012442,0.0033926
0.015869,0.010842,0.003417
0.015895,0.010893,0.003417
0.016682,0.012467,0.003417
0.015818,0.010791,0.0034414
0.015818,0.010817,0.0034414
0.016682,0.012492,0.0034414
0.016682,0.012518,0.0034658
0.016225,0.012035,0.0034902
0.016199,0.012035,0.0035146
0.016682,0.012543,0.0035146
0.017037,0.01234,0.0035146
0.015691,0.010842,0.003539
0.015717,0.010867,0.003539
0.016174,0.012035,0.003539
0.017037,0.012365,0.003539
0.015666,0.010766,0.0035635
0.015615,0.010791,0.0035879
0.015615,0.010817,0.0035879
0.016631,0.010487,0.0035879
0.016682,0.012568,0.0035879
0.01559,0.010766,0.0036123
0.015818,0.010588,0.0036123
0.017062,0.012365,0.0036123
0.017062,0.012391,0.0036123
0.015564,0.010766,0.0036367
0.015793,0.010588,0.0036367
0.016707,0.012568,0.0036367
0.015564,0.01074,0.0036611
0.015768,0.010588,0.0036611
0.01592,0.011502,0.0036611
0.01658,0.010436,0.0036611
0.017062,0.012416,0.0036611
0.015438,0.010842,0.0036855
0.015438,0.010867,0.0036855
0.016682,0.012594,0.0037099
0.016707,0.012594,0.0037099
0.015361,0.010867,0.0037343
0.015387,0.010893,0.0037343
0.015742,0.010563,0.0037343
0.017088,0.012365,0.0037343
0.017088,0.012391,0.0037343
0.017342,0.010563,0.0037343
0.017367,0.01069,0.0037343
0.015717,0.010563,0.0037587
0.016479,0.010385,0.0037587
0.016504,0.010385,0.0037587
0.01724,0.010334,0.0037587
0.017266,0.010334,0.0037587
0.017342,0.010537,0.0037587
0.017367,0.010664,0.0037587
0.017393,0.011324,0.0037587
0.015336,0.010893,0.0037831
0.015691,0.010563,0.0037831
0.017088,0.012442,0.0037831
0.017215,0.010309,0.0037831
0.01724,0.010309,0.0037831
0.017342,0.010537,0.0037831
0.015311,0.010842,0.0038076
0.015311,0.010867,0.0038076
0.015666,0.010563,0.0038076
0.016707,0.012619,0.0038076
0.017189,0.010283,0.0038076
0.017393,0.010715,0.0038076
0.015717,0.011959,0.003832
0.017139,0.010258,0.003832
0.017164,0.010258,0.003832
0.017393,0.01069,0.003832
0.017494,0.011096,0.003832
0.017494,0.011121,0.003832
0.015641,0.010563,0.0038564
0.015666,0.011832,0.0038564
0.015691,0.011959,0.0038564
0.017113,0.010233,0.0038564
0.017139,0.010233,0.0038564
0.017494,0.011096,0.0038564
0.017494,0.011121,0.0038564
0.01526,0.010867,0.0038808
0.015691,0.012035,0.0038808
0.015717,0.012061,0.0038808
0.016021,0.012264,0.0038808
0.016732,0.012619,0.0038808
0.017113,0.010207,0.0038808
0.015234,0.01074,0.0039052
0.015234,0.010842,0.0039052
0.015311,0.010639,0.0039052
0.015412,0.011324,0.0039052
0.015666,0.012035,0.0039052
0.015691,0.012061,0.0039052
0.016021,0.012289,0.0039052
0.017139,0.012416,0.0039052
0.017139,0.012442,0.0039052
0.015209,0.010766,0.0039296
0.015209,0.010791,0.0039296
0.015209,0.010817,0.0039296
0.015387,0.011324,0.0039296
0.016377,0.010334,0.0039296
0.015361,0.011324,0.003954
0.016352,0.010334,0.003954
0.015234,0.010613,0.0039784
0.015336,0.011324,0.0039784
0.015641,0.012061,0.0039784
0.016732,0.012645,0.0039784
0.015184,0.010639,0.0040028
0.015311,0.011324,0.0040028
0.015615,0.01201,0.0040028
0.015996,0.01234,0.0040028
0.016707,0.012645,0.0040028
0.017139,0.012467,0.0040028
0.017494,0.010918,0.0040028
0.015133,0.01074,0.0040273
0.015133,0.010766,0.0040273
0.015158,0.010639,0.0040273
0.017494,0.010893,0.0040273
0.017494,0.010918,0.0040273
0.015133,0.010639,0.0040517
0.015158,0.010613,0.0040517
0.015234,0.011248,0.0040517
0.01691,0.010131,0.0040517
0.016936,0.010131,0.0040517
0.017189,0.012416,0.0040517
0.017494,0.010893,0.0040517
0.017494,0.010918,0.0040517
0.015107,0.010639,0.0040761
0.015133,0.010613,0.0040761
0.016758,0.012645,0.0040761
0.017494,0.010918,0.0040761
0.016885,0.010106,0.0041005
0.015057,0.010664,0.0041249
0.015057,0.01074,0.0041249
0.015057,0.010766,0.0041249
0.016732,0.01267,0.0041249
0.016859,0.010106,0.0041249
0.015057,0.010639,0.0041493
0.015082,0.010613,0.0041493
0.015209,0.01135,0.0041493
0.016732,0.01267,0.0041493
0.017215,0.012467,0.0041493
0.015031,0.010664,0.0041737
0.015158,0.011274,0.0041737
0.015996,0.012442,0.0041737
0.016732,0.01267,0.0041737
0.01724,0.012442,0.0041737
0.017469,0.011299,0.0041737
0.015031,0.010639,0.0041981
0.015057,0.010613,0.0041981
0.016402,0.012619,0.0041981
0.017469,0.011299,0.0041981
0.015996,0.012467,0.0042225
0.015006,0.010639,0.0042469
0.016402,0.012645,0.0042469
0.017266,0.012416,0.0042469
0.017266,0.012442,0.0042469
0.015006,0.010766,0.0042714
0.015996,0.012492,0.0042714
0.017469,0.011324,0.0042714
0.014981,0.010639,0.0042958
0.015463,0.012111,0.0042958
0.017469,0.011324,0.0042958
0.014981,0.010613,0.0043202
0.016377,0.01267,0.0043202
0.016402,0.01267,0.0043202
0.014955,0.010639,0.0043446
0.014955,0.010664,0.0043446
0.016123,0.010309,0.0043446
0.014955,0.010613,0.004369
0.014981,0.011248,0.004369
0.015438,0.012238,0.004369
0.016732,0.012645,0.004369
0.017418,0.010309,0.004369
0.014955,0.011248,0.0043934
0.015742,0.01036,0.0043934
0.017418,0.010283,0.0043934
0.015209,0.01168,0.0044178
0.015717,0.01036,0.0044178
0.017316,0.012416,0.0044178
0.01493,0.011274,0.0044422
0.015082,0.011502,0.0044422
0.015996,0.012568,0.0044422
0.017316,0.012442,0.0044422
0.017393,0.010207,0.0044422
0.015387,0.012264,0.0044666
0.017037,0.010004,0.0044666
0.017316,0.010131,0.0044666
0.014904,0.010613,0.004491
0.014904,0.010639,0.004491
0.014904,0.011299,0.004491
0.015387,0.012289,0.004491
0.017012,0.0099787,0.004491
0.017342,0.012416,0.004491
0.014904,0.010613,0.0045154
0.015006,0.011502,0.0045154
0.015996,0.012594,0.0045154
0.016986,0.0099533,0.0045154
0.017291,0.01008,0.0045154
0.014981,0.011502,0.0045399
0.015361,0.012289,0.0045399
0.017266,0.010055,0.0045399
0.017291,0.01008,0.0045399
0.014879,0.011172,0.0045643
0.015361,0.012315,0.0045643
0.01724,0.01003,0.0045643
0.017266,0.010055,0.0045643
0.017367,0.012416,0.0045643
0.015336,0.012289,0.0045887
0.01658,0.010004,0.0045887
0.017367,0.012391,0.0045887
0.014828,0.011401,0.0046131
0.014828,0.011426,0.0046131
0.015336,0.012315,0.0046131
0.016885,0.0098772,0.0046131
0.017215,0.01003,0.0046131
0.017443,0.01135,0.0046131
0.014828,0.011248,0.0046375
0.015336,0.01234,0.0046375
0.016402,0.012746,0.0046375
0.016555,0.0099787,0.0046375
0.017113,0.012594,0.0046375
0.01724,0.012543,0.0046375
0.014828,0.010944,0.0046619
0.014828,0.010969,0.0046619
0.016402,0.012746,0.0046619
0.016834,0.0098518,0.0046619
0.017139,0.012594,0.0046619
0.017164,0.010004,0.0046619
0.015311,0.01234,0.0046863
0.016529,0.0099533,0.0046863
0.016834,0.0098518,0.0046863
0.017266,0.012543,0.0046863
0.017393,0.012391,0.0046863
0.014803,0.010944,0.0047107
0.014803,0.010969,0.0047107
0.016834,0.0098518,0.0047107
0.017393,0.012365,0.0047107
0.017393,0.012391,0.0047107
0.014777,0.011477,0.0047351
0.014854,0.011629,0.0047351
0.015488,0.010309,0.0047351
0.016834,0.0098518,0.0047351
0.014777,0.010944,0.0047596
0.014803,0.011578,0.0047596
0.014828,0.011629,0.0047596
0.014854,0.010664,0.0047596
0.014854,0.011654,0.0047596
0.015285,0.012365,0.0047596
0.017291,0.012543,0.0047596
0.014828,0.011654,0.004784
0.017646,0.01102,0.004784
0.014803,0.011654,0.0048084
0.016758,0.009801,0.0048084
0.014777,0.010715,0.0048328
0.014777,0.011654,0.0048328
0.016707,0.0097756,0.0048328
0.016758,0.009801,0.0048328
0.016707,0.0097756,0.0048572
0.017418,0.012365,0.0048572
0.014752,0.011654,0.0048816
0.016352,0.0098772,0.0048816
0.014625,0.011375,0.004906
0.014625,0.011401,0.004906
0.01465,0.011248,0.004906
0.014701,0.010842,0.004906
0.014701,0.010867,0.004906
0.014701,0.010893,0.004906
0.014752,0.010715,0.004906
0.014752,0.01168,0.004906
0.017291,0.012568,0.004906
0.017316,0.012543,0.004906
0.017723,0.010867,0.004906
0.014625,0.011274,0.0049304
0.016326,0.0098518,0.0049304
0.017443,0.01234,0.0049304
0.0146,0.011375,0.0049548
0.0146,0.011401,0.0049548
0.014676,0.010918,0.0049548
0.014727,0.01074,0.0049548
0.015996,0.012848,0.0049548
0.016631,0.0097502,0.0049548
0.017037,0.012695,0.0049548
0.017062,0.012695,0.0049548
0.0146,0.011426,0.0049792
0.015336,0.010233,0.0049792
0.015387,0.012518,0.0049792
0.016605,0.0097502,0.0049792
0.017697,0.010791,0.0049792
0.014574,0.011401,0.0050037
0.014676,0.011604,0.0050037
0.014803,0.011807,0.0050037
0.015971,0.012848,0.0050037
0.016275,0.0098264,0.0050037
0.01658,0.0097502,0.0050037
0.014574,0.011426,0.0050281
0.014676,0.011629,0.0050281
0.015311,0.010207,0.0050281
0.01625,0.0098264,0.0050281
0.017443,0.012162,0.0050281
0.014777,0.011807,0.0050525
0.015158,0.012518,0.0050525
0.015641,0.010131,0.0050525
0.017697,0.010613,0.0050525
0.017697,0.010639,0.0050525
0.014625,0.010944,0.0050769
0.015285,0.010207,0.0050769
0.017697,0.010563,0.0050769
0.017697,0.010588,0.0050769
0.015133,0.012543,0.0051013
0.015361,0.012594,0.0051013
0.015996,0.012899,0.0051013
0.016555,0.0097248,0.0051013
0.017469,0.012188,0.0051013
0.017697,0.010537,0.0051013
0.017697,0.010563,0.0051013
0.014625,0.011604,0.0051257
0.014752,0.010664,0.0051257
0.01526,0.010207,0.0051257
0.01559,0.010106,0.0051257
0.017672,0.010512,0.0051257
0.017697,0.010537,0.0051257
0.017494,0.012238,0.0051501
0.017672,0.010512,0.0051501
0.01465,0.01168,0.0051745
0.014727,0.010664,0.0051745
0.015107,0.012594,0.0051745
0.01559,0.01008,0.0051745
0.017494,0.012213,0.0051745
0.014549,0.011045,0.0051989
0.014625,0.01074,0.0051989
0.01465,0.010715,0.0051989
0.014803,0.011985,0.0051989
0.015107,0.012619,0.0051989
0.015564,0.01008,0.0051989
0.017088,0.012746,0.0051989
0.017113,0.012746,0.0051989
0.01724,0.012721,0.0051989
0.0146,0.010766,0.0052233
0.014676,0.01069,0.0052233
0.016123,0.009801,0.0052233
0.017266,0.012721,0.0052233
0.017621,0.010461,0.0052233
0.0146,0.01074,0.0052477
0.016098,0.009801,0.0052477
0.016859,0.009801,0.0052477
0.014574,0.010791,0.0052722
0.015996,0.012949,0.0052722
0.016072,0.009801,0.0052722
0.017443,0.012492,0.0052722
0.014523,0.01102,0.0052966
0.016834,0.0097756,0.0052966
0.01752,0.012213,0.0052966
0.015311,0.012695,0.005321
0.016809,0.0097502,0.005321
0.017291,0.012721,0.005321
0.01752,0.012213,0.005321
0.015996,0.012975,0.0053454
0.016783,0.0097248,0.0053454
0.017469,0.012467,0.0053454
0.014498,0.011401,0.0053698
0.014574,0.011731,0.0053698
0.015158,0.010182,0.0053698
0.015209,0.010156,0.0053698
0.015311,0.012721,0.0053698
0.016047,0.0097502,0.0053698
0.016758,0.0096994,0.0053698
0.016783,0.0097248,0.0053698
0.017469,0.012492,0.0053698
0.017494,0.01041,0.0053698
0.015488,0.010055,0.0053942
0.016021,0.0097502,0.0053942
0.016758,0.0096994,0.0053942
0.017469,0.012492,0.0053942
0.01465,0.010664,0.0054186
0.015133,0.010182,0.0054186
0.017316,0.012721,0.0054186
0.017469,0.012492,0.0054186
0.017545,0.01069,0.0054186
0.014523,0.010766,0.005443
0.014549,0.01074,0.005443
0.017291,0.012746,0.005443
0.017494,0.012137,0.005443
0.014498,0.010791,0.0054674
0.014523,0.010766,0.0054674
0.014549,0.01074,0.0054674
0.015031,0.012721,0.0054674
0.015107,0.010182,0.0054674
0.017494,0.012137,0.0054674
0.014498,0.010791,0.0054919
0.014523,0.010766,0.0054919
0.014549,0.01074,0.0054919
0.015006,0.012721,0.0054919
0.017494,0.012137,0.0054919
0.017545,0.010563,0.0054919
0.017545,0.010588,0.0054919
0.014549,0.01074,0.0055163
0.015184,0.012772,0.0055163
0.015996,0.013026,0.0055163
0.016021,0.013026,0.0055163
0.017113,0.012797,0.0055163
0.017139,0.012797,0.0055163
0.017494,0.012137,0.0055163
0.015006,0.012746,0.0055407
0.015057,0.010207,0.0055407
0.015996,0.013026,0.0055407
0.016021,0.013026,0.0055407
0.016098,0.0095725,0.0055407
0.016555,0.0095979,0.0055407
0.017164,0.012797,0.0055407
0.017469,0.012467,0.0055407
0.017494,0.012137,0.0055407
0.014981,0.012746,0.0055651
0.015945,0.0096486,0.0055651
0.015996,0.013026,0.0055651
0.016021,0.013026,0.0055651
0.016098,0.0095471,0.0055651
0.016123,0.0095471,0.0055651
0.017164,0.012797,0.0055651
0.017189,0.012797,0.0055651
0.017316,0.012772,0.0055651
0.014422,0.01102,0.0055895
0.01592,0.0096486,0.0055895
0.015996,0.013026,0.0055895
0.016529,0.0095725,0.0055895
0.017189,0.012797,0.0055895
0.017316,0.012772,0.0055895
0.014422,0.011807,0.0056139
0.014955,0.012746,0.0056139
0.017189,0.012797,0.0056139
0.017316,0.012772,0.0056139
0.017494,0.010461,0.0056139
0.014397,0.011045,0.0056383
0.014397,0.01107,0.0056383
0.014397,0.011807,0.0056383
0.014422,0.010918,0.0056383
0.014955,0.012772,0.0056383
0.015031,0.010182,0.0056383
0.015057,0.010156,0.0056383
0.016072,0.0094963,0.0056383
0.017189,0.012797,0.0056383
0.017316,0.012772,0.0056383
0.014371,0.011781,0.0056627
0.014371,0.011807,0.0056627
0.014854,0.010385,0.0056627
0.016021,0.0094963,0.0056627
0.016479,0.0095471,0.0056627
0.017189,0.012797,0.0056627
0.017316,0.012772,0.0056627
0.017469,0.01041,0.0056627
0.017469,0.012035,0.0056627
0.014371,0.011832,0.0056871
0.01465,0.012162,0.0056871
0.016021,0.0094709,0.0056871
0.016047,0.0094709,0.0056871
0.017189,0.012797,0.0056871
0.017443,0.010385,0.0056871
0.017494,0.012391,0.0056871
0.014447,0.010817,0.0057115
0.01493,0.010258,0.0057115
0.015844,0.0096233,0.0057115
0.015869,0.0095979,0.0057115
0.017494,0.012391,0.0057115
0.016428,0.0095217,0.005736
0.016834,0.0097502,0.005736
0.017469,0.01201,0.005736
0.014346,0.011832,0.0057604
0.014371,0.010969,0.0057604
0.014397,0.010893,0.0057604
0.01493,0.010233,0.0057604
0.015133,0.012899,0.0057604
0.015971,0.0094455,0.0057604
0.016021,0.0094455,0.0057604
0.017393,0.012721,0.0057604
0.017469,0.01201,0.0057604
0.014346,0.011858,0.0057848
0.014397,0.010867,0.0057848
0.015945,0.0094455,0.0057848
0.016809,0.0096994,0.0057848
0.017367,0.010309,0.0057848
0.017418,0.012695,0.0057848
0.01432,0.011807,0.0058092
0.014397,0.010842,0.0058092
0.014422,0.010817,0.0058092
0.014422,0.011985,0.0058092
0.014904,0.010233,0.0058092
0.015006,0.010131,0.0058092
0.015971,0.0094201,0.0058092
0.016783,0.009674,0.0058092
0.01432,0.011832,0.0058336
0.014346,0.01107,0.0058336
0.014397,0.010842,0.0058336
0.016758,0.0096486,0.0058336
0.017316,0.010233,0.0058336
0.017418,0.012721,0.0058336
0.017494,0.01234,0.0058336
0.014295,0.011401,0.005858
0.014295,0.011426,0.005858
0.01432,0.011858,0.005858
0.014371,0.010918,0.005858
0.014447,0.012061,0.005858
0.014473,0.012086,0.005858
0.014879,0.010233,0.005858
0.017291,0.010207,0.005858
0.017393,0.01041,0.005858
0.017443,0.012695,0.005858
0.017494,0.01234,0.005858
0.015895,0.0093948,0.0058824
0.017291,0.010207,0.0058824
0.017367,0.01036,0.0058824
0.017443,0.012695,0.0058824
0.014854,0.010233,0.0059068
0.015768,0.0095217,0.0059068
0.015869,0.0093948,0.0059068
0.015895,0.0093694,0.0059068
0.017266,0.010182,0.0059068
0.017443,0.012695,0.0059068
0.01493,0.010131,0.0059312
0.016377,0.013076,0.0059312
0.01724,0.010156,0.0059312
0.017266,0.010182,0.0059312
0.017443,0.012695,0.0059312
0.01427,0.011299,0.0059556
0.01432,0.011934,0.0059556
0.014447,0.012137,0.0059556
0.014473,0.012162,0.0059556
0.014828,0.010233,0.0059556
0.016377,0.013076,0.0059556
0.01724,0.010156,0.0059556
0.017443,0.012695,0.0059556
0.014346,0.010918,0.00598
0.014727,0.010385,0.00598
0.014904,0.010131,0.00598
0.015844,0.009344,0.00598
0.015869,0.009344,0.00598
0.016377,0.013076,0.00598
0.017215,0.010131,0.00598
0.017494,0.012289,0.00598
0.014422,0.012137,0.0060045
0.014828,0.010207,0.0060045
0.014828,0.012899,0.0060045
0.015057,0.013051,0.0060045
0.015818,0.009344,0.0060045
0.016377,0.013076,0.0060045
0.016631,0.0094709,0.0060045
0.017494,0.012289,0.0060045
0.01427,0.011197,0.0060289
0.014447,0.012188,0.0060289
0.015031,0.013051,0.0060289
0.015793,0.009344,0.0060289
0.016021,0.013102,0.0060289
0.016605,0.0094455,0.0060289
0.016631,0.0094709,0.0060289
0.014219,0.01135,0.0060533
0.014346,0.010893,0.0060533
0.014727,0.010334,0.0060533
0.014803,0.010207,0.0060533
0.014879,0.010131,0.0060533
0.015793,0.0093186,0.0060533
0.016021,0.013102,0.0060533
0.01658,0.0094201,0.0060533
0.016605,0.0094455,0.0060533
0.014193,0.011401,0.0060777
0.014193,0.011426,0.0060777
0.014193,0.011451,0.0060777
0.014219,0.011324,0.0060777
0.01465,0.010436,0.0060777
0.014701,0.01036,0.0060777
0.014803,0.012924,0.0060777
0.015031,0.013076,0.0060777
0.015768,0.0093186,0.0060777
0.016021,0.013102,0.0060777
0.016402,0.013076,0.0060777
0.016555,0.0093948,0.0060777
0.01658,0.0094201,0.0060777
0.014193,0.011375,0.0061021
0.014244,0.011197,0.0061021
0.01427,0.011985,0.0061021
0.014676,0.010385,0.0061021
0.015768,0.0092932,0.0061021
0.015793,0.0092932,0.0061021
0.016021,0.013102,0.0061021
0.016047,0.013102,0.0061021
0.016529,0.0093694,0.0061021
0.016555,0.0093948,0.0061021
0.014193,0.01135,0.0061265
0.014219,0.011934,0.0061265
0.014244,0.011172,0.0061265
0.01427,0.01201,0.0061265
0.014447,0.012264,0.0061265
0.014701,0.010334,0.0061265
0.015031,0.013102,0.0061265
0.016021,0.013102,0.0061265
0.016047,0.013102,0.0061265
0.016529,0.0093694,0.0061265
0.017494,0.012594,0.0061265
0.017494,0.012619,0.0061265
0.014168,0.011451,0.0061509
0.014193,0.011324,0.0061509
0.014219,0.011959,0.0061509
0.01427,0.010994,0.0061509
0.016021,0.013102,0.0061509
0.016047,0.013102,0.0061509
0.017494,0.012619,0.0061509
0.014168,0.011375,0.0061753
0.014168,0.011502,0.0061753
0.014193,0.011299,0.0061753
0.014219,0.011985,0.0061753
0.014777,0.010182,0.0061753
0.014777,0.012975,0.0061753
0.014828,0.010131,0.0061753
0.015717,0.0092678,0.0061753
0.015742,0.0092678,0.0061753
0.016021,0.013102,0.0061753
0.016047,0.013102,0.0061753
0.017494,0.012619,0.0061753
0.014168,0.01135,0.0061997
0.014168,0.011553,0.0061997
0.014193,0.011934,0.0061997
0.014219,0.01201,0.0061997
0.014828,0.010131,0.0061997
0.015742,0.0092678,0.0061997
0.016021,0.013102,0.0061997
0.014168,0.011324,0.0062242
0.014193,0.011959,0.0062242
0.014219,0.012035,0.0062242
0.014752,0.012975,0.0062242
0.015031,0.013127,0.0062242
0.015691,0.0092678,0.0062242
0.015742,0.0092678,0.0062242
0.016021,0.013102,0.0062242
0.016428,0.0093186,0.0062242
0.016479,0.009344,0.0062242
0.01757,0.011604,0.0062242
0.014143,0.011502,0.0062486
0.014143,0.011528,0.0062486
0.014193,0.011985,0.0062486
0.01427,0.010969,0.0062486
0.014752,0.013,0.0062486
0.016021,0.013102,0.0062486
0.017139,0.01008,0.0062486
0.017342,0.012899,0.0062486
0.01757,0.011604,0.0062486
0.014143,0.011578,0.006273
0.014193,0.01201,0.006273
0.014371,0.012289,0.006273
0.016021,0.013102,0.006273
0.016402,0.0092932,0.006273
0.017139,0.01008,0.006273
0.014193,0.012035,0.0062974
0.014727,0.010207,0.0062974
0.014727,0.013,0.0062974
0.014752,0.010182,0.0062974
0.016021,0.013102,0.0062974
0.016377,0.0092932,0.0062974
0.017316,0.012924,0.0062974
0.017342,0.012924,0.0062974
0.017367,0.012899,0.0062974
0.01752,0.012543,0.0062974
0.017545,0.011578,0.0062974
0.017545,0.011604,0.0062974
0.014143,0.01135,0.0063218
0.01427,0.010944,0.0063218
0.014727,0.013026,0.0063218
0.015717,0.0092678,0.0063218
0.016352,0.0092932,0.0063218
0.016377,0.0092932,0.0063218
0.017342,0.012924,0.0063218
0.017367,0.012899,0.0063218
0.017393,0.012873,0.0063218
0.01752,0.012518,0.0063218
0.01752,0.012543,0.0063218
0.014117,0.011426,0.0063462
0.014117,0.011451,0.0063462
0.014143,0.011324,0.0063462
0.014168,0.011223,0.0063462
0.014168,0.011934,0.0063462
0.014168,0.011959,0.0063462
0.014193,0.012061,0.0063462
0.014244,0.010969,0.0063462
0.014346,0.012289,0.0063462
0.0146,0.010334,0.0063462
0.015031,0.0099787,0.0063462
0.016352,0.0092932,0.0063462
0.016377,0.0092932,0.0063462
0.017367,0.012899,0.0063462
0.017393,0.012873,0.0063462
0.01752,0.011578,0.0063462
0.01752,0.012492,0.0063462
0.01752,0.012518,0.0063462
0.014117,0.011401,0.0063706
0.01432,0.012264,0.0063706
0.014574,0.01036,0.0063706
0.014701,0.010207,0.0063706
0.014701,0.013026,0.0063706
0.014727,0.013051,0.0063706
0.016326,0.0092932,0.0063706
0.016352,0.0092932,0.0063706
0.017062,0.0099787,0.0063706
0.017367,0.012899,0.0063706
0.017393,0.012873,0.0063706
0.017418,0.012848,0.0063706
0.01752,0.012492,0.0063706
0.01752,0.012518,0.0063706
0.014117,0.011375,0.006395
0.014193,0.012086,0.006395
0.014549,0.010385,0.006395
0.014727,0.010182,0.006395
0.015006,0.0099787,0.006395
0.015006,0.013178,0.006395
0.015615,0.0092678,0.006395
0.016047,0.013102,0.006395
0.016275,0.013127,0.006395
0.016352,0.0092932,0.006395
0.017062,0.0099787,0.006395
0.017393,0.012873,0.006395
0.017418,0.012848,0.006395
0.01752,0.012492,0.006395
0.014117,0.01135,0.0064194
0.014168,0.012061,0.0064194
0.014549,0.01036,0.0064194
0.014701,0.013051,0.0064194
0.015006,0.013178,0.0064194
0.015615,0.0092424,0.0064194
0.016047,0.013102,0.0064194
0.016555,0.013127,0.0064194
0.017037,0.0099533,0.0064194
0.017062,0.0099787,0.0064194
0.017418,0.012848,0.0064194
0.01752,0.012467,0.0064194
0.01752,0.012492,0.0064194
0.014092,0.011502,0.0064438
0.014092,0.011528,0.0064438
0.014092,0.011553,0.0064438
0.014143,0.01201,0.0064438
0.014244,0.012188,0.0064438
0.01432,0.012315,0.0064438
0.015006,0.013178,0.0064438
0.01559,0.0092678,0.0064438
0.015615,0.0092424,0.0064438
0.016047,0.013102,0.0064438
0.017037,0.0099533,0.0064438
0.017418,0.012848,0.0064438
0.01752,0.012442,0.0064438
0.01752,0.012467,0.0064438
0.01752,0.012492,0.0064438
0.014219,0.012162,0.0064683
0.014523,0.01036,0.0064683
0.014676,0.010207,0.0064683
0.014981,0.0099787,0.0064683
0.015006,0.013178,0.0064683
0.01559,0.0092424,0.0064683
0.015615,0.0092424,0.0064683
0.016047,0.013102,0.0064683
0.01658,0.013127,0.0064683
0.017418,0.012848,0.0064683
0.017443,0.012797,0.0064683
0.017469,0.010766,0.0064683
0.017469,0.010791,0.0064683
0.01752,0.012442,0.0064683
0.01752,0.012467,0.0064683
0.014092,0.011375,0.0064927
0.014117,0.011274,0.0064927
0.01432,0.01234,0.0064927
0.014498,0.010385,0.0064927
0.014701,0.013076,0.0064927
0.015006,0.013178,0.0064927
0.015564,0.0092678,0.0064927
0.01559,0.0092424,0.0064927
0.016047,0.013102,0.0064927
0.016275,0.013152,0.0064927
0.017443,0.012797,0.0064927
0.017469,0.010766,0.0064927
0.01752,0.012416,0.0064927
0.01752,0.012442,0.0064927
0.01752,0.012467,0.0064927
0.014092,0.01135,0.0065171
0.014117,0.011248,0.0065171
0.014143,0.012061,0.0065171
0.014498,0.01036,0.0065171
0.015006,0.013178,0.0065171
0.01559,0.0092424,0.0065171
0.016047,0.013102,0.0065171
0.017443,0.012797,0.0065171
0.01752,0.012416,0.0065171
0.01752,0.012442,0.0065171
0.014066,0.011477,0.0065415
0.014066,0.011502,0.0065415
0.014295,0.01234,0.0065415
0.016605,0.013127,0.0065415
0.017443,0.012797,0.0065415
0.01752,0.012391,0.0065415
0.01752,0.012416,0.0065415
0.01752,0.012442,0.0065415
0.014117,0.012035,0.0065659
0.014143,0.011172,0.0065659
0.014193,0.012188,0.0065659
0.01427,0.012315,0.0065659
0.014676,0.013076,0.0065659
0.017469,0.012746,0.0065659
0.01752,0.012391,0.0065659
0.01752,0.012416,0.0065659
0.014117,0.012035,0.0065903
0.014295,0.012365,0.0065903
0.016631,0.013127,0.0065903
0.017469,0.012746,0.0065903
0.01752,0.012365,0.0065903
0.01752,0.012391,0.0065903
0.01752,0.012416,0.0065903
0.014117,0.012035,0.0066147
0.016199,0.0092678,0.0066147
0.016631,0.013127,0.0066147
0.017469,0.012746,0.0066147
0.01752,0.01234,0.0066147
0.01752,0.012365,0.0066147
0.01752,0.012391,0.0066147
0.014117,0.012035,0.0066391
0.014193,0.010994,0.0066391
0.014676,0.013102,0.0066391
0.016174,0.0092678,0.0066391
0.016199,0.0092678,0.0066391
0.017494,0.01267,0.0066391
0.01752,0.01234,0.0066391
0.01752,0.012365,0.0066391
0.015158,0.0097248,0.0066635
0.015514,0.0092678,0.0066635
0.016174,0.0092678,0.0066635
0.017367,0.012873,0.0066635
0.017494,0.01267,0.0066635
0.014016,0.011528,0.0066879
0.014092,0.011223,0.0066879
0.014193,0.010969,0.0066879
0.016148,0.0092678,0.0066879
0.016174,0.0092678,0.0066879
0.016275,0.013178,0.0066879
0.017367,0.012873,0.0066879
0.017494,0.01267,0.0066879
0.014016,0.011477,0.0067123
0.014092,0.011223,0.0067123
0.014193,0.010969,0.0067123
0.014625,0.013076,0.0067123
0.015133,0.0097248,0.0067123
0.016148,0.0092678,0.0067123
0.016174,0.0092678,0.0067123
0.017367,0.012873,0.0067123
0.017494,0.01267,0.0067123
0.014168,0.01102,0.0067368
0.014498,0.010334,0.0067368
0.014523,0.010309,0.0067368
0.014625,0.010207,0.0067368
0.01465,0.010182,0.0067368
0.015488,0.0092678,0.0067368
0.016123,0.0092678,0.0067368
0.016148,0.0092678,0.0067368
0.016174,0.0092678,0.0067368
0.016809,0.0098264,0.0067368
0.016834,0.0098518,0.0067368
0.017367,0.012873,0.0067368
0.017494,0.012645,0.0067368
0.014625,0.013102,0.0067612
0.015107,0.0097248,0.0067612
0.016123,0.0092678,0.0067612
0.016148,0.0092678,0.0067612
0.016809,0.0098264,0.0067612
0.017342,0.012873,0.0067612
0.017494,0.012264,0.0067612
0.017494,0.012619,0.0067612
0.017494,0.012645,0.0067612
0.01399,0.01168,0.0067856
0.0146,0.013076,0.0067856
0.01465,0.013127,0.0067856
0.014879,0.0099787,0.0067856
0.016098,0.0092678,0.0067856
0.016123,0.0092678,0.0067856
0.016148,0.0092678,0.0067856
0.016301,0.013203,0.0067856
0.017494,0.012264,0.0067856
0.017494,0.012594,0.0067856
0.017494,0.012619,0.0067856
0.017494,0.012645,0.0067856
0.01399,0.011528,0.00681
0.014143,0.01107,0.00681
0.014397,0.01041,0.00681
0.0146,0.013102,0.00681
0.016098,0.0092678,0.00681
0.016123,0.0092678,0.00681
0.016301,0.013203,0.00681
0.017393,0.012822,0.00681
0.017494,0.012264,0.00681
0.017494,0.012568,0.00681
0.017494,0.012594,0.00681
0.017494,0.012619,0.00681
0.017494,0.012645,0.00681
0.013965,0.011654,0.0068344
0.013965,0.01168,0.0068344
0.01399,0.011502,0.0068344
0.014625,0.013127,0.0068344
0.014981,0.013203,0.0068344
0.015082,0.0097248,0.0068344
0.016301,0.013203,0.0068344
0.017367,0.012848,0.0068344
0.017494,0.012543,0.0068344
0.017494,0.012568,0.0068344
0.017494,0.012594,0.0068344
0.017494,0.012619,0.0068344
0.013965,0.011629,0.0068588
0.015184,0.0095979,0.0068588
0.017494,0.012518,0.0068588
0.017494,0.012543,0.0068588
0.017494,0.012568,0.0068588
0.017494,0.012594,0.0068588
0.017494,0.012619,0.0068588
0.013965,0.011629,0.0068832
0.01399,0.011477,0.0068832
0.014854,0.0099787,0.0068832
0.017494,0.012467,0.0068832
0.017494,0.012492,0.0068832
0.017494,0.012518,0.0068832
0.017494,0.012543,0.0068832
0.017494,0.012568,0.0068832
0.017494,0.012594,0.0068832
0.013965,0.011629,0.0069076
0.016732,0.0097756,0.0069076
0.017418,0.012772,0.0069076
0.017494,0.012442,0.0069076
0.017494,0.012467,0.0069076
0.017494,0.012492,0.0069076
0.017494,0.012518,0.0069076
0.017494,0.012543,0.0069076
0.013965,0.011629,0.006932
0.01399,0.011451,0.006932
0.014041,0.011299,0.006932
0.014676,0.013178,0.006932
0.016732,0.0097756,0.006932
0.016732,0.013051,0.006932
0.017494,0.012492,0.006932
0.017494,0.012518,0.006932
0.017494,0.012543,0.006932
0.014346,0.01041,0.0069565
0.014371,0.010385,0.0069565
0.014904,0.013254,0.0069565
0.016326,0.013178,0.0069565
0.016732,0.0097756,0.0069565
0.016732,0.013051,0.0069565
0.017393,0.012797,0.0069565
0.017469,0.012137,0.0069565
0.017494,0.012543,0.0069565
0.014092,0.011147,0.0069809
0.014168,0.010969,0.0069809
0.01493,0.013254,0.0069809
0.015133,0.0095725,0.0069809
0.016047,0.013127,0.0069809
0.016732,0.013051,0.0069809
0.014143,0.01102,0.0070053
0.015514,0.009217,0.0070053
0.016047,0.013127,0.0070053
0.016732,0.013051,0.0070053
0.014117,0.01107,0.0070297
0.014117,0.012492,0.0070297
0.014904,0.013279,0.0070297
0.015107,0.0095725,0.0070297
0.015488,0.009217,0.0070297
0.016047,0.013127,0.0070297
0.016732,0.013051,0.0070297
0.01399,0.01135,0.0070541
0.01432,0.01041,0.0070541
0.0146,0.010182,0.0070541
0.015082,0.0095979,0.0070541
0.015971,0.0092424,0.0070541
0.015996,0.0092424,0.0070541
0.016047,0.013127,0.0070541
0.017393,0.012772,0.0070541
0.017418,0.010512,0.0070541
0.014117,0.011045,0.0070785
0.015945,0.0092424,0.0070785
0.015996,0.0092424,0.0070785
0.016047,0.013127,0.0070785
0.016326,0.0093694,0.0070785
0.017418,0.010512,0.0070785
0.01399,0.011324,0.0071029
0.015082,0.0095725,0.0071029
0.01592,0.0092424,0.0071029
0.016047,0.013127,0.0071029
0.017418,0.010487,0.0071029
0.017418,0.010512,0.0071029
0.01399,0.011324,0.0071273
0.014092,0.012518,0.0071273
0.015057,0.0095979,0.0071273
0.016047,0.013127,0.0071273
0.01399,0.011324,0.0071517
0.014219,0.01074,0.0071517
0.014295,0.01041,0.0071517
0.015438,0.0091916,0.0071517
0.015463,0.0091916,0.0071517
0.016047,0.013127,0.0071517
0.016301,0.0093186,0.0071517
0.016732,0.009801,0.0071517
0.017393,0.012746,0.0071517
0.014574,0.010182,0.0071761
0.015031,0.0096233,0.0071761
0.015438,0.0091916,0.0071761
0.015463,0.0091916,0.0071761
0.016047,0.013127,0.0071761
0.016707,0.0097756,0.0071761
0.017443,0.01201,0.0071761
0.01752,0.012365,0.0071761
0.01752,0.012391,0.0071761
0.013914,0.011756,0.0072006
0.013914,0.011781,0.0072006
0.01394,0.011858,0.0072006
0.014574,0.010182,0.0072006
0.014625,0.013279,0.0072006
0.014879,0.01333,0.0072006
0.015412,0.0091916,0.0072006
0.015438,0.0091916,0.0072006
0.016047,0.013127,0.0072006
0.016707,0.0097756,0.0072006
0.01752,0.01234,0.0072006
0.01752,0.012391,0.0072006
0.013914,0.011731,0.007225
0.01394,0.011883,0.007225
0.01399,0.011324,0.007225
0.014574,0.010182,0.007225
0.014879,0.01333,0.007225
0.015031,0.0095979,0.007225
0.015412,0.0091916,0.007225
0.015438,0.0091916,0.007225
0.01625,0.0092932,0.007225
0.016275,0.013178,0.007225
0.016682,0.0097502,0.007225
0.016707,0.0097756,0.007225
0.017342,0.010791,0.007225
0.017443,0.011985,0.007225
0.01752,0.012391,0.007225
0.013914,0.011832,0.0072494
0.01399,0.011324,0.0072494
0.014193,0.010766,0.0072494
0.0146,0.013279,0.0072494
0.015031,0.0095979,0.0072494
0.015387,0.0091916,0.0072494
0.015412,0.0091916,0.0072494
0.01625,0.0092932,0.0072494
0.016275,0.013178,0.0072494
0.016301,0.013178,0.0072494
0.016682,0.0097502,0.0072494
0.016707,0.0097756,0.0072494
0.013914,0.011705,0.0072738
0.013914,0.011858,0.0072738
0.01399,0.011324,0.0072738
0.014041,0.012568,0.0072738
0.014041,0.012594,0.0072738
0.0146,0.013279,0.0072738
0.015006,0.0096233,0.0072738
0.015387,0.0091916,0.0072738
0.015412,0.0091916,0.0072738
0.016275,0.013178,0.0072738
0.016682,0.0097502,0.0072738
0.017443,0.011959,0.0072738
0.01399,0.011324,0.0072982
0.014066,0.011096,0.0072982
0.0146,0.013279,0.0072982
0.016275,0.013178,0.0072982
0.016656,0.0097248,0.0072982
0.016656,0.013102,0.0072982
0.016682,0.0097502,0.0072982
0.017316,0.010258,0.0072982
0.014066,0.011096,0.0073226
0.014092,0.01102,0.0073226
0.014574,0.010182,0.0073226
0.0146,0.013279,0.0073226
0.014981,0.0096486,0.0073226
0.015107,0.013254,0.0073226
0.016656,0.0097248,0.0073226
0.016682,0.0097502,0.0073226
0.016682,0.013102,0.0073226
0.017316,0.010258,0.0073226
0.017443,0.011934,0.0073226
0.017469,0.01267,0.0073226
0.013889,0.011832,0.007347
0.013889,0.011858,0.007347
0.013965,0.011401,0.007347
0.014066,0.011096,0.007347
0.014092,0.01102,0.007347
0.0146,0.013279,0.007347
0.015412,0.0091916,0.007347
0.016631,0.0096994,0.007347
0.016656,0.0097248,0.007347
0.017291,0.010207,0.007347
0.017316,0.010283,0.007347
0.017316,0.010309,0.007347
0.017469,0.01267,0.007347
0.014066,0.011096,0.0073714
0.014092,0.01102,0.0073714
0.014219,0.010436,0.0073714
0.0146,0.013279,0.0073714
0.015387,0.0091916,0.0073714
0.015412,0.0091916,0.0073714
0.016631,0.0096994,0.0073714
0.016707,0.013102,0.0073714
0.017291,0.010207,0.0073714
0.017494,0.012619,0.0073714
0.017545,0.012213,0.0073714
0.017545,0.012238,0.0073714
0.014066,0.011096,0.0073958
0.014219,0.010436,0.0073958
0.0146,0.013279,0.0073958
0.015107,0.013279,0.0073958
0.015387,0.0091916,0.0073958
0.016936,0.013026,0.0073958
0.017266,0.010182,0.0073958
0.017291,0.010207,0.0073958
0.017494,0.012619,0.0073958
0.017545,0.012188,0.0073958
0.013889,0.011756,0.0074202
0.014066,0.011096,0.0074202
0.014219,0.010436,0.0074202
0.0146,0.013279,0.0074202
0.015361,0.0091916,0.0074202
0.015844,0.0091916,0.0074202
0.015869,0.0091916,0.0074202
0.016605,0.009674,0.0074202
0.016732,0.013102,0.0074202
0.017189,0.012873,0.0074202
0.017266,0.010182,0.0074202
0.017291,0.010207,0.0074202
0.01752,0.012568,0.0074202
0.017545,0.012162,0.0074202
0.013863,0.011858,0.0074446
0.013863,0.011883,0.0074446
0.013863,0.011908,0.0074446
0.014066,0.011096,0.0074446
0.014092,0.01102,0.0074446
0.014143,0.010817,0.0074446
0.014219,0.010436,0.0074446
0.0146,0.013279,0.0074446
0.014955,0.0096486,0.0074446
0.015361,0.0091916,0.0074446
0.016732,0.013102,0.0074446
0.017266,0.010182,0.0074446
0.017291,0.010233,0.0074446
0.017291,0.010258,0.0074446
0.01752,0.012568,0.0074446
0.017545,0.012137,0.0074446
0.013863,0.011858,0.0074691
0.013863,0.011883,0.0074691
0.013863,0.011908,0.0074691
0.013863,0.011934,0.0074691
0.01399,0.011375,0.0074691
0.014066,0.011096,0.0074691
0.014092,0.01102,0.0074691
0.014143,0.010817,0.0074691
0.014219,0.010436,0.0074691
0.0146,0.013279,0.0074691
0.016123,0.0092678,0.0074691
0.016326,0.013203,0.0074691
0.017215,0.012848,0.0074691
0.017545,0.012111,0.0074691
0.013863,0.011858,0.0074935
0.013863,0.011883,0.0074935
0.013863,0.011908,0.0074935
0.013863,0.011934,0.0074935
0.014016,0.012619,0.0074935
0.014092,0.01102,0.0074935
0.014143,0.010817,0.0074935
0.014219,0.010436,0.0074935
0.0146,0.013279,0.0074935
0.016326,0.013203,0.0074935
0.01658,0.0096486,0.0074935
0.017469,0.012619,0.0074935
0.013863,0.011883,0.0075179
0.013863,0.011908,0.0075179
0.013863,0.011934,0.0075179
0.013863,0.011959,0.0075179
0.014092,0.01102,0.0075179
0.014143,0.010817,0.0075179
0.0146,0.013279,0.0075179
0.015818,0.0091662,0.0075179
0.016326,0.013203,0.0075179
0.01658,0.0096486,0.0075179
0.017113,0.012899,0.0075179
0.017266,0.010207,0.0075179
0.017418,0.011477,0.0075179
0.017545,0.012467,0.0075179
0.013863,0.011883,0.0075423
0.013863,0.011908,0.0075423
0.013863,0.011934,0.0075423
0.013863,0.011959,0.0075423
0.014092,0.01102,0.0075423
0.0146,0.013279,0.0075423
0.015082,0.013356,0.0075423
0.016098,0.0092678,0.0075423
0.016326,0.013203,0.0075423
0.01724,0.012822,0.0075423
0.017418,0.011451,0.0075423
0.017545,0.012492,0.0075423
0.013863,0.011858,0.0075667
0.013863,0.011883,0.0075667
0.013863,0.011908,0.0075667
0.013863,0.011934,0.0075667
0.013863,0.011959,0.0075667
0.013863,0.011985,0.0075667
0.013965,0.011451,0.0075667
0.014092,0.01102,0.0075667
0.0146,0.013279,0.0075667
0.014904,0.009674,0.0075667
0.01493,0.0096486,0.0075667
0.015133,0.0094455,0.0075667
0.016326,0.013203,0.0075667
0.017215,0.010131,0.0075667
0.017266,0.012797,0.0075667
0.017545,0.012492,0.0075667
0.013863,0.011807,0.0075911
0.013863,0.011832,0.0075911
0.013863,0.011858,0.0075911
0.013863,0.011883,0.0075911
0.013863,0.011908,0.0075911
0.013863,0.011934,0.0075911
0.013863,0.011959,0.0075911
0.013863,0.011985,0.0075911
0.013965,0.011451,0.0075911
0.014092,0.01102,0.0075911
0.014193,0.010487,0.0075911
0.0146,0.013279,0.0075911
0.016072,0.0092678,0.0075911
0.016326,0.013203,0.0075911
0.016479,0.013152,0.0075911
0.017215,0.010131,0.0075911
0.017418,0.011426,0.0075911
0.01752,0.012518,0.0075911
0.013863,0.011781,0.0076155
0.013863,0.011807,0.0076155
0.013863,0.011832,0.0076155
0.013863,0.011858,0.0076155
0.013863,0.011883,0.0076155
0.013863,0.011908,0.0076155
0.013863,0.011934,0.0076155
0.013863,0.011959,0.0076155
0.013863,0.011985,0.0076155
0.013965,0.011451,0.0076155
0.014092,0.01102,0.0076155
0.014193,0.010487,0.0076155
0.015285,0.009217,0.0076155
0.015818,0.0091408,0.0076155
0.016326,0.013203,0.0076155
0.013863,0.011781,0.0076399
0.013863,0.011807,0.0076399
0.013863,0.011832,0.0076399
0.013863,0.011858,0.0076399
0.013863,0.011883,0.0076399
0.013863,0.011908,0.0076399
0.013863,0.011934,0.0076399
0.013863,0.011959,0.0076399
0.013863,0.011985,0.0076399
0.013965,0.011451,0.0076399
0.014143,0.010791,0.0076399
0.014193,0.010487,0.0076399
0.014219,0.010461,0.0076399
0.015844,0.0091408,0.0076399
0.016326,0.013203,0.0076399
0.017189,0.010106,0.0076399
0.013863,0.011781,0.0076643
0.013863,0.011807,0.0076643
0.013863,0.011832,0.0076643
0.013863,0.011858,0.0076643
0.013863,0.011883,0.0076643
0.013863,0.011908,0.0076643
0.013863,0.011934,0.0076643
0.013863,0.011959,0.0076643
0.013863,0.011985,0.0076643
0.013965,0.011451,0.0076643
0.014066,0.011121,0.0076643
0.014193,0.010487,0.0076643
0.014574,0.013279,0.0076643
0.014879,0.009674,0.0076643
0.015412,0.0091662,0.0076643
0.015844,0.0091408,0.0076643
0.016301,0.013203,0.0076643
0.016326,0.013203,0.0076643
0.017139,0.012873,0.0076643
0.013863,0.011781,0.0076888
0.013863,0.011807,0.0076888
0.013863,0.011832,0.0076888
0.013863,0.011858,0.0076888
0.013863,0.011883,0.0076888
0.013863,0.011908,0.0076888
0.013863,0.011934,0.0076888
0.013863,0.011959,0.0076888
0.013863,0.011985,0.0076888
0.013965,0.011451,0.0076888
0.014066,0.011121,0.0076888
0.014193,0.010487,0.0076888
0.014574,0.013279,0.0076888
0.015057,0.013381,0.0076888
0.01526,0.009217,0.0076888
0.015387,0.0091662,0.0076888
0.015793,0.0091155,0.0076888
0.016301,0.013203,0.0076888
0.016326,0.013203,0.0076888
0.016783,0.013051,0.0076888
0.017139,0.01003,0.0076888
0.01757,0.012416,0.0076888
0.017596,0.012365,0.0076888
0.013863,0.011756,0.0077132
0.013863,0.011781,0.0077132
0.013863,0.011807,0.0077132
0.013863,0.011832,0.0077132
0.013863,0.011858,0.0077132
0.013863,0.011883,0.0077132
0.013863,0.011908,0.0077132
0.013863,0.011934,0.0077132
0.013863,0.011959,0.0077132
0.013863,0.011985,0.0077132
0.013965,0.011451,0.0077132
0.015057,0.013381,0.0077132
0.015234,0.0092424,0.0077132
0.015387,0.0091662,0.0077132
0.016301,0.013203,0.0077132
0.016326,0.013203,0.0077132
0.016504,0.013152,0.0077132
0.017139,0.01003,0.0077132
0.017316,0.012721,0.0077132
0.017596,0.012365,0.0077132
0.013863,0.011756,0.0077376
0.013863,0.011781,0.0077376
0.013863,0.011807,0.0077376
0.013863,0.011832,0.0077376
0.013863,0.011858,0.0077376
0.013863,0.011883,0.0077376
0.013863,0.011908,0.0077376
0.013863,0.011934,0.0077376
0.013863,0.011959,0.0077376
0.013863,0.011985,0.0077376
0.015057,0.013381,0.0077376
0.016504,0.013152,0.0077376
0.017342,0.012695,0.0077376
0.017596,0.012365,0.0077376
0.013863,0.011781,0.007762
0.013863,0.011807,0.007762
0.013863,0.011832,0.007762
0.013863,0.011858,0.007762
0.013863,0.011883,0.007762
0.013863,0.011908,0.007762
0.013863,0.011934,0.007762
0.013863,0.011959,0.007762
0.013863,0.011985,0.007762
0.014117,0.010842,0.007762
0.015057,0.013381,0.007762
0.016504,0.013152,0.007762
0.017621,0.012315,0.007762
0.013863,0.011781,0.0077864
0.013863,0.011807,0.0077864
0.013863,0.011832,0.0077864
0.013863,0.011858,0.0077864
0.013863,0.011883,0.0077864
0.013863,0.011908,0.0077864
0.013863,0.011934,0.0077864
0.013863,0.011959,0.0077864
0.013863,0.011985,0.0077864
0.013889,0.012061,0.0077864
0.015057,0.013381,0.0077864
0.017164,0.012822,0.0077864
0.01757,0.012391,0.0077864
0.017621,0.012315,0.0077864
0.013863,0.011781,0.0078108
0.013863,0.011807,0.0078108
0.013863,0.011832,0.0078108
0.013863,0.011858,0.0078108
0.013863,0.011883,0.0078108
0.013863,0.011908,0.0078108
0.014168,0.010537,0.0078108
0.015057,0.013381,0.0078108
0.017189,0.012797,0.0078108
0.017621,0.012315,0.0078108
0.013863,0.011781,0.0078352
0.013863,0.011807,0.0078352
0.013863,0.011832,0.0078352
0.013863,0.011858,0.0078352
0.01394,0.011502,0.0078352
0.014168,0.010537,0.0078352
0.014828,0.009674,0.0078352
0.015057,0.013381,0.0078352
0.015768,0.0090901,0.0078352
0.016301,0.013178,0.0078352
0.017266,0.010436,0.0078352
0.017342,0.01267,0.0078352
0.017621,0.012315,0.0078352
0.017646,0.012264,0.0078352
0.013863,0.011781,0.0078596
0.013863,0.011807,0.0078596
0.013863,0.011832,0.0078596
0.0146,0.013305,0.0078596
0.015031,0.013381,0.0078596
0.015057,0.013381,0.0078596
0.015742,0.0090901,0.0078596
0.015768,0.0090901,0.0078596
0.017266,0.01041,0.0078596
0.017646,0.012264,0.0078596
0.013863,0.011807,0.007884
0.014574,0.013305,0.007884
0.015031,0.013381,0.007884
0.015057,0.013381,0.007884
0.015184,0.0092424,0.007884
0.015768,0.0090901,0.007884
0.016529,0.013152,0.007884
0.017393,0.011172,0.007884
0.017646,0.012264,0.007884
0.017672,0.012213,0.007884
0.013863,0.011807,0.0079084
0.01394,0.011477,0.0079084
0.014193,0.010512,0.0079084
0.014574,0.013305,0.0079084
0.015031,0.013381,0.0079084
0.016529,0.013152,0.0079084
0.017367,0.012619,0.0079084
0.017672,0.012213,0.0079084
0.013863,0.011781,0.0079328
0.01394,0.011477,0.0079328
0.014016,0.012695,0.0079328
0.014092,0.010893,0.0079328
0.014193,0.010512,0.0079328
0.014574,0.013305,0.0079328
0.015031,0.013381,0.0079328
0.016529,0.013152,0.0079328
0.017037,0.0098772,0.0079328
0.017672,0.012213,0.0079328
0.017697,0.012137,0.0079328
0.017697,0.012162,0.0079328
0.01394,0.011477,0.0079573
0.014016,0.012695,0.0079573
0.014092,0.010867,0.0079573
0.014193,0.010512,0.0079573
0.014574,0.013305,0.0079573
0.014803,0.009674,0.0079573
0.015031,0.013381,0.0079573
0.016529,0.013152,0.0079573
0.017037,0.0098772,0.0079573
0.017088,0.0099787,0.0079573
0.017189,0.012772,0.0079573
0.017672,0.012213,0.0079573
0.017697,0.012162,0.0079573
0.01394,0.011477,0.0079817
0.014016,0.012695,0.0079817
0.014092,0.010867,0.0079817
0.014168,0.010537,0.0079817
0.014193,0.010512,0.0079817
0.014574,0.013305,0.0079817
0.015031,0.013381,0.0079817
0.015717,0.0090647,0.0079817
0.016529,0.013152,0.0079817
0.017088,0.0099787,0.0079817
0.017367,0.012594,0.0079817
0.017393,0.012568,0.0079817
0.017697,0.012162,0.0079817
0.01394,0.011477,0.0080061
0.014016,0.012695,0.0080061
0.014092,0.010867,0.0080061
0.014168,0.010537,0.0080061
0.014193,0.010512,0.0080061
0.014574,0.013305,0.0080061
0.014777,0.0096994,0.0080061
0.015717,0.0090647,0.0080061
0.016504,0.013152,0.0080061
0.016529,0.013152,0.0080061
0.016986,0.012848,0.0080061
0.017088,0.0099787,0.0080061
0.017697,0.012162,0.0080061
0.017723,0.012111,0.0080061
0.013863,0.012086,0.0080305
0.014016,0.012695,0.0080305
0.014168,0.010537,0.0080305
0.014193,0.010512,0.0080305
0.014574,0.013305,0.0080305
0.015691,0.0090647,0.0080305
0.015717,0.0090647,0.0080305
0.016986,0.0097756,0.0080305
0.017062,0.0099279,0.0080305
0.017697,0.012162,0.0080305
0.013838,0.01201,0.0080549
0.013914,0.011528,0.0080549
0.014016,0.012695,0.0080549
0.014168,0.010537,0.0080549
0.014193,0.010512,0.0080549
0.014574,0.013305,0.0080549
0.015691,0.0090647,0.0080549
0.015717,0.0090647,0.0080549
0.016986,0.0097756,0.0080549
0.017012,0.012822,0.0080549
0.017062,0.0099279,0.0080549
0.017189,0.012746,0.0080549
0.017393,0.012543,0.0080549
0.017697,0.012162,0.0080549
0.017748,0.012035,0.0080549
0.017748,0.012061,0.0080549
0.013838,0.011985,0.0080793
0.013838,0.012035,0.0080793
0.014016,0.012695,0.0080793
0.014168,0.010537,0.0080793
0.014193,0.010512,0.0080793
0.014574,0.013305,0.0080793
0.01526,0.0091662,0.0080793
0.015691,0.0090647,0.0080793
0.016986,0.0097756,0.0080793
0.014016,0.012695,0.0081037
0.014168,0.010537,0.0081037
0.014193,0.010512,0.0081037
0.014574,0.013305,0.0081037
0.015234,0.0091662,0.0081037
0.015691,0.0090647,0.0081037
0.017393,0.01107,0.0081037
0.01394,0.011477,0.0081281
0.014016,0.012695,0.0081281
0.014092,0.010842,0.0081281
0.014168,0.010537,0.0081281
0.014574,0.013305,0.0081281
0.014752,0.0096994,0.0081281
0.015209,0.0091662,0.0081281
0.016961,0.0097248,0.0081281
0.017215,0.012721,0.0081281
0.017773,0.011959,0.0081281
0.01394,0.011477,0.0081525
0.014143,0.010563,0.0081525
0.014168,0.010537,0.0081525
0.014549,0.013305,0.0081525
0.014574,0.013305,0.0081525
0.014752,0.0096994,0.0081525
0.015184,0.0091662,0.0081525
0.016936,0.0096994,0.0081525
0.013863,0.011807,0.0081769
0.014066,0.010944,0.0081769
0.014143,0.010563,0.0081769
0.014168,0.010537,0.0081769
0.014549,0.013305,0.0081769
0.014574,0.013305,0.0081769
0.015158,0.0091662,0.0081769
0.01625,0.013127,0.0081769
0.016961,0.012822,0.0081769
0.017215,0.012695,0.0081769
0.017799,0.011985,0.0081769
0.017799,0.01201,0.0081769
0.013838,0.011908,0.0082014
0.014066,0.010918,0.0082014
0.014143,0.010563,0.0082014
0.014168,0.010537,0.0082014
0.014549,0.013305,0.0082014
0.014574,0.013305,0.0082014
0.014727,0.0097248,0.0082014
0.015006,0.01333,0.0082014
0.01625,0.013127,0.0082014
0.016529,0.013127,0.0082014
0.017773,0.011858,0.0082014
0.017799,0.011959,0.0082014
0.017799,0.011985,0.0082014
0.017799,0.01201,0.0082014
0.013838,0.011908,0.0082258
0.014016,0.012721,0.0082258
0.014066,0.010918,0.0082258
0.014143,0.010563,0.0082258
0.014168,0.010537,0.0082258
0.014574,0.013305,0.0082258
0.01625,0.013127,0.0082258
0.016275,0.013127,0.0082258
0.017773,0.011832,0.0082258
0.017799,0.011959,0.0082258
0.017799,0.011985,0.0082258
0.013838,0.011908,0.0082502
0.014143,0.010563,0.0082502
0.014574,0.013305,0.0082502
0.016986,0.012797,0.0082502
0.017393,0.012442,0.0082502
0.017773,0.011807,0.0082502
0.017799,0.011959,0.0082502
0.017799,0.011985,0.0082502
0.013813,0.012111,0.0082746
0.014143,0.010563,0.0082746
0.014574,0.013305,0.0082746
0.017773,0.011781,0.0082746
0.017799,0.011934,0.0082746
0.017799,0.011959,0.0082746
0.014016,0.012746,0.008299
0.014143,0.010563,0.008299
0.014549,0.013305,0.008299
0.014574,0.013305,0.008299
0.014701,0.0097502,0.008299
0.015107,0.0091408,0.008299
0.016275,0.013127,0.008299
0.013787,0.012061,0.0083234
0.014117,0.012848,0.0083234
0.014143,0.010563,0.0083234
0.014549,0.013305,0.0083234
0.014574,0.013305,0.0083234
0.015082,0.0091408,0.0083234
0.015539,0.0090647,0.0083234
0.016275,0.013127,0.0083234
0.016809,0.0095725,0.0083234
0.017393,0.012416,0.0083234
0.013787,0.012061,0.0083478
0.013787,0.012086,0.0083478
0.013813,0.012137,0.0083478
0.013889,0.011654,0.0083478
0.014143,0.010563,0.0083478
0.014549,0.013305,0.0083478
0.014574,0.013305,0.0083478
0.015514,0.0090647,0.0083478
0.015539,0.0090647,0.0083478
0.016275,0.013127,0.0083478
0.016783,0.0095471,0.0083478
0.013787,0.012061,0.0083722
0.013787,0.012086,0.0083722
0.013889,0.011654,0.0083722
0.014041,0.010994,0.0083722
0.014143,0.010563,0.0083722
0.014549,0.013305,0.0083722
0.014574,0.013305,0.0083722
0.015514,0.0090647,0.0083722
0.016758,0.0095217,0.0083722
0.017393,0.012391,0.0083722
0.013787,0.012061,0.0083966
0.013787,0.012086,0.0083966
0.013787,0.012111,0.0083966
0.013889,0.011654,0.0083966
0.014041,0.010969,0.0083966
0.014549,0.013305,0.0083966
0.014574,0.013305,0.0083966
0.015057,0.0091408,0.0083966
0.015488,0.0090647,0.0083966
0.015514,0.0090647,0.0083966
0.01724,0.012594,0.0083966
0.013787,0.012061,0.008421
0.013787,0.012086,0.008421
0.013787,0.012111,0.008421
0.013889,0.011654,0.008421
0.014092,0.012848,0.008421
0.014549,0.013305,0.008421
0.015006,0.013305,0.008421
0.015057,0.0091408,0.008421
0.015488,0.0090647,0.008421
0.015514,0.0090647,0.008421
0.013787,0.012061,0.0084455
0.013787,0.012086,0.0084455
0.013787,0.012111,0.0084455
0.013889,0.011654,0.0084455
0.014549,0.013305,0.0084455
0.014981,0.013305,0.0084455
0.015057,0.0091408,0.0084455
0.015463,0.0090647,0.0084455
0.015488,0.0090647,0.0084455
0.016859,0.0095471,0.0084455
0.017164,0.010131,0.0084455
0.013787,0.012061,0.0084699
0.013787,0.012086,0.0084699
0.013787,0.012111,0.0084699
0.013813,0.012162,0.0084699
0.013889,0.011654,0.0084699
0.01399,0.012746,0.0084699
0.014143,0.010588,0.0084699
0.014549,0.013305,0.0084699
0.014981,0.013305,0.0084699
0.015463,0.0090647,0.0084699
0.015488,0.0090647,0.0084699
0.016529,0.013102,0.0084699
0.016834,0.0094963,0.0084699
0.017164,0.010106,0.0084699
0.013787,0.012086,0.0084943
0.013787,0.012111,0.0084943
0.013813,0.012162,0.0084943
0.013889,0.01168,0.0084943
0.01399,0.012772,0.0084943
0.014016,0.012797,0.0084943
0.014143,0.010588,0.0084943
0.014549,0.013305,0.0084943
0.014981,0.013305,0.0084943
0.015438,0.0090647,0.0084943
0.015463,0.0090647,0.0084943
0.016529,0.013102,0.0084943
0.016834,0.0094963,0.0084943
0.017164,0.01008,0.0084943
0.017393,0.01234,0.0084943
0.017799,0.011528,0.0084943
0.013787,0.012086,0.0085187
0.013787,0.012111,0.0085187
0.014092,0.012873,0.0085187
0.014143,0.010588,0.0085187
0.014549,0.013305,0.0085187
0.015438,0.0090647,0.0085187
0.015463,0.0090647,0.0085187
0.016529,0.013102,0.0085187
0.016809,0.0094709,0.0085187
0.016834,0.0094963,0.0085187
0.017012,0.0098264,0.0085187
0.01724,0.012543,0.0085187
0.017799,0.011502,0.0085187
0.013787,0.012086,0.0085431
0.013787,0.012111,0.0085431
0.015438,0.0090647,0.0085431
0.015463,0.0090647,0.0085431
0.016529,0.013102,0.0085431
0.016809,0.0094709,0.0085431
0.016834,0.0094963,0.0085431
0.017799,0.011477,0.0085431
0.014016,0.01102,0.0085675
0.014143,0.010613,0.0085675
0.015412,0.0090647,0.0085675
0.015438,0.0090647,0.0085675
0.016529,0.013102,0.0085675
0.016555,0.013102,0.0085675
0.016809,0.0094709,0.0085675
0.017799,0.011451,0.0085675
0.013914,0.011654,0.0085919
0.014016,0.010994,0.0085919
0.014066,0.012873,0.0085919
0.015006,0.0091662,0.0085919
0.015412,0.0090647,0.0085919
0.015438,0.0090647,0.0085919
0.016529,0.013102,0.0085919
0.016555,0.013102,0.0085919
0.016783,0.0094455,0.0085919
0.01724,0.012518,0.0085919
0.017799,0.011426,0.0085919
0.01399,0.012822,0.0086163
0.014016,0.010994,0.0086163
0.0146,0.0097502,0.0086163
0.015412,0.0090647,0.0086163
0.016529,0.013102,0.0086163
0.016555,0.013102,0.0086163
0.016783,0.0094455,0.0086163
0.017773,0.011375,0.0086163
0.014016,0.010994,0.0086407
0.014168,0.010588,0.0086407
0.01625,0.013076,0.0086407
0.016529,0.013102,0.0086407
0.016555,0.013102,0.0086407
0.016656,0.009344,0.0086407
0.016986,0.0097248,0.0086407
0.013813,0.012188,0.0086651
0.014016,0.010994,0.0086651
0.016529,0.013102,0.0086651
0.016631,0.0093186,0.0086651
0.013813,0.012188,0.0086896
0.014016,0.010994,0.0086896
0.014219,0.010537,0.0086896
0.015006,0.0091408,0.0086896
0.013813,0.012188,0.008714
0.013965,0.012822,0.008714
0.014016,0.010994,0.008714
0.014981,0.0091408,0.008714
0.013813,0.012188,0.0087384
0.013965,0.012848,0.0087384
0.014016,0.010994,0.0087384
0.014168,0.010613,0.0087384
0.014981,0.0091408,0.0087384
0.015336,0.0090901,0.0087384
0.016732,0.012949,0.0087384
0.013813,0.012061,0.0087628
0.013813,0.012188,0.0087628
0.013965,0.012848,0.0087628
0.01399,0.012873,0.0087628
0.015336,0.0090901,0.0087628
0.01658,0.0092678,0.0087628
0.016605,0.0092678,0.0087628
0.016732,0.012949,0.0087628
0.01785,0.011629,0.0087628
0.013813,0.012061,0.0087872
0.013813,0.012188,0.0087872
0.014955,0.0091408,0.0087872
0.015336,0.0090901,0.0087872
0.016605,0.0092678,0.0087872
0.016986,0.0097756,0.0087872
0.017545,0.012111,0.0087872
0.01757,0.012086,0.0087872
0.013813,0.012086,0.0088116
0.013813,0.012111,0.0088116
0.013813,0.012137,0.0088116
0.013813,0.012162,0.0088116
0.013813,0.012188,0.0088116
0.013914,0.011731,0.0088116
0.013965,0.012873,0.0088116
0.014574,0.0098264,0.0088116
0.014904,0.013229,0.0088116
0.01493,0.013229,0.0088116
0.014955,0.0091408,0.0088116
0.015336,0.0090901,0.0088116
0.016885,0.0095725,0.0088116
0.017545,0.012111,0.0088116
0.01757,0.012086,0.0088116
0.013813,0.012086,0.008836
0.013813,0.012111,0.008836
0.013813,0.012137,0.008836
0.013813,0.012162,0.008836
0.013813,0.012188,0.008836
0.013914,0.011731,0.008836
0.01399,0.011045,0.008836
0.01399,0.01107,0.008836
0.014168,0.010639,0.008836
0.014574,0.0098264,0.008836
0.01493,0.0091662,0.008836
0.014955,0.0091408,0.008836
0.015336,0.0090901,0.008836
0.016885,0.0095725,0.008836
0.017012,0.0098518,0.008836
0.013813,0.012137,0.0088604
0.013813,0.012162,0.0088604
0.013813,0.012188,0.0088604
0.013914,0.011731,0.0088604
0.01399,0.011045,0.0088604
0.01399,0.01107,0.0088604
0.014574,0.0098264,0.0088604
0.014955,0.0091408,0.0088604
0.016529,0.0092424,0.0088604
0.016555,0.0092424,0.0088604
0.016885,0.0095725,0.0088604
0.017012,0.0098518,0.0088604
0.013813,0.012137,0.0088848
0.013813,0.012162,0.0088848
0.013813,0.012188,0.0088848
0.013838,0.012035,0.0088848
0.013914,0.011731,0.0088848
0.01399,0.011045,0.0088848
0.01399,0.01107,0.0088848
0.014219,0.010563,0.0088848
0.014574,0.0098264,0.0088848
0.014955,0.0091408,0.0088848
0.01625,0.013051,0.0088848
0.016504,0.013076,0.0088848
0.016555,0.0092424,0.0088848
0.016555,0.013076,0.0088848
0.016859,0.0095217,0.0088848
0.013813,0.012137,0.0089092
0.013813,0.012162,0.0089092
0.013813,0.012188,0.0089092
0.013914,0.011731,0.0089092
0.013965,0.012899,0.0089092
0.01399,0.011045,0.0089092
0.01399,0.01107,0.0089092
0.014904,0.0091916,0.0089092
0.014955,0.0091408,0.0089092
0.016529,0.013076,0.0089092
0.016555,0.013076,0.0089092
0.016859,0.0095217,0.0089092
0.013813,0.012137,0.0089337
0.013813,0.012162,0.0089337
0.013813,0.012188,0.0089337
0.013914,0.011731,0.0089337
0.013965,0.012899,0.0089337
0.01399,0.011045,0.0089337
0.01399,0.01107,0.0089337
0.014904,0.013203,0.0089337
0.014955,0.0091408,0.0089337
0.01526,0.0091155,0.0089337
0.016859,0.0095217,0.0089337
0.013813,0.012137,0.0089581
0.013813,0.012162,0.0089581
0.013813,0.012188,0.0089581
0.013965,0.012899,0.0089581
0.01399,0.011045,0.0089581
0.01399,0.01107,0.0089581
0.01399,0.011096,0.0089581
0.014676,0.0096486,0.0089581
0.014879,0.013203,0.0089581
0.014904,0.0091662,0.0089581
0.014955,0.0091408,0.0089581
0.016479,0.009217,0.0089581
0.016504,0.009217,0.0089581
0.017875,0.011426,0.0089581
0.0179,0.011375,0.0089581
0.013813,0.012137,0.0089825
0.013813,0.012162,0.0089825
0.013813,0.012188,0.0089825
0.013965,0.012899,0.0089825
0.01399,0.011045,0.0089825
0.01399,0.01107,0.0089825
0.01399,0.011096,0.0089825
0.014676,0.0096486,0.0089825
0.015158,0.013102,0.0089825
0.016834,0.0094709,0.0089825
0.01691,0.0096233,0.0089825
0.017596,0.012035,0.0089825
0.017621,0.01201,0.0089825
0.0179,0.011324,0.0089825
0.0179,0.01135,0.0089825
0.0179,0.011375,0.0089825
0.013813,0.012162,0.0090069
0.013965,0.012899,0.0090069
0.01399,0.01107,0.0090069
0.01399,0.011096,0.0090069
0.014193,0.010639,0.0090069
0.014219,0.010588,0.0090069
0.014676,0.0096486,0.0090069
0.014879,0.0091916,0.0090069
0.016809,0.012899,0.0090069
0.01691,0.0096233,0.0090069
0.017215,0.012442,0.0090069
0.017621,0.01201,0.0090069
0.0179,0.011299,0.0090069
0.0179,0.011324,0.0090069
0.013813,0.012162,0.0090313
0.013838,0.012086,0.0090313
0.01394,0.012873,0.0090313
0.013965,0.012899,0.0090313
0.01399,0.01107,0.0090313
0.01399,0.011096,0.0090313
0.016809,0.012899,0.0090313
0.01724,0.012416,0.0090313
0.017621,0.011985,0.0090313
0.0179,0.011274,0.0090313
0.0179,0.011299,0.0090313
0.013813,0.012162,0.0090557
0.01394,0.012873,0.0090557
0.013965,0.012899,0.0090557
0.01399,0.01107,0.0090557
0.01399,0.011096,0.0090557
0.016225,0.013026,0.0090557
0.016809,0.0094201,0.0090557
0.016809,0.012899,0.0090557
0.0179,0.011248,0.0090557
0.01394,0.012873,0.0090801
0.01399,0.01107,0.0090801
0.01399,0.011096,0.0090801
0.01399,0.011121,0.0090801
0.014523,0.013152,0.0090801
0.016783,0.0093948,0.0090801
0.016809,0.012899,0.0090801
0.016859,0.012873,0.0090801
0.017266,0.012391,0.0090801
0.0179,0.011223,0.0090801
0.01399,0.01107,0.0091045
0.01399,0.011096,0.0091045
0.01399,0.011121,0.0091045
0.014219,0.010639,0.0091045
0.014854,0.0091916,0.0091045
0.014879,0.0091662,0.0091045
0.01625,0.013026,0.0091045
0.016758,0.0093694,0.0091045
0.016783,0.0093948,0.0091045
0.016809,0.012899,0.0091045
0.016859,0.012873,0.0091045
0.017266,0.012391,0.0091045
0.0179,0.011197,0.0091045
0.013838,0.012111,0.0091289
0.01394,0.011705,0.0091289
0.01394,0.012848,0.0091289
0.01399,0.011096,0.0091289
0.01399,0.011121,0.0091289
0.01399,0.012924,0.0091289
0.014854,0.0091916,0.0091289
0.014879,0.0091662,0.0091289
0.016377,0.0091916,0.0091289
0.016479,0.013051,0.0091289
0.016758,0.0093694,0.0091289
0.017266,0.012391,0.0091289
0.017291,0.012365,0.0091289
0.017621,0.011883,0.0091289
0.017875,0.011147,0.0091289
0.0179,0.011172,0.0091289
0.01399,0.011096,0.0091533
0.01399,0.011121,0.0091533
0.01399,0.012924,0.0091533
0.014803,0.013152,0.0091533
0.014828,0.013152,0.0091533
0.014854,0.0091916,0.0091533
0.014879,0.0091662,0.0091533
0.014904,0.0091662,0.0091533
0.016479,0.013051,0.0091533
0.01691,0.012848,0.0091533
0.017291,0.012365,0.0091533
0.017875,0.011121,0.0091533
0.013889,0.012391,0.0091778
0.01399,0.011096,0.0091778
0.01399,0.011121,0.0091778
0.01399,0.012924,0.0091778
0.014523,0.0098518,0.0091778
0.014854,0.0091916,0.0091778
0.014879,0.0091662,0.0091778
0.015641,0.013,0.0091778
0.016479,0.013051,0.0091778
0.01691,0.012848,0.0091778
0.017875,0.011096,0.0091778
0.013838,0.012137,0.0092022
0.013889,0.012391,0.0092022
0.01394,0.011731,0.0092022
0.01399,0.011096,0.0092022
0.01399,0.011121,0.0092022
0.014854,0.0091916,0.0092022
0.015641,0.013,0.0092022
0.016479,0.013051,0.0092022
0.01691,0.012848,0.0092022
0.016936,0.012822,0.0092022
0.017875,0.01107,0.0092022
0.013838,0.012162,0.0092266
0.013889,0.012391,0.0092266
0.01399,0.011096,0.0092266
0.01399,0.011121,0.0092266
0.015641,0.013,0.0092266
0.016479,0.013051,0.0092266
0.016936,0.012822,0.0092266
0.017621,0.011807,0.0092266
0.017875,0.011045,0.0092266
0.013889,0.012391,0.009251
0.01399,0.011096,0.009251
0.01399,0.011121,0.009251
0.01399,0.011147,0.009251
0.014219,0.01069,0.009251
0.014244,0.010639,0.009251
0.015641,0.013,0.009251
0.016936,0.012822,0.009251
0.013889,0.012391,0.0092754
0.01394,0.011731,0.0092754
0.01394,0.012899,0.0092754
0.01399,0.011096,0.0092754
0.01399,0.011121,0.0092754
0.01399,0.011147,0.0092754
0.014803,0.013127,0.0092754
0.016682,0.0092932,0.0092754
0.016707,0.0093186,0.0092754
0.016732,0.009344,0.0092754
0.01785,0.010994,0.0092754
0.013889,0.012391,0.0092998
0.01394,0.011731,0.0092998
0.01399,0.011121,0.0092998
0.014828,0.009217,0.0092998
0.016682,0.0092932,0.0092998
0.016707,0.0093186,0.0092998
0.013889,0.012391,0.0093242
0.01399,0.011121,0.0093242
0.014828,0.009217,0.0093242
0.014854,0.009217,0.0093242
0.016656,0.0092678,0.0093242
0.016682,0.0092932,0.0093242
0.016707,0.0093186,0.0093242
0.017316,0.012264,0.0093242
0.017596,0.011781,0.0093242
0.013914,0.012873,0.0093486
0.014498,0.013076,0.0093486
0.014803,0.0092424,0.0093486
0.015311,0.013051,0.0093486
0.016656,0.0092678,0.0093486
0.016682,0.0092932,0.0093486
0.016707,0.0093186,0.0093486
0.017316,0.012238,0.0093486
0.017621,0.011731,0.0093486
0.013914,0.012873,0.009373
0.013914,0.012899,0.009373
0.014777,0.013102,0.009373
0.014803,0.0092424,0.009373
0.014803,0.013102,0.009373
0.016479,0.013026,0.009373
0.016656,0.0092678,0.009373
0.016682,0.0092932,0.009373
0.017646,0.01168,0.009373
0.017697,0.011604,0.009373
0.013914,0.012873,0.0093974
0.013914,0.012899,0.0093974
0.01394,0.011756,0.0093974
0.014803,0.0092424,0.0093974
0.016631,0.0092424,0.0093974
0.016656,0.0092678,0.0093974
0.016682,0.0092932,0.0093974
0.017799,0.010842,0.0093974
0.017799,0.010867,0.0093974
0.013914,0.012873,0.0094219
0.013914,0.012899,0.0094219
0.01394,0.011756,0.0094219
0.01658,0.009217,0.0094219
0.016631,0.0092424,0.0094219
0.016656,0.0092678,0.0094219
0.017646,0.011654,0.0094219
0.013863,0.012162,0.0094463
0.013863,0.012188,0.0094463
0.013889,0.012391,0.0094463
0.013914,0.012873,0.0094463
0.013914,0.012899,0.0094463
0.01394,0.011756,0.0094463
0.014574,0.0097756,0.0094463
0.015438,0.009217,0.0094463
0.016479,0.013,0.0094463
0.016631,0.0092424,0.0094463
0.016656,0.0092678,0.0094463
0.013889,0.012391,0.0094707
0.013914,0.012873,0.0094707
0.01394,0.011756,0.0094707
0.014777,0.0092932,0.0094707
0.016225,0.0090901,0.0094707
0.016631,0.0092424,0.0094707
0.013914,0.012848,0.0094951
0.013914,0.012873,0.0094951
0.01394,0.011756,0.0094951
0.016605,0.009217,0.0094951
0.016631,0.0092424,0.0094951
0.017748,0.010715,0.0094951
0.017773,0.01074,0.0094951
0.013889,0.012086,0.0095195
0.013914,0.012822,0.0095195
0.013914,0.012848,0.0095195
0.013914,0.012873,0.0095195
0.01394,0.011756,0.0095195
0.014244,0.010664,0.0095195
0.016199,0.0090647,0.0095195
0.016605,0.009217,0.0095195
0.016961,0.012695,0.0095195
0.013914,0.012797,0.0095439
0.013914,0.012822,0.0095439
0.013914,0.012848,0.0095439
0.013914,0.012873,0.0095439
0.016199,0.0090647,0.0095439
0.016453,0.012949,0.0095439
0.016555,0.0091916,0.0095439
0.013914,0.012772,0.0095683
0.013914,0.012797,0.0095683
0.013914,0.012822,0.0095683
0.013914,0.012848,0.0095683
0.01394,0.011781,0.0095683
0.014016,0.011223,0.0095683
0.014498,0.0099279,0.0095683
0.014549,0.009801,0.0095683
0.016174,0.0090647,0.0095683
0.017494,0.010385,0.0095683
0.017723,0.010664,0.0095683
0.013889,0.012391,0.0095927
0.013914,0.012772,0.0095927
0.013914,0.012797,0.0095927
0.013914,0.012899,0.0095927
0.01394,0.011807,0.0095927
0.014016,0.011121,0.0095927
0.014016,0.011147,0.0095927
0.014016,0.011172,0.0095927
0.014016,0.011197,0.0095927
0.014016,0.011223,0.0095927
0.014549,0.009801,0.0095927
0.017494,0.01036,0.0095927
0.013889,0.012391,0.0096171
0.013914,0.012746,0.0096171
0.013914,0.012924,0.0096171
0.014016,0.011121,0.0096171
0.014016,0.011147,0.0096171
0.014016,0.011172,0.0096171
0.014016,0.011197,0.0096171
0.014016,0.011223,0.0096171
0.014549,0.009801,0.0096171
0.015361,0.0092424,0.0096171
0.013889,0.012111,0.0096415
0.013889,0.012213,0.0096415
0.013889,0.012238,0.0096415
0.013889,0.01234,0.0096415
0.013889,0.012365,0.0096415
0.013889,0.012391,0.0096415
0.013914,0.012746,0.0096415
0.013914,0.012924,0.0096415
0.014016,0.011121,0.0096415
0.014016,0.011147,0.0096415
0.014016,0.011172,0.0096415
0.014016,0.011197,0.0096415
0.014016,0.011223,0.0096415
0.014016,0.011248,0.0096415
0.016504,0.0091662,0.0096415
0.017113,0.012467,0.0096415
0.017494,0.010309,0.0096415
0.017646,0.011553,0.0096415
0.013889,0.012137,0.009666
0.013914,0.012746,0.009666
0.013914,0.012924,0.009666
0.014016,0.011121,0.009666
0.014016,0.011147,0.009666
0.014016,0.011172,0.009666
0.014016,0.011197,0.009666
0.014016,0.011223,0.009666
0.014016,0.011248,0.009666
0.014219,0.01069,0.009666
0.014473,0.0099533,0.009666
0.017113,0.012467,0.009666
0.013914,0.012924,0.0096904
0.014016,0.011147,0.0096904
0.014016,0.011172,0.0096904
0.014016,0.011197,0.0096904
0.014016,0.011223,0.0096904
0.014016,0.011248,0.0096904
0.014219,0.01069,0.0096904
0.014473,0.0099533,0.0096904
0.015311,0.013127,0.0096904
0.016098,0.0090647,0.0096904
0.013914,0.012924,0.0097148
0.014016,0.011147,0.0097148
0.014016,0.011172,0.0097148
0.014016,0.011197,0.0097148
0.014016,0.011223,0.0097148
0.014422,0.013,0.0097148
0.014523,0.0098518,0.0097148
0.015311,0.013127,0.0097148
0.016402,0.012873,0.0097148
0.017672,0.011502,0.0097148
0.013889,0.012365,0.0097392
0.013914,0.012924,0.0097392
0.014016,0.011147,0.0097392
0.014016,0.011172,0.0097392
0.014016,0.011197,0.0097392
0.014016,0.011223,0.0097392
0.014219,0.010715,0.0097392
0.014422,0.013,0.0097392
0.015311,0.013127,0.0097392
0.017062,0.012543,0.0097392
0.017469,0.010207,0.0097392
0.017672,0.011477,0.0097392
0.017697,0.011426,0.0097392
0.013889,0.012365,0.0097636
0.013889,0.012391,0.0097636
0.013914,0.012924,0.0097636
0.014016,0.011147,0.0097636
0.014016,0.011172,0.0097636
0.014016,0.011197,0.0097636
0.014422,0.013,0.0097636
0.014727,0.0093186,0.0097636
0.015311,0.013127,0.0097636
0.017062,0.012543,0.0097636
0.017443,0.010182,0.0097636
0.017469,0.010207,0.0097636
0.013889,0.012365,0.009788
0.013889,0.012391,0.009788
0.013914,0.012924,0.009788
0.014016,0.011147,0.009788
0.014016,0.011172,0.009788
0.014016,0.011197,0.009788
0.014422,0.013,0.009788
0.014701,0.009344,0.009788
0.014727,0.0093186,0.009788
0.014752,0.0093186,0.009788
0.015311,0.013127,0.009788
0.016834,0.012721,0.009788
0.017062,0.012543,0.009788
0.013889,0.01234,0.0098124
0.013889,0.012365,0.0098124
0.013914,0.012924,0.0098124
0.014016,0.011172,0.0098124
0.014016,0.011197,0.0098124
0.014422,0.013,0.0098124
0.014701,0.009344,0.0098124
0.014727,0.0093186,0.0098124
0.015311,0.013127,0.0098124
0.016555,0.012822,0.0098124
0.017062,0.012543,0.0098124
0.013889,0.01234,0.0098368
0.013889,0.012365,0.0098368
0.013889,0.012899,0.0098368
0.013889,0.012924,0.0098368
0.013914,0.012924,0.0098368
0.014016,0.011172,0.0098368
0.014016,0.011197,0.0098368
0.014016,0.011223,0.0098368
0.014422,0.013,0.0098368
0.014701,0.009344,0.0098368
0.015311,0.013127,0.0098368
0.013889,0.01234,0.0098612
0.013889,0.012365,0.0098612
0.013889,0.012391,0.0098612
0.013889,0.012873,0.0098612
0.013889,0.012924,0.0098612
0.013914,0.012924,0.0098612
0.014016,0.011172,0.0098612
0.014016,0.011197,0.0098612
0.014016,0.011223,0.0098612
0.014701,0.009344,0.0098612
0.016225,0.0090393,0.0098612
0.017672,0.011324,0.0098612
0.013889,0.012315,0.0098856
0.013889,0.01234,0.0098856
0.013889,0.012365,0.0098856
0.013889,0.012391,0.0098856
0.013889,0.012848,0.0098856
0.014016,0.011172,0.0098856
0.014016,0.011197,0.0098856
0.014016,0.011223,0.0098856
0.014016,0.011248,0.0098856
0.017646,0.01135,0.0098856
0.013889,0.012289,0.0099101
0.013889,0.012315,0.0099101
0.013889,0.01234,0.0099101
0.013889,0.012365,0.0099101
0.013889,0.012391,0.0099101
0.013914,0.012111,0.0099101
0.014016,0.011172,0.0099101
0.014016,0.011197,0.0099101
0.014016,0.011223,0.0099101
0.014016,0.011248,0.0099101
0.014473,0.0099025,0.0099101
0.016352,0.0091155,0.0099101
0.016377,0.0091408,0.0099101
0.013889,0.012289,0.0099345
0.013889,0.012315,0.0099345
0.013889,0.01234,0.0099345
0.013889,0.012365,0.0099345
0.013889,0.012822,0.0099345
0.013914,0.012111,0.0099345
0.014016,0.011197,0.0099345
0.014016,0.011223,0.0099345
0.014016,0.011248,0.0099345
0.014473,0.0099025,0.0099345
0.014701,0.0093694,0.0099345
0.01526,0.013102,0.0099345
0.015311,0.013102,0.0099345
0.016555,0.012797,0.0099345
0.016834,0.01267,0.0099345
0.013889,0.012315,0.0099589
0.013889,0.01234,0.0099589
0.013889,0.012365,0.0099589
0.014016,0.011197,0.0099589
0.014016,0.011223,0.0099589
0.014016,0.011248,0.0099589
0.014422,0.01003,0.0099589
0.01526,0.013102,0.0099589
0.016225,0.012822,0.0099589
0.016529,0.012797,0.0099589
0.016758,0.012695,0.0099589
0.017113,0.012492,0.0099589
0.017646,0.011223,0.0099589
0.017646,0.011274,0.0099589
0.013889,0.01234,0.0099833
0.013889,0.012365,0.0099833
0.01394,0.012035,0.0099833
0.014016,0.011197,0.0099833
0.014016,0.011223,0.0099833
0.014016,0.011248,0.0099833
0.014422,0.01003,0.0099833
0.015285,0.013102,0.0099833
0.017113,0.012492,0.0099833
0.017367,0.011934,0.0099833
0.017646,0.011248,0.0099833
0.013889,0.01234,0.010008
0.013889,0.012365,0.010008
0.014016,0.011223,0.010008
0.014016,0.011248,0.010008
0.014371,0.012975,0.010008
0.014422,0.01003,0.010008
0.016555,0.012772,0.010008
0.013889,0.012365,0.010032
0.013914,0.012162,0.010032
0.014016,0.011223,0.010032
0.014016,0.011248,0.010032
0.014016,0.011553,0.010032
0.014371,0.010283,0.010032
0.014371,0.012975,0.010032
0.014422,0.01003,0.010032
0.01465,0.0094709,0.010032
0.016199,0.012797,0.010032
0.016225,0.012797,0.010032
0.016529,0.012772,0.010032
0.016783,0.01267,0.010032
0.017139,0.012467,0.010032
0.014016,0.011528,0.010057
0.014016,0.011553,0.010057
0.014016,0.011578,0.010057
0.014422,0.01003,0.010057
0.01724,0.0098772,0.010057
0.013965,0.011959,0.010081
0.014016,0.011528,0.010081
0.014016,0.011553,0.010081
0.014016,0.011578,0.010081
0.014422,0.01003,0.010081
0.016098,0.0089123,0.010081
0.016123,0.0089377,0.010081
0.016555,0.012746,0.010081
0.016758,0.01267,0.010081
0.017139,0.012442,0.010081
0.017215,0.0098518,0.010081
0.017393,0.011858,0.010081
0.013863,0.012873,0.010105
0.013863,0.012899,0.010105
0.014016,0.011553,0.010105
0.014016,0.011578,0.010105
0.016098,0.0089123,0.010105
0.016529,0.012746,0.010105
0.017139,0.012416,0.010105
0.017189,0.0098264,0.010105
0.013863,0.012899,0.01013
0.013889,0.012899,0.01013
0.013914,0.012188,0.01013
0.01394,0.012061,0.01013
0.014016,0.011553,0.01013
0.014016,0.011578,0.01013
0.015285,0.013076,0.01013
0.016098,0.0089123,0.01013
0.013863,0.012899,0.010154
0.013889,0.012899,0.010154
0.01394,0.012061,0.010154
0.014016,0.011528,0.010154
0.014016,0.011553,0.010154
0.014016,0.011578,0.010154
0.014041,0.011223,0.010154
0.017113,0.012416,0.010154
0.013863,0.012899,0.010179
0.013889,0.012899,0.010179
0.014016,0.011528,0.010179
0.014016,0.011553,0.010179
0.014016,0.011578,0.010179
0.01432,0.01036,0.010179
0.016021,0.0088616,0.010179
0.016047,0.0088616,0.010179
0.016529,0.012721,0.010179
0.017393,0.011807,0.010179
0.013863,0.012899,0.010203
0.013889,0.012899,0.010203
0.013914,0.012188,0.010203
0.014016,0.011528,0.010203
0.014016,0.011553,0.010203
0.014016,0.011578,0.010203
0.014041,0.011248,0.010203
0.017113,0.012391,0.010203
0.013863,0.012899,0.010227
0.013889,0.01234,0.010227
0.013889,0.012365,0.010227
0.013914,0.012188,0.010227
0.014016,0.011553,0.010227
0.014016,0.011578,0.010227
0.014016,0.011604,0.010227
0.014346,0.012949,0.010227
0.014371,0.010106,0.010227
0.01526,0.013076,0.010227
0.017393,0.011781,0.010227
0.013838,0.012848,0.010252
0.013838,0.012873,0.010252
0.013863,0.012899,0.010252
0.013914,0.012188,0.010252
0.013965,0.011985,0.010252
0.014016,0.011553,0.010252
0.014016,0.011578,0.010252
0.014016,0.011604,0.010252
0.014371,0.010106,0.010252
0.01526,0.013076,0.010252
0.016783,0.012594,0.010252
0.013838,0.012848,0.010276
0.013838,0.012873,0.010276
0.013889,0.012315,0.010276
0.014016,0.011553,0.010276
0.014016,0.011578,0.010276
0.014371,0.010106,0.010276
0.01526,0.013076,0.010276
0.015971,0.0088362,0.010276
0.016199,0.012695,0.010276
0.013838,0.012822,0.010301
0.013838,0.012848,0.010301
0.013838,0.012873,0.010301
0.014016,0.011553,0.010301
0.014016,0.011578,0.010301
0.014295,0.010385,0.010301
0.014371,0.010106,0.010301
0.014574,0.0095979,0.010301
0.015971,0.0088362,0.010301
0.015996,0.0088616,0.010301
0.017113,0.01234,0.010301
0.017291,0.0099025,0.010301
0.017393,0.011731,0.010301
0.013838,0.012822,0.010325
0.013838,0.012848,0.010325
0.013838,0.012873,0.010325
0.014016,0.011553,0.010325
0.014066,0.011197,0.010325
0.014371,0.010106,0.010325
0.014574,0.0095979,0.010325
0.01592,0.0088616,0.010325
0.013838,0.012822,0.010349
0.013838,0.012848,0.010349
0.013838,0.012873,0.010349
0.014016,0.011553,0.010349
0.01427,0.010436,0.010349
0.01592,0.0088616,0.010349
0.016504,0.012645,0.010349
0.017113,0.012315,0.010349
0.013838,0.012822,0.010374
0.013838,0.012848,0.010374
0.013838,0.012873,0.010374
0.014016,0.011553,0.010374
0.014066,0.011223,0.010374
0.014549,0.0096486,0.010374
0.015234,0.013051,0.010374
0.01526,0.013051,0.010374
0.016783,0.012568,0.010374
0.017113,0.012289,0.010374
0.013838,0.012797,0.010398
0.013838,0.012822,0.010398
0.013838,0.012848,0.010398
0.013838,0.012873,0.010398
0.014016,0.011553,0.010398
0.014066,0.011248,0.010398
0.014549,0.0096486,0.010398
0.016504,0.012619,0.010398
0.016809,0.012543,0.010398
0.017113,0.012264,0.010398
0.017139,0.0096486,0.010398
0.013838,0.012797,0.010423
0.013838,0.012822,0.010423
0.013838,0.012848,0.010423
0.013838,0.012873,0.010423
0.013863,0.01234,0.010423
0.014016,0.011553,0.010423
0.016783,0.012543,0.010423
0.017113,0.0096233,0.010423
0.013838,0.012797,0.010447
0.013838,0.012822,0.010447
0.013838,0.012848,0.010447
0.013838,0.012873,0.010447
0.013863,0.012315,0.010447
0.013863,0.01234,0.010447
0.014346,0.010182,0.010447
0.017088,0.012238,0.010447
0.013838,0.012797,0.010471
0.013838,0.012822,0.010471
0.013838,0.012848,0.010471
0.013838,0.012873,0.010471
0.013863,0.012315,0.010471
0.013863,0.01234,0.010471
0.014346,0.010182,0.010471
0.014549,0.009674,0.010471
0.01526,0.013026,0.010471
0.015818,0.0089377,0.010471
0.016199,0.012619,0.010471
0.016783,0.012518,0.010471
0.017088,0.012213,0.010471
0.013838,0.012797,0.010496
0.013838,0.012822,0.010496
0.013838,0.012848,0.010496
0.013838,0.012873,0.010496
0.013863,0.012289,0.010496
0.013863,0.012315,0.010496
0.013863,0.01234,0.010496
0.014016,0.011578,0.010496
0.014295,0.012873,0.010496
0.014346,0.010182,0.010496
0.014549,0.0096994,0.010496
0.015234,0.013026,0.010496
0.016479,0.012568,0.010496
0.01658,0.012543,0.010496
0.013838,0.012797,0.01052
0.013838,0.012822,0.01052
0.013838,0.012848,0.01052
0.013838,0.012873,0.01052
0.013863,0.012289,0.01052
0.013863,0.012315,0.01052
0.013863,0.01234,0.01052
0.013863,0.012873,0.01052
0.013965,0.011883,0.01052
0.014016,0.011578,0.01052
0.014244,0.010461,0.01052
0.013838,0.012772,0.010545
0.013838,0.012797,0.010545
0.013838,0.012822,0.010545
0.013838,0.012848,0.010545
0.013838,0.012873,0.010545
0.013863,0.012289,0.010545
0.013863,0.012315,0.010545
0.013863,0.01234,0.010545
0.013863,0.012873,0.010545
0.013965,0.011883,0.010545
0.014016,0.011578,0.010545
0.014244,0.010461,0.010545
0.016479,0.012543,0.010545
0.01658,0.012518,0.010545
0.016758,0.012492,0.010545
0.01757,0.010563,0.010545
0.013838,0.012772,0.010569
0.013838,0.012797,0.010569
0.013838,0.012822,0.010569
0.013838,0.012848,0.010569
0.013838,0.012873,0.010569
0.013863,0.012289,0.010569
0.013863,0.012315,0.010569
0.013863,0.01234,0.010569
0.013863,0.012873,0.010569
0.013965,0.011883,0.010569
0.014016,0.011578,0.010569
0.013838,0.012772,0.010594
0.013838,0.012797,0.010594
0.013838,0.012822,0.010594
0.013838,0.012848,0.010594
0.013838,0.012873,0.010594
0.013863,0.012289,0.010594
0.013863,0.012315,0.010594
0.013965,0.011883,0.010594
0.014016,0.011578,0.010594
0.014219,0.010512,0.010594
0.014397,0.01008,0.010594
0.015234,0.013,0.010594
0.015971,0.012619,0.010594
0.01757,0.010537,0.010594
0.013838,0.012772,0.010618
0.013838,0.012797,0.010618
0.013838,0.012822,0.010618
0.013838,0.012848,0.010618
0.013863,0.012315,0.010618
0.014397,0.01008,0.010618
0.016199,0.012568,0.010618
0.013838,0.012746,0.010642
0.013838,0.012772,0.010642
0.013838,0.012797,0.010642
0.013838,0.012822,0.010642
0.013838,0.012848,0.010642
0.015158,0.0092932,0.010642
0.01757,0.010512,0.010642
0.013838,0.012746,0.010667
0.014092,0.011248,0.010667
0.017646,0.010334,0.010667
0.017646,0.01036,0.010667
0.014016,0.011578,0.010691
0.015209,0.012949,0.010691
0.017646,0.010283,0.010691
0.017646,0.010309,0.010691
0.017646,0.010334,0.010691
0.014016,0.011578,0.010716
0.014041,0.011375,0.010716
0.016783,0.012416,0.010716
0.016885,0.0093694,0.010716
0.017646,0.010283,0.010716
0.017646,0.010309,0.010716
0.013965,0.011908,0.01074
0.014016,0.011578,0.01074
0.014041,0.011375,0.01074
0.014371,0.010156,0.01074
0.014981,0.012848,0.01074
0.015184,0.012924,0.01074
0.013965,0.011908,0.010764
0.014041,0.011375,0.010764
0.01427,0.012797,0.010764
0.014371,0.010156,0.010764
0.015691,0.0089885,0.010764
0.016631,0.012416,0.010764
0.016859,0.0093694,0.010764
0.017189,0.01168,0.010764
0.013965,0.011908,0.010789
0.014041,0.011375,0.010789
0.014168,0.010563,0.010789
0.015691,0.0089885,0.010789
0.015717,0.0089885,0.010789
0.013838,0.012848,0.010813
0.014016,0.011604,0.010813
0.014041,0.011375,0.010813
0.014168,0.010563,0.010813
0.015082,0.0092678,0.010813
0.015691,0.0089885,0.010813
0.016783,0.009344,0.010813
0.017393,0.011324,0.010813
0.013838,0.012695,0.010838
0.014041,0.011375,0.010838
0.014168,0.010563,0.010838
0.014371,0.010182,0.010838
0.015082,0.0092678,0.010838
0.017393,0.011299,0.010838
0.017393,0.011324,0.010838
0.014041,0.011375,0.010862
0.015057,0.0092932,0.010862
0.016174,0.012518,0.010862
0.016707,0.0093186,0.010862
0.017393,0.011299,0.010862
0.017596,0.010004,0.010862
0.013838,0.01267,0.010886
0.014041,0.011375,0.010886
0.014955,0.012797,0.010886
0.015057,0.0092932,0.010886
0.016707,0.012365,0.010886
0.017596,0.0099787,0.010886
0.013813,0.012822,0.010911
0.014041,0.011375,0.010911
0.014168,0.010588,0.010911
0.014752,0.0096486,0.010911
0.015057,0.0092932,0.010911
0.01559,0.0090901,0.010911
0.016148,0.012518,0.010911
0.01757,0.0099533,0.010911
0.013813,0.012797,0.010935
0.013813,0.012822,0.010935
0.014041,0.011375,0.010935
0.014066,0.011274,0.010935
0.014168,0.010588,0.010935
0.014701,0.0097502,0.010935
0.014727,0.0096994,0.010935
0.017189,0.011604,0.010935
0.013813,0.012797,0.01096
0.013813,0.012822,0.01096
0.013838,0.012822,0.01096
0.014168,0.010588,0.01096
0.014371,0.010207,0.01096
0.015031,0.0093186,0.01096
0.01752,0.0099279,0.01096
0.013813,0.012772,0.010984
0.013813,0.012797,0.010984
0.013813,0.012822,0.010984
0.013863,0.012238,0.010984
0.013863,0.012264,0.010984
0.014168,0.010588,0.010984
0.015031,0.0093186,0.010984
0.017367,0.011248,0.010984
0.017469,0.0099025,0.010984
0.013813,0.012746,0.011009
0.013813,0.012772,0.011009
0.013813,0.012797,0.011009
0.013813,0.012822,0.011009
0.013863,0.012213,0.011009
0.013863,0.012238,0.011009
0.013863,0.012264,0.011009
0.013813,0.012721,0.011033
0.013813,0.012746,0.011033
0.013813,0.012772,0.011033
0.013813,0.012797,0.011033
0.013813,0.012822,0.011033
0.013863,0.012213,0.011033
0.013863,0.012238,0.011033
0.013863,0.012264,0.011033
0.014041,0.011324,0.011033
0.016479,0.009217,0.011033
0.013813,0.012695,0.011057
0.013813,0.012721,0.011057
0.013813,0.012746,0.011057
0.013813,0.012772,0.011057
0.013813,0.012797,0.011057
0.013863,0.012213,0.011057
0.013863,0.012238,0.011057
0.014041,0.011324,0.011057
0.01432,0.010334,0.011057
0.01493,0.012721,0.011057
0.016453,0.009217,0.011057
0.016479,0.009217,0.011057
0.013813,0.012695,0.011082
0.013813,0.012721,0.011082
0.013813,0.012746,0.011082
0.013813,0.012772,0.011082
0.013813,0.012797,0.011082
0.013863,0.012213,0.011082
0.014041,0.011324,0.011082
0.014168,0.010613,0.011082
0.01432,0.010334,0.011082
0.016098,0.012492,0.011082
0.017621,0.010258,0.011082
0.013813,0.01267,0.011106
0.013813,0.012746,0.011106
0.013813,0.012772,0.011106
0.013813,0.012797,0.011106
0.013863,0.012213,0.011106
0.014168,0.010613,0.011106
0.01493,0.012695,0.011106
0.016072,0.012492,0.011106
0.017621,0.010207,0.011106
0.017621,0.010233,0.011106
0.017621,0.010258,0.011106
0.013813,0.012645,0.011131
0.013813,0.012797,0.011131
0.013863,0.012213,0.011131
0.014041,0.01135,0.011131
0.014168,0.010613,0.011131
0.017621,0.010182,0.011131
0.017621,0.010207,0.011131
0.017621,0.010233,0.011131
0.013813,0.012797,0.011155
0.01399,0.011604,0.011155
0.014168,0.010613,0.011155
0.014371,0.010283,0.011155
0.017621,0.010156,0.011155
0.017621,0.010182,0.011155
0.013813,0.012619,0.011179
0.013813,0.012797,0.011179
0.01399,0.011604,0.011179
0.014168,0.010613,0.011179
0.01399,0.011604,0.011204
0.01432,0.01036,0.011204
0.014904,0.012645,0.011204
0.017596,0.010106,0.011204
0.01399,0.011604,0.011228
0.01757,0.010055,0.011228
0.013813,0.012568,0.011253
0.01399,0.011604,0.011253
0.01399,0.011629,0.011253
0.017342,0.011121,0.011253
0.013813,0.012772,0.011277
0.013914,0.012111,0.011277
0.01399,0.011604,0.011277
0.017342,0.011121,0.011277
0.013813,0.012772,0.011301
0.014041,0.011426,0.011301
0.01432,0.010385,0.011301
0.017342,0.011096,0.011301
0.014066,0.01135,0.011326
0.016809,0.012086,0.011326
0.017342,0.011096,0.011326
0.013787,0.012645,0.01135
0.01394,0.012061,0.01135
0.016021,0.012391,0.01135
0.016072,0.012365,0.01135
0.017342,0.01107,0.01135
0.013787,0.012619,0.011375
0.013787,0.012645,0.011375
0.013813,0.012746,0.011375
0.014346,0.01036,0.011375
0.016047,0.012365,0.011375
0.016834,0.012035,0.011375
0.017342,0.011045,0.011375
0.017342,0.011197,0.011375
0.013787,0.012619,0.011399
0.013787,0.012645,0.011399
0.013965,0.011985,0.011399
0.016047,0.01234,0.011399
0.016834,0.012035,0.011399
0.017469,0.01003,0.011399
0.013787,0.012619,0.011423
0.013787,0.012645,0.011423
0.013787,0.01267,0.011423
0.013914,0.012162,0.011423
0.014016,0.011553,0.011423
0.013787,0.012619,0.011448
0.013787,0.012645,0.011448
0.013787,0.01267,0.011448
0.017494,0.0098264,0.011448
0.017494,0.0098518,0.011448
0.013787,0.012619,0.011472
0.013787,0.012645,0.011472
0.013787,0.01267,0.011472
0.014066,0.011375,0.011472
0.016529,0.0092932,0.011472
0.013787,0.012594,0.011497
0.013787,0.012619,0.011497
0.013787,0.012645,0.011497
0.013787,0.01267,0.011497
0.014016,0.011553,0.011497
0.014066,0.011375,0.011497
0.014219,0.010563,0.011497
0.014346,0.010385,0.011497
0.016834,0.01201,0.011497
0.017469,0.0097756,0.011497
0.017469,0.009801,0.011497
0.013787,0.012594,0.011521
0.013787,0.012619,0.011521
0.013787,0.012645,0.011521
0.014066,0.011375,0.011521
0.014219,0.010563,0.011521
0.016834,0.011985,0.011521
0.017443,0.0097502,0.011521
0.013787,0.012594,0.011546
0.013787,0.012619,0.011546
0.013787,0.012645,0.011546
0.014066,0.011375,0.011546
0.014219,0.010563,0.011546
0.014219,0.010588,0.011546
0.016783,0.012086,0.011546
0.013787,0.012594,0.01157
0.013787,0.012619,0.01157
0.013787,0.012645,0.01157
0.014066,0.011375,0.01157
0.014219,0.010563,0.01157
0.015387,0.01234,0.01157
0.016783,0.012086,0.01157
0.013787,0.012594,0.011594
0.013787,0.012619,0.011594
0.013787,0.012645,0.011594
0.013965,0.012035,0.011594
0.014041,0.011528,0.011594
0.014092,0.011324,0.011594
0.016428,0.0092424,0.011594
0.016453,0.0092424,0.011594
0.016783,0.012086,0.011594
0.013787,0.012645,0.011619
0.013813,0.01267,0.011619
0.013965,0.012035,0.011619
0.014041,0.011553,0.011619
0.016428,0.0092424,0.011619
0.016453,0.0092424,0.011619
0.016783,0.012086,0.011619
0.017316,0.010994,0.011619
0.013787,0.012645,0.011643
0.013965,0.012035,0.011643
0.015361,0.012315,0.011643
0.016783,0.012086,0.011643
0.016809,0.01201,0.011643
0.017316,0.010969,0.011643
0.013787,0.012568,0.011668
0.013787,0.012645,0.011668
0.016783,0.012086,0.011668
0.017316,0.010944,0.011668
0.013787,0.012645,0.011692
0.013813,0.012645,0.011692
0.01394,0.012162,0.011692
0.015361,0.012289,0.011692
0.016783,0.012086,0.011692
0.017316,0.010893,0.011692
0.017316,0.010918,0.011692
0.01394,0.012162,0.011716
0.014244,0.010563,0.011716
0.017291,0.009674,0.011716
0.017316,0.0096994,0.011716
0.01394,0.012162,0.011741
0.015361,0.012264,0.011741
0.017291,0.009674,0.011741
0.01394,0.012162,0.011765
0.016758,0.012086,0.011765
0.01394,0.012162,0.01179
0.015361,0.012238,0.01179
0.016758,0.012086,0.01179
0.013965,0.012061,0.011814
0.014244,0.010588,0.011814
0.016758,0.012086,0.011814
0.016834,0.011858,0.011814
0.017215,0.0096233,0.011814
0.01399,0.011959,0.011838
0.016758,0.012086,0.011838
0.016834,0.011832,0.011838
0.017088,0.0095471,0.011838
0.013762,0.012568,0.011863
0.016758,0.012086,0.011863
0.016834,0.011781,0.011863
0.013762,0.012568,0.011887
0.013813,0.012594,0.011887
0.014066,0.011553,0.011887
0.016707,0.012086,0.011887
0.016732,0.012086,0.011887
0.017062,0.0095217,0.011887
0.013787,0.012594,0.011912
0.014066,0.011553,0.011912
0.017189,0.0096233,0.011912
0.013965,0.012035,0.011936
0.014879,0.012365,0.011936
0.014904,0.012365,0.011936
0.015031,0.0093186,0.011936
0.015057,0.0093186,0.011936
0.015336,0.012162,0.011936
0.017164,0.0095979,0.011936
0.01465,0.0094709,0.01196
0.013813,0.012568,0.011985
0.014092,0.011426,0.011985
0.014625,0.0094963,0.011985
0.01465,0.0094455,0.011985
0.014904,0.01234,0.011985
0.015336,0.012137,0.011985
0.015945,0.009217,0.011985
0.015971,0.009217,0.011985
0.013787,0.012568,0.012009
0.013965,0.01201,0.012009
0.014854,0.009344,0.012009
0.014854,0.01234,0.012009
0.015971,0.009217,0.012009
0.017215,0.010537,0.012009
0.013965,0.01201,0.012034
0.01399,0.011934,0.012034
0.014777,0.0093694,0.012034
0.014828,0.009344,0.012034
0.016885,0.011451,0.012034
0.013965,0.01201,0.012058
0.01399,0.011934,0.012058
0.014803,0.009344,0.012058
0.013762,0.012518,0.012083
0.013965,0.01201,0.012083
0.01399,0.011934,0.012083
0.016885,0.011426,0.012083
0.013762,0.012518,0.012107
0.013787,0.012543,0.012107
0.013965,0.01201,0.012107
0.01399,0.011934,0.012107
0.014066,0.011528,0.012107
0.014574,0.0094455,0.012107
0.014574,0.0094709,0.012107
0.014777,0.009344,0.012107
0.014854,0.012315,0.012107
0.016707,0.011934,0.012107
0.013762,0.012518,0.012131
0.013965,0.01201,0.012131
0.014066,0.011528,0.012131
0.016936,0.0093694,0.012131
0.013965,0.01201,0.012156
0.014066,0.011528,0.012156
0.0146,0.0094201,0.012156
0.014828,0.012289,0.012156
0.01691,0.009344,0.012156
0.016936,0.0093694,0.012156
0.016936,0.011299,0.012156
0.013787,0.012518,0.01218
0.014066,0.011528,0.01218
0.014371,0.010487,0.01218
0.016682,0.011908,0.01218
0.016885,0.0093186,0.01218
0.01691,0.009344,0.01218
0.01559,0.0091916,0.012205
0.015615,0.0091916,0.012205
0.016859,0.0092932,0.012205
0.016885,0.0093186,0.012205
0.017189,0.010487,0.012205
0.013787,0.012467,0.012229
0.013813,0.012492,0.012229
0.016707,0.011858,0.012229
0.016859,0.0092932,0.012229
0.013787,0.012467,0.012253
0.013787,0.012492,0.012253
0.01399,0.011908,0.012253
0.016859,0.0092932,0.012253
0.016961,0.011223,0.012253
0.017189,0.010461,0.012253
0.013787,0.012467,0.012278
0.01399,0.011908,0.012278
0.014371,0.010512,0.012278
0.014549,0.0094455,0.012278
0.014803,0.012213,0.012278
0.013787,0.012467,0.012302
0.013914,0.012188,0.012302
0.01399,0.011908,0.012302
0.014549,0.0093948,0.012302
0.015412,0.0091662,0.012302
0.015438,0.0091662,0.012302
0.016707,0.011807,0.012302
0.013914,0.012188,0.012327
0.01399,0.011908,0.012327
0.014066,0.011528,0.012327
0.015387,0.0091662,0.012327
0.01399,0.011908,0.012351
0.014066,0.011528,0.012351
0.014752,0.012188,0.012351
0.01399,0.011908,0.012375
0.014523,0.0093948,0.012375
0.016707,0.011756,0.012375
0.01399,0.011908,0.0124
0.014549,0.0093694,0.0124
0.014574,0.0093694,0.0124
0.0146,0.0093694,0.0124
0.01399,0.011908,0.012424
0.014549,0.0093694,0.012424
0.014574,0.0093694,0.012424
0.0146,0.0093694,0.012424
0.017215,0.010334,0.012424
0.01399,0.011908,0.012449
0.014523,0.0094201,0.012449
0.014549,0.0093694,0.012449
0.014574,0.0093694,0.012449
0.014727,0.012137,0.012449
0.014752,0.012137,0.012449
0.01559,0.0090901,0.012449
0.016707,0.011705,0.012449
0.017215,0.010334,0.012449
0.013965,0.012035,0.012473
0.01399,0.011908,0.012473
0.014549,0.0093694,0.012473
0.014574,0.0093694,0.012473
0.015666,0.0090901,0.012473
0.017215,0.010334,0.012473
0.01399,0.011908,0.012498
0.014066,0.011426,0.012498
0.014549,0.0093694,0.012498
0.014574,0.0093694,0.012498
0.014523,0.0093694,0.012522
0.014549,0.0093694,0.012522
0.014574,0.0093694,0.012522
0.015641,0.0090647,0.012522
0.014523,0.0093694,0.012546
0.014549,0.0093694,0.012546
0.015539,0.0090393,0.012546
0.015564,0.0090393,0.012546
0.01658,0.011807,0.012546
0.01559,0.0090393,0.012571
0.013965,0.01201,0.012595
0.01724,0.010283,0.012595
0.013965,0.01201,0.01262
0.015564,0.0090393,0.01262
0.014041,0.011426,0.012644
0.017088,0.01102,0.012644
0.013965,0.011985,0.012717
0.014041,0.011401,0.012717
0.016453,0.011858,0.012717
0.017266,0.010233,0.012717
0.014041,0.011401,0.012742
0.016453,0.011858,0.012742
0.016631,0.011705,0.012742
0.017088,0.011045,0.012742
0.014041,0.011401,0.012766
0.015691,0.0090139,0.012766
0.015717,0.0090139,0.012766
0.015742,0.0090139,0.012766
0.016453,0.011858,0.012766
0.016961,0.011299,0.012766
0.016986,0.011274,0.012766
0.017113,0.010994,0.012766
0.017316,0.0096994,0.012766
0.013965,0.011959,0.01279
0.014701,0.011985,0.01279
0.015691,0.0090139,0.01279
0.016453,0.011858,0.01279
0.016986,0.011274,0.01279
0.017316,0.009674,0.01279
0.017316,0.0096994,0.01279
0.014447,0.0094201,0.012815
0.017113,0.01102,0.012815
0.017164,0.010791,0.012815
0.017316,0.009674,0.012815
0.013965,0.011934,0.012839
0.017164,0.010817,0.012839
0.017316,0.0096486,0.012839
0.017316,0.009674,0.012839
0.014473,0.0093948,0.012864
0.015717,0.0090139,0.012864
0.017316,0.0096486,0.012864
0.017316,0.009674,0.012864
0.014447,0.0093948,0.012888
0.014473,0.0093948,0.012888
0.016529,0.0089123,0.012888
0.016555,0.0089123,0.012888
0.017291,0.0096233,0.012888
0.017291,0.010156,0.012888
0.017291,0.010182,0.012888
0.017316,0.0096486,0.012888
0.014422,0.0094201,0.012912
0.014422,0.0094455,0.012912
0.014422,0.0094709,0.012912
0.014447,0.0093948,0.012912
0.014473,0.0093948,0.012912
0.016504,0.0089123,0.012912
0.017189,0.010766,0.012912
0.014447,0.0093948,0.012937
0.014473,0.0093948,0.012937
0.016631,0.01168,0.012937
0.014447,0.0093948,0.012961
0.014473,0.0093948,0.012961
0.016479,0.011832,0.012961
0.016631,0.01168,0.012961
0.017164,0.010918,0.012961
0.014447,0.0093948,0.012986
0.014473,0.0093948,0.012986
0.015818,0.0089885,0.012986
0.016428,0.011832,0.012986
0.016453,0.011832,0.012986
0.016479,0.011832,0.012986
0.016631,0.01168,0.012986
0.017113,0.011096,0.012986
0.017164,0.010944,0.012986
0.017215,0.01074,0.012986
0.014447,0.0093948,0.01301
0.014473,0.0093948,0.01301
0.015818,0.0089885,0.01301
0.016631,0.01168,0.01301
0.017113,0.011096,0.01301
0.017215,0.010766,0.01301
0.017266,0.0095725,0.01301
0.014397,0.01003,0.013035
0.014473,0.0093948,0.013035
0.016479,0.0088869,0.013035
0.017088,0.011121,0.013035
0.017113,0.011096,0.013035
0.017215,0.010791,0.013035
0.016453,0.0088869,0.013059
0.016453,0.011807,0.013059
0.016479,0.0088869,0.013059
0.017139,0.011045,0.013059
0.017215,0.010817,0.013059
0.01724,0.01069,0.013059
0.01724,0.010715,0.013059
0.017291,0.0095725,0.013059
0.017316,0.010131,0.013059
0.01394,0.011908,0.013083
0.014371,0.0094963,0.013083
0.014371,0.0095217,0.013083
0.014371,0.0095471,0.013083
0.016453,0.0088869,0.013083
0.016479,0.0088869,0.013083
0.017139,0.011045,0.013083
0.013914,0.011883,0.013108
0.014066,0.011299,0.013108
0.014371,0.0099787,0.013108
0.014422,0.0093948,0.013108
0.014447,0.0093948,0.013108
0.01592,0.0089631,0.013108
0.016453,0.0088869,0.013108
0.016479,0.0088869,0.013108
0.017113,0.01107,0.013108
0.017139,0.011045,0.013108
0.017215,0.010842,0.013108
0.013914,0.011858,0.013132
0.013914,0.011883,0.013132
0.014422,0.0093948,0.013132
0.014447,0.0093948,0.013132
0.014473,0.0093948,0.013132
0.01592,0.0089631,0.013132
0.016453,0.0088869,0.013132
0.016479,0.0088869,0.013132
0.013914,0.011832,0.013157
0.013914,0.011858,0.013157
0.013914,0.011883,0.013157
0.014422,0.0093948,0.013157
0.014447,0.0093948,0.013157
0.014473,0.0093948,0.013157
0.016453,0.0088869,0.013157
0.016479,0.0088869,0.013157
0.016529,0.011756,0.013157
0.017266,0.01069,0.013157
0.017291,0.0095471,0.013157
0.013914,0.011832,0.013181
0.013914,0.011858,0.013181
0.013914,0.011883,0.013181
0.014422,0.0093948,0.013181
0.014447,0.0093948,0.013181
0.014473,0.0093948,0.013181
0.016453,0.0088869,0.013181
0.016504,0.011756,0.013181
0.013914,0.011807,0.013205
0.013914,0.011832,0.013205
0.013914,0.011858,0.013205
0.014066,0.011274,0.013205
0.01427,0.010207,0.013205
0.01427,0.010233,0.013205
0.014371,0.0094201,0.013205
0.014422,0.0093948,0.013205
0.014447,0.0093948,0.013205
0.01592,0.0090139,0.013205
0.015971,0.0089631,0.013205
0.016479,0.011756,0.013205
0.01724,0.010817,0.013205
0.017266,0.010766,0.013205
0.017291,0.0095217,0.013205
0.013914,0.011807,0.01323
0.013914,0.011832,0.01323
0.014092,0.010893,0.01323
0.014092,0.010918,0.01323
0.014371,0.0094201,0.01323
0.014701,0.0094201,0.01323
0.015717,0.011832,0.01323
0.016605,0.01168,0.01323
0.016631,0.011654,0.01323
0.016707,0.011553,0.01323
0.017266,0.0094963,0.01323
0.017291,0.0095217,0.01323
0.017342,0.010334,0.01323
0.013914,0.011807,0.013254
0.013914,0.011832,0.013254
0.014092,0.010893,0.013254
0.014092,0.010918,0.013254
0.014346,0.0095725,0.013254
0.014701,0.0094201,0.013254
0.015818,0.011832,0.013254
0.016707,0.011553,0.013254
0.017266,0.0094963,0.013254
0.017291,0.0095217,0.013254
0.014066,0.011248,0.013279
0.015818,0.011832,0.013279
0.016047,0.0089377,0.013279
0.017266,0.0094963,0.013279
0.017291,0.01074,0.013279
0.017367,0.010258,0.013279
0.017367,0.010283,0.013279
0.017367,0.010309,0.013279
0.01394,0.011756,0.013303
0.014397,0.0094201,0.013303
0.014422,0.0094201,0.013303
0.014447,0.0094201,0.013303
0.014473,0.0094201,0.013303
0.014676,0.0094201,0.013303
0.015818,0.011832,0.013303
0.016453,0.011731,0.013303
0.017266,0.0094963,0.013303
0.014676,0.0094201,0.013327
0.016072,0.0089631,0.013327
0.016631,0.011604,0.013327
0.017266,0.0094963,0.013327
0.014676,0.0094201,0.013352
0.015844,0.011832,0.013352
0.016529,0.01168,0.013352
0.016732,0.011477,0.013352
0.017266,0.0094963,0.013352
0.017316,0.010715,0.013352
0.017393,0.010207,0.013352
0.014066,0.011172,0.013376
0.014244,0.01003,0.013376
0.015844,0.011832,0.013376
0.015996,0.0090901,0.013376
0.016047,0.0090393,0.013376
0.016072,0.0090139,0.013376
0.016377,0.0089123,0.013376
0.016656,0.011553,0.013376
0.016682,0.011528,0.013376
0.01724,0.0094709,0.013376
0.017266,0.0094963,0.013376
0.017342,0.010664,0.013376
0.014066,0.011172,0.013401
0.01432,0.0095979,0.013401
0.015844,0.011832,0.013401
0.016377,0.0089123,0.013401
0.016479,0.01168,0.013401
0.016555,0.011654,0.013401
0.01724,0.0094709,0.013401
0.017266,0.0094963,0.013401
0.017367,0.010588,0.013401
0.017418,0.010004,0.013401
0.017418,0.01003,0.013401
0.017418,0.010055,0.013401
0.017418,0.01008,0.013401
0.017418,0.010106,0.013401
0.014066,0.011172,0.013425
0.014219,0.01003,0.013425
0.015311,0.011908,0.013425
0.015336,0.011908,0.013425
0.015844,0.011832,0.013425
0.016021,0.0091155,0.013425
0.016098,0.0090393,0.013425
0.017062,0.010969,0.013425
0.01724,0.0094709,0.013425
0.017266,0.0094963,0.013425
0.017418,0.0099787,0.013425
0.014066,0.011172,0.01345
0.016402,0.0089123,0.01345
0.016428,0.0089123,0.01345
0.01724,0.0094709,0.01345
0.017418,0.0099533,0.01345
0.014498,0.0094709,0.013474
0.014727,0.0094709,0.013474
0.016148,0.0090393,0.013474
0.016402,0.0089123,0.013474
0.016428,0.0089123,0.013474
0.01724,0.0094709,0.013474
0.017418,0.0099279,0.013474
0.017418,0.010487,0.013474
0.014092,0.010918,0.013498
0.016605,0.0090139,0.013498
0.017393,0.0098264,0.013498
0.017418,0.0099025,0.013498
0.016123,0.0091408,0.013523
0.016148,0.0091155,0.013523
0.01658,0.0089885,0.013523
0.017215,0.0094455,0.013523
0.017316,0.01074,0.013523
0.017443,0.010004,0.013523
0.014168,0.010131,0.013547
0.014168,0.010156,0.013547
0.01625,0.0090393,0.013547
0.016326,0.0089885,0.013547
0.017266,0.010766,0.013547
0.017316,0.01074,0.013547
0.017443,0.0099787,0.013547
0.014193,0.0099025,0.013572
0.016174,0.0091662,0.013572
0.016352,0.0089885,0.013572
0.017393,0.0097756,0.013572
0.014168,0.01003,0.013596
0.014193,0.0098772,0.013596
0.014752,0.0095217,0.013596
0.014854,0.011985,0.013596
0.01625,0.0091155,0.013596
0.016377,0.0089885,0.013596
0.017342,0.01069,0.013596
0.017367,0.01069,0.013596
0.017418,0.0098264,0.013596
0.017443,0.010613,0.013596
0.017469,0.010588,0.013596
0.016225,0.0091916,0.01362
0.016352,0.0090393,0.01362
0.016428,0.0089885,0.01362
0.016555,0.0089631,0.01362
0.016783,0.0091408,0.01362
0.017189,0.0094201,0.01362
0.017367,0.010639,0.01362
0.017418,0.0098264,0.01362
0.017418,0.010639,0.01362
0.017443,0.010613,0.01362
0.017469,0.010588,0.01362
0.017494,0.010258,0.01362
0.017494,0.010283,0.01362
0.016301,0.0091408,0.013645
0.016428,0.0090139,0.013645
0.016555,0.0089631,0.013645
0.01724,0.010537,0.013645
0.017316,0.010563,0.013645
0.017418,0.0098518,0.013645
0.017443,0.010613,0.013645
0.017469,0.010588,0.013645
0.017494,0.010233,0.013645
0.01752,0.010512,0.013645
0.014422,0.0095217,0.013669
0.015311,0.011959,0.013669
0.016326,0.0091662,0.013669
0.016529,0.0089885,0.013669
0.016732,0.0090901,0.013669
0.017316,0.010512,0.013669
0.017367,0.0096994,0.013669
0.017393,0.0097502,0.013669
0.017393,0.010537,0.013669
0.017418,0.0098772,0.013669
0.017469,0.010563,0.013669
0.017494,0.010207,0.013669
0.017494,0.010563,0.013669
0.01752,0.010487,0.013669
0.01752,0.010512,0.013669
0.016428,0.0090901,0.013694
0.016479,0.0090393,0.013694
0.016732,0.0090901,0.013694
0.017062,0.010385,0.013694
0.017215,0.0094201,0.013694
0.01724,0.0094455,0.013694
0.017316,0.010461,0.013694
0.017418,0.0099025,0.013694
0.017469,0.010512,0.013694
0.017494,0.010207,0.013694
0.017494,0.010512,0.013694
0.01752,0.010461,0.013694
0.01752,0.010487,0.013694
0.01752,0.010512,0.013694
0.016352,0.0092424,0.013718
0.016479,0.0090901,0.013718
0.016605,0.0090139,0.013718
0.017012,0.0092932,0.013718
0.017215,0.0094201,0.013718
0.01724,0.0094455,0.013718
0.017342,0.0096233,0.013718
0.017342,0.01041,0.013718
0.017494,0.010461,0.013718
0.01752,0.010461,0.013718
0.016402,0.0092424,0.013742
0.016428,0.0091916,0.013742
0.016504,0.0091155,0.013742
0.01658,0.0090647,0.013742
0.016631,0.0090393,0.013742
0.017037,0.010283,0.013742
0.017215,0.0094201,0.013742
0.01724,0.0094455,0.013742
0.017266,0.010334,0.013742
0.017316,0.0095725,0.013742
0.017342,0.0096233,0.013742
0.017443,0.010385,0.013742
0.017469,0.010385,0.013742
0.014473,0.0095217,0.013767
0.014498,0.0095217,0.013767
0.016428,0.0092932,0.013767
0.016453,0.0092424,0.013767
0.016479,0.0091916,0.013767
0.016555,0.0091155,0.013767
0.016605,0.0090901,0.013767
0.017088,0.010233,0.013767
0.017215,0.0094201,0.013767
0.01724,0.0094455,0.013767
0.017316,0.0095725,0.013767
0.017342,0.0096233,0.013767
0.017342,0.010309,0.013767
0.017367,0.009674,0.013767
0.017367,0.010309,0.013767
0.017393,0.0097248,0.013767
0.017443,0.010309,0.013767
0.017469,0.010309,0.013767
0.017494,0.010258,0.013767
0.017494,0.010283,0.013767
0.01658,0.0091408,0.013791
0.016631,0.0091155,0.013791
0.016682,0.0090901,0.013791
0.016707,0.0090901,0.013791
0.016732,0.0090901,0.013791
0.016961,0.010156,0.013791
0.017215,0.0094201,0.013791
0.01724,0.0094455,0.013791
0.017316,0.0095725,0.013791
0.017342,0.0096233,0.013791
0.017367,0.009674,0.013791
0.017393,0.0097248,0.013791
0.017393,0.0097502,0.013791
0.017393,0.0097756,0.013791
0.017393,0.009801,0.013791
0.017443,0.010233,0.013791
0.014066,0.01008,0.013816
0.014066,0.010106,0.013816
0.014066,0.010131,0.013816
0.014777,0.0095979,0.013816
0.016529,0.0092932,0.013816
0.016656,0.0091408,0.013816
0.016732,0.0091155,0.013816
0.016758,0.0091155,0.013816
0.016986,0.0092424,0.013816
0.017062,0.010131,0.013816
0.017215,0.0094201,0.013816
0.01724,0.0094455,0.013816
0.017316,0.0095725,0.013816
0.017342,0.0096233,0.013816
0.017367,0.009674,0.013816
0.015387,0.01201,0.01384
0.016555,0.0093694,0.01384
0.01658,0.0093186,0.01384
0.016605,0.0092678,0.01384
0.016758,0.0091408,0.01384
0.016783,0.0091408,0.01384
0.016936,0.01003,0.01384
0.016986,0.010055,0.01384
0.017164,0.010106,0.01384
0.017189,0.010106,0.01384
0.017215,0.010106,0.01384
0.01724,0.010106,0.01384
0.017266,0.010106,0.01384
0.017316,0.0095725,0.01384
0.017342,0.0096233,0.01384
0.01399,0.011274,0.013864
0.01399,0.011299,0.013864
0.014955,0.012086,0.013864
0.014981,0.012086,0.013864
0.016605,0.0094201,0.013864
0.016631,0.009344,0.013864
0.016656,0.0092932,0.013864
0.016682,0.0092424,0.013864
0.016758,0.0091916,0.013864
0.016783,0.0091916,0.013864
0.016885,0.0091916,0.013864
0.01691,0.0099533,0.013864
0.017012,0.0092424,0.013864
0.017037,0.010004,0.013864
0.01724,0.010055,0.013864
0.017342,0.0096486,0.013864
0.014041,0.010283,0.013889
0.014143,0.0097248,0.013889
0.014625,0.0095725,0.013889
0.014955,0.012086,0.013889
0.014981,0.012086,0.013889
0.016656,0.0094963,0.013889
0.016656,0.0095217,0.013889
0.016656,0.0095471,0.013889
0.016682,0.0094201,0.013889
0.016707,0.0093186,0.013889
0.016758,0.0097756,0.013889
0.016783,0.0092424,0.013889
0.016834,0.0098518,0.013889
0.016885,0.0098772,0.013889
0.016986,0.0092424,0.013889
0.017012,0.0099279,0.013889
0.017139,0.0099787,0.013889
0.01724,0.0099787,0.013889
0.017266,0.0099787,0.013889
0.017342,0.009674,0.013889
0.017342,0.0096994,0.013889
0.014981,0.012086,0.013913
0.015006,0.012086,0.013913
0.016732,0.0095471,0.013913
0.016732,0.0095725,0.013913
0.016758,0.0093694,0.013913
0.016783,0.009674,0.013913
0.016809,0.0092932,0.013913
0.016859,0.0097756,0.013913
0.016936,0.0092678,0.013913
0.016936,0.0098264,0.013913
0.016961,0.0092678,0.013913
0.016986,0.0092678,0.013913
0.016986,0.0098518,0.013913
0.017139,0.0093694,0.013913
0.017139,0.0099025,0.013913
0.017164,0.0099025,0.013913
0.017189,0.0099025,0.013913
0.017215,0.0099025,0.013913
0.01724,0.0099025,0.013913
0.017266,0.0099025,0.013913
0.017291,0.0095471,0.013913
0.017316,0.0096233,0.013913
0.017316,0.0096486,0.013913
0.017316,0.009674,0.013913
0.017316,0.0096994,0.013913
0.017316,0.0097248,0.013913
0.014143,0.0096486,0.013938
0.014422,0.0095725,0.013938
0.014447,0.0095725,0.013938
0.014473,0.0095725,0.013938
0.014828,0.009674,0.013938
0.015006,0.012086,0.013938
0.01592,0.011426,0.013938
0.016809,0.0094709,0.013938
0.016834,0.0094201,0.013938
0.016834,0.0095979,0.013938
0.016859,0.0093948,0.013938
0.016885,0.0093694,0.013938
0.016885,0.009674,0.013938
0.01691,0.009344,0.013938
0.016936,0.0097248,0.013938
0.016961,0.0093186,0.013938
0.016961,0.0097502,0.013938
0.016986,0.0093186,0.013938
0.017012,0.0097756,0.013938
0.017113,0.0093694,0.013938
0.017113,0.009801,0.013938
0.017164,0.0093948,0.013938
0.017164,0.0098264,0.013938
0.017189,0.0094201,0.013938
0.017189,0.0098264,0.013938
0.017215,0.0094455,0.013938
0.017215,0.0098264,0.013938
0.01724,0.0098264,0.013938
0.017266,0.0095217,0.013938
0.017291,0.0095725,0.013938
0.017291,0.0095979,0.013938
0.017291,0.0096233,0.013938
0.014143,0.0096486,0.013962
0.014244,0.0096233,0.013962
0.014346,0.0095979,0.013962
0.014625,0.0095979,0.013962
0.015895,0.011375,0.013962
0.015895,0.011401,0.013962
0.015895,0.011426,0.013962
0.01691,0.0094709,0.013962
0.016936,0.0094963,0.013962
0.016936,0.0095217,0.013962
0.016936,0.0095471,0.013962
0.016936,0.0095725,0.013962
0.016936,0.0095979,0.013962
0.016961,0.0095471,0.013962
0.016961,0.0095725,0.013962
0.016961,0.0095979,0.013962
0.016986,0.0094201,0.013962
0.016986,0.0094455,0.013962
0.016986,0.0095979,0.013962
0.016986,0.0096233,0.013962
0.016986,0.0096486,0.013962
0.017012,0.0093948,0.013962
0.017012,0.0094201,0.013962
0.017012,0.0094455,0.013962
0.017012,0.0094709,0.013962
0.017012,0.0096486,0.013962
0.017012,0.009674,0.013962
0.017037,0.0093948,0.013962
0.017037,0.0094201,0.013962
0.017037,0.0094455,0.013962
0.017037,0.0094709,0.013962
0.017037,0.0094963,0.013962
0.017037,0.009674,0.013962
0.017062,0.0094201,0.013962
0.017062,0.0094455,0.013962
0.017062,0.0094709,0.013962
0.017062,0.0094963,0.013962
0.017062,0.0095217,0.013962
0.017062,0.0095471,0.013962
0.017088,0.0094201,0.013962
0.017088,0.0094455,0.013962
0.017088,0.0094709,0.013962
0.017088,0.0094963,0.013962
0.017088,0.0095217,0.013962
0.017088,0.0095471,0.013962
0.017088,0.0095725,0.013962
0.017088,0.0095979,0.013962
0.017113,0.0094455,0.013962
0.017113,0.0094709,0.013962
0.017113,0.0094963,0.013962
0.017113,0.0095217,0.013962
0.017113,0.0095471,0.013962
0.017113,0.0095725,0.013962
0.017113,0.0095979,0.013962
0.017113,0.0096233,0.013962
0.017113,0.0096486,0.013962
0.017139,0.0094455,0.013962
0.017139,0.0094709,0.013962
0.017139,0.0094963,0.013962
0.017139,0.0095217,0.013962
0.017139,0.0095471,0.013962
0.017139,0.0095725,0.013962
0.017139,0.0095979,0.013962
0.017139,0.0096233,0.013962
0.017139,0.0096486,0.013962
0.017164,0.0094709,0.013962
0.017164,0.0094963,0.013962
0.017164,0.0095217,0.013962
0.017164,0.0095471,0.013962
0.017164,0.0095725,0.013962
0.017164,0.0095979,0.013962
0.017164,0.0096233,0.013962
0.017164,0.0096486,0.013962
0.017164,0.009674,0.013962
0.017189,0.0094963,0.013962
0.017189,0.0095217,0.013962
0.017189,0.0095471,0.013962
0.017189,0.0095725,0.013962
0.017189,0.0095979,0.013962
0.017189,0.0096233,0.013962
0.017189,0.0096486,0.013962
0.017189,0.009674,0.013962
0.017215,0.0095217,0.013962
0.017215,0.0095471,0.013962
0.017215,0.0095725,0.013962
0.017215,0.0095979,0.013962
0.017215,0.0096233,0.013962
0.017215,0.0096486,0.013962
0.017215,0.009674,0.013962
0.01724,0.0095725,0.013962
0.01724,0.0095979,0.013962
0.01724,0.0096233,0.013962
0.01724,0.0096486,0.013962
0.01724,0.009674,0.013962
0.01427,0.0096233,0.013987
0.014397,0.0095979,0.013987
0.0146,0.0095979,0.013987
0.015869,0.011274,0.013987
0.015869,0.01135,0.013987
0.015869,0.011375,0.013987
0.015869,0.011401,0.013987
0.015869,0.011426,0.013987
0.014447,0.0095979,0.014011
0.014473,0.0095979,0.014011
0.014498,0.0095979,0.014011
0.014523,0.0095979,0.014011
0.014625,0.0096233,0.014011
0.014117,0.0096994,0.014035
0.01427,0.0096486,0.014035
0.014371,0.0096233,0.014035
0.0146,0.0096233,0.014035
0.015818,0.011223,0.014035
0.015818,0.011248,0.014035
0.014092,0.0097248,0.01406
0.014143,0.0096994,0.01406
0.01432,0.0096486,0.01406
0.014447,0.0096233,0.01406
0.014473,0.0096233,0.01406
0.014498,0.0096233,0.01406
0.014523,0.0096233,0.01406
0.014549,0.0096233,0.01406
0.015793,0.011172,0.01406
0.015793,0.011197,0.01406
0.015793,0.011223,0.01406
0.01399,0.0098518,0.014084
0.014016,0.009801,0.014084
0.014066,0.0097502,0.014084
0.014117,0.0097248,0.014084
0.01427,0.009674,0.014084
0.014371,0.0096486,0.014084
0.015768,0.011147,0.014084
0.013965,0.0098772,0.014109
0.01399,0.0098264,0.014109
0.014016,0.009801,0.014109
0.014041,0.0097756,0.014109
0.014092,0.0097502,0.014109
0.014143,0.0097248,0.014109
0.014219,0.0096994,0.014109
0.01432,0.009674,0.014109
0.014473,0.0096486,0.014109
0.014498,0.0096486,0.014109
0.014523,0.0096486,0.014109
0.015742,0.010944,0.014109
0.015742,0.010969,0.014109
0.015742,0.010994,0.014109
0.015742,0.01102,0.014109
0.013965,0.0098518,0.014133
0.01399,0.0098264,0.014133
0.014016,0.009801,0.014133
0.014066,0.0097756,0.014133
0.014117,0.0097502,0.014133
0.014397,0.009674,0.014133
0.0146,0.009674,0.014133
0.014879,0.009801,0.014133
0.015717,0.010893,0.014133
0.015717,0.010918,0.014133
0.015717,0.010944,0.014133
0.015717,0.010969,0.014133
0.015793,0.011883,0.014133
0.015793,0.011908,0.014133
0.013965,0.0098518,0.014157
0.014092,0.0097756,0.014157
0.01465,0.0096994,0.014157
0.014854,0.009801,0.014157
0.01559,0.012061,0.014157
0.015666,0.01069,0.014157
0.015691,0.010867,0.014157
0.015691,0.011324,0.014157
0.015691,0.01135,0.014157
0.01394,0.0098772,0.014182
0.014193,0.0097502,0.014182
0.0146,0.0096994,0.014182
0.014828,0.009801,0.014182
0.014879,0.0098264,0.014182
0.01493,0.0098518,0.014182
0.015539,0.012086,0.014182
0.015564,0.012086,0.014182
0.015641,0.010664,0.014182
0.015666,0.011172,0.014182
0.015666,0.011197,0.014182
0.015666,0.011324,0.014182
0.015666,0.012035,0.014182
0.014168,0.0097756,0.014206
0.014346,0.0097248,0.014206
0.014803,0.009801,0.014206
0.014854,0.0098264,0.014206
0.014955,0.0098772,0.014206
0.015615,0.010613,0.014206
0.015641,0.011121,0.014206
0.015641,0.011147,0.014206
0.015641,0.011172,0.014206
0.015641,0.011197,0.014206
0.015691,0.012035,0.014206
0.013863,0.0099533,0.014231
0.01394,0.0099025,0.014231
0.01399,0.0098772,0.014231
0.01432,0.0097502,0.014231
0.014422,0.0097248,0.014231
0.014447,0.0097248,0.014231
0.014574,0.0097248,0.014231
0.014777,0.009801,0.014231
0.014828,0.0098264,0.014231
0.015006,0.0099279,0.014231
0.015082,0.0099787,0.014231
0.015615,0.01102,0.014231
0.015615,0.011045,0.014231
0.015615,0.01107,0.014231
0.015615,0.011096,0.014231
0.015615,0.011121,0.014231
0.015615,0.011147,0.014231
0.014295,0.0097756,0.014255
0.014371,0.0097502,0.014255
0.014625,0.0097502,0.014255
0.014752,0.009801,0.014255
0.015133,0.01003,0.014255
0.015539,0.010537,0.014255
0.01559,0.010969,0.014255
0.01559,0.010994,0.014255
0.01559,0.01102,0.014255
0.01559,0.011045,0.014255
0.01559,0.01107,0.014255
0.01559,0.011096,0.014255
0.01559,0.011121,0.014255
0.015691,0.012061,0.014255
0.013813,0.01069,0.014279
0.013914,0.0099533,0.014279
0.01427,0.009801,0.014279
0.014346,0.0097756,0.014279
0.014498,0.0097502,0.014279
0.014523,0.0097502,0.014279
0.014549,0.0097502,0.014279
0.014904,0.0099025,0.014279
0.015285,0.010182,0.014279
0.015539,0.011274,0.014279
0.015564,0.010918,0.014279
0.015564,0.010944,0.014279
0.015564,0.010969,0.014279
0.015564,0.010994,0.014279
0.015564,0.01102,0.014279
0.015564,0.011045,0.014279
0.015564,0.01107,0.014279
0.013711,0.01008,0.014304
0.013838,0.010004,0.014304
0.014041,0.0099025,0.014304
0.014244,0.0098264,0.014304
0.01432,0.009801,0.014304
0.014422,0.0097756,0.014304
0.0146,0.0097756,0.014304
0.014727,0.0098264,0.014304
0.014777,0.0098518,0.014304
0.014955,0.0099533,0.014304
0.015031,0.010004,0.014304
0.015107,0.010055,0.014304
0.015463,0.010461,0.014304
0.015514,0.011248,0.014304
0.015539,0.010867,0.014304
0.015539,0.010893,0.014304
0.015539,0.010918,0.014304
0.015539,0.010944,0.014304
0.015539,0.010969,0.014304
0.015539,0.010994,0.014304
0.015539,0.01102,0.014304
0.013736,0.01008,0.014328
0.014219,0.0098518,0.014328
0.014295,0.0098264,0.014328
0.014371,0.009801,0.014328
0.015311,0.010258,0.014328
0.015412,0.01041,0.014328
0.015488,0.011223,0.014328
0.015514,0.010817,0.014328
0.015514,0.010842,0.014328
0.015514,0.010867,0.014328
0.015514,0.010893,0.014328
0.015514,0.010918,0.014328
0.015514,0.010944,0.014328
0.015539,0.012137,0.014328
0.015564,0.012137,0.014328
0.015641,0.012111,0.014328
0.013762,0.01008,0.014353
0.013914,0.010004,0.014353
0.014143,0.0099025,0.014353
0.014193,0.0098772,0.014353
0.01427,0.0098518,0.014353
0.014346,0.0098264,0.014353
0.014752,0.0098772,0.014353
0.014854,0.0099279,0.014353
0.01493,0.0099787,0.014353
0.015006,0.01003,0.014353
0.015133,0.010131,0.014353
0.015361,0.010385,0.014353
0.015463,0.011172,0.014353
0.015488,0.010766,0.014353
0.015488,0.010791,0.014353
0.015488,0.010817,0.014353
0.015488,0.010842,0.014353
0.015488,0.010867,0.014353
0.015488,0.010893,0.014353
0.015488,0.010918,0.014353
0.015488,0.010944,0.014353
0.015488,0.010969,0.014353
0.013762,0.01107,0.014377
0.013762,0.011096,0.014377
0.013762,0.011121,0.014377
0.013965,0.010004,0.014377
0.014016,0.0099787,0.014377
0.014244,0.0098772,0.014377
0.01432,0.0098518,0.014377
0.014422,0.0098264,0.014377
0.015107,0.010131,0.014377
0.015285,0.010309,0.014377
0.015412,0.011248,0.014377
0.015438,0.010639,0.014377
0.015438,0.011121,0.014377
0.015463,0.010766,0.014377
0.015463,0.010791,0.014377
0.015463,0.010893,0.014377
0.015463,0.010918,0.014377
0.013736,0.010131,0.014401
0.013762,0.011274,0.014401
0.014066,0.0099787,0.014401
0.014295,0.0098772,0.014401
0.0146,0.0098518,0.014401
0.014676,0.0098772,0.014401
0.014777,0.0099279,0.014401
0.01493,0.01003,0.014401
0.015006,0.01008,0.014401
0.015158,0.010207,0.014401
0.015184,0.010233,0.014401
0.01366,0.010182,0.014426
0.013787,0.011426,0.014426
0.013838,0.010106,0.014426
0.014117,0.0099787,0.014426
0.014168,0.0099533,0.014426
0.014498,0.0098518,0.014426
0.014523,0.0098518,0.014426
0.014625,0.0098772,0.014426
0.014701,0.0099025,0.014426
0.01493,0.010055,0.014426
0.015006,0.010106,0.014426
0.015057,0.010156,0.014426
0.015082,0.010182,0.014426
0.015133,0.010233,0.014426
0.015336,0.011274,0.014426
0.015361,0.011045,0.014426
0.015387,0.01069,0.014426
0.015387,0.010715,0.014426
0.015387,0.01074,0.014426
0.015387,0.010766,0.014426
0.015387,0.010791,0.014426
0.015387,0.010817,0.014426
0.015387,0.010842,0.014426
0.015438,0.012162,0.014426
0.015463,0.012162,0.014426
0.015488,0.012162,0.014426
0.015514,0.012162,0.014426
0.015539,0.012162,0.014426
0.01394,0.01008,0.01445
0.014168,0.0099787,0.01445
0.014219,0.0099533,0.01445
0.014473,0.0098772,0.01445
0.014498,0.0098772,0.01445
0.014523,0.0098772,0.01445
0.014549,0.0098772,0.01445
0.014752,0.0099533,0.01445
0.014828,0.010004,0.01445
0.015285,0.011274,0.01445
0.015285,0.011299,0.01445
0.015285,0.011324,0.01445
0.015311,0.010563,0.01445
0.015311,0.011096,0.01445
0.015336,0.010893,0.01445
0.013635,0.010233,0.014475
0.013736,0.010182,0.014475
0.013863,0.010131,0.014475
0.01399,0.01008,0.014475
0.014117,0.01003,0.014475
0.014219,0.0099787,0.014475
0.01427,0.0099533,0.014475
0.01432,0.0099279,0.014475
0.014397,0.0099025,0.014475
0.014422,0.0099025,0.014475
0.014447,0.0099025,0.014475
0.014473,0.0099025,0.014475
0.014498,0.0099025,0.014475
0.014523,0.0099025,0.014475
0.014549,0.0099025,0.014475
0.014574,0.0099025,0.014475
0.01465,0.0099279,0.014475
0.014777,0.010004,0.014475
0.015234,0.010487,0.014475
0.015234,0.011274,0.014475
0.015234,0.011299,0.014475
0.01526,0.011096,0.014475
0.015285,0.010613,0.014475
0.015285,0.010944,0.014475
0.015285,0.010969,0.014475
0.015311,0.010715,0.014475
0.013584,0.010283,0.014499
0.013787,0.010182,0.014499
0.014117,0.010055,0.014499
0.014168,0.01003,0.014499
0.014219,0.010004,0.014499
0.014397,0.0099279,0.014499
0.014422,0.0099279,0.014499
0.014447,0.0099279,0.014499
0.014473,0.0099279,0.014499
0.014498,0.0099279,0.014499
0.014523,0.0099279,0.014499
0.014549,0.0099279,0.014499
0.014574,0.0099279,0.014499
0.0146,0.0099279,0.014499
0.01465,0.0099533,0.014499
0.014701,0.0099787,0.014499
0.015184,0.010461,0.014499
0.015184,0.011248,0.014499
0.015184,0.011274,0.014499
0.015209,0.010537,0.014499
0.015209,0.01107,0.014499
0.015209,0.011477,0.014499
0.015234,0.010613,0.014499
0.015234,0.010817,0.014499
0.013533,0.01036,0.014524
0.013533,0.010385,0.014524
0.013533,0.01041,0.014524
0.013609,0.010283,0.014524
0.013711,0.010233,0.014524
0.01399,0.010131,0.014524
0.01465,0.0099787,0.014524
0.015133,0.011223,0.014524
0.015133,0.011248,0.014524
0.015133,0.011274,0.014524
0.015158,0.010512,0.014524
0.015158,0.01102,0.014524
0.015158,0.011451,0.014524
0.015184,0.010588,0.014524
0.015184,0.010613,0.014524
0.015184,0.010639,0.014524
0.015184,0.010791,0.014524
0.015184,0.010817,0.014524
0.015488,0.012188,0.014524
0.015514,0.012188,0.014524
0.015539,0.012162,0.014524
0.013533,0.01036,0.014548
0.013559,0.010334,0.014548
0.013914,0.010182,0.014548
0.01399,0.010156,0.014548
0.015082,0.010436,0.014548
0.015082,0.011197,0.014548
0.015082,0.011401,0.014548
0.015107,0.010512,0.014548
0.015107,0.010994,0.014548
0.015133,0.010588,0.014548
0.015133,0.010613,0.014548
0.015133,0.010639,0.014548
0.015133,0.010664,0.014548
0.015133,0.01069,0.014548
0.015133,0.010715,0.014548
0.015133,0.01074,0.014548
0.015133,0.010766,0.014548
0.015133,0.010791,0.014548
0.015133,0.010817,0.014548
0.015133,0.010842,0.014548
0.015158,0.011604,0.014548
0.013686,0.010283,0.014572
0.013914,0.010207,0.014572
0.015006,0.011096,0.014572
0.015006,0.011375,0.014572
0.015031,0.010436,0.014572
0.015031,0.011477,0.014572
0.015057,0.010512,0.014572
0.015057,0.010867,0.014572
0.015082,0.010588,0.014572
0.015082,0.010613,0.014572
0.015082,0.010639,0.014572
0.015082,0.010664,0.014572
0.015082,0.010766,0.014572
0.015514,0.012188,0.014572
0.013482,0.010436,0.014597
0.013813,0.010258,0.014597
0.014879,0.011274,0.014597
0.014879,0.011299,0.014597
0.014879,0.011324,0.014597
0.014879,0.01135,0.014597
0.014879,0.011375,0.014597
0.014904,0.011172,0.014597
0.014904,0.011451,0.014597
0.01493,0.010334,0.014597
0.01493,0.01107,0.014597
0.014955,0.010385,0.014597
0.014981,0.010436,0.014597
0.014981,0.010893,0.014597
0.015006,0.010512,0.014597
0.015006,0.010791,0.014597
0.013457,0.010487,0.014621
0.01394,0.010258,0.014621
0.014117,0.010207,0.014621
0.01432,0.010131,0.014621
0.014625,0.011223,0.014621
0.014676,0.011197,0.014621
0.014727,0.011172,0.014621
0.014752,0.011147,0.014621
0.014803,0.01107,0.014621
0.014854,0.010309,0.014621
0.014854,0.010969,0.014621
0.014879,0.010893,0.014621
0.014904,0.010385,0.014621
0.014904,0.010842,0.014621
0.01493,0.010436,0.014621
0.01493,0.010766,0.014621
0.014955,0.010588,0.014621
0.014955,0.010613,0.014621
0.014955,0.010639,0.014621
0.014955,0.010664,0.014621
0.015387,0.012213,0.014621
0.015412,0.012213,0.014621
0.015438,0.012213,0.014621
0.015463,0.012213,0.014621
0.015488,0.012213,0.014621
0.013457,0.010487,0.014646
0.013482,0.010563,0.014646
0.013635,0.010385,0.014646
0.013762,0.010334,0.014646
0.013838,0.010309,0.014646
0.01399,0.010283,0.014646
0.014168,0.010233,0.014646
0.014549,0.01102,0.014646
0.01465,0.010131,0.014646
0.014676,0.010156,0.014646
0.014676,0.010969,0.014646
0.014701,0.010182,0.014646
0.014701,0.010969,0.014646
0.014752,0.010233,0.014646
0.014752,0.010918,0.014646
0.014803,0.010842,0.014646
0.014828,0.010334,0.014646
0.014828,0.010791,0.014646
0.014854,0.010385,0.014646
0.014854,0.01069,0.014646
0.014879,0.010512,0.014646
0.014879,0.010537,0.014646
0.014879,0.010563,0.014646
0.014879,0.010588,0.014646
0.015387,0.012213,0.014646
0.015412,0.012213,0.014646
0.015438,0.012213,0.014646
0.013482,0.010588,0.01467
0.013533,0.010461,0.01467
0.013584,0.010436,0.01467
0.013711,0.010385,0.01467
0.01427,0.010233,0.01467
0.014346,0.010182,0.01467
0.014371,0.010182,0.01467
0.014397,0.010182,0.01467
0.014523,0.010867,0.01467
0.014574,0.010842,0.01467
0.01465,0.010817,0.01467
0.014727,0.010258,0.01467
0.014752,0.010309,0.01467
0.014752,0.010715,0.01467
0.014777,0.010664,0.01467
0.014803,0.010436,0.01467
0.014803,0.010461,0.01467
0.014803,0.010487,0.01467
0.014803,0.010512,0.01467
0.014803,0.010537,0.01467
0.014803,0.010563,0.01467
0.014803,0.010588,0.01467
0.015387,0.012213,0.01467
0.015412,0.012213,0.01467
0.015438,0.012213,0.01467
0.013482,0.010512,0.014694
0.013584,0.010461,0.014694
0.01366,0.010436,0.014694
0.013787,0.010385,0.014694
0.013813,0.010385,0.014694
0.013838,0.010385,0.014694
0.013863,0.010385,0.014694
0.01427,0.010334,0.014694
0.01432,0.010283,0.014694
0.014397,0.010233,0.014694
0.014447,0.01069,0.014694
0.014473,0.010207,0.014694
0.014473,0.01069,0.014694
0.014498,0.010207,0.014694
0.014498,0.01069,0.014694
0.014523,0.010207,0.014694
0.014523,0.01069,0.014694
0.014549,0.010207,0.014694
0.014574,0.010207,0.014694
0.014574,0.010664,0.014694
0.014625,0.010639,0.014694
0.01465,0.010258,0.014694
0.014676,0.010563,0.014694
0.014701,0.01036,0.014694
0.014701,0.010537,0.014694
0.014727,0.010461,0.014694
0.015336,0.012137,0.014694
0.015412,0.012213,0.014694
0.013736,0.010436,0.014719
0.013762,0.010436,0.014719
0.013787,0.010436,0.014719
0.013813,0.010436,0.014719
0.013838,0.010436,0.014719
0.013863,0.010436,0.014719
0.01394,0.010461,0.014719
0.014422,0.010385,0.014719
0.014422,0.01041,0.014719
0.014422,0.010436,0.014719
0.014447,0.01036,0.014719
0.014447,0.010385,0.014719
0.014447,0.01041,0.014719
0.014447,0.010436,0.014719
0.014447,0.010461,0.014719
0.014473,0.010334,0.014719
0.014473,0.01036,0.014719
0.014473,0.010385,0.014719
0.014473,0.01041,0.014719
0.014473,0.010436,0.014719
0.014473,0.010461,0.014719
0.014473,0.010487,0.014719
0.014498,0.010334,0.014719
0.014498,0.01036,0.014719
0.014498,0.010385,0.014719
0.014498,0.01041,0.014719
0.014498,0.010436,0.014719
0.014498,0.010461,0.014719
0.014498,0.010487,0.014719
0.014523,0.010334,0.014719
0.014523,0.01036,0.014719
0.014523,0.010385,0.014719
0.014523,0.01041,0.014719
0.014523,0.010436,0.014719
0.014523,0.010461,0.014719
0.014549,0.010309,0.014719
0.014549,0.010334,0.014719
0.014549,0.01036,0.014719
0.014549,0.010385,0.014719
0.014549,0.01041,0.014719
0.014549,0.010436,0.014719
0.014549,0.010461,0.014719
0.014574,0.010334,0.014719
0.014574,0.01036,0.014719
0.014574,0.010385,0.014719
0.014574,0.01041,0.014719
0.014574,0.010436,0.014719
0.014574,0.010461,0.014719
0.0146,0.01041,0.014719
0.0146,0.010436,0.014719
0.01526,0.012111,0.014719
0.013533,0.010817,0.014743
0.013686,0.010487,0.014743
0.013711,0.010487,0.014743
0.013711,0.011832,0.014743
0.013736,0.010487,0.014743
0.013762,0.010487,0.014743
0.013787,0.010487,0.014743
0.013813,0.010487,0.014743
0.013863,0.010512,0.014743
0.013533,0.010867,0.014768
0.013635,0.010537,0.014768
0.013686,0.01168,0.014768
0.013686,0.011705,0.014768
0.013686,0.011731,0.014768
0.013686,0.011756,0.014768
0.013686,0.011781,0.014768
0.013686,0.011807,0.014768
0.013711,0.011883,0.014768
0.013762,0.010537,0.014768
0.013813,0.010563,0.014768
0.013863,0.010588,0.014768
0.015184,0.012137,0.014768
0.015311,0.012213,0.014768
0.013559,0.010588,0.014792
0.013736,0.010588,0.014792
0.015158,0.012162,0.014792
0.015209,0.012188,0.014792
0.013533,0.010639,0.014816
0.013559,0.011147,0.014816
0.013584,0.011223,0.014816
0.013635,0.010613,0.014816
0.01366,0.01168,0.014816
0.01366,0.011756,0.014816
0.01366,0.011781,0.014816
0.013686,0.011908,0.014816
0.015184,0.012213,0.014816
0.013559,0.011172,0.014841
0.013584,0.010664,0.014841
0.013609,0.010664,0.014841
0.013635,0.010664,0.014841
0.013635,0.011502,0.014841
0.013686,0.01069,0.014841
0.013711,0.010715,0.014841
0.013711,0.012035,0.014841
0.013736,0.01074,0.014841
0.013736,0.012086,0.014841
0.013762,0.010766,0.014841
0.013762,0.012137,0.014841
0.013787,0.012162,0.014841
0.013813,0.012188,0.014841
0.013838,0.012213,0.014841
0.013863,0.012238,0.014841
0.014117,0.012365,0.014841
0.014879,0.012213,0.014841
0.01493,0.012264,0.014841
0.013508,0.010715,0.014865
0.013508,0.01074,0.014865
0.013533,0.010715,0.014865
0.013584,0.010715,0.014865
0.013609,0.010715,0.014865
0.013635,0.010715,0.014865
0.013635,0.011756,0.014865
0.013635,0.011781,0.014865
0.013711,0.012061,0.014865
0.013736,0.012111,0.014865
0.013762,0.012162,0.014865
0.013787,0.012188,0.014865
0.013813,0.012213,0.014865
0.013838,0.012238,0.014865
0.013863,0.012264,0.014865
0.013889,0.012289,0.014865
0.01394,0.012315,0.014865
0.01399,0.01234,0.014865
0.014041,0.012365,0.014865
0.01493,0.012238,0.014865
0.015107,0.012238,0.014865
0.013686,0.010842,0.01489
0.013711,0.012086,0.01489
0.013736,0.012137,0.01489
0.013762,0.012188,0.01489
0.013787,0.012213,0.01489
0.013813,0.012238,0.01489
0.013838,0.012264,0.01489
0.013863,0.012289,0.01489
0.01394,0.01234,0.01489
0.014066,0.012391,0.01489
0.01493,0.012289,0.01489
0.014981,0.012264,0.01489
0.015006,0.012264,0.01489
0.015031,0.012264,0.01489
0.015057,0.012264,0.01489
0.013533,0.01102,0.014914
0.013609,0.011705,0.014914
0.013609,0.011731,0.014914
0.013609,0.011756,0.014914
0.013609,0.011807,0.014914
0.013609,0.011832,0.014914
0.013635,0.010842,0.014914
0.01366,0.010893,0.014914
0.01366,0.011985,0.014914
0.013686,0.010944,0.014914
0.013686,0.012061,0.014914
0.013711,0.012111,0.014914
0.013736,0.012162,0.014914
0.013787,0.012238,0.014914
0.013813,0.012264,0.014914
0.013838,0.012289,0.014914
0.014041,0.012391,0.014914
0.014117,0.012416,0.014914
0.014143,0.012416,0.014914
0.014168,0.012416,0.014914
0.014193,0.012416,0.014914
0.014219,0.012416,0.014914
0.014244,0.012416,0.014914
0.01427,0.012416,0.014914
0.014371,0.012416,0.014914
0.014397,0.012416,0.014914
0.014422,0.012416,0.014914
0.013533,0.010842,0.014939
0.013533,0.010994,0.014939
0.013533,0.01102,0.014939
0.013533,0.011045,0.014939
0.013584,0.010867,0.014939
0.01366,0.010994,0.014939
0.013686,0.01107,0.014939
0.013686,0.012086,0.014939
0.013711,0.012137,0.014939
0.013762,0.012213,0.014939
0.013787,0.012238,0.014939
0.013813,0.012264,0.014939
0.013838,0.012289,0.014939
0.013914,0.01234,0.014939
0.013533,0.010994,0.014963
0.013533,0.01102,0.014963
0.013533,0.011045,0.014963
0.013533,0.01107,0.014963
0.013559,0.010918,0.014963
0.013584,0.011654,0.014963
0.013584,0.01168,0.014963
0.013609,0.010969,0.014963
0.013635,0.011045,0.014963
0.013635,0.011985,0.014963
0.01366,0.011121,0.014963
0.01366,0.011477,0.014963
0.013686,0.012111,0.014963
0.013813,0.012264,0.014963
0.013838,0.012289,0.014963
0.013863,0.012315,0.014963
0.014016,0.012391,0.014963
0.01427,0.012442,0.014963
0.014295,0.012442,0.014963
0.013533,0.010969,0.014987
0.013533,0.010994,0.014987
0.013533,0.01102,0.014987
0.013533,0.011045,0.014987
0.013533,0.01107,0.014987
0.013559,0.010994,0.014987
0.013584,0.011045,0.014987
0.013584,0.011629,0.014987
0.013584,0.011654,0.014987
0.013584,0.01168,0.014987
0.013584,0.011705,0.014987
0.013584,0.011731,0.014987
0.013584,0.011756,0.014987
0.013609,0.011121,0.014987
0.013635,0.011274,0.014987
0.013686,0.012137,0.014987
0.01394,0.012365,0.014987
0.01432,0.012442,0.014987
0.013533,0.01107,0.015012
0.013533,0.011096,0.015012
0.013559,0.011121,0.015012
0.013559,0.011147,0.015012
0.013559,0.011172,0.015012
0.013559,0.011197,0.015012
0.013559,0.011223,0.015012
0.013584,0.011223,0.015012
0.013584,0.011248,0.015012
0.013584,0.011274,0.015012
0.013584,0.011299,0.015012
0.013584,0.011324,0.015012
0.013584,0.01135,0.015012
0.013584,0.011604,0.015012
0.013584,0.011629,0.015012
0.013584,0.011654,0.015012
0.013584,0.01168,0.015012
0.013584,0.011705,0.015012
0.013584,0.011731,0.015012
0.013584,0.011756,0.015012
0.013584,0.011781,0.015012
0.013584,0.011807,0.015012
0.013584,0.011832,0.015012
0.013787,0.012238,0.015012
0.013813,0.012264,0.015012
0.013838,0.012289,0.015012
0.013584,0.011629,0.015036
0.013584,0.011654,0.015036
0.013584,0.01168,0.015036
0.013584,0.011705,0.015036
0.013584,0.011731,0.015036
0.013584,0.011756,0.015036
0.013584,0.011781,0.015036
0.013584,0.011807,0.015036
0.013584,0.011832,0.015036
0.013584,0.011858,0.015036
0.013787,0.012238,0.015036
0.013813,0.012264,0.015036
0.013838,0.012289,0.015036
0.013863,0.012315,0.015036
0.013965,0.012391,0.015036
0.014117,0.012442,0.015036
0.013584,0.011731,0.015061
0.013584,0.011756,0.015061
0.013584,0.011781,0.015061
0.013584,0.011807,0.015061
0.013584,0.011832,0.015061
0.013584,0.011858,0.015061
0.013584,0.011883,0.015061
0.013584,0.011908,0.015061
0.013584,0.011934,0.015061
0.013609,0.011832,0.015061
0.013813,0.012264,0.015061
0.013838,0.012289,0.015061
0.013863,0.012315,0.015061
0.014092,0.012442,0.015061
0.014193,0.012467,0.015061
0.014219,0.012467,0.015061
0.014244,0.012467,0.015061
0.013711,0.012061,0.015085
0.013787,0.012213,0.015085
0.014168,0.012467,0.015085
0.014193,0.012467,0.015085
0.014219,0.012467,0.015085
0.013787,0.012188,0.015109
0.013813,0.012238,0.015109
0.013914,0.012365,0.015109
0.01394,0.012391,0.015109
0.014143,0.012467,0.015109
0.014168,0.012467,0.015109
0.013838,0.012264,0.015134
0.013914,0.012365,0.015134
0.01394,0.012391,0.015134
0.014117,0.012467,0.015134
0.014143,0.012467,0.015134
0.013914,0.012365,0.015158
0.01394,0.012391,0.015158
0.013965,0.012416,0.015158
0.014016,0.012442,0.015158
0.013914,0.012365,0.015183
0.01394,0.012391,0.015183
0.013965,0.012416,0.015183
0.013965,0.012416,0.015207
0.01399,0.012442,0.015207
0.01399,0.012442,0.015231
676,688,779
2946,3022,2730
3269,3260,3261
2789,2796,2797
2815,2816,2804
3149,3129,3147
2592,2585,2584
2228,2129,2016
2228,2016,2066
2479,2480,2472
2681,2659,2669
2539,2436,2551
420,411,397
2195,2322,2334
2730,2729,2723
922,780,865
996,969,958
818,804,790
1064,948,1012
862,580,804
226,225,217
958,847,939
131,128,141
1191,1202,1319
2210,2318,2224
2067,1954,1969
1925,1924,1936
1303,1412,1371
1734,2043,1792
3017,3014,3046
3158,3142,3159
3437,3460,3402
3925,3926,3942
2120,2107,2115
3335,3293,3344
3325,3354,3547
3126,3131,3125
4050,4049,4028
3806,3777,3797
3790,3780,3791
4034,4059,4061
4519,4520,4508
3865,3839,3852
3756,3749,3755
3047,3103,3086
3047,3046,3103
3091,3103,3046
4506,4481,4505
2340,2341,2328
2354,2366,2342
3099,3097,3100
4493,4513,4500
3890,3876,3891
2831,2876,2877
4275,4279,4276
4405,4392,4167
3279,4367,4368
4519,4531,4520
4374,4469,4470
4374,4470,4450
4522,4534,4535
4505,4481,4480
4521,4533,4522
2382,2370,2369
2643,2631,2642
2348,2312,2325
2837,2861,2865
2837,2865,2864
4564,4559,4563
2806,2807,2797
4309,4262,4315
3074,3042,3062
4542,4426,4425
2710,2711,2674
2642,2631,2630
1882,1909,1883
2065,2052,2064
2796,2806,2797
2615,2616,2602
2987,3085,3150
1736,1726,1735
1519,1531,1498
2040,1995,2005
2459,2337,2349
2459,2460,2337
1576,1525,1538
1259,1192,1181
4439,4452,4453
1490,1478,1489
1941,1951,1942
1714,1725,1715
1231,1249,1319
1317,1368,1336
364,376,371
364,371,365
4504,4515,4516
1019,1105,1010
1117,1062,1144
1994,1928,1873
685,698,721
1105,991,1003
1368,1386,1367
103,107,104
878,880,867
1943,1955,2274
111,108,110
100,132,166
593,560,604
349,249,257
890,883,891
320,239,325
454,500,491
435,381,434
603,755,608
799,784,798
572,563,509
560,593,509
871,841,857
1080,1287,1086
2089,2100,2008
2028,2008,2100
2529,2567,2568
4184,4212,4213
2482,2579,2500
3154,3020,3161
2891,2767,2884
1866,1880,1881
899,890,891
2285,2458,2492
3527,3494,3525
3210,3220,3182
3630,3607,3629
3467,3417,3410
4262,4264,4315
3448,3397,3436
2697,2704,2745
2092,2146,2048
1745,2093,1759
42,70,78
1796,1804,1502
95,91,87
1122,1085,1078
939,922,923
1004,939,923
1099,1124,1112
1194,1205,1193
1012,1065,1085
1085,1064,1012
1085,1097,1064
1120,1371,1166
1120,1302,1371
777,877,980
777,862,877
1213,1231,1319
485,473,461
542,557,600
583,600,557
664,653,665
845,818,779
609,478,542
654,706,688
1262,1249,1477
779,818,790
664,790,581
566,565,533
1089,1037,1096
1089,1063,1037
1249,1262,1319
1233,1150,1122
1136,1233,1122
1663,1653,1654
1342,1343,1328
1247,1248,1260
1260,1248,1261
1626,1514,1527
944,1046,979
1271,1260,1261
1319,1338,1467
1319,1467,1352
1229,1190,1230
993,1003,978
1270,1269,1283
773,875,860
255,272,232
403,376,363
321,265,287
460,461,473
226,276,339
821,719,727
404,395,432
559,558,520
201,273,276
187,146,155
131,146,187
131,141,146
120,119,135
139,136,135
442,396,438
432,511,520
806,922,847
631,612,632
808,630,726
709,584,536
1058,1048,949
1194,1193,1182
1355,1393,1340
1138,1151,1137
918,941,931
1111,949,1090
1111,1058,949
1139,1691,1703
1829,1251,1712
1355,1217,1139
1355,1139,1251
1581,1570,1571
1500,1558,1545
1782,1792,1791
1734,1756,1743
1817,1806,1779
2402,2272,2263
2261,2269,2270
1617,1706,1696
1929,1930,1915
1846,1916,1890
1824,1817,1779
1929,1914,1890
2388,2377,2376
2509,2390,2566
2451,2390,2509
2224,2318,2234
2067,1984,2130
2130,2116,2121
1654,1653,1639
2209,2067,2210
1557,1530,1612
1734,1792,1756
1732,1721,1799
1631,1499,1391
1769,1781,1799
1755,1756,1770
1799,1800,1809
1742,1681,1722
1755,1743,1756
1819,1894,1878
1932,1918,1894
1809,1838,1799
2079,2069,2116
2330,2319,2331
2027,1956,1932
2027,1932,1944
2344,2355,2436
1954,1818,2026
2058,1945,2069
2130,2026,2041
1800,1792,1810
3669,3783,3776
3281,3292,3280
3134,3131,3132
3197,3196,3186
3111,3107,3108
3132,3131,3126
3186,3185,3181
3085,3225,3289
3046,3048,3057
3140,3127,3136
2729,2716,2723
2539,2566,2390
2306,2319,2318
2318,2319,2330
2756,2737,2757
3182,3168,3210
3830,3804,3819
3294,3394,3344
3779,3831,3821
3782,3795,3669
3639,3640,3771
3670,3671,3763
3638,3639,3771
3282,3318,3336
3671,3670,3508
3508,3638,3671
3182,3318,3305
3291,3304,3364
3317,3291,3364
3139,3181,3138
3914,3934,3952
3193,3194,3173
3146,3226,3219
3185,3250,3193
3185,3196,3250
2056,2130,2041
3133,3106,3110
3262,3226,3146
3291,3193,3250
3418,3422,3378
3411,3378,3422
3807,3798,3852
3820,3852,3798
3422,3418,3544
3670,3763,3669
3763,3777,3669
3778,3771,3785
3806,3783,3669
4190,4147,4191
3805,3819,3796
3851,3950,3912
3830,3818,3804
3913,3851,3895
4048,4049,4071
4026,4070,4069
3617,3648,3647
4452,4471,4472
3974,3932,3951
4028,4049,4048
3990,4031,4003
4075,4052,4053
3774,3788,3787
3976,3897,4002
3871,3919,3900
3545,3546,3411
4316,4263,4261
4250,4221,4071
4072,4250,4071
4283,4284,4278
4050,4051,4073
4355,4356,4376
4342,4337,4338
4080,4096,4079
4286,4281,4280
4049,4072,4071
4250,4248,4219
4220,4250,4219
4269,4243,4270
4269,4270,4324
4460,4255,4222
4442,4255,4460
4334,3998,4333
4338,4326,4247
4324,4325,4336
4325,4271,4272
4260,4309,4302
4215,4112,4189
4215,4189,4216
4132,4094,4147
4070,4071,4165
4070,4047,4071
3815,3816,3829
3411,3422,3544
3248,3303,3288
3351,3316,3315
3401,3351,3315
4120,4141,4140
4521,4520,4532
4275,4276,4364
4364,4274,4275
4364,4338,4274
4341,4328,4348
4323,4322,4268
4320,4267,4322
4348,4336,4342
4489,4490,4488
4362,4338,4364
4432,4370,4431
4234,4233,4208
4179,4180,4210
4161,4181,4144
4157,4136,4158
4288,4249,4441
4300,4294,4293
4312,4313,4307
4210,4181,4235
4206,4235,4181
4282,4248,4250
3994,3977,4007
4198,4007,4200
4209,4208,4178
4264,4316,4315
4085,4100,4082
3967,3966,3942
4062,4103,4085
4088,4103,4062
3903,3924,3835
4121,4103,4104
3464,3452,3439
3825,3811,3826
3980,3884,3856
4083,4099,4098
3887,3888,3908
3924,3941,3940
3943,3967,3942
3905,3906,3929
4130,4129,4107
4086,4061,4083
3289,3411,3412
2800,2743,2812
2709,2715,2722
2621,2772,2715
2557,2488,2537
2520,2566,2528
2007,2014,2015
2882,3046,3047
2635,2596,2604
2765,3017,2772
2634,2618,2587
2700,2670,2695
2735,2780,2771
2709,2722,2620
2257,2245,2244
2246,2245,2258
2442,2431,2448
2280,2291,2271
2077,2064,2022
1900,1887,1805
2479,2478,2485
2120,2221,2222
2015,1997,2007
2400,2413,2414
2374,2375,2364
2478,2461,2448
2388,2387,2399
1966,1967,1952
2259,2258,2267
2970,3009,2979
2088,2096,2097
2497,2505,2498
2477,2506,2507
2707,2670,2700
2707,2706,2670
2535,2536,2527
3005,3024,3000
3005,3030,3024
3051,3062,3042
4466,4425,4527
4485,4527,4425
3030,3029,3024
2176,2074,2168
2168,2074,2158
2272,2257,2263
2517,2518,2506
3097,3079,3063
2799,2844,2762
2952,2944,3000
3084,3079,3097
3286,3277,3285
3102,3147,3105
2838,2819,2871
3302,3157,3153
2248,2249,2233
2931,2936,2852
3096,3090,3097
3099,3096,3097
3247,3147,3258
3150,3258,3147
3097,3090,3084
2024,2015,2023
2120,2223,2208
2222,2223,2120
2088,2087,2095
2095,2087,2022
4022,3944,4021
3959,3909,3891
3874,3826,3814
3769,3770,3837
3874,3888,3873
3885,3873,3886
4035,4060,4034
4011,4034,4038
3930,3968,3929
3908,3930,3907
4110,3892,3946
3828,4110,3827
4149,4150,4169
4141,4142,4180
4152,4168,4151
4168,4167,4199
4453,4488,4354
4470,4471,4451
4517,4506,4505
4295,4253,4251
4438,4451,4439
3313,3971,3987
3313,3331,3971
4439,4451,4452
4479,4456,4478
2808,2844,2799
4414,4351,4380
4413,4414,4380
4509,4522,4537
4412,4413,4380
4456,4455,4477
4422,4445,4446
3266,3157,3285
4420,4462,4444
4402,4403,4391
4402,4425,4403
4365,3314,4363
4370,3279,4391
4445,4510,4446
4560,4542,4565
3123,3124,3143
4363,4381,4395
4446,4510,4463
4527,4554,4564
4423,4422,4446
4399,4422,4423
4382,4396,4365
4383,4421,4397
4399,4398,4422
4535,4536,4522
3286,3300,3301
3105,3109,3095
2912,3024,2991
2974,2958,2978
3095,3090,3096
4370,4429,4430
2695,2701,2700
2633,2548,2556
2700,2701,2707
2556,2431,2499
2548,2431,2556
2779,2681,2778
4449,4465,4485
4558,4553,4541
2991,2958,2912
2919,2908,2963
2788,2789,2778
2720,2712,2707
2657,2661,2668
2632,2514,2628
2835,2849,2874
2003,2119,2113
2003,2085,2119
2515,2477,2615
2927,2934,2928
2908,2879,2837
2792,2785,2784
2928,2934,2935
4426,4427,4370
2935,2911,2928
2881,2867,2911
2905,2911,2867
4423,4446,4447
4566,4546,4571
4566,4551,4546
2893,2888,2887
4414,4509,4537
4401,4400,4424
3089,3077,3073
4533,4534,4522
4562,4541,4540
4504,4516,4505
4402,4401,4424
4399,4385,4398
2894,2895,2888
3051,3041,3073
2909,2908,2919
4538,4531,4530
4427,4426,4467
4543,4467,4426
4565,4564,4570
4433,4432,4468
3074,3078,3088
3037,2995,2983
3380,3559,3319
3985,3965,3966
3905,3929,3928
4064,4063,4039
2822,2992,2988
2979,2876,2970
2518,2519,2507
2871,2819,2852
2844,2720,2726
4108,4020,4182
2080,2131,2274
2089,2080,2274
2207,2342,2366
2180,2156,2188
2338,2228,2217
2129,2293,2305
2494,2514,2434
2508,2434,2514
2752,2667,2688
2696,2711,2831
2276,2287,2281
2622,2508,2619
2299,2300,2286
2324,2311,2299
2657,2645,2661
2239,2240,2164
2311,2312,2300
2286,2300,2241
2149,2074,2114
1948,1949,1938
2005,2104,2040
2633,2629,2615
2669,2658,2668
2479,2471,2478
2602,2595,2594
2603,2602,2616
2386,2429,2381
2687,2688,2680
2359,2358,2369
2637,2625,2636
2239,2286,2240
2281,2129,2276
2266,2276,2129
2594,2469,2495
2594,2525,2469
2746,2733,2681
2658,2643,2642
2629,2641,2630
2591,2599,2592
2483,2475,2513
2603,2616,2617
2563,2574,2514
1699,1709,1710
2555,2563,2514
2476,2484,2434
2467,2513,2475
2514,2601,2614
2338,2326,2313
2533,2523,2532
2547,2514,2534
2434,2403,2343
2339,2329,2326
2337,2460,2338
2338,2243,2228
2368,2369,2358
2338,2339,2326
2326,2317,2313
2362,2300,2312
2190,2189,2198
2165,2147,2119
1937,1936,1947
1994,1940,1928
1994,1950,1940
2593,2585,2592
1678,1672,1664
1853,1844,1873
2523,2512,2532
1807,1678,1778
1807,1686,1678
1710,1544,1699
1720,1644,1544
1710,1720,1544
1167,1158,1259
1683,1694,1670
1844,1816,1764
1768,1780,1875
1641,1778,1678
968,1109,1030
968,994,1109
981,1135,1109
1158,1167,1121
490,501,484
689,807,725
793,807,689
707,666,724
690,691,680
761,793,689
1336,1351,1400
621,582,573
716,684,733
741,716,733
526,599,622
526,622,623
938,967,981
568,495,484
501,568,484
541,549,532
550,430,549
275,259,207
361,309,360
316,302,311
458,448,531
367,358,388
448,427,444
549,573,582
992,991,1105
1056,892,900
900,992,907
928,893,915
1083,1157,1087
1525,1626,1538
1576,1485,1420
1817,1888,1806
1966,2013,2006
1902,1915,1953
1963,1978,1964
1763,1746,1750
1859,1887,1900
1448,1461,1462
1948,1947,1962
1258,1257,1268
1282,1268,1281
1962,1992,1978
1464,1575,1465
1464,1474,1575
2654,2639,2638
1716,1670,1694
1695,1670,1716
1593,1577,1695
1670,1695,1577
1552,1539,1670
1696,1693,1683
1662,1696,1683
1899,1910,1911
1365,1366,1350
1257,1243,1256
1312,1295,1294
1348,1333,1347
1242,1241,1255
1538,1626,1551
1717,1797,1728
2105,2106,2096
1625,1513,1576
1270,1298,1259
1454,1575,1455
1463,1464,1450
1349,1365,1350
1293,1267,1255
723,717,734
705,716,722
697,684,716
1063,929,1036
1429,1592,1565
1429,1442,1592
1270,1244,1258
1258,1269,1270
1256,1243,1242
1056,894,892
1190,1189,1180
716,774,775
928,1045,936
2006,1996,1966
1914,1929,1915
1817,1824,1888
1180,1230,1190
1179,1189,1156
1165,1230,1180
944,929,937
830,927,831
830,885,927
935,993,978
652,777,735
652,760,777
620,651,660
773,860,816
661,594,660
714,704,721
1229,1246,1228
810,641,680
810,670,641
213,196,195
316,346,399
316,327,346
430,389,398
407,424,431
407,431,399
311,306,327
513,504,512
1092,1287,1100
1264,1252,1287
1074,1287,1080
1687,1699,1544
1113,1126,1100
1068,997,1060
1086,1287,1092
1159,1287,1252
1390,1394,1374
1053,1287,1060
657,680,648
852,823,973
504,513,616
809,868,751
1121,1214,1232
720,807,728
507,479,499
142,143,192
253,245,153
101,54,98
101,58,54
208,269,242
262,256,280
66,102,105
97,94,93
93,47,42
1537,1550,1636
1007,1017,1016
1254,1523,1589
870,855,856
471,475,454
123,127,135
41,42,40
64,86,144
28,27,47
91,90,87
10,7,11
64,73,86
34,53,32
29,49,94
7,26,11
53,52,74
55,74,52
17,3,14
7,24,25
79,80,67
1774,1814,1880
33,30,37
455,433,323
455,323,445
97,98,94
349,257,260
330,305,281
113,117,126
466,447,453
486,454,491
347,368,369
555,603,560
65,53,74
905,906,913
507,499,616
881,869,853
854,840,853
1172,1061,1054
768,786,643
592,603,578
842,843,858
1017,1008,1018
871,872,882
608,694,603
603,592,755
912,920,911
902,852,887
965,976,964
1483,1549,1587
1017,1018,1035
873,843,919
740,963,974
1035,1026,1017
1104,1044,1223
1254,1155,1130
898,904,889
890,889,882
1223,1198,1209
921,920,912
872,871,857
1034,1026,1035
921,1000,999
1016,1017,1026
1326,1308,1239
943,910,1021
765,783,766
1103,921,1104
1432,1266,1188
1307,1432,1188
1326,1511,1459
1510,1396,1501
1326,1482,1511
1549,1483,1459
1787,1713,1692
1588,1587,1666
1668,1661,1669
1200,1446,1504
890,882,883
906,899,891
1588,1692,1650
1494,1484,1483
1549,1548,1587
1658,1682,1559
2083,2072,2082
1771,1702,1783
1544,1679,1687
1480,1632,1645
1657,1544,1702
1833,1702,1826
1783,1702,1793
1793,1702,1801
1820,1702,1827
1826,1920,1833
2323,2407,2308
2521,2529,2417
2473,2417,2529
2750,2758,2822
4108,4183,4184
2101,2195,2061
2407,2265,2295
2308,2407,2295
4211,4212,4183
1042,1021,985
998,1042,985
2195,2334,2323
2739,2732,2544
2000,1989,2126
2251,2265,2126
2982,2971,2822
2961,2924,2916
2891,2884,2610
2891,2610,2872
2948,2939,2750
2885,2878,2886
2870,2866,2873
3256,3432,3349
3256,3431,3432
3214,3221,3170
4185,4213,4238
3274,3307,3221
3206,3202,3155
3296,3213,3232
3296,3284,3213
3296,3232,3892
3861,3892,3232
1823,1481,1606
1823,1493,1481
2458,2419,2456
2465,2458,2456
1650,1636,1588
2011,2001,2002
1989,1881,1973
1989,1974,1881
450,426,420
2000,2146,1858
2000,2048,2146
2213,2694,2693
2155,2357,2408
2873,2866,2886
2886,2956,2885
3781,3837,3836
2154,2155,2186
2420,2544,2732
2112,2357,2155
2878,2873,2886
3481,3466,3479
3215,3156,3163
3174,3156,3215
2956,3081,3148
3428,3452,3429
3428,3439,3452
3623,3625,3605
2971,2989,2961
4135,4393,4154
3409,3416,3429
3234,3222,3229
3207,3235,3230
3163,3075,3094
3128,3122,3082
3942,3926,3943
3461,3477,3464
3312,3371,3330
3376,3375,3239
3350,3455,3445
3470,3468,3484
3754,3758,3759
3892,3861,3850
4211,4183,4182
1881,1880,1973
3492,3506,3479
3585,3856,3603
3922,3618,3884
3602,3884,3618
3623,3585,3603
3745,3751,3752
3724,3742,3701
3570,3520,3569
3748,3747,3754
3743,3751,3744
3603,3856,3602
3171,3013,3006
3520,3506,3492
3569,3588,3570
3410,3444,3454
3387,3372,3410
3717,3726,3718
3357,3283,3366
3437,3188,3360
3071,3070,3066
3856,3566,3846
3856,3565,3566
3505,3521,3519
3238,3192,3276
3343,3322,3348
3238,3276,3299
4027,4046,4045
4003,4029,4002
3715,3721,3722
3727,3719,3718
3489,3586,3475
3665,3631,3666
3572,3557,3573
3936,4037,3958
4176,4157,4158
3753,3758,3754
4200,4203,4225
3430,3440,3523
3430,3523,3463
3635,3634,3609
3610,3541,3542
3732,3740,3733
4120,4121,4141
3715,3694,3687
3665,3751,3662
4076,4075,4053
3726,3725,3734
3700,3682,3693
3618,3653,3620
3600,3618,3922
3348,3322,3361
3916,3917,3991
3548,3510,3511
3499,3532,3531
3294,3295,3325
3678,3676,3677
3995,4010,4009
3395,3405,3641
3772,3640,3773
3486,3496,3471
3512,3548,3511
3283,3390,3389
3071,3080,3076
3066,3067,3071
3187,2954,3188
2946,2811,2947
2558,2540,2724
2811,2724,2540
2043,2178,2193
2110,2045,2111
2179,2173,2184
2143,2144,2152
2724,2811,2946
2730,2724,2946
2144,2153,2152
2124,2133,2132
2581,2446,2543
2581,2543,2751
2699,2694,2823
2832,2841,2840
3659,3742,3750
2379,2703,2474
2125,2134,2133
1863,2009,2017
2009,2446,2111
2125,2133,2124
2118,2110,2111
2125,2118,2111
2009,1822,1971
1795,1879,1923
1171,1170,1162
1040,1127,1093
1573,1547,1562
1186,1238,1237
1614,1786,1830
1170,1184,1183
970,959,971
1274,1216,1217
971,972,983
1758,1772,1784
681,745,729
839,682,672
709,668,677
681,729,612
681,612,585
385,379,410
391,273,372
161,154,139
157,167,121
169,159,151
1,12,13
90,91,145
211,177,216
145,165,152
171,245,178
178,177,171
82,73,74
149,150,158
74,73,65
731,856,493
606,618,613
576,796,650
1185,825,1163
1185,839,825
1137,1122,1078
1078,1065,1058
1085,1065,1078
1012,969,1065
1122,1137,1339
1215,1339,1137
969,996,1065
1058,1065,996
1058,996,958
1058,958,1048
836,821,849
837,849,821
847,922,939
1004,1048,958
1004,958,939
780,922,806
879,866,850
865,780,655
923,922,865
1085,1122,1097
1193,1205,1215
1182,1193,1151
1193,1215,1151
1151,1215,1137
1137,1078,1058
949,1004,923
1234,1391,1339
1392,1391,1234
1215,1234,1339
1413,1613,1392
1499,1412,1391
1136,1412,1304
1233,1412,1303
1233,1304,1412
1769,1721,1688
1499,1371,1412
1499,1477,1371
1339,1391,1122
1303,1371,1302
1302,1233,1303
1150,1233,1168
1304,1233,1136
1122,1391,1412
1122,1412,1136
1168,1302,1096
1168,1233,1302
1108,1096,1302
1120,1108,1302
1064,1097,1122
1064,1122,1150
948,846,969
969,1012,948
1096,1064,1150
1168,1096,1150
1037,945,946
1037,980,945
1037,946,947
1064,1037,948
947,948,1037
1036,980,1037
1096,1037,1064
1063,1036,1037
1249,1231,1477
1213,1202,1477
1202,1213,1319
1527,1618,1540
1191,1319,1230
1231,1213,1477
1338,1319,1262
624,637,654
629,489,483
461,404,468
461,416,404
423,473,485
557,502,535
536,584,535
637,624,630
557,567,583
708,780,806
417,395,400
611,605,612
468,404,432
432,395,425
416,461,460
535,502,485
536,535,485
536,485,461
567,557,535
600,609,542
488,487,482
818,845,804
609,630,624
805,708,718
805,750,708
609,615,630
654,688,653
654,630,655
637,630,654
615,600,583
615,583,567
535,615,567
584,615,535
655,780,708
615,609,600
806,847,708
718,708,847
708,750,706
805,847,958
655,708,654
654,708,706
877,791,846
805,718,847
750,791,706
748,706,791
791,750,805
846,791,805
948,947,846
779,748,791
846,805,958
969,846,958
846,947,877
877,947,946
980,877,945
877,946,945
481,477,482
845,791,877
862,804,845
862,845,877
845,779,791
706,748,779
664,779,790
779,688,706
664,629,653
488,556,487
624,653,629
624,654,653
676,664,665
664,676,779
653,688,665
688,676,665
664,489,629
609,624,478
629,478,624
664,494,489
629,483,478
664,581,556
565,574,580
597,565,580
664,556,494
556,489,494
482,487,481
488,489,556
482,478,483
482,477,478
488,482,483
489,488,483
441,444,436
519,448,481
441,481,444
460,415,344
441,436,428
478,477,441
477,481,441
1247,1229,1230
1542,1541,1528
1476,1467,1388
1353,1338,1262
1262,1369,1353
4132,4093,4094
1262,1388,1369
1262,1354,1388
1202,1191,1477
1191,1371,1477
1166,1371,1191
1120,1166,1191
1191,1089,1096
1096,1108,1191
1108,1120,1191
1338,1353,1467
1467,1353,1369
1467,1369,1388
1639,1653,1638
1248,1319,1261
1088,1089,1191
1165,1180,1179
1089,1088,1063
1134,1088,1191
1088,1046,937
1443,1368,1337
1351,1336,1368
1228,1212,1229
1261,1319,1352
1261,1352,1272
1541,1554,1618
1230,1319,1248
1164,1157,1165
1352,1467,1443
1271,1261,1272
1133,1157,1146
1165,1191,1230
1165,1134,1191
1337,1318,1443
1318,1300,1443
1271,1272,1443
1285,1271,1443
1443,1300,1285
1443,1272,1352
1230,1248,1247
1190,1212,1201
1190,1229,1212
1527,1443,1467
1165,1179,1164
1246,1247,1260
1247,1246,1229
1164,1179,1156
1246,1271,1285
1246,1260,1271
1246,1300,1318
1071,1134,1165
929,980,1036
1071,1088,1134
1046,1088,1071
1071,1165,1157
929,915,777
979,1071,1055
979,1051,1071
1088,937,929
1063,1088,929
944,937,1046
1071,1051,1046
1051,979,1046
597,628,698
597,698,565
588,530,565
565,566,574
735,698,652
589,580,862
698,735,777
980,929,777
644,674,651
663,651,674
580,790,804
581,790,580
556,581,580
652,589,862
628,597,580
628,580,652
589,652,580
760,652,862
802,788,759
760,862,777
565,698,674
565,674,588
652,698,628
487,556,481
580,533,481
556,580,481
533,565,530
580,574,533
574,566,533
448,444,481
530,519,533
531,448,530
530,448,519
472,441,437
441,472,478
393,388,382
519,481,533
195,196,160
212,232,213
217,185,214
251,261,258
231,232,212
265,232,240
225,194,185
225,185,217
265,321,322
265,255,232
213,194,212
194,213,195
155,162,187
179,161,186
136,139,140
139,185,194
139,195,160
139,194,195
196,139,160
161,139,196
186,161,196
154,161,179
322,321,333
332,333,321
364,363,376
436,444,427
436,427,403
366,377,363
371,341,365
377,366,428
429,428,366
363,286,352
415,460,423
441,428,429
423,460,473
403,363,436
341,363,364
364,365,341
436,377,428
436,363,377
437,441,429
557,437,502
429,423,437
423,485,502
437,423,502
429,366,423
415,423,366
557,542,472
557,472,437
478,472,542
212,194,225
415,366,344
366,363,352
332,287,341
363,341,287
363,287,286
332,321,287
366,352,286
292,366,286
292,286,395
395,404,292
404,416,292
460,344,292
416,460,292
344,366,292
232,231,240
261,267,264
261,395,267
261,383,395
267,395,286
264,267,286
264,286,287
214,218,217
230,212,225
214,185,205
217,218,226
235,236,247
240,264,265
258,264,240
236,225,226
225,236,235
261,235,247
261,246,235
246,261,251
240,230,235
258,261,264
230,225,235
240,235,246
251,240,246
231,212,230
265,264,287
258,240,251
240,231,230
214,205,218
139,187,185
201,185,187
162,155,273
205,185,201
266,328,359
205,201,218
247,339,383
247,383,261
395,339,400
395,383,339
201,162,172
201,187,162
172,162,273
146,273,155
218,201,276
218,276,226
201,172,273
226,339,236
236,339,247
425,395,417
135,187,139
114,120,136
123,187,127
123,130,187
131,187,130
115,114,136
128,130,123
128,131,130
120,135,136
119,123,135
127,187,135
118,123,119
124,123,118
124,128,123
120,107,106
119,106,118
120,106,119
107,120,114
104,114,115
107,114,104
77,85,76
77,147,92
57,60,56
103,104,84
107,103,84
101,166,116
101,100,166
339,276,396
141,128,124
77,92,96
85,77,96
85,106,76
96,124,118
536,461,668
551,612,569
551,585,612
558,432,520
468,432,558
432,425,511
511,425,469
514,537,551
514,551,543
351,355,354
543,520,511
559,575,611
879,850,950
551,537,552
917,924,930
551,569,520
551,520,543
551,552,585
570,585,552
668,610,647
575,559,520
575,520,569
611,631,640
612,631,611
575,612,605
569,612,575
656,668,647
656,640,631
656,647,640
678,631,632
764,763,752
917,850,837
575,605,611
558,461,468
558,610,461
611,558,559
610,558,611
611,647,610
640,647,611
668,656,677
821,808,726
950,930,940
941,951,940
865,630,836
865,655,630
837,850,849
709,710,821
710,719,821
709,821,726
668,709,536
668,461,610
866,923,849
710,677,678
656,631,677
678,677,631
709,677,710
615,726,630
615,584,709
615,709,726
865,836,849
762,821,727
866,849,850
821,836,808
865,849,923
808,836,630
866,949,923
866,879,949
1048,1004,949
1059,1090,949
1182,1151,1152
1138,1123,1124
1123,1138,1137
1098,1111,1090
1052,1090,1059
1052,1091,1090
1124,1123,1112
1112,1123,1111
1124,1152,1138
1098,1099,1112
1091,1099,1098
1091,1098,1090
1052,949,879
1052,1059,949
1112,1111,1098
1058,1111,1137
1137,1111,1123
1152,1151,1138
1392,1234,1372
1855,1906,1905
1372,1205,1194
1372,1215,1205
1372,1234,1215
1393,1479,1372
1392,1372,1545
1479,1491,1372
1274,1217,1340
1217,1067,1073
1066,1072,1052
1079,1217,1216
1274,1091,1216
1091,1079,1216
1288,1834,1321
1093,1276,1624
1093,1624,1139
1340,1217,1355
1079,1091,1072
1052,1072,1091
930,931,940
1124,1393,1152
1182,1152,1393
1393,1124,1099
1393,1091,1274
1393,1099,1091
1340,1393,1274
1194,1182,1393
1194,1393,1372
1681,1742,1688
1769,1688,1742
1393,1355,1373
1393,1373,1479
1139,1624,1691
1321,1834,1500
1079,1072,1217
879,1066,1052
1066,1217,1072
1067,1217,1066
982,983,1067
2275,2489,1894
1571,1570,1558
1893,1904,1956
1500,1571,1558
1545,1372,1491
1392,1545,1413
1479,1545,1491
1492,1545,1479
1492,1500,1545
1558,1570,1545
1500,1582,1571
2125,2111,2134
1723,1733,1722
1799,1791,1800
1742,1733,1743
1711,1701,1723
1945,1894,2489
1734,1723,1701
1791,1792,1800
1722,1711,1723
1689,1605,1701
1545,1570,1413
1598,1582,1605
1605,1689,1598
1598,1581,1582
1582,1581,1571
1392,1623,1391
1392,1613,1623
1734,1733,1723
1734,1743,1733
1413,1597,1604
1700,1711,1722
1581,1689,1570
1701,1700,1689
1700,1701,1711
1598,1689,1581
1700,1722,1681
1755,1742,1743
1799,1721,1769
1733,1742,1722
1809,1800,1810
1782,1791,1781
1791,1799,1781
1781,1769,1770
1769,1755,1770
1782,1770,1756
1782,1781,1770
1756,1792,1782
1809,1810,1819
1769,1742,1755
1842,1819,1848
1842,1838,1819
1877,1878,1893
1957,1894,1945
2463,2452,2453
2463,2453,2474
2463,2474,2490
1854,1848,1819
2530,2170,2489
2463,2490,2452
2490,2540,2530
2490,2530,2489
2452,2490,2489
2259,2267,2268
2304,2303,2315
2402,2263,2264
2402,2390,2416
2264,2192,2099
2210,2067,2169
1954,1917,1903
2067,1983,1916
2264,1983,2067
2067,1917,1954
1941,1929,1890
1845,1841,1798
1841,1836,1798
2264,2067,2209
2067,1916,1837
2099,1983,2264
2488,2272,2433
1942,1951,1952
2424,2442,2415
2280,2271,2270
2022,2064,2051
2088,2095,2096
2098,2025,2099
2098,2099,2192
1964,1978,1992
2221,2120,2220
2260,2259,2268
2400,2401,2389
2277,2267,2257
2064,2052,2051
2353,2341,2352
2038,2022,2051
2289,2279,2278
2261,2260,2269
2431,2442,2424
2248,2233,2247
2015,2014,2023
2221,2220,2230
2257,2267,2258
2269,2268,2278
2232,2231,2246
2007,2013,2014
2231,2221,2230
2065,2064,2077
2097,2078,2088
2087,2078,2077
2232,2222,2231
2014,2013,2022
1980,1967,1966
1901,1914,1902
1766,1752,1708
2106,2115,2107
2105,2022,1982
2105,2095,2022
1951,1966,1952
1824,1832,1888
1914,1915,1902
2014,2022,2023
1996,1980,1966
1515,1670,1526
2007,2006,2013
1763,1887,1872
2257,2244,2263
1868,1867,1882
1902,1889,1901
1949,1948,1963
1805,1887,1750
1763,1750,1887
1997,1996,2006
2007,1997,2006
2023,2022,2038
1337,1246,1318
1368,1246,1337
1806,1888,1797
1930,1941,1942
1342,1328,1327
1901,1889,1888
1841,1888,1836
1832,1836,1888
1888,1841,1845
1930,1929,1941
1966,2022,2013
1942,1952,1953
1553,1638,1540
1594,1618,1578
1516,1443,1527
1806,1797,1718
1797,1707,1718
1553,1609,1638
1707,1626,1638
1718,1707,1638
1653,1718,1638
1517,1541,1507
1540,1638,1527
1626,1527,1638
1655,1640,1818
1602,1818,1640
1640,1654,1639
1627,1618,1619
1567,1618,1554
1655,1671,1663
1476,1527,1467
1541,1517,1528
1476,1388,1541
1507,1541,1388
1527,1476,1618
1541,1618,1476
1628,1640,1639
1578,1568,1579
1708,1818,1779
1766,1806,1752
1982,1890,1983
1832,1824,1779
1951,1941,1890
1966,1951,1890
1888,1798,1901
1888,1845,1798
1836,1779,1798
1836,1832,1779
1846,1779,1825
1846,1798,1779
1806,1766,1779
1766,1708,1779
1846,1890,1914
1901,1846,1914
1901,1798,1846
1837,1825,1779
1578,1579,1594
1982,2025,2098
2025,1982,1983
1983,1890,1916
1982,1966,1890
2022,1966,1982
2105,2115,2106
2095,2105,2096
1825,1916,1846
1837,1916,1825
1627,1619,1628
1594,1579,1595
1627,1628,1639
1554,1541,1542
1595,1601,1594
1602,1640,1628
1554,1542,1555
1601,1610,1618
1627,1639,1638
1677,1818,1685
1677,1655,1818
1640,1655,1654
1610,1619,1618
1671,1718,1663
1653,1663,1718
1677,1718,1671
1655,1677,1671
1818,1697,1685
1685,1697,1718
1655,1663,1654
1685,1718,1677
1806,1708,1752
1718,1708,1806
1697,1708,1718
1818,1708,1697
1578,1618,1567
1618,1627,1638
1618,1594,1601
1554,1555,1567
1609,1618,1638
1540,1609,1553
1618,1609,1540
1567,1568,1578
1567,1555,1568
1507,1388,1517
1595,1602,1601
1602,1610,1601
1619,1610,1602
1602,1628,1619
2263,2098,2192
1983,2099,2025
2264,2263,2192
2673,2577,2605
2673,2550,2577
2402,2273,2378
2273,2402,2264
2537,2488,2509
2433,2272,2402
2488,2402,2509
2433,2402,2488
2402,2416,2509
2451,2509,2445
2435,2445,2509
2435,2509,2426
2509,2416,2426
2169,2318,2210
2426,2416,2390
2445,2390,2451
2435,2426,2390
2445,2435,2390
2224,2264,2210
2390,2402,2378
1891,2067,1874
2234,2264,2224
2282,2378,2264
2273,2264,2378
2234,2282,2264
1891,1818,1903
2210,2264,2209
2234,2318,2378
2282,2234,2378
2378,2436,2390
1984,2067,1969
1681,1604,1700
1613,1604,1681
1595,1818,1602
1818,1680,1643
1555,1680,1818
1555,1818,1568
1568,1818,1579
1579,1818,1595
1837,1874,2067
1917,2067,1903
1903,2067,1891
1874,1779,1818
1874,1837,1779
1874,1818,1891
1903,1818,1954
1956,1904,1918
1528,1517,1643
1622,1643,1612
1517,1388,1643
1643,1388,1354
1643,1542,1528
1612,1643,1354
1721,1818,1643
1721,1643,1622
1680,1542,1643
1680,1555,1542
1477,1557,1262
1262,1557,1612
1354,1262,1612
1530,1557,1477
1818,1721,1808
2027,1944,1957
1956,1918,1932
1819,1838,1809
1861,1892,1818
1861,1842,1847
2056,2057,2068
2068,2057,2069
1877,1893,1956
1861,1956,1892
1861,1877,1956
1931,1818,1892
1842,1861,1818
1808,1842,1818
1741,1838,1842
1721,1732,1842
1808,1721,1842
1732,1741,1842
1799,1741,1732
1623,1631,1391
1688,1530,1477
1688,1477,1499
1612,1530,1688
1721,1622,1612
1688,1721,1612
1838,1741,1799
1688,1499,1631
1688,1631,1681
1413,1604,1613
1623,1681,1631
1604,1597,1700
1613,1681,1623
1570,1689,1700
1597,1570,1700
1597,1413,1570
1877,1862,1878
1854,1861,1848
1862,1854,1819
1861,1854,1862
1861,1847,1848
1847,1842,1848
1819,1878,1862
1918,1904,1894
2170,1945,2489
1877,1861,1862
1894,1893,1878
1904,1893,1894
1944,1932,1894
1957,1944,1894
2130,2056,2116
1957,1945,2058
2079,2116,2068
2069,1945,2170
1957,2058,2069
1957,2069,2057
2042,2027,1957
2042,2057,2056
1818,1931,1985
2121,2140,2130
3106,3048,3107
3106,3091,3048
3250,3208,3218
2041,2042,2056
2027,2042,2041
2069,2170,2530
2069,2530,2235
1969,1954,2026
2057,2042,1957
2027,2041,2026
2318,2436,2378
2067,2130,2177
2067,2177,2169
2318,2169,2177
2177,2150,2318
2235,2530,2122
2552,2122,2530
2330,2331,2344
2140,2150,2177
2130,2140,2177
3304,3291,3292
2056,2068,2116
2130,1984,2026
1984,1969,2026
1818,1985,2026
2026,1985,1956
2026,1956,2027
1892,1985,1931
1892,1956,1985
2079,2068,2069
2320,2122,2552
2122,2069,2235
2150,2319,2306
2069,2121,2116
2150,2122,2320
2069,2122,2121
2122,2150,2121
2121,2150,2140
2306,2318,2150
2331,2319,2150
2320,2331,2150
2344,2331,2355
2318,2330,2436
2436,2355,2391
2436,2539,2390
2391,2355,2331
2320,2552,2331
2330,2344,2436
2551,2436,2391
2566,2539,2551
2551,2577,2566
2766,3014,3017
2391,2331,2729
2689,2729,2331
2741,2737,2749
3110,3106,3107
3018,3046,3014
3117,3126,3125
3117,3116,3111
3200,3201,3203
3091,3046,3057
3091,3057,3048
3036,3018,3031
3036,3046,3018
3048,3046,3036
3135,3132,3139
3117,3125,3116
3108,3112,3111
3107,3048,3108
3111,3116,3110
3091,3106,3103
3111,3112,3117
3110,3107,3111
2755,3014,2766
2766,3017,2765
2605,2755,2766
2621,2605,2766
2550,2620,2604
2550,2673,2620
2509,2566,2520
2414,2401,2400
2621,2766,2765
2577,2551,2605
2749,2737,2756
3098,3048,3036
3032,3025,3010
3010,3036,3032
3098,3036,3010
3092,3098,3010
3092,3010,3011
2781,2605,2773
2781,3010,3025
2755,2605,2781
2781,2773,2756
3032,3036,2781
3031,2781,3036
3018,2781,3031
3025,3032,2781
3018,2755,2781
3014,2755,3018
2756,2773,2749
2749,2773,2741
2551,2773,2605
2741,2773,2551
2741,2551,2729
2391,2729,2551
2741,2729,2737
2730,2558,2724
2730,2723,2558
2737,2729,2730
2729,2689,2607
2716,2729,2607
2757,2737,2730
2757,3010,2781
2757,3011,3010
2757,2781,2756
2490,2541,2540
2530,2540,2552
2558,2723,2716
2558,2552,2540
2607,2689,2331
2552,2607,2331
2558,2716,2607
2812,2907,2947
2558,2607,2552
3022,3021,2730
3069,3021,3120
3069,3120,3068
2757,3092,3011
3068,3093,3092
2730,3068,3092
2730,3092,2757
2730,3069,3068
3021,3069,2730
3022,3027,3136
3265,3188,3273
3136,3160,3142
3136,3127,3021
3022,3136,3021
3140,3139,3120
3021,3140,3120
3021,3127,3140
3098,3139,3048
3139,3108,3048
3139,3098,3092
3092,3093,3139
3068,3139,3093
3120,3139,3068
3139,3126,3117
3139,3117,3112
3139,3132,3126
3146,3158,3168
3108,3139,3112
3250,3200,3203
3159,3142,3160
3140,3142,3158
3139,3140,3158
3142,3140,3136
3146,3139,3158
3182,3146,3168
3168,3158,3210
3159,3210,3158
3159,3160,3210
3393,3332,3333
3396,3414,3341
3382,3355,3383
3784,3777,3763
3325,3295,3263
3252,3325,3263
3210,3252,3220
3220,3252,3263
3340,3182,3344
3340,3318,3182
3641,3419,3822
3341,3355,3325
3325,3355,3354
3341,3356,3355
3936,3616,3922
3395,3672,3547
3395,3641,3672
3355,3382,3547
3354,3355,3547
3789,3821,3840
3789,3840,3810
3509,3344,3394
3344,3182,3220
3394,3294,3325
3325,3424,3394
3424,3325,3592
3547,3592,3325
3820,3785,3808
3592,3765,3640
3592,3509,3394
3424,3592,3394
3509,3592,3640
3772,3771,3640
3640,3508,3509
3592,3672,3765
3640,3639,3508
3773,3640,3774
3765,3672,3775
3547,3672,3592
3641,3775,3672
3765,3774,3640
3775,3641,3831
3821,3831,3840
3798,3784,3778
3831,3765,3775
3831,3779,3765
3840,3868,3810
3773,3787,3786
3789,3774,3765
3774,3787,3773
3779,3789,3765
3810,3897,3809
3779,3821,3789
3788,3774,3789
3810,3788,3789
3788,3809,3787
3786,3787,3808
3787,3809,3808
3788,3810,3809
3773,3786,3772
3784,3807,3797
3778,3785,3798
3785,3820,3798
3777,3784,3797
3776,3783,3796
3852,3806,3807
3806,3797,3807
3806,3669,3777
3671,3638,3764
3784,3763,3778
3778,3763,3671
3785,3786,3808
3764,3771,3778
3393,3344,3509
3764,3778,3671
3764,3638,3771
3514,3513,3498
3772,3785,3771
3772,3786,3785
3798,3807,3784
3639,3638,3508
3637,3364,3304
3456,3669,3637
3456,3670,3669
3220,3263,3344
3280,3292,3291
3456,3508,3670
3332,3292,3333
3208,3209,3218
3637,3304,3332
3304,3292,3332
3456,3637,3332
3185,3137,3181
3344,3263,3295
3294,3344,3295
3260,3269,3291
3393,3333,3334
3334,3335,3344
3334,3344,3393
3340,3336,3318
3195,3241,3242
3332,3508,3456
3393,3508,3332
3508,3393,3509
3292,3293,3333
3293,3334,3333
3335,3334,3293
3281,3282,3293
3250,3203,3208
3173,3194,3195
3251,3250,3226
3204,3146,3209
3226,3250,3218
3194,3193,3241
3201,3197,3146
3270,3271,3281
3204,3208,3203
3251,3226,3262
3270,3269,3261
3251,3261,3260
3317,3242,3241
3243,3195,3242
3196,3197,3200
3317,3241,3291
3146,3219,3209
3262,3270,3261
3293,3292,3281
3282,3340,3344
3293,3282,3344
3280,3269,3270
3280,3270,3281
3250,3251,3260
3269,3280,3291
3262,3146,3271
3209,3219,3218
3281,3271,3282
3291,3250,3260
3251,3262,3261
3271,3270,3262
3282,3336,3340
3305,3318,3282
3305,3282,3182
3146,3182,3282
3282,3271,3146
3185,3133,3137
3173,3133,3185
3219,3226,3218
3193,3291,3241
3203,3201,3204
3204,3201,3146
3134,3138,3137
3197,3139,3146
3197,3186,3139
3139,3138,3135
3196,3200,3250
3204,3209,3208
3931,3911,3947
3200,3197,3201
3195,3194,3241
3133,3125,3131
3103,3173,3115
3186,3196,3185
3186,3181,3139
3134,3133,3131
3193,3173,3185
3134,3137,3133
3133,3110,3116
3106,3133,3103
3133,3116,3125
3173,3103,3133
3137,3138,3181
3135,3134,3132
3135,3138,3134
3378,3352,3243
3195,3249,3225
3195,3243,3249
3352,3289,3243
3544,3545,3411
3411,3546,3412
3378,3243,3418
3418,3242,3317
3418,3243,3242
3418,3317,3423
3364,3423,3317
3879,3839,3865
3804,3818,3795
3932,3974,3950
3364,3591,3423
3895,3879,3914
3934,3915,3976
3801,3794,3802
3364,3637,3591
3805,3783,3806
3839,3806,3852
3933,3975,3951
3819,3804,3796
3839,3805,3806
3776,3782,3669
3830,3864,3817
3805,3796,3783
3816,3817,3829
3782,3796,3804
3801,3816,3815
3795,3818,3803
3776,3796,3782
3819,3805,3839
3801,3793,3794
3795,3782,3804
3803,3818,3817
3802,3816,3801
3803,3817,3802
3423,3793,3800
3793,3591,3637
3794,3669,3802
3795,3803,3669
3803,3802,3669
3669,3794,3637
3817,3818,3830
3817,3838,3829
3637,3794,3793
3947,4041,3986
3815,3829,3838
3801,3815,3793
3793,3815,3800
3802,3817,3816
3423,3591,3793
3913,3932,3851
3932,3950,3851
3989,3974,3951
4189,4112,4132
3864,3912,3863
4042,3948,4025
3999,3948,4042
3916,4004,3990
3862,3838,3863
3863,3838,3817
3973,3948,3912
4044,4026,4069
3973,3912,3988
4026,4000,4001
4026,4045,4070
4000,4026,4044
3864,3863,3817
3948,3973,3972
3815,3838,3862
3911,3894,3948
3911,3862,3863
3863,3894,3911
3863,3948,3894
3863,3912,3948
3912,3864,3830
3865,3852,3880
3851,3830,3819
3851,3819,3839
3830,3851,3912
3852,3866,3880
3950,3949,3912
4027,4026,4001
3988,3912,3949
4027,4045,4026
3951,3932,3913
3851,3839,3895
3988,4001,4000
3988,3949,4001
4001,3949,3950
3974,4001,3950
3974,4027,4001
3866,3897,3915
3867,3897,3866
4073,4051,4074
4002,3898,4003
4004,4055,4031
3952,3976,4048
3913,3895,3933
3952,3933,3914
3952,3975,3933
3952,4048,3975
3865,3880,3896
3952,3934,3976
3951,3913,3933
3880,3866,3915
3895,3839,3879
3820,3866,3852
3808,3866,3820
3808,3867,3866
3933,3895,3914
3914,3896,3934
3879,3896,3914
3879,3865,3896
3915,3897,3976
3934,3896,3880
3934,3880,3915
3528,3529,3549
3899,3898,3810
3898,3897,3810
3808,3897,3867
3809,3897,3808
3897,3898,4002
4054,4076,4053
4003,3898,3899
4048,3976,4002
4028,4048,4002
4054,4055,4077
4031,4053,4030
4051,4028,4029
4031,4030,4003
4052,4074,4051
3918,3954,3953
4051,4050,4028
4029,4028,4002
4075,4074,4052
4048,4071,4047
4248,4247,4219
4055,4078,4077
4030,4053,4052
3991,4005,4004
4046,4070,4045
4031,4054,4053
3975,3989,3951
4047,3989,4048
4027,4047,4046
3989,4047,3974
4027,3974,4047
4077,4076,4054
4030,4052,4029
4003,4030,4029
4052,4051,4029
3989,3975,4048
4050,4072,4049
4050,4073,4072
4070,4046,4047
4004,4031,3990
4081,4080,4056
4055,4079,4078
4056,4080,4079
3514,3499,3530
4080,4081,4096
4033,4081,4032
4033,4057,4081
3581,3582,3601
4079,4005,4056
4079,4004,4005
3992,4032,4005
4054,4031,4055
3529,3528,3514
4004,4079,4055
3513,3486,3472
4081,4005,4032
4081,4056,4005
3954,3992,4005
3953,3954,4005
3881,3882,3917
4006,3993,3994
4033,4032,3954
3992,3954,4032
3900,3954,3918
3954,3919,3955
3832,3842,3854
3870,3900,3918
4005,3991,3917
4005,3918,3953
4005,3917,3918
3882,3918,3917
3868,3899,3810
3916,3991,4004
3869,3853,3870
3841,3832,3854
3868,3881,3899
4003,3916,3990
3881,3840,3831
3868,3840,3881
3916,3899,3881
4003,3899,3916
3831,3869,3882
3881,3917,3916
3853,3869,3831
3870,3841,3854
3870,3918,3882
3831,3641,3832
3832,3641,3822
3870,3882,3869
3870,3853,3841
3881,3831,3882
3841,3853,3831
3832,3841,3831
3854,3842,3843
3883,3920,3872
3871,3920,3919
3855,3900,3870
3854,3855,3870
3855,3854,3843
3872,3920,3871
4033,3955,3993
3855,3871,3900
3955,3919,3956
4033,3954,3955
3954,3900,3919
3956,3919,3920
3529,3530,3549
3956,3993,3955
4277,4283,4278
4174,4155,4157
3920,3883,3921
3956,3920,3921
4221,4250,4220
4285,4286,4280
4283,4277,4282
4275,4274,4278
4306,4311,4312
4283,4282,4289
4274,4277,4278
4280,4281,4276
4336,4325,4342
4073,4250,4072
4282,4277,4247
4248,4282,4247
4277,4274,4247
4378,4342,4359
4378,4357,4342
4165,4071,4219
4285,4291,4292
4074,4250,4073
4071,4220,4219
4071,4221,4220
4305,4299,4298
4284,4279,4278
4292,4286,4285
4287,4281,4286
4275,4278,4279
4288,4281,4287
4314,4295,4308
4279,4285,4280
4279,4280,4276
4300,4301,4294
4284,4291,4285
4284,4285,4279
4491,4494,4492
4373,4436,4469
4374,4373,4469
4450,4470,4451
4293,4287,4286
4287,4293,4294
4326,4273,4247
4114,4069,4164
4043,4069,4068
4043,4044,4069
4114,4095,4068
4274,4246,4247
4219,4193,4164
4164,4070,4165
4165,4219,4164
4069,4070,4164
4219,4218,4193
4219,4247,4218
4163,4191,4147
4272,4245,4218
4247,4272,4218
4270,4243,4244
4268,4322,4267
4192,4245,4244
4244,4243,4192
4245,4192,4218
4192,4193,4218
4164,4193,4192
4271,4245,4272
4271,4244,4245
4270,4244,4271
4338,4247,4246
4338,4246,4274
4320,4319,4267
4324,4270,4325
4241,4267,4319
4338,4337,4326
4348,4323,4324
4336,4348,4324
4341,4239,4240
4241,4189,4217
4239,4215,4240
4374,4437,4438
4374,4438,4409
4239,4187,4215
4436,4375,4355
4271,4325,4270
4267,4241,4217
4269,4324,4323
4242,4191,4192
4242,4192,4243
4215,4216,4240
4345,4239,4341
4240,4189,4241
4240,4216,4189
4322,4323,4348
4190,4242,4217
4319,4341,4240
4319,4328,4341
4240,4241,4319
4328,4319,4348
4325,4247,4273
4325,4272,4247
4326,4325,4273
4348,4320,4322
4267,4242,4268
4242,4243,4269
4268,4242,4269
4323,4268,4269
4348,4319,4320
4325,4326,4342
4337,4342,4326
4190,4191,4242
4487,4471,4470
4217,4189,4190
4217,4242,4267
4437,4450,4438
4146,4090,4111
4189,4132,4190
4187,4112,4215
4187,4146,4112
4112,4146,4111
4190,4132,4147
4147,4133,4163
4040,4094,4093
4147,4094,4067
4147,4042,4113
4111,4090,4066
4111,4066,4112
4112,4093,4132
4112,4066,4093
2023,2038,2024
2316,2327,2328
2263,2105,2098
4214,4188,4162
4214,4162,4187
4187,4162,4146
4092,4091,4162
4146,4162,4090
4091,4090,4162
4114,4068,4069
4191,4163,4192
4164,4192,4163
4043,4000,4044
4025,3948,3972
4147,4067,4042
4147,4113,4133
4113,4114,4133
4114,4164,4163
4163,4133,4114
4113,4095,4114
4043,4095,4113
4042,4043,4113
4043,3988,4000
4043,3973,3988
4095,4043,4068
4025,3972,3973
4025,3973,4043
4042,4025,4043
3997,4066,3910
4091,4092,3910
3893,4162,3969
4066,4040,4093
4067,4041,4042
4066,3997,4040
3931,3947,3997
4042,4041,3999
3997,3986,4041
4094,4040,4041
4040,3997,4041
4094,4041,4067
4090,4091,3910
3910,4066,4090
3947,3986,3997
3948,3947,3911
4041,3947,3948
4041,3948,3999
3910,3545,3544
3911,3931,3910
3931,3997,3910
3815,3862,3910
3800,3815,3910
3911,3910,3862
3423,3800,3910
3418,3423,3910
3544,3418,3910
3910,3546,3545
3546,3910,3590
3225,3249,3289
3289,3249,3243
3289,3378,3411
3378,3289,3352
3302,3910,3315
3302,3590,3910
4016,4015,3982
3303,3302,3315
3969,3388,3893
3969,3574,3388
3302,3290,3289
3302,3289,3412
3316,3303,3315
4092,3315,3910
3302,3412,3546
3590,3302,3546
3969,3970,3574
4162,3970,3969
3401,3363,3351
3893,3315,4092
3401,3315,3893
4092,4162,3893
4473,4472,4487
4415,4362,4364
4487,4472,4471
4356,4355,4348
4373,4187,4239
4374,4450,4437
4357,4378,4377
4318,4188,4327
4214,4327,4188
4458,4475,4457
4451,4471,4452
4374,4409,4327
4440,4454,4436
4480,4479,4504
4438,4450,4451
4458,4457,4441
4487,4474,4475
4457,4415,4416
4440,4415,4457
4288,4418,4457
4281,4288,4457
4454,4457,4474
4454,4474,4469
4487,4469,4474
4487,4470,4469
4452,4472,4453
4472,4473,4453
4439,4409,4438
4482,4475,4458
4475,4474,4457
4493,4498,4499
4373,4355,4375
4239,4345,4373
4440,4436,4378
4454,4469,4436
4378,4436,4377
4214,4374,4327
4355,4341,4348
4214,4187,4374
4375,4436,4373
4374,4187,4373
4373,4345,4341
4373,4341,4355
4377,4436,4376
4376,4356,4377
4436,4355,4376
4454,4440,4457
4416,4415,4394
4415,4440,4378
4281,4416,4394
4416,4281,4457
4359,4338,4360
4359,4360,4415
4415,4364,4394
4394,4364,4276
4281,4394,4276
4342,4338,4359
4360,4338,4362
4356,4348,4357
4357,4348,4342
4356,4357,4377
4360,4362,4415
4378,4359,4415
4458,4441,4442
4457,4418,4441
4288,4441,4418
4288,4251,4249
4251,4441,4249
4251,4442,4441
4354,4488,4493
4288,4295,4251
4222,4197,4194
4170,4199,4201
4170,4201,4172
4159,4172,4173
4156,4172,4159
4139,4119,4159
4161,4144,4139
4177,4181,4161
4142,4143,4181
4224,4255,4258
4105,4122,4104
4121,4142,4141
4144,4181,4143
4104,4122,4121
4161,4139,4159
4128,4129,4144
4160,4140,4178
4143,4123,4124
4175,4204,4177
4175,4159,4173
4202,4204,4175
4141,4180,4179
4178,4140,4179
4295,4255,4253
4177,4159,4175
4177,4161,4159
4209,4234,4208
4264,4234,4235
4264,4235,4263
4140,4141,4179
4406,4405,4151
4152,4151,4405
4180,4142,4181
4206,4177,4204
4206,4181,4177
4173,4202,4175
4235,4206,4228
4305,4306,4299
4180,4181,4210
4179,4210,4178
4206,4204,4228
4173,4172,4202
4172,4201,4202
4263,4235,4228
4204,4202,4227
4201,4199,4224
4227,4228,4204
4201,4227,4202
4201,4224,4227
4311,4315,4312
4224,4258,4259
4224,4259,4227
4299,4306,4300
4223,4199,4222
4197,4222,4199
4224,4199,4223
4222,4255,4223
4224,4223,4255
4293,4286,4292
4291,4298,4292
4304,4305,4298
4442,4251,4253
4442,4253,4255
4294,4301,4295
4259,4258,4314
4314,4261,4259
4311,4310,4315
4305,4311,4306
4262,4226,4229
4295,4258,4255
4258,4295,4314
4283,4289,4290
4305,4310,4311
4315,4313,4312
4298,4299,4292
4316,4313,4315
4316,4261,4314
4290,4291,4284
4257,4256,4195
4312,4307,4306
4227,4259,4261
4227,4261,4263
4227,4263,4228
4292,4299,4293
4289,4302,4296
4299,4300,4293
4316,4314,4313
4306,4307,4300
4307,4301,4300
4308,4301,4307
4314,4308,4313
4307,4313,4308
4301,4308,4295
4294,4295,4288
4297,4304,4298
4260,4262,4309
3703,3702,3708
4287,4294,4288
4256,4257,4302
4058,4085,4082
4033,4196,4195
4057,4033,4195
4007,4006,3994
3994,3993,3956
3921,3994,3956
3957,3977,3921
4310,4304,4309
4283,4290,4284
4260,4302,4257
4304,4303,4309
4195,4260,4257
4315,4310,4309
4291,4290,4297
4282,4302,4289
4290,4289,4296
4310,4305,4304
4291,4297,4298
4302,4254,4256
4302,4252,4254
4302,4250,4252
4282,4250,4302
4290,4296,4297
4297,4296,4303
4296,4302,4303
4304,4297,4303
4309,4303,4302
4195,4077,4078
3714,3721,3715
3736,3744,3737
4203,4171,4155
4195,4078,4079
4195,4079,4096
4256,4254,4195
4081,4195,4096
4057,4195,4081
4195,4254,4252
4076,4195,4075
4074,4075,4195
4074,4195,4250
4195,4252,4250
4077,4195,4076
4196,4225,4195
4260,4195,4225
4198,4225,4196
4198,4200,4225
4260,4225,4262
4120,4140,4118
4176,4174,4157
4007,4198,4196
4033,4007,4196
4006,4007,4033
3993,4006,4033
3977,3994,3921
4100,4103,4120
4238,4213,4237
4155,4008,4009
4155,4007,4008
4100,4120,4118
4200,4007,4155
4200,4155,4171
4405,4571,4392
3995,3996,4010
4160,4136,4138
3682,3679,3678
4138,4115,4118
4155,4009,4010
3737,3730,3729
4136,4115,4138
3723,3715,3722
3729,3720,3728
4140,4160,4138
4140,4138,4118
4229,4230,4264
3731,3730,3738
4160,4158,4136
3762,3663,3757
4136,4157,4115
4157,4155,4115
4210,4209,4178
4160,4176,4158
3737,3738,3730
4264,4232,4233
3737,3729,3736
3729,3728,3736
4264,4262,4229
4200,4171,4203
4178,4207,4160
4207,4176,4160
4226,4262,4225
4235,4234,4209
4209,4210,4235
4264,4231,4232
4316,4264,4263
4229,4205,4176
4229,4226,4205
4205,4174,4176
4174,4203,4155
4226,4225,4203
4226,4203,4205
4174,4205,4203
4207,4230,4229
4178,4208,4207
4264,4230,4231
4207,4229,4176
4233,4207,4208
4408,4407,4151
4233,4232,4207
4232,4231,4207
4207,4231,4230
4264,4233,4234
4126,4144,4125
4063,4089,4065
4106,4065,4107
4085,4103,4100
4122,4143,4142
4122,4142,4121
4089,4107,4065
4123,4143,4122
4130,4064,4119
4101,4119,4064
3749,3750,3742
4100,4118,4115
4082,4100,4115
4121,4120,4103
4038,4061,4064
3926,3927,3943
4061,4086,4064
4062,4037,4013
3978,4058,4082
3957,3901,3977
4037,4085,4058
4062,4085,4037
4065,4088,4062
3846,3960,3856
4008,3995,4009
4007,3995,4008
3977,3995,4007
3996,4082,4115
3996,4155,4010
3996,4115,4155
3648,3676,3647
3978,4082,3996
3958,4037,4058
3978,3958,4058
3957,3921,3901
3995,3977,3901
3935,3995,3901
3935,3978,3996
3676,3685,3686
3935,3996,3995
3562,3579,3561
3935,3936,3978
3958,3978,3936
3666,3667,3759
3922,3884,3980
4015,4014,3982
3906,3930,3929
3961,3983,3960
4013,4037,3980
3936,3980,4037
3922,3980,3936
3938,3963,3962
3960,3983,3982
3938,3961,3960
3962,3983,3961
3982,4013,3980
4014,4013,3982
3960,3980,3856
4143,4124,4125
3982,3983,4017
4017,3983,4018
3982,4017,4016
4064,4130,4063
3982,3980,3960
3938,3924,3939
3924,3940,3939
3938,3939,3963
3943,3927,3928
3961,3938,3962
3968,3981,3985
3964,3940,3965
3904,3927,3903
3963,3939,3964
3942,3966,3941
3924,3925,3941
3941,3925,3942
3965,3940,3941
3928,3929,3968
4139,4144,4130
3967,3968,3985
3964,3939,3940
3963,3984,3983
3967,3985,3966
3985,4039,4019
4018,3983,4019
3962,3963,3983
3984,3985,4019
4019,3983,3984
3985,3984,3965
3964,3984,3963
3964,3965,3984
3968,3967,3943
3966,3965,3941
4020,3642,4182
3968,3943,3928
3903,3927,3926
3926,3925,3903
3903,3925,3924
3885,3905,3904
3568,3588,3569
3568,3567,3588
3886,3907,3906
3886,3887,3907
3887,3908,3907
3930,3908,3909
3904,3928,3927
3905,3928,3904
3906,3907,3930
3985,4012,4039
4139,4130,4119
4116,4099,4102
4143,4125,4144
4130,4107,4063
4129,4106,4107
4129,4128,4106
4126,4127,4144
4127,4128,4144
4144,4129,4130
4065,4103,4088
4065,4104,4103
4063,4065,4039
4065,4105,4104
4086,4101,4064
4123,4065,4124
4062,4013,4065
4408,4340,4266
4108,4184,4185
4014,4065,4013
4015,4065,4014
4016,4065,4015
4016,4017,4065
4019,4065,4018
4039,4065,4019
4128,4065,4106
4124,4065,4125
4125,4065,4126
4126,4065,4127
4063,4107,4089
4128,4127,4065
4018,4065,4017
4065,4123,4122
4105,4065,4122
4012,4064,4039
4038,4064,4012
3924,3938,3835
3886,3873,3887
3909,3888,3889
3908,3888,3909
3799,3792,3848
3858,3859,3878
3889,3874,3875
3890,3875,3876
3814,3826,3813
3889,3875,3890
3873,3888,3887
3904,3903,3885
3906,3905,3885
3886,3906,3885
3888,3874,3889
3825,3873,3885
3826,3873,3825
3873,3826,3874
3826,3812,3813
3859,3860,3878
3824,3811,3825
3860,3891,3878
3860,3923,3891
3811,3812,3826
3811,3824,3823
3960,3835,3938
3846,3835,3960
3835,3885,3903
3835,3825,3885
3824,3825,3835
3823,3824,3835
3834,3835,3846
3780,3766,3781
2869,2923,2914
2882,2923,2869
2937,2852,2930
2931,2852,2937
2635,2647,2722
2672,2635,2722
2550,2596,2538
2715,2728,2722
2930,2852,2923
3085,3289,3290
2772,3017,3046
2846,2772,3046
2557,2596,2635
2673,2605,2682
2765,2772,2621
2772,2736,2715
2709,2682,2715
2682,2605,2715
2621,2715,2605
2528,2566,2538
2577,2550,2566
2538,2566,2550
2230,2220,2229
2557,2292,2272
2488,2557,2272
2620,2673,2682
2557,2528,2596
2772,2821,2809
2736,2772,2735
2727,2799,2734
2727,2763,2799
2715,2735,2728
2821,2780,2809
2735,2715,2736
2754,2735,2764
2105,1982,2098
2097,2106,2107
2096,2106,2097
2672,2557,2635
2596,2528,2538
2620,2722,2647
2596,2550,2604
2557,2520,2528
2557,2509,2520
2557,2537,2509
2635,2620,2647
2620,2635,2604
2620,2682,2709
2735,2772,2809
2854,2821,2772
2854,2772,2846
2923,2852,2914
2846,2882,2854
2854,2882,2869
2882,2846,3046
3085,3290,3302
3103,3115,3064
2882,3047,2915
3173,3064,3115
3173,3195,3064
3195,3225,3085
3195,3085,3064
2937,2975,2987
2882,2930,2923
2915,3047,2937
2937,3047,2975
2937,2882,2915
2937,2930,2882
2845,2852,2819
2987,3064,3085
3103,3064,2987
3086,2975,3047
2987,2975,3086
3103,2987,3086
3302,3153,3150
3157,3302,3303
2852,2845,2780
2852,2780,2821
2734,2799,2740
2799,2747,2740
2721,2763,2727
2860,2838,2865
2852,2821,2854
2914,2854,2869
2852,2854,2914
2809,2780,2735
2754,2728,2735
2771,2764,2735
2820,2780,2829
2780,2839,2829
2845,2839,2780
2065,2077,2078
2087,2077,2022
2087,2088,2078
1716,1652,1608
2222,2221,2231
2105,2263,2219
2065,2078,2097
2229,2219,2263
2038,2051,2039
2039,2051,2052
2039,2024,2038
2414,2415,2401
2229,2220,2219
2414,2413,2423
2316,2315,2327
2244,2245,2230
2219,2120,2105
2120,2219,2220
2327,2340,2328
1936,1924,1882
2105,2120,2115
2052,2065,2097
2233,2232,2247
2247,2232,2246
2257,2314,2302
2262,2249,2261
2249,2248,2261
2261,2248,2260
2248,2247,2260
2120,2176,2168
2207,2377,2442
2207,2442,2432
2191,2271,2291
2191,2291,2207
2207,2291,2342
2223,2222,2232
2259,2247,2246
2244,2229,2263
2229,2244,2230
2260,2268,2269
2279,2269,2278
2354,2365,2366
2303,2314,2315
2268,2267,2277
2278,2268,2277
2259,2246,2258
2257,2258,2245
2223,2232,2233
2233,2249,2223
2260,2247,2259
2246,2231,2245
2230,2245,2231
2279,2280,2270
2302,2289,2288
2315,2314,2327
2352,2341,2340
2374,2399,2387
2374,2387,2375
2354,2353,2364
2270,2262,2261
2314,2352,2340
2415,2423,2424
2302,2314,2303
2424,2423,2430
2290,2289,2303
2365,2376,2366
2415,2414,2423
2354,2342,2353
2423,2413,2430
2218,2207,2432
2388,2400,2389
2314,2257,2272
2292,2314,2272
2462,2450,2461
2461,2449,2448
2499,2430,2481
2207,2366,2377
2374,2413,2399
2505,2497,2496
2505,2506,2498
2707,2701,2708
2377,2366,2376
2444,2449,2450
2374,2364,2363
2376,2375,2387
2479,2485,2486
2486,2480,2479
2431,2424,2430
2354,2364,2365
2497,2486,2496
2485,2431,2496
2120,2191,2182
2208,2191,2120
2388,2399,2400
2431,2430,2499
2399,2413,2400
2478,2471,2461
2479,2472,2471
2461,2450,2449
2432,2442,2443
2471,2462,2461
2443,2449,2444
2443,2448,2449
2442,2448,2443
2388,2376,2387
2353,2342,2341
2471,2472,2462
2389,2377,2388
2442,2401,2415
2496,2486,2485
2478,2431,2485
2526,2496,2535
2478,2448,2431
2290,2303,2304
2316,2304,2315
2376,2365,2375
2278,2288,2289
2278,2277,2288
2314,2363,2352
2365,2364,2375
2302,2288,2257
2280,2279,2290
2290,2279,2289
2291,2280,2290
2288,2277,2257
2182,2176,2120
2303,2289,2302
2270,2269,2279
2271,2262,2270
2291,2304,2316
2304,2291,2290
2342,2316,2328
2342,2291,2316
2353,2363,2364
2327,2314,2340
2442,2389,2401
2377,2389,2442
2363,2314,2374
2314,2292,2557
2374,2314,2557
2374,2672,2413
2557,2672,2374
2353,2352,2363
2342,2328,2341
2526,2517,2496
3313,3300,3323
2497,2487,2486
2857,2853,2838
2505,2496,2517
2386,2470,2477
2429,2386,2477
2701,2646,2587
2497,2498,2487
2646,2701,2662
2549,2481,2430
2413,2549,2430
2535,2496,2548
2499,2481,2549
2549,2565,2499
2565,2549,2722
2413,2722,2549
2413,2672,2722
2576,2565,2701
2701,2671,2662
2499,2565,2576
2987,3147,3130
2987,3150,3147
2799,2764,2771
2799,2763,2764
2763,2754,2764
2728,2754,2763
2728,2763,2722
2808,2820,2819
2762,2753,2799
2799,2753,2747
2799,2820,2808
2799,2780,2820
2799,2771,2780
2912,2913,2922
3005,3045,3030
3043,3079,3052
3044,3079,3043
2852,2913,2871
2987,3016,2945
3302,3150,3085
2944,3016,3005
2944,3005,3000
2713,2707,2708
2857,2838,2860
2912,2944,2952
2868,2838,2871
3097,3130,3147
3097,3147,3100
2922,2929,2912
2912,2868,2913
2906,2913,2868
3109,3147,3114
3114,3147,3124
2865,2897,2912
2851,2844,2819
2819,2844,2808
2753,2762,2844
2853,2851,2819
2838,2853,2819
2860,2865,2861
3063,3079,3056
2868,2865,2838
2868,2897,2865
2943,2951,2896
2645,2646,2661
3053,3079,3045
3105,3147,3109
2912,2936,2944
2496,2431,2548
2734,2740,2707
2726,2707,2740
2526,2518,2517
2618,2633,2587
2633,2564,2575
2695,2671,2701
2740,2747,2844
2740,2844,2726
2747,2753,2844
2727,2734,2707
2727,2707,2721
2713,2721,2707
2633,2535,2548
2633,2536,2535
2477,2498,2506
2505,2517,2506
2535,2527,2526
2526,2527,2518
2518,2507,2506
2486,2487,2480
2556,2499,2564
2564,2499,2575
2499,2587,2575
2701,2587,2576
2499,2576,2587
2634,2587,2646
3124,3147,3129
3177,3166,3149
3177,3149,3147
3102,3099,3147
3100,3147,3099
3258,3259,3247
4571,4561,4560
3247,3177,3147
3035,3039,3038
3267,3268,3259
4556,4561,4550
2951,2912,2958
2875,2896,2864
3055,3052,3079
2828,2844,2837
2587,2633,2575
2726,2720,2707
2670,2662,2671
2564,2633,2556
2633,2634,2645
2661,2646,2662
2645,2634,2646
2661,2662,2670
2633,2618,2634
2670,2671,2695
2706,2707,2712
2633,2527,2536
2518,2633,2519
2518,2527,2633
2447,2477,2470
2516,2633,2477
2477,2447,2498
2447,2487,2498
2447,2480,2487
2472,2447,2462
2450,2462,2447
2480,2447,2472
2036,2107,2103
2097,2107,2036
1937,1938,1926
2036,2103,2076
1913,1953,1927
2103,2107,2114
2158,2074,2149
2149,2114,2158
2120,2168,2114
2386,2218,2412
2114,2107,2120
2076,2103,2035
2168,2158,2114
2207,2187,2191
2191,2262,2271
2191,2249,2262
2223,2191,2208
2223,2249,2191
2191,2074,2182
1962,2003,1992
2182,2074,2176
2850,2748,2714
2850,2810,2748
3056,3079,3053
3063,3130,3097
3030,3045,3035
3045,3044,3039
3035,3045,3039
3045,3079,3044
3016,3063,3056
3016,3045,3005
3016,3056,3053
3045,3016,3053
3278,3277,3286
3063,3016,3130
3016,2987,3130
2819,2820,2829
2945,3016,2936
2936,2929,2852
2852,2929,2922
2945,2937,2987
2897,2868,2912
2713,2763,2721
2852,2922,2913
2945,2936,2931
2906,2871,2913
2944,2936,3016
2906,2868,2871
2912,2929,2936
2945,2931,2937
2839,2845,2819
2829,2839,2819
2708,2763,2713
2701,2763,2708
2692,2565,2722
2701,2565,2692
2701,2722,2763
2701,2692,2722
3001,2877,2883
3151,3154,3002
3345,3324,3337
3849,3860,3848
3909,3889,3890
3847,3848,3860
3909,3890,3891
3345,3319,3324
3612,3844,3559
3769,3768,3673
3468,3443,3453
3345,3353,3211
3353,3365,3211
4433,4434,3576
3306,3380,3319
3319,3345,3211
3211,3381,3232
3365,3381,3211
3675,3674,3643
4145,4186,3937
3767,3781,3766
3770,3674,3675
3790,3791,3799
3781,3792,3780
3790,3799,3814
3799,3791,3792
3836,3792,3781
3836,3848,3792
3792,3791,3780
3769,3674,3770
3768,3837,3767
3643,3674,3673
3767,3837,3781
3827,3675,3643
3673,3767,3766
3827,3770,3675
3827,3837,3770
3769,3673,3674
3673,3768,3767
3768,3769,3837
3814,3799,3847
3857,3814,3847
3849,3836,3837
3836,3849,3848
3859,3847,3860
4183,4212,4184
3799,3848,3847
3891,3876,3877
3874,3814,3857
3923,3849,3902
3923,3860,3849
3477,3479,3464
3876,3857,3877
3858,3857,3847
3891,3877,3878
4024,3945,3944
3875,3857,3876
3857,3875,3874
3857,3878,3877
3857,3858,3878
3858,3847,3859
4012,3981,4038
3891,3923,3937
4038,4034,4061
4102,4059,4060
3981,4011,4038
4036,4035,4011
4059,4084,4061
4087,4102,4060
4083,4061,4084
4102,4084,4059
4034,4060,4059
4212,4211,4236
3937,3959,3891
3985,3981,4012
3968,3909,3981
3968,3930,3909
3909,3959,3981
3979,4011,3981
3959,3979,3981
4035,4087,4060
4035,4034,4011
4087,4035,4036
3353,3559,3365
4393,4408,4154
3612,3559,3577
4560,4561,4555
4560,4555,4542
4153,4148,4170
4134,4116,4135
4168,4405,4167
4151,4150,4154
4135,4154,4150
4102,4131,4117
4084,4102,4099
4086,4098,4097
4098,4086,4083
4116,4119,4101
4119,4116,4134
4116,4137,4135
4116,4117,4137
4156,4134,4135
4117,4116,4102
4084,4099,4083
4119,4134,4159
4116,4098,4099
4098,4116,4097
4134,4156,4159
4086,4116,4101
4086,4097,4116
4156,4135,4153
4149,4135,4150
4172,4153,4170
4172,4156,4153
4149,4148,4153
4153,4135,4149
4151,4169,4150
4168,4169,4151
4194,4167,4166
4199,4169,4168
4170,4169,4199
4169,4170,4148
4148,4149,4169
4199,4194,4197
4199,4167,4194
4347,3987,4346
4494,4483,4495
4379,4410,4411
4380,4351,4350
4456,4412,4411
4503,4502,4514
4346,3987,3971
4461,4483,4166
4483,4194,4166
4571,4560,4570
4530,4531,4519
4456,4480,4481
4516,4515,4529
4500,4501,4476
4497,4498,4493
4354,4455,4346
4347,4346,4455
4493,4500,4476
4483,4499,4498
4483,4498,4497
4489,4488,4487
4483,4497,4496
4538,4532,4531
4490,4491,4488
4354,4439,4453
4496,4497,4493
4488,4453,4473
4494,4491,4490
4488,4473,4487
4482,4489,4475
4489,4487,4475
4491,4492,4488
4493,4488,4492
4533,4521,4532
4480,4504,4505
4516,4529,4517
4494,4489,4482
4494,4490,4489
4493,4492,4494
4222,4483,4460
4194,4483,4222
4460,4458,4442
4482,4458,4460
4495,4496,4493
4495,4483,4496
4493,4494,4495
4483,4494,4460
4482,4460,4494
4477,4455,4476
4354,4346,4439
4346,4327,4409
4346,4409,4439
4346,3971,4327
4327,3971,4318
3971,4188,4318
4162,3971,3970
4188,3971,4162
3313,3998,3314
4347,3998,3987
3248,3157,3303
3987,3998,3313
3401,3377,3363
3893,3377,3401
3893,3388,3377
3363,3331,3351
3574,3970,3971
3303,3351,3323
3388,3574,3377
3331,3363,3574
3377,3574,3363
3971,3575,3574
3971,3331,3575
3316,3351,3303
3303,3323,3288
3313,3301,3300
3286,3285,3300
3301,3287,3286
3285,3248,3288
3267,3277,3278
3267,3266,3277
3267,3259,3258
3286,3287,3278
3266,3267,3258
3279,3268,3278
3268,3267,3278
3266,3153,3157
3266,3285,3277
3287,3279,3278
3285,3157,3248
3266,3258,3150
3266,3150,3153
3323,3300,3285
3323,3285,3288
3313,3323,3351
3331,3313,3351
3279,3287,3314
3287,3301,3314
3314,3301,3313
3575,3331,3574
4335,3314,4321
4331,4332,3998
4476,4455,4493
4354,4493,4455
4412,4380,4379
4332,4331,4350
4330,4331,3998
4329,4330,3998
3314,4334,4321
3314,3998,4334
3247,3166,3177
4396,4421,4383
4352,4335,4334
4332,4333,3998
4335,4321,4334
4522,4536,4537
4379,4380,4350
4351,4334,4333
4331,4330,4350
4521,4509,4520
4503,4515,4504
4410,4379,4349
4333,4332,4351
4351,4332,4350
4531,4532,4520
4414,4352,4334
4417,4352,4414
4414,4334,4351
4518,4519,4507
4507,4519,4508
4329,3998,4358
4456,4414,4413
4456,4481,4414
4509,4508,4520
2644,2632,2640
4515,4514,4529
4419,4443,4395
4509,4481,4508
4525,4526,4512
4414,4481,4509
4398,4397,4422
4554,4559,4564
4518,4507,4506
4366,4384,4367
4522,4509,4521
4456,4413,4412
4481,4507,4508
4481,4506,4507
4479,4503,4504
4518,4506,4517
4479,4478,4503
4410,4456,4411
4505,4516,4517
4329,4349,4330
4530,4519,4518
4538,4530,4529
4529,4530,4518
4517,4529,4518
4347,4358,3998
4540,4541,4526
4478,4456,4477
4479,4480,4456
4478,4502,4503
4513,4529,4514
4477,4476,4501
4483,4529,4499
4493,4499,4529
4493,4529,4513
4501,4500,4513
4477,4501,4502
4501,4513,4502
4502,4513,4514
4478,4477,4502
4503,4514,4515
4358,4349,4329
4349,4379,4350
4358,4456,4410
4358,4455,4456
4347,4455,4358
4358,4410,4349
4330,4349,4350
4379,4411,4412
4464,4463,4511
4381,4419,4395
3379,3380,3119
4528,4426,4542
4340,4393,4353
3118,3119,3101
3049,3009,3008
4542,4555,4528
3279,3314,4365
3279,4365,4366
4390,4402,4391
4384,4383,4397
4361,4417,4459
4361,4459,4419
4510,4445,4484
4449,4485,4402
4465,4424,4448
3279,4368,4369
4387,4401,4388
4400,4387,4386
4369,4388,3279
4401,4402,4388
4384,4398,4385
4388,4389,3279
4463,4510,4511
4465,4464,4512
4400,4401,4387
4539,4525,4524
4368,4386,4369
4368,4385,4386
4464,4465,4448
4365,4383,4366
4420,4443,4462
4369,4386,4387
4448,4463,4464
4510,4523,4511
4387,4388,4369
4484,4552,4539
4547,4552,4484
4385,4399,4386
4512,4524,4525
4524,4511,4523
4444,4462,4484
4396,4383,4365
3279,4366,4367
3062,3051,3078
4464,4511,4512
4368,4367,4385
4384,4385,4367
4421,4484,4397
4386,4399,4400
4424,4400,4423
4424,4423,4447
4424,4447,4448
3007,3037,2983
4423,4400,4399
4448,4447,4463
4446,4463,4447
4551,4552,4547
4512,4511,4524
4540,4525,4539
4566,4540,4539
4566,4539,4557
4551,4557,4552
4557,4539,4552
4539,4524,4523
4523,4510,4484
4422,4397,4484
4422,4484,4445
4396,4444,4421
4459,4462,4443
4547,4537,4551
4547,4484,4537
4484,4539,4523
4384,4397,4398
4366,4383,4384
4421,4444,4484
4382,4420,4396
4396,4420,4444
4382,4395,4420
4414,4459,4417
4363,4361,4381
4537,4484,4459
4459,4484,4462
4459,4414,4537
4569,4570,4568
4534,4546,4535
4546,4536,4535
4546,4537,4536
4537,4546,4551
4533,4546,4534
4532,4546,4533
4532,4538,4546
4568,4570,4564
4538,4529,4546
4420,4395,4443
4352,4417,4361
4459,4443,4419
4361,4419,4381
4382,4363,4395
4363,4382,4365
4363,3314,4361
4361,3314,4335
4361,4335,4352
4465,4512,4526
3123,3143,3095
3123,3095,3114
3109,3114,3095
3102,3105,3095
3124,3123,3114
3143,3124,3129
3149,3145,3143
3149,3143,3129
3099,3102,3095
3090,3095,3089
3090,3089,3084
4568,4564,4567
4567,4564,4563
3096,3099,3095
4540,4526,4525
3247,3149,3166
3035,3038,3034
3039,3044,3043
4567,4563,4566
3030,3034,3029
3039,3043,3038
3084,3089,3055
3030,3035,3034
3084,3055,3079
2991,3024,3007
3000,3024,2952
2912,2952,3024
2958,2981,2978
2958,2986,2981
2951,2958,2896
2912,2951,2943
2958,2991,3007
2986,2958,3007
4388,4402,4389
4558,4562,4559
3051,3077,3083
2986,2983,2981
2986,3007,2983
2969,2958,2974
2853,2837,2851
2837,2844,2851
2818,2844,2828
2896,2958,2969
2860,2861,2837
2857,2837,2853
2860,2837,2857
2864,2896,2837
2720,2844,2788
2788,2844,2796
2720,2788,2712
2712,2788,2706
2779,2778,2789
2668,2658,2657
2806,2844,2818
2796,2844,2806
2788,2796,2789
2790,2797,2798
2789,2797,2790
2668,2661,2670
2668,2778,2681
2779,2789,2790
2669,2659,2658
2668,2681,2669
2733,2691,2681
2889,2943,2896
2875,2865,2889
2875,2864,2865
2875,2889,2896
2943,2889,2912
2865,2912,2889
4370,4427,4428
4549,4556,4550
3008,2968,2999
3015,3008,2999
4555,4561,4556
2803,2793,2792
2777,2776,2786
2776,2777,2769
2768,2776,2769
2590,2636,2598
2752,2688,2687
2677,2663,2684
2653,2652,2663
2760,2761,2752
2814,2802,2813
2802,2803,2792
2775,2768,2760
2760,2733,2746
2805,2794,2804
2706,2788,2668
2786,2776,2785
2791,2746,2801
2615,2504,2515
2615,2594,2504
2788,2778,2668
2826,2817,2816
2904,2909,2910
2784,2775,2760
2733,2760,2691
2760,2752,2691
2599,2611,2612
2666,2667,2656
2777,2786,2787
2791,2792,2784
2804,2794,2793
2775,2785,2776
2815,2804,2803
2816,2817,2805
2752,2761,2725
2760,2768,2761
2827,2795,2817
2769,2761,2768
2908,2909,2903
2714,2725,2770
2761,2769,2725
2827,2817,2826
2770,2795,2714
2792,2793,2785
2801,2802,2791
2791,2784,2760
2791,2760,2746
2787,2725,2777
2805,2804,2816
3004,2967,2998
2787,2795,2725
2770,2725,2795
2777,2725,2769
2768,2775,2776
2998,2967,2995
2795,2794,2805
2787,2786,2794
2794,2786,2793
2793,2786,2785
2787,2794,2795
2817,2795,2805
2843,2850,2795
2804,2793,2803
2785,2775,2784
2802,2814,2803
2803,2814,2815
2802,2792,2791
2706,2668,2670
2863,2867,2850
2887,2880,2879
2836,2843,2795
2881,2967,2950
2826,2816,2825
2827,2836,2795
2900,2905,2867
2795,2850,2714
2825,2816,2815
2849,2835,2779
2908,2903,2898
2813,2802,2801
2824,2813,2801
2968,3008,2855
2934,2941,2935
2843,2874,2850
2895,2900,2867
2859,2790,2798
2859,2849,2779
2859,2779,2790
2859,2806,2818
2807,2806,2859
2859,2818,2828
2859,2828,2837
2859,2797,2807
2798,2797,2859
2824,2801,2835
2779,2835,2801
2859,2874,2849
2909,2919,2920
2911,2964,2967
2911,2967,2881
2874,2879,2880
2887,2888,2880
2933,2940,2934
4370,4428,4429
2911,2957,2964
2926,2927,2920
2933,2926,2963
2900,2895,2899
2934,2927,2933
3038,3043,3041
2909,2920,2910
2926,2920,2919
2963,2837,2896
2963,2908,2837
2919,2963,2926
2879,2908,2887
2894,2888,2893
2933,2927,2926
2895,2894,2899
2874,2859,2879
2826,2825,2874
2825,2815,2874
2927,2921,2920
2940,2941,2934
2827,2826,2874
2815,2814,2874
2813,2874,2814
2836,2827,2874
2843,2836,2874
1938,1949,1994
2941,2942,2935
2905,2900,2904
2898,2899,2894
2824,2874,2813
2835,2874,2824
2904,2900,2899
2837,2879,2859
2928,2911,2921
2893,2908,2898
2887,2908,2893
2893,2898,2894
2949,2957,2911
3051,3023,2998
3051,2998,3041
2921,2911,2910
2942,2949,2911
4571,4570,4569
2910,2920,2921
2911,2905,2910
2935,2942,2911
2863,2895,2867
2863,2850,2895
2874,2895,2850
2880,2895,2874
2888,2895,2880
2905,2904,2910
2898,2903,2899
2927,2928,2921
2903,2904,2899
2903,2909,2904
3037,2998,2995
2995,2964,2957
2983,2995,2981
2978,2981,2995
2995,2896,2969
2969,2974,2995
2974,2978,2995
2896,2995,2963
2933,2995,2940
2933,2963,2995
2995,2967,2964
3062,3078,3074
3089,3083,3077
2995,2957,2949
2995,2949,2942
2995,2942,2941
2995,2941,2940
3051,3042,3023
4528,4543,4426
2950,3004,2968
2950,2967,3004
3015,2999,3004
3023,3004,2998
2968,3004,2999
3023,3042,3015
3015,3004,3023
3051,3073,3077
3034,3038,3037
3029,3034,3037
3029,3037,3024
3037,3007,3024
3038,3041,3037
3041,2998,3037
3052,3055,3073
3089,3073,3055
3043,3052,3073
3041,3043,3073
3088,3051,3083
3088,3078,3051
3089,3088,3083
3095,3088,3089
3088,3145,3149
3143,3145,3088
3095,3143,3088
3247,3088,3149
3247,3259,3088
3259,3268,3088
3279,3240,3088
3268,3279,3088
3118,3088,3167
3101,3074,3088
3101,3088,3118
4569,4567,4566
4402,4424,4449
4449,4424,4465
4566,4562,4540
4541,4553,4526
4558,4541,4562
4563,4559,4562
4566,4563,4562
4566,4557,4551
4569,4568,4567
4569,4566,4571
4529,4571,4546
4571,4483,4461
4529,4483,4571
4571,4461,4166
4168,4152,4405
4560,4565,4570
4467,4432,4431
3026,3015,3049
4485,4425,4402
4390,4391,3279
4389,4390,3279
4390,4389,4402
4403,4426,4370
4485,4465,4554
4526,4554,4465
4526,4553,4554
4527,4485,4554
4558,4554,4553
4558,4559,4554
4565,4527,4564
4542,4527,4565
4542,4425,4466
4542,4466,4527
4544,4545,4467
4434,4435,3576
3593,3576,4435
4391,4403,4370
4426,4403,4425
4555,4556,4548
4549,4543,4548
4468,4467,4545
4548,4556,4549
4433,4370,4432
4370,4430,4431
4548,4528,4555
4528,4548,4543
4427,4467,4428
4468,4545,4486
4431,4430,4467
4467,4430,4429
4467,4429,4428
4435,4468,4486
4435,4434,4468
4434,4433,4468
4432,4467,4468
3049,3042,3074
4543,4544,4467
4549,4544,4543
4549,4550,4544
4544,4550,4545
3074,3101,3058
3119,3087,3101
3101,3087,3058
3119,3380,3087
3380,3058,3087
4371,4571,4166
4405,4561,4571
4135,4137,4393
3058,3049,3074
3049,3015,3042
4371,4392,4571
4486,4545,4435
3576,4370,4433
3380,3049,3058
3380,3306,3049
4024,4109,3946
4392,4166,4167
4371,4166,4392
4393,4137,4343
4404,4561,4405
4154,4408,4151
4407,4406,4151
4408,4393,4340
4344,4340,4353
3009,3049,3019
2984,2979,3009
2970,2876,2959
3049,3008,3026
3015,3026,3008
3167,3425,3118
3119,3118,3425
3611,3642,3612
3012,3049,3020
3012,3019,3049
3019,3012,2984
3009,3019,2984
3828,3892,4110
3319,3559,3324
4435,3611,3593
3611,3594,3593
3612,3577,3594
4370,3576,3279
3577,3380,3379
3577,3457,3380
3425,3088,3240
3425,3167,3088
3576,3240,3279
3576,3425,3240
3577,3379,3119
3576,3119,3425
3576,3577,3119
3594,3577,3593
3577,3576,3593
3611,4435,3642
4372,3642,4435
3457,3559,3380
3611,3612,3594
3345,3559,3353
3365,3559,3381
3337,3324,3559
3559,3457,3577
3850,3861,3381
3345,3337,3559
4131,4317,4339
3833,3850,3381
3861,3232,3381
4108,4182,4183
3845,3559,3844
3381,3845,3833
3381,3559,3845
3850,3833,3845
3850,3845,3892
4022,4023,3944
3845,3844,3944
3892,3845,3946
3845,3944,3945
4022,4021,4108
4023,4024,3944
4020,4021,3944
4108,4021,4020
4237,4212,4236
3945,4024,3946
4145,3946,4186
4110,3946,4145
3946,3845,3945
3923,3902,4145
4108,4023,4022
3612,3642,4020
3612,4020,3944
4213,4212,4237
4186,4109,4108
3612,3944,3844
4109,4024,4023
3837,4110,3849
3837,3827,4110
3923,4145,3937
3937,4186,4238
4185,4238,4186
4109,4023,4108
4186,3946,4109
4185,4184,4213
4185,4186,4108
3849,4145,3902
4110,4145,3849
4182,3642,4372
4238,4237,4266
3979,4266,4011
3959,3937,4238
3959,4238,4266
3959,4266,3979
4266,4265,4011
4036,4011,4265
4087,4036,4265
4340,4265,4266
3306,3020,3049
4344,4353,4393
4131,4339,4117
4117,4339,4137
4137,4339,4343
4339,4393,4343
4339,4344,4393
4265,4340,4317
4317,4344,4339
4340,4344,4317
4317,4131,4102
4087,4317,4102
4087,4265,4317
2959,3009,2970
3020,2984,3012
2938,3009,2959
2938,2959,2876
2984,2890,2883
2984,2883,2876
2979,2984,2876
2876,2883,2877
2674,2696,2831
2675,2674,2758
2831,2758,2674
2830,2938,2711
2830,2855,2938
3009,2855,3008
2855,3009,2938
2968,2855,2950
2881,2950,2855
2855,2867,2881
2830,2810,2855
2850,2867,2810
2867,2855,2810
2711,2876,2831
2711,2938,2876
2748,2810,2711
2810,2830,2711
2748,2710,2714
2508,2644,2660
2710,2748,2711
2714,2619,2725
2201,2404,2284
2711,2696,2674
2417,2403,2510
2567,2622,2568
2606,2568,2622
2674,2606,2622
2510,2521,2417
2567,2529,2508
2473,2393,2417
2403,2417,2345
2417,2393,2345
2345,2392,2403
2674,2675,2606
2606,2675,2531
2044,1919,2059
2100,2089,2274
2131,2080,2070
2055,2054,2108
2139,2392,2345
2108,2274,2055
2016,2108,2054
2332,2139,2345
2332,2141,2139
2307,2141,2321
2283,2141,2294
2294,2141,2307
2108,2016,2139
2129,2139,2016
2321,2141,2332
2108,2139,2141
2108,2141,2283
2274,2108,2283
2338,2287,2276
2293,2129,2281
2129,2329,2343
2129,2343,2139
2343,2329,2339
2129,2305,2317
2403,2392,2139
2343,2403,2139
2129,2317,2329
2343,2339,2351
2521,2434,2529
2508,2529,2434
2434,2510,2403
2622,2567,2508
2425,2434,2343
2679,2666,2665
2591,2592,2584
2710,2674,2714
2619,2714,2674
2508,2514,2632
2572,2583,2573
2514,2614,2628
2600,2601,2593
2652,2653,2637
2619,2674,2622
2627,2628,2614
2654,2664,2665
2521,2510,2434
2187,2163,2191
2236,2218,2373
2397,2396,2410
2325,2335,2336
2254,2381,2368
2369,2368,2381
2368,2358,2324
2600,2612,2613
2477,2515,2504
2595,2602,2603
2207,2218,2236
2207,2236,2187
2147,2137,2119
2337,2199,2206
2217,2199,2337
2174,2085,2164
2324,2286,2238
2156,2166,2157
2396,2383,2382
2372,2384,2398
2128,2137,2138
2165,2085,2174
2324,2299,2286
2336,2347,2348
2300,2362,2241
2311,2300,2299
2346,2336,2335
2534,2524,2533
2198,2206,2199
2240,2286,2241
2311,2324,2325
2174,2203,2196
2174,2196,2165
2370,2383,2371
2397,2383,2396
2324,2335,2325
2428,2586,2503
2428,2502,2586
2163,2164,2085
2312,2311,2325
2228,2167,2217
1965,1994,1979
2114,2035,2103
1962,1947,1882
1751,1716,1764
1749,1764,1716
1747,1736,1746
2165,2119,2085
2533,2524,2523
2534,2514,2524
1962,2035,2003
1993,2035,1962
1925,1910,1924
2164,2238,2286
2239,2164,2286
2174,2164,2214
2214,2164,2226
2164,2240,2241
2226,2164,2241
2114,2074,2035
2163,2074,2191
2085,2074,2163
2187,2236,2163
2237,2164,2254
2398,2410,2411
2164,2163,2254
2163,2236,2254
2237,2324,2238
2254,2324,2237
2238,2164,2237
2412,2218,2432
2254,2236,2373
2572,2571,2582
2368,2324,2254
2369,2381,2382
2003,2094,2086
2358,2335,2324
2254,2386,2381
2373,2386,2254
2346,2335,2358
2572,2582,2583
2477,2504,2495
2428,2421,2502
2429,2495,2469
2429,2477,2495
2617,2636,2603
2218,2386,2373
2412,2432,2443
2412,2443,2444
2450,2412,2444
2447,2412,2450
2477,2507,2519
2477,2519,2516
2633,2516,2519
2412,2470,2386
2447,2470,2412
2641,2645,2657
2617,2631,2636
2630,2616,2629
2658,2659,2643
2657,2642,2641
2681,2801,2746
2779,2801,2681
2630,2641,2642
2410,2421,2411
2629,2616,2615
2603,2636,2595
2637,2626,2625
2495,2504,2594
2641,2629,2633
2477,2633,2615
2641,2633,2645
2658,2642,2657
2594,2595,2586
2602,2594,2615
2381,2502,2421
2421,2396,2381
2594,2586,2525
2630,2617,2616
2631,2617,2630
2545,2532,2571
2346,2347,2336
2372,2398,2411
2371,2383,2384
2347,2346,2359
2571,2561,2553
2398,2397,2410
2638,2627,2626
2384,2397,2398
2411,2421,2422
2383,2397,2384
2361,2348,2360
2347,2359,2360
2370,2371,2360
2361,2371,2372
2383,2370,2382
2370,2360,2359
2571,2572,2561
2346,2358,2359
2371,2361,2360
2382,2381,2396
2359,2369,2370
2381,2525,2502
2381,2469,2525
2586,2502,2525
2613,2601,2600
2429,2469,2381
2410,2396,2421
2372,2371,2384
2336,2348,2325
2421,2428,2422
2348,2347,2360
2585,2514,2574
2665,2664,2678
2339,2338,2350
2660,2656,2667
2613,2614,2601
2512,2422,2428
2612,2626,2613
2595,2636,2586
2636,2582,2586
2666,2680,2667
2636,2684,2652
2684,2636,2631
2679,2665,2678
2625,2612,2611
2643,2684,2631
2659,2684,2643
2681,2684,2659
2691,2684,2681
2655,2639,2654
2652,2684,2663
2655,2640,2639
2684,2752,2685
2691,2752,2684
2546,2533,2545
2600,2593,2592
2599,2598,2611
2508,2632,2644
2638,2626,2637
2678,2685,2686
2533,2532,2545
2684,2685,2677
2636,2611,2598
2625,2611,2636
2590,2598,2591
2598,2599,2591
2677,2685,2678
2678,2686,2679
2685,2752,2686
2679,2686,2687
2752,2687,2686
2514,2593,2601
2532,2503,2586
2571,2532,2586
2625,2626,2612
2652,2637,2636
2655,2656,2640
2644,2640,2656
2636,2590,2582
2590,2583,2582
2553,2545,2571
2532,2428,2503
2590,2591,2583
2586,2582,2571
2512,2428,2532
2680,2688,2667
2554,2555,2547
2523,2513,2512
2523,2524,2513
2563,2573,2574
2555,2562,2563
2562,2573,2563
2534,2533,2546
2555,2514,2547
2484,2483,2493
2476,2434,2468
2501,2513,2514
2514,2513,2524
2553,2554,2546
2562,2554,2561
2562,2572,2573
2553,2561,2554
2585,2574,2584
2554,2562,2555
2214,2203,2174
2554,2547,2546
2553,2546,2545
2547,2534,2546
2593,2514,2585
2663,2677,2664
2372,2411,2512
2422,2512,2411
2512,2361,2372
2459,2361,2512
2591,2584,2583
2660,2667,2725
2573,2584,2574
2667,2752,2725
2627,2614,2613
2679,2680,2666
2639,2640,2628
2632,2628,2640
2627,2639,2628
2599,2612,2600
2654,2653,2664
2665,2655,2654
2725,2619,2660
2508,2660,2619
2679,2687,2680
2561,2572,2562
2592,2599,2600
2660,2644,2656
2665,2666,2655
2666,2656,2655
2583,2584,2573
2627,2613,2626
2638,2639,2627
2653,2663,2664
2653,2638,2637
2653,2654,2638
2664,2677,2678
2460,2459,2513
2494,2484,2493
2494,2434,2484
2351,2339,2350
2337,2204,2216
2337,2205,2204
2385,2348,2459
2361,2459,2348
2329,2317,2326
2338,2313,2301
2501,2514,2494
2313,2317,2305
2305,2293,2301
2385,2312,2348
2483,2484,2476
2313,2305,2301
2513,2459,2512
2483,2513,2493
2493,2513,2501
2467,2475,2468
2243,2256,2129
2468,2351,2350
2494,2493,2501
2460,2513,2467
2468,2434,2351
2475,2476,2468
2475,2483,2476
2338,2217,2337
2468,2350,2467
2467,2350,2460
2351,2425,2343
2338,2460,2350
2228,2243,2129
2434,2425,2351
2349,2337,2242
2255,2349,2242
2338,2276,2266
2362,2312,2385
2338,2301,2287
2256,2266,2129
2338,2256,2243
2338,2266,2256
2287,2293,2281
2301,2293,2287
2196,2188,2165
2337,2206,2205
2337,2215,2227
2190,2198,2199
2197,2205,2198
2205,2206,2198
2337,2216,2215
2227,2242,2337
2385,2459,2362
2362,2459,2349
2349,2255,2241
2362,2349,2241
2226,2241,2227
2214,2226,2227
2214,2227,2203
2241,2242,2227
2241,2255,2242
2215,2203,2227
2197,2204,2205
2196,2204,2197
2188,2196,2197
2204,2196,2203
2215,2204,2203
2216,2204,2215
2138,2147,2148
2166,2156,2180
2040,1979,1995
2175,2166,2180
2189,2180,2188
2053,2016,2040
2053,2066,2016
2005,1995,2104
2165,2188,2147
2188,2156,2147
2040,1965,1979
2181,2175,2180
2228,2138,2148
2228,2066,2138
1994,1965,1950
1925,1911,1910
2040,1950,1965
2189,2190,2181
2197,2198,2189
2188,2197,2189
2166,2175,2167
2053,2138,2066
2181,2190,2167
2189,2181,2180
2148,2156,2157
2228,2148,2157
2175,2181,2167
1979,1994,1995
1940,1950,2040
2137,2147,2138
2012,2128,2138
2217,2190,2199
2147,2156,2148
2228,2157,2167
2157,2166,2167
2217,2167,2190
2040,2104,2138
2053,2040,2138
1994,2104,1995
2004,2104,1994
2003,2035,2074
2119,2137,2128
2113,2119,2128
2102,2113,2128
2102,2128,2094
2094,2128,2086
2086,2128,2075
2075,2128,2063
1910,1909,1924
2037,2128,2012
2004,2138,2104
2004,2012,2138
1687,1686,1698
1497,1490,1489
1876,2274,1970
1876,1943,2274
1699,1687,1698
1720,1719,1730
1544,1498,1531
2040,1928,1940
1780,1928,2040
2040,2016,1780
1840,1844,1764
1873,1767,1753
1873,1753,1739
1853,1873,1739
1767,1873,1780
1780,1873,1928
1844,1807,1816
1739,1730,1853
1730,1719,1853
1719,1709,1853
1853,1698,1807
1709,1698,1853
1686,1807,1698
1778,1816,1807
1778,1729,1816
1699,1698,1709
1686,1679,1678
1860,1994,1851
1994,1844,1852
1994,1873,1844
1925,1926,1911
1853,1807,1844
1911,1926,1994
1937,1948,1938
1749,1716,1727
1790,1831,1777
1840,1831,1835
1764,1816,1765
1885,1897,1898
1897,1885,1884
1751,1652,1716
1676,1729,1684
1761,1760,1776
1870,1790,1869
1886,1871,1885
1947,1936,1882
2085,2003,2074
1748,1747,1760
1566,1552,1670
1676,1751,1764
1720,1753,1767
1729,1765,1816
1765,1729,1676
1764,1765,1676
2131,2070,1970
1955,2055,2274
2131,1970,2274
2054,2055,1955
1875,1780,1955
1720,1739,1753
1740,1720,1754
2016,2054,1955
1768,1875,1876
1955,1943,1876
1875,1955,1876
2016,1955,1780
1710,1709,1719
1719,1720,1710
1739,1720,1730
1679,1672,1678
1679,1686,1687
1768,1876,1970
1768,1970,2070
1754,1720,1768
1768,1720,1767
1780,1768,1767
1731,1544,1644
1702,1544,1731
1740,1644,1720
1519,1498,1509
1509,1498,1497
1498,1490,1497
1544,1664,1672
1679,1544,1672
1754,1644,1740
1731,1644,1768
1754,1768,1644
1543,1544,1531
1778,1629,1620
1729,1778,1620
1468,1457,1489
1478,1468,1489
1444,1430,1489
1275,1264,1287
1457,1444,1489
1121,1203,1214
1121,1192,1203
1320,1488,1390
1684,1526,1676
1539,1676,1526
1390,1286,1301
1447,1435,1434
1298,1315,1316
1591,1513,1637
1348,1364,1349
1704,1694,1693
1566,1652,1676
1676,1652,1751
1600,1608,1652
1566,1676,1552
1600,1652,1593
1577,1593,1652
1566,1577,1652
1552,1676,1539
1508,1620,1518
1259,1158,1149
1529,1543,1531
1556,1543,1620
1543,1529,1620
1526,1684,1515
1580,1569,1620
1518,1519,1509
1569,1580,1544
1556,1569,1544
1664,1641,1678
1621,1620,1629
1603,1544,1596
1497,1508,1509
1596,1544,1580
1620,1603,1596
1529,1531,1519
1543,1556,1544
1641,1664,1656
1529,1519,1518
1569,1556,1620
1596,1580,1620
1630,1641,1642
1629,1641,1630
1729,1620,1684
1621,1611,1620
1778,1641,1629
1664,1544,1656
1642,1641,1656
1620,1611,1603
1630,1621,1629
1611,1544,1603
1630,1544,1621
1621,1544,1611
1642,1544,1630
1656,1544,1642
1370,1389,1496
1370,1496,1488
1390,1250,1263
1390,1273,1286
1390,1263,1273
1515,1389,1370
1320,1370,1488
1389,1515,1496
1430,1411,1489
1488,1489,1411
1390,1488,1411
1497,1496,1508
1508,1518,1509
1496,1489,1488
1620,1496,1684
1508,1496,1620
1620,1529,1518
1390,1301,1320
1489,1496,1497
1259,1181,1167
1515,1684,1496
1301,1370,1320
1301,1286,1370
1370,1286,1273
1370,1273,1263
981,1148,1135
1121,1167,1181
981,994,968
981,1109,994
968,957,981
807,793,863
1121,1181,1192
1149,1158,1121
1135,1149,1121
1109,1135,1110
1390,1287,1121
1121,1110,1135
1390,1232,1250
1390,1121,1232
1169,1287,1204
1169,1110,1287
1287,1110,1121
1110,1057,1109
667,707,689
1057,1110,1169
1057,1047,995
1057,995,878
1038,1030,1109
1038,1109,1057
1057,878,864
1038,1057,864
820,835,751
707,667,646
534,646,639
534,638,646
639,568,501
534,639,501
638,707,646
638,666,707
526,534,510
526,510,490
490,510,501
689,639,667
639,646,667
863,793,819
819,896,863
736,707,724
736,724,749
736,761,689
689,707,736
749,761,736
792,793,761
863,896,916
761,749,792
793,792,819
819,938,896
819,792,938
981,896,938
848,1038,864
916,807,863
1038,916,1030
968,1030,916
1038,820,807
916,1038,807
1038,835,820
1038,848,835
957,968,916
981,957,916
981,916,896
534,501,510
723,686,717
638,534,526
789,778,743
705,722,717
895,834,833
399,431,408
484,495,431
490,484,431
490,431,424
302,306,311
817,876,894
861,886,792
886,901,792
1383,1365,1364
792,901,1056
938,792,1056
1192,1259,1203
1333,1315,1314
1135,1259,1149
1135,1148,1259
1259,1515,1370
1203,1370,1214
1203,1259,1370
1214,1370,1232
1232,1370,1250
1250,1370,1263
1439,1440,1427
1244,1147,1227
1381,1405,1382
1408,1384,1407
1436,1435,1448
1456,1385,1409
886,895,1056
901,886,1056
1148,1084,1147
1148,1056,1084
1056,1148,981
967,1056,981
1056,967,938
687,638,645
723,734,742
573,579,587
621,598,582
579,564,541
622,598,636
564,579,573
541,564,549
541,540,579
573,587,596
697,686,675
564,573,549
684,697,621
550,526,490
598,622,599
623,622,645
623,638,526
645,638,623
636,645,622
636,687,645
789,723,776
599,550,598
598,550,582
549,582,550
526,550,599
275,237,279
269,338,283
275,338,269
389,367,398
342,353,343
490,424,430
407,430,424
430,532,549
430,525,532
490,430,550
310,309,361
459,430,422
525,459,532
458,393,387
422,430,398
525,430,459
422,398,394
389,430,407
399,389,407
367,353,358
367,389,353
337,353,342
297,293,310
310,343,338
338,297,310
343,350,348
342,343,310
342,310,337
350,343,353
361,337,310
388,358,382
361,353,337
427,376,403
427,371,376
343,348,345
338,343,345
315,301,322
371,322,333
371,362,322
371,333,332
341,371,332
301,265,322
362,315,322
360,315,371
362,371,315
360,309,315
232,272,268
288,315,309
278,315,288
278,301,315
309,278,288
309,310,278
272,301,278
265,301,272
265,272,255
310,272,278
237,272,310
293,237,310
459,422,532
374,360,371
360,374,375
360,375,361
361,375,382
540,541,393
382,358,361
367,394,398
367,388,394
361,358,353
394,532,422
387,393,382
541,532,414
414,532,394
387,371,427
448,458,427
427,458,387
374,371,387
387,375,374
387,382,375
458,540,393
541,414,393
394,393,414
394,388,393
594,620,660
697,716,705
662,695,703
661,595,594
594,595,458
540,595,579
458,595,540
702,673,683
531,594,458
588,620,530
531,530,620
685,674,698
673,651,663
594,531,620
875,773,777
683,674,696
588,644,651
620,588,651
714,702,696
644,588,674
929,944,928
929,928,915
1119,1087,1157
1077,1157,1083
1516,1527,1506
1514,1506,1527
1359,1358,1377
935,978,991
935,991,927
1011,1003,993
991,992,927
1028,1003,1011
1010,1003,1028
1019,1010,1028
1003,991,978
1344,1330,1329
1309,1293,1255
1227,1177,1226
1077,1144,1062
1386,1475,1367
1475,1420,1400
1346,1361,1362
1010,1105,1003
1027,1062,1117
1028,1062,1027
1028,1027,1019
1027,1117,1019
1105,1019,1117
1189,1201,1156
935,1011,993
1071,1157,1077
979,1045,928
979,1055,1045
1190,1201,1189
1189,1179,1180
1246,1156,1228
1402,1379,1378
1525,1576,1514
1506,1576,1420
1345,1346,1331
1178,1083,1087
1317,1299,1178
1245,1317,1178
1327,1309,1225
1789,1746,1763
1525,1514,1626
1259,1298,1316
1336,1400,1317
1293,1310,1311
1258,1268,1269
1283,1282,1295
1310,1329,1311
1309,1241,1225
1297,1315,1298
1473,1474,1464
1576,1617,1696
1435,1447,1448
1177,1132,1106
1177,1106,1176
1178,1144,1077
1083,1178,1077
1317,1400,1299
1316,1315,1334
1403,1380,1379
1178,1299,1400
1178,1400,1327
1227,1243,1244
1344,1329,1343
1422,1403,1402
1351,1475,1400
1367,1475,1351
1462,1472,1463
1146,1178,1133
1178,1146,1156
1156,1246,1178
1514,1576,1506
1245,1178,1246
1178,1211,1144
1133,1178,1119
1087,1119,1178
1728,1797,1738
1506,1386,1410
1475,1386,1506
1617,1607,1707
1797,1617,1707
1576,1707,1607
1576,1626,1707
1626,1576,1551
1576,1607,1617
1889,1805,1750
1576,1538,1551
1317,1246,1368
1245,1246,1317
1475,1506,1420
1915,1930,1953
1980,1996,1981
1981,1996,1997
1953,1967,1968
1952,1967,1953
1981,1968,1980
1968,1967,1980
1981,1997,2015
1953,1930,1942
1900,1953,1913
1888,1889,1750
1888,1750,1797
1910,1898,1909
1738,1750,1746
1883,1897,1884
1805,1902,1900
1805,1889,1902
2003,2113,2102
1939,1993,1962
1912,1939,1962
1939,1968,1981
2015,1939,1981
1939,1953,1968
2024,1939,2015
2024,2039,1939
2039,2052,1939
2097,2036,1939
2052,2097,1939
1900,1902,1953
1927,1953,1939
1576,1696,1625
1575,1473,1487
1575,1474,1473
1797,1717,1706
1617,1797,1706
1738,1797,1750
1651,1625,1662
1472,1473,1463
1451,1450,1464
1637,1625,1651
1696,1704,1693
1683,1693,1694
1949,1963,1964
1883,1868,1882
1706,1714,1704
1746,1735,1738
1715,1705,1714
1316,1334,1335
1333,1334,1315
1760,1746,1776
1705,1694,1704
1869,1790,1868
1716,1715,1726
1859,1789,1850
1728,1738,1735
1728,1735,1725
1662,1625,1696
1714,1717,1725
1717,1728,1725
1913,1859,1900
1993,2036,2035
2076,2035,2036
1867,1859,1882
1835,1831,1790
1727,1716,1726
1927,1859,1913
1898,1897,1909
1843,1839,1790
1761,1831,1762
1761,1777,1831
1909,1897,1883
1962,1978,1963
2036,1993,1939
1869,1884,1870
1926,1938,1994
2086,2075,2003
1912,1962,1882
1869,1883,1884
1885,1870,1884
1994,1871,1886
1736,1737,1727
1898,1886,1885
1964,1992,2003
1851,1843,1790
1871,1790,1870
1860,1790,1871
1839,1835,1790
1882,1924,1909
1789,1790,1777
1868,1883,1869
1882,1859,1912
1887,1859,1872
1763,1872,1859
1763,1859,1850
1939,1859,1927
1939,1912,1859
1851,1852,1844
1963,1948,1962
1885,1871,1870
1871,1994,1860
1851,1994,1852
1843,1851,1844
1840,1835,1839
1844,1840,1839
1843,1844,1839
1899,1911,1994
1899,1886,1898
1747,1746,1760
1964,2004,1994
1964,2012,2004
2037,1964,2128
2063,2128,1964
1949,1964,1994
2037,2012,1964
2003,2102,2094
1910,1899,1898
1937,1947,1948
1886,1899,1994
1937,1925,1936
1964,2075,2063
1964,2003,2075
1925,1937,1926
1736,1727,1726
1456,1350,1366
1715,1725,1726
1577,1566,1670
1539,1526,1670
1761,1748,1760
1737,1748,1749
1747,1748,1737
1748,1761,1749
1683,1651,1662
1565,1592,1670
1736,1747,1737
1714,1705,1704
1705,1715,1716
1706,1717,1714
1860,1851,1790
1736,1735,1746
1749,1727,1737
1696,1706,1704
1591,1637,1683
1637,1651,1683
1485,1472,1471
1868,1790,1867
1726,1725,1735
1447,1461,1448
1283,1296,1284
1310,1328,1329
1789,1777,1776
1776,1746,1789
1777,1761,1776
1463,1473,1464
1789,1763,1850
1831,1749,1762
1831,1840,1749
1764,1749,1840
1761,1762,1749
1867,1789,1859
1593,1716,1600
1695,1716,1593
1716,1608,1600
1790,1789,1867
1565,1670,1515
1694,1705,1716
1592,1683,1670
1575,1591,1683
1485,1486,1472
1575,1683,1592
1440,1428,1427
1442,1575,1592
1442,1455,1575
1485,1505,1495
1405,1406,1382
1486,1487,1473
1591,1495,1505
1384,1383,1407
1401,1377,1400
1452,1575,1453
1452,1466,1575
1259,1565,1515
1259,1456,1565
1451,1465,1452
1442,1454,1455
1148,1270,1259
1335,1349,1350
1283,1295,1296
1314,1297,1296
1335,1334,1349
1328,1309,1327
1456,1366,1385
1452,1439,1451
1360,1379,1361
1363,1348,1347
1456,1335,1350
1456,1259,1335
1259,1316,1335
1283,1269,1282
1270,1283,1284
1296,1295,1313
1427,1408,1407
1297,1298,1284
1314,1315,1297
1270,1284,1298
1349,1334,1348
1348,1334,1333
1296,1297,1284
1384,1366,1365
1385,1408,1409
1437,1424,1436
1267,1256,1255
1330,1345,1331
1314,1313,1332
1314,1296,1313
1428,1409,1408
1423,1404,1403
1428,1408,1427
1293,1281,1267
1402,1403,1379
1294,1295,1282
1311,1312,1294
1257,1256,1267
1243,1227,1242
1244,1270,1148
1147,1244,1148
1364,1363,1382
1385,1366,1384
1383,1364,1382
1385,1384,1408
1409,1429,1565
1409,1565,1456
1454,1453,1575
1383,1384,1365
1442,1429,1441
1442,1441,1454
1453,1454,1441
1453,1441,1440
1364,1365,1349
1429,1409,1428
1429,1428,1441
1440,1441,1428
1333,1314,1332
1268,1282,1269
1343,1329,1328
1244,1243,1257
1347,1332,1346
1346,1332,1331
1268,1267,1281
1256,1242,1255
1406,1383,1382
1407,1383,1406
1436,1424,1423
1424,1404,1423
1426,1439,1427
1485,1513,1505
1381,1404,1405
1379,1380,1361
1359,1360,1344
1420,1401,1400
1378,1379,1360
1268,1257,1267
1422,1423,1403
1380,1404,1381
1244,1257,1258
1293,1294,1281
1281,1294,1282
1311,1294,1293
1344,1345,1330
1378,1359,1377
1402,1378,1401
1313,1331,1332
1313,1312,1331
1312,1313,1295
1420,1421,1401
1106,992,1105
1241,1242,1226
1241,1226,1225
1359,1344,1343
1242,1227,1226
1377,1358,1400
1225,1226,1177
1144,1225,1117
1144,1211,1225
1132,1107,1106
1176,1106,1105
1176,1105,1225
1117,1225,1105
1177,1176,1225
1421,1422,1402
1401,1378,1377
1211,1178,1327
1255,1241,1309
1360,1345,1344
1358,1359,1343
1342,1358,1343
1327,1225,1211
1329,1330,1311
1312,1311,1330
1312,1330,1331
1345,1361,1346
1360,1361,1345
1327,1400,1342
1309,1328,1310
1378,1360,1359
1421,1402,1401
1404,1380,1403
1310,1293,1309
1342,1400,1358
1465,1575,1466
1472,1486,1473
1420,1461,1447
1637,1513,1625
1576,1513,1485
1425,1438,1426
1435,1422,1434
1451,1464,1465
1437,1425,1424
1439,1452,1440
1438,1439,1426
1437,1438,1425
1452,1453,1440
1438,1451,1439
1452,1465,1466
1451,1438,1450
1438,1437,1450
1426,1427,1407
1406,1426,1407
1591,1505,1513
1436,1448,1449
1449,1448,1462
1449,1437,1436
1436,1423,1435
1435,1423,1422
1485,1495,1486
1463,1449,1462
1463,1450,1449
1450,1437,1449
1591,1486,1495
1591,1575,1486
1575,1487,1486
1447,1434,1420
1434,1421,1420
1434,1422,1421
1420,1485,1471
1471,1472,1462
1461,1471,1462
1420,1471,1461
1362,1363,1347
1406,1425,1426
1405,1425,1406
1424,1425,1405
1404,1424,1405
1333,1332,1347
1346,1362,1347
1361,1380,1362
1381,1362,1380
1363,1362,1381
1363,1381,1382
1364,1348,1363
1145,1132,1177
1145,1177,1227
1107,992,1106
1118,1145,1227
1227,1147,1118
1107,1132,1118
1118,1132,1145
1056,900,907
803,833,776
834,743,778
789,834,778
747,832,817
742,832,747
832,734,722
734,832,742
833,803,844
817,803,776
817,776,747
723,742,747
686,598,621
686,636,598
747,776,723
686,723,636
717,686,705
717,722,734
705,686,697
686,621,675
697,675,621
684,596,587
596,684,573
573,684,621
684,587,579
832,722,716
775,832,716
733,831,741
684,662,715
775,774,832
749,743,792
638,687,666
834,861,792
833,789,776
723,789,743
743,834,792
834,789,833
743,724,666
687,743,666
687,636,743
743,636,723
743,749,724
886,861,834
886,834,895
1118,1084,1056
894,803,817
894,844,803
894,895,833
833,844,894
895,894,1056
1107,1118,914
1118,1056,914
1084,1118,1147
892,992,900
1107,907,992
1107,914,907
832,966,992
832,992,892
817,892,876
817,832,892
876,892,894
1056,907,914
874,816,860
1367,1351,1368
1157,1164,1156
1410,1387,1506
1506,1387,1516
1516,1387,1368
1443,1516,1368
1368,1387,1386
1387,1410,1386
1119,1157,1133
1157,1156,1146
1228,1156,1212
1212,1156,1201
1246,1285,1300
698,773,721
1029,1045,1062
802,859,788
1045,1055,1071
935,927,884
884,927,885
992,966,831
992,831,927
979,928,944
875,893,928
1077,1062,1045
1077,1045,1071
935,884,859
935,874,928
928,874,875
1029,936,1045
928,1011,935
936,1029,928
928,1062,1011
928,1029,1062
1062,1028,1011
874,859,816
772,721,773
874,860,875
829,884,885
935,859,874
859,802,816
893,875,777
777,915,893
695,733,703
695,732,733
770,788,859
772,773,816
816,802,772
696,702,683
802,759,772
759,721,772
884,770,859
884,829,770
829,885,830
662,703,715
714,696,704
702,714,770
788,721,759
788,770,721
770,714,721
830,771,829
770,829,771
832,774,831
832,831,966
771,830,831
716,741,831
774,716,831
771,831,733
715,733,684
732,771,733
770,771,732
695,662,661
733,715,703
673,702,660
660,695,661
660,702,695
695,702,770
732,695,770
673,663,674
673,674,683
651,673,660
662,595,661
579,595,662
684,579,662
696,674,704
721,674,685
721,704,674
777,773,698
293,279,237
272,241,268
272,237,241
275,297,338
297,275,293
279,293,275
173,206,189
241,237,219
154,202,199
154,219,202
219,206,202
219,237,206
219,154,179
186,219,179
219,186,196
241,219,268
219,232,268
232,219,196
232,196,213
199,202,173
206,173,202
136,140,188
139,188,140
139,197,188
188,197,173
173,197,199
139,199,197
139,154,199
110,101,111
115,132,104
173,132,188
132,115,136
188,132,136
166,132,173
174,166,173
173,189,174
237,189,206
207,189,237
208,181,190
182,181,191
191,181,208
259,203,207
190,189,203
256,250,269
189,207,203
181,166,180
180,189,190
181,180,190
25,24,29
180,174,189
166,174,180
237,275,207
269,190,203
269,208,190
275,269,259
269,203,259
289,269,283
338,345,283
289,280,256
298,306,302
302,289,298
289,283,298
306,298,283
306,283,345
306,348,350
306,345,348
280,316,294
280,302,316
306,353,327
306,350,353
311,327,316
248,137,242
399,346,389
353,346,327
353,389,346
384,316,399
451,462,390
409,390,462
378,408,431
378,431,390
504,503,512
495,462,431
462,451,431
451,390,431
316,378,294
384,378,316
384,399,408
384,408,378
250,242,269
670,823,633
625,633,823
256,269,289
289,302,280
409,378,390
496,455,568
690,807,699
728,807,737
699,700,691
669,657,807
725,807,648
657,648,807
689,725,648
809,822,932
868,809,932
679,669,807
690,679,807
807,820,751
744,737,807
751,744,807
867,851,864
699,711,700
822,809,751
669,680,657
690,680,679
699,807,711
679,680,669
700,711,712
711,807,720
699,691,690
639,521,512
504,497,503
689,648,521
639,512,503
689,521,639
409,462,445
445,495,455
445,462,495
512,648,513
512,521,648
568,455,495
497,496,503
639,496,568
639,503,496
496,497,455
1113,1287,1126
838,751,835
864,851,848
838,822,751
868,973,823
878,995,880
848,851,838
848,838,835
878,867,864
1049,1057,1169
1068,1287,1074
1060,1287,1068
1049,1204,1287
1049,1287,1053
1049,1169,1204
1252,1264,1235
1100,1126,1092
1374,1275,1287
1322,1305,1374
1100,1287,1113
1305,1289,1374
1544,1645,1632
1394,1411,1414
1826,1731,1768
1480,1645,1657
1919,2070,2008
1323,1275,1289
1431,1416,1415
1445,1431,1415
1235,1275,1323
1264,1275,1235
1252,1141,1126
1140,1252,1126
1323,1289,1305
1501,1445,1415
1374,1394,1375
1375,1416,1356
1374,1375,1356
1289,1275,1374
1172,1161,1252
1414,1430,1444
1414,1444,1457
1153,1252,1140
1153,1287,1159
1159,1252,1153
1287,1153,1140
1060,997,1053
1126,1080,1086
1039,1252,1161
1039,1141,1252
1126,1086,1092
1053,997,1049
997,1161,1172
909,997,1172
1049,984,973
984,909,973
1057,973,1047
1049,973,1057
1047,973,995
852,973,887
887,973,902
902,973,909
1141,997,1126
1141,1039,997
1074,997,1068
1080,997,1074
1080,1126,997
1287,1140,1126
1416,1305,1322
1416,1323,1305
1252,1219,1196
1041,909,1050
1196,1172,1252
1050,909,1172
1039,1161,997
851,867,932
822,838,932
670,810,823
616,625,823
973,880,995
868,932,973
744,751,868
1049,997,984
997,909,984
838,851,932
867,880,932
497,504,616
932,880,973
737,744,868
728,737,868
720,728,868
711,720,868
711,868,712
810,868,823
712,868,700
868,691,700
868,680,691
810,680,868
633,625,648
625,616,648
670,633,641
680,641,633
648,680,633
513,648,616
498,433,616
209,233,204
191,109,182
191,112,109
134,138,156
61,110,63
138,129,122
242,122,208
242,137,122
137,138,122
208,122,112
191,208,112
126,117,112
252,248,256
248,250,256
294,378,262
409,445,323
262,252,256
248,242,250
380,317,323
294,262,280
380,270,317
262,378,317
409,317,378
409,323,317
262,317,263
166,181,116
66,63,99
102,99,110
105,102,110
111,116,182
105,110,108
182,108,111
109,108,182
181,182,116
111,101,116
101,98,100
98,97,100
132,100,97
104,78,84
47,43,40
42,47,40
94,47,93
94,49,47
572,509,593
786,827,841
509,563,548
491,500,548
593,635,572
1240,1043,1224
758,740,1043
740,986,1043
740,974,986
1661,1650,1669
1199,1210,1043
898,890,899
1174,1279,1155
1647,1616,1635
1512,1504,1503
563,572,731
731,572,635
1155,785,757
1155,757,1130
1155,1279,785
1254,1102,1043
1254,1043,1240
1130,758,1102
757,758,1130
450,349,426
828,843,842
758,757,740
64,65,73
14,8,15
257,249,245
349,260,314
7,6,2
19,13,12
0,1,3
4,5,8
40,20,19
40,19,21
6,5,2
12,1,0
18,21,0
21,19,12
21,12,0
0,3,18
90,86,87
145,144,86
83,82,74
10,11,16
87,86,82
87,82,83
83,74,55
88,87,83
330,281,320
244,88,222
73,82,86
53,65,32
3,8,14
4,8,3
15,65,64
8,9,15
18,3,17
17,15,64
15,9,10
15,17,14
1,4,3
2,4,1
9,6,10
15,10,16
6,7,10
1,13,2
9,5,6
5,9,8
19,20,13
2,5,4
16,65,15
32,65,16
52,53,34
16,11,34
32,16,34
88,83,55
33,31,30
38,48,39
37,46,52
31,33,34
33,37,34
52,34,37
49,29,47
28,47,29
11,31,34
26,37,30
7,25,26
38,44,45
39,46,37
11,26,31
27,43,47
27,24,13
24,2,13
7,2,24
30,31,26
29,24,28
27,28,24
20,27,13
20,40,27
43,27,40
45,44,54
209,204,163
125,126,142
117,81,89
117,113,81
509,548,500
454,486,480
314,397,349
349,411,420
349,420,426
349,397,411
509,500,454
787,768,769
454,370,450
480,370,454
233,210,227
233,239,210
138,163,156
98,54,94
48,50,51
26,25,39
29,94,54
58,110,61
58,101,110
66,105,108
66,108,79
66,99,102
63,110,99
50,66,67
61,50,58
50,67,51
38,45,48
37,26,39
48,45,54
63,66,50
48,58,50
48,54,58
61,63,50
44,29,54
39,25,38
25,29,44
38,25,44
48,51,39
69,62,39
69,39,51
46,69,52
46,62,69
81,113,69
46,39,62
320,281,254
239,254,244
88,125,142
88,55,125
126,55,113
126,125,55
66,79,67
113,52,69
55,52,113
254,277,253
222,193,244
244,193,239
192,88,142
254,253,244
192,222,88
142,126,143
209,163,252
245,291,257
245,277,291
319,325,239
193,143,126
260,331,335
305,291,281
314,260,397
257,308,331
260,257,331
291,305,257
238,317,243
331,347,369
331,369,336
320,325,330
277,281,291
281,277,254
331,305,347
305,330,347
331,308,305
305,308,257
320,254,239
222,192,193
253,277,245
88,253,153
88,244,253
239,193,210
193,192,143
204,183,163
134,193,126
134,156,193
156,210,193
183,156,163
80,89,81
81,51,80
81,69,51
51,67,80
79,108,109
80,79,109
80,109,89
117,89,109
126,112,134
109,112,117
129,138,134
112,122,134
122,129,134
163,138,137
137,252,163
248,252,137
156,204,210
156,183,204
233,317,238
233,263,317
233,319,239
238,319,233
243,319,238
209,262,233
209,252,262
233,262,263
243,317,270
330,435,347
330,325,435
204,227,210
227,204,233
433,455,497
381,325,319
381,319,243
439,435,434
381,433,434
433,497,616
380,433,381
435,325,381
380,243,270
380,381,243
433,380,323
499,434,498
499,498,616
498,434,433
517,516,616
516,507,616
527,523,616
516,517,507
523,517,616
538,527,616
518,523,524
454,466,471
457,466,450
454,450,466
479,439,499
439,434,499
524,523,527
368,439,369
457,447,466
373,457,420
450,420,457
560,603,694
560,694,693
528,527,538
260,335,373
397,260,373
373,420,397
336,369,357
357,331,336
373,331,357
373,335,331
447,369,439
447,373,357
447,357,369
373,447,457
347,439,368
347,435,439
453,447,439
474,466,453
528,524,527
466,474,518
518,439,479
453,439,518
518,479,507
517,518,507
518,517,523
453,518,474
528,538,539
603,508,475
603,475,471
466,578,603
471,466,603
466,518,578
571,578,518
701,799,713
756,694,701
767,627,619
766,767,755
854,769,756
854,756,713
902,753,852
767,619,614
767,608,755
767,614,608
767,783,784
767,766,783
592,571,518
592,518,524
592,524,528
539,592,528
592,578,571
539,546,592
1054,1050,1172
814,813,826
765,754,902
754,753,902
909,765,902
823,852,753
753,616,823
539,739,546
539,754,739
755,592,739
546,739,592
754,755,739
783,765,797
765,766,755
854,814,826
906,934,943
854,799,814
783,797,784
754,765,755
975,976,988
854,826,840
826,813,840
869,854,853
888,903,897
881,897,869
888,881,853
888,897,881
767,784,799
799,798,813
799,813,814
784,797,798
797,813,798
853,813,797
813,853,840
827,828,842
801,843,828
869,897,854
858,873,872
919,769,897
801,815,800
786,768,787
873,858,843
694,799,701
854,713,799
1660,1661,1668
756,701,713
854,897,769
1660,1649,1661
769,801,787
815,828,827
827,842,841
858,872,857
1001,988,989
756,693,694
538,616,545
756,769,768
619,627,694
614,619,694
608,614,694
627,799,694
767,799,627
508,603,555
555,454,475
555,475,508
454,555,509
604,560,693
756,604,693
756,635,604
593,604,635
801,828,815
786,787,800
919,897,903
801,800,787
827,800,815
800,827,786
898,899,905
872,873,883
857,841,842
1648,1635,1649
858,857,842
889,890,898
882,872,883
1024,1025,1033
905,899,906
1692,1713,1650
1550,1563,1636
883,873,891
882,889,871
912,905,913
904,898,905
740,841,871
731,841,740
740,871,889
560,509,555
731,643,786
731,786,841
756,768,643
731,635,643
756,643,635
753,553,616
553,753,545
754,545,753
754,538,545
539,538,754
553,545,616
1280,1292,1399
955,942,909
1041,1032,909
1235,1219,1252
1196,1219,1206
1196,1206,1061
1172,1196,1061
1116,1200,1104
1308,1292,1239
1376,1458,1418
1220,1206,1277
1235,1206,1219
1103,1104,1200
1002,1009,1008
740,920,963
986,974,920
986,920,1103
1034,1035,1104
1103,1115,986
1102,758,1043
1174,1155,1254
1043,1210,1224
1470,1460,1433
1254,1130,1102
1279,1174,1254
920,921,1103
1015,1006,1016
1103,1199,1115
1103,1200,1199
921,999,1006
1005,921,1006
1419,1433,1446
1199,986,1115
1199,1043,986
912,911,904
974,963,920
1013,921,1014
1023,1022,921
1023,921,1013
1650,1866,1669
913,921,912
904,905,912
1025,1034,1033
1018,1044,1035
1713,1774,1866
1713,1866,1650
1104,1033,1034
740,889,911
740,911,920
889,904,911
1025,1026,1034
1025,1024,1015
1013,1014,1023
1014,1024,1023
1023,1104,1022
1033,1104,1024
1024,1104,1023
1022,1104,921
1008,1007,1001
1131,1200,1116
1104,1035,1044
1116,1223,1280
1116,1280,1131
1116,1104,1223
1006,1007,1016
1239,1223,1209
1223,1239,1292
1223,1292,1280
1239,1209,1266
1326,1239,1266
990,1009,1002
1015,1024,1014
1005,1006,1015
1017,1007,1008
1001,1000,988
1000,1006,999
1015,921,1005
1014,921,1015
1009,1198,1223
1018,1008,1009
1015,1016,1025
1025,1016,1026
1018,1009,1223
1018,1223,1044
1006,1000,1007
1007,1000,1001
913,1000,921
987,1000,913
988,1000,987
1001,1002,1008
988,906,975
988,913,906
988,987,913
976,906,964
976,975,906
910,934,926
977,965,943
943,990,977
1589,1635,1616
910,943,934
919,903,910
1669,1866,1881
956,906,943
926,891,919
934,906,891
910,926,919
910,903,888
965,906,956
965,964,906
926,934,891
919,891,873
843,801,919
801,769,919
943,965,956
976,989,988
977,976,965
977,989,976
990,989,977
1002,989,990
1002,1001,989
943,1021,990
765,909,942
933,765,942
955,985,910
955,998,985
955,910,888
985,1021,910
765,925,797
853,797,925
955,853,942
955,888,853
925,765,933
853,933,942
853,925,933
1206,1054,1061
1042,998,1220
1188,1069,1095
1175,1069,1188
1032,1041,962
955,909,1032
955,1032,962
1206,955,962
1206,998,955
998,1206,1220
1206,1041,1050
1206,962,1041
1206,1050,1054
1188,1290,1307
1308,1419,1399
1009,1175,1198
1069,1042,1220
1042,1069,1175
1069,1220,1095
1198,1175,1188
1307,1418,1432
1266,1209,1188
1209,1198,1188
1290,1188,1253
1095,1220,1188
1253,1188,1220
1021,1042,1175
990,1021,1175
990,1175,1009
1307,1376,1418
1326,1266,1432
1326,1459,1398
1326,1398,1308
1131,1280,1399
1131,1399,1200
1308,1399,1292
1433,1419,1308
1398,1433,1308
1483,1398,1459
1483,1433,1398
1470,1433,1483
1200,1399,1446
1433,1460,1446
1446,1399,1419
1376,1220,1277
1290,1376,1307
1206,1376,1277
1376,1290,1220
1253,1220,1290
1418,1458,1469
1482,1432,1535
1535,1469,1458
1535,1586,1615
1418,1469,1535
1418,1535,1432
1326,1432,1482
1511,1549,1459
1549,1511,1548
1692,1587,1724
1692,1666,1587
1482,1535,1615
1615,1511,1482
1615,1548,1511
1548,1615,1587
1634,1724,1615
1587,1615,1724
1615,1665,1849
1880,1865,1774
1724,1787,1692
1973,1880,2047
1973,2047,2061
2020,1814,1999
1999,1814,1988
1814,1774,1713
1787,1814,1713
1588,1666,1692
1674,1668,1675
1880,1814,2047
1774,1865,1866
1650,1649,1636
1866,1865,1880
1660,1648,1649
1674,1660,1668
1668,1669,1675
1974,1675,1669
1974,1669,1881
1589,1636,1635
1649,1650,1661
1279,1254,1616
1589,1616,1254
1649,1635,1636
1574,1588,1636
1588,1574,1536
1537,1524,1536
1590,1636,1589
1574,1563,1536
1563,1550,1536
1523,1590,1589
1504,1446,1484
1550,1537,1536
1224,1523,1240
1523,1254,1240
1210,1523,1224
1484,1446,1460
1503,1504,1494
1503,1494,1483
1522,1512,1503
1504,1484,1494
1484,1460,1470
1484,1470,1483
1483,1536,1503
1483,1587,1536
1536,1587,1588
1536,1522,1503
1524,1522,1536
1563,1574,1636
1564,1636,1590
1524,1504,1512
1524,1200,1504
1199,1200,1524
1523,1524,1590
1564,1590,1524
1523,1199,1524
1210,1199,1523
1524,1636,1564
1537,1636,1524
1524,1512,1522
2046,2061,2047
2032,2031,2072
2019,1986,1998
2060,2032,2072
2010,2018,2019
2019,1849,1857
2019,1857,1986
1615,1849,2019
1633,1584,1561
1584,1586,1535
1633,1586,1584
1633,1615,1586
1665,1615,1633
1535,1458,1561
1458,1376,1561
1561,1584,1535
1561,1376,1396
1396,1376,1206
1206,1235,1396
1520,1396,1510
1501,1396,1235
1235,1323,1416
1396,1520,1532
1416,1322,1341
1501,1431,1445
1416,1341,1356
1416,1431,1501
1235,1416,1501
1646,1560,1559
1394,1414,1395
1414,1480,1415
1395,1416,1375
1395,1375,1394
1702,1646,1690
1396,1532,1546
1560,1396,1546
1561,1396,1560
1561,1560,1646
1414,1457,1468
1561,1802,1633
1561,1646,1802
1682,1646,1559
1544,1657,1645
1532,1415,1546
1414,1411,1430
1341,1322,1374
1415,1416,1395
1415,1532,1520
1390,1374,1287
1341,1374,1356
1510,1415,1520
1510,1501,1415
1414,1498,1480
1415,1480,1559
1395,1414,1415
1546,1415,1560
1559,1560,1415
1394,1390,1411
1414,1468,1478
1490,1414,1478
1498,1414,1490
1480,1658,1559
1690,1646,1682
1544,1632,1480
1657,1658,1480
1657,1682,1658
1544,1480,1498
1657,1690,1682
1657,1702,1690
1811,1820,1812
1802,1646,1757
1757,1702,1771
1826,1702,1731
1783,1793,1802
1771,1783,1802
1820,1811,1702
1919,2028,2071
2059,1919,2071
1768,2070,1919
1768,1919,1826
2008,2028,1919
1827,1833,1828
1633,1802,1665
1812,1820,1821
1828,1849,1821
1702,1757,1646
1802,1757,1771
1802,1793,1801
1811,1801,1702
1827,1702,1833
1802,1801,1811
1849,1665,1802
1812,1821,1849
1802,1812,1849
1811,1812,1802
1821,1820,1827
1821,1827,1828
1826,1919,1920
1933,1920,2044
1934,1828,1833
1934,1922,1828
1833,1920,1933
1828,1922,1857
1857,1849,1828
1986,1857,1934
1933,1934,1833
1934,1857,1922
1934,1998,1986
1934,2019,1998
1934,2010,2019
2018,2010,1934
2059,2071,1933
1920,1919,2044
2071,2081,1933
1934,1933,2081
2044,2059,1933
2307,2142,2294
2321,2142,2307
2332,2142,2321
2345,2142,2332
2345,2171,2142
2071,2028,2081
2070,2080,2008
2080,2089,2008
2100,2274,2028
2090,2028,2274
2028,2090,2081
2090,2274,2142
2283,2294,2142
2274,2283,2142
2438,2568,2606
2171,2345,2404
2438,2606,2531
2438,2529,2568
2438,2437,2529
2171,2404,2201
2393,2473,2404
2437,2404,2529
2473,2529,2404
2437,2438,2404
2345,2393,2404
2531,2675,2608
2742,2578,2559
2683,2742,2559
2758,2742,2683
2758,2683,2675
2608,2675,2683
2822,2758,2831
2955,2948,2750
2965,2916,2960
2717,2758,2750
2648,2758,2717
2623,2758,2648
2649,2648,2717
2624,2648,2649
2464,2454,2439
2464,2438,2491
2454,2427,2439
2171,2405,2394
2405,2284,2404
2201,2405,2171
2284,2405,2201
2171,2394,2333
2491,2454,2464
2404,2438,2405
2438,2439,2405
2439,2438,2464
2578,2758,2623
2578,2742,2758
2648,2578,2623
2624,2578,2648
2531,2608,2559
2608,2683,2559
2427,2405,2439
2559,2491,2531
2394,2405,2427
2491,2438,2531
2650,2702,2609
2750,2702,2717
2542,2579,2560
2588,2609,2579
2609,2702,2579
2522,2455,2569
2491,2569,2455
2394,2427,2455
2406,2394,2440
2455,2440,2394
2455,2427,2454
2454,2491,2455
2588,2579,2569
2702,2650,2717
2650,2649,2717
2649,2650,2624
2650,2578,2624
2588,2650,2609
2491,2559,2569
2578,2569,2559
2578,2650,2569
2588,2569,2650
2702,2570,2560
2702,2560,2579
2082,2090,2142
2500,2579,2542
2500,2456,2482
2465,2456,2542
2500,2542,2456
2482,2456,2579
2441,2569,2579
2579,2456,2441
2569,2441,2522
2455,2522,2441
2440,2455,2441
2407,2418,2441
2334,2407,2323
2334,2418,2407
1988,2083,1999
2441,2395,2440
2441,2418,2395
2322,2394,2406
2440,2322,2406
2395,2322,2440
2171,2333,2322
2394,2322,2333
2418,2322,2395
2418,2334,2322
2195,2323,2308
2195,2308,2295
2171,2322,2101
2295,2265,2251
2195,2295,2251
2047,1814,2020
1814,1787,2060
2020,1999,2033
2195,2251,2061
2060,2072,2083
2047,2020,2033
2047,2033,2046
2033,1999,2083
2033,2083,2046
2046,2091,2101
2060,2019,2032
2101,2322,2195
2060,2083,1814
1787,1724,2060
2061,2046,2101
2090,1934,2081
2031,1934,2090
1814,2083,1988
2091,2082,2101
2082,2091,2083
2083,2091,2046
2060,1724,1634
1615,2019,2060
1615,2060,1634
2031,2082,2072
2031,2090,2082
2032,2019,2031
2031,2019,2018
2018,1934,2031
2142,2171,2101
2082,2142,2101
2000,2126,2135
2407,2126,2265
2407,2441,2126
2251,2126,2061
1989,1973,2061
2126,2441,2135
2061,2126,1989
2456,2419,2441
2441,2419,2135
2610,2580,2597
2580,2702,2597
2580,2570,2702
2610,2597,2702
2702,2872,2610
2750,2872,2702
2872,2939,2891
2932,2939,2872
2891,2955,2960
2891,2960,2916
2965,2960,2750
2891,2939,2948
2960,2955,2750
2891,2948,2955
2996,2992,2877
2939,2932,2750
2988,2992,2971
2822,2988,2985
2996,2993,2989
2822,2985,2982
2996,2877,3002
3002,2877,3001
2750,2822,2971
2750,2971,2965
2971,2961,2916
2971,2916,2965
2982,2985,2971
2831,2877,2992
2822,2831,2992
2992,2996,2971
2996,2989,2971
2985,2988,2971
2932,2872,2750
2890,3001,2883
3002,3065,3050
3050,2996,3002
3214,3206,3155
3213,3214,3155
3358,3359,3342
3368,3346,3338
3368,3338,3367
3155,3202,3162
3359,3308,3342
3320,3308,3359
3308,3221,3307
3367,3338,3892
3121,3155,3162
3162,3202,3206
3075,2996,3050
3065,3075,3050
3320,3309,3308
3221,3308,3309
3155,3104,3094
3104,3155,3121
3075,2993,2996
2891,2916,2767
2719,2610,2767
2610,2884,2767
2544,2610,2719
2886,2961,2989
2886,2924,2961
2989,2993,2886
2744,2739,2886
2886,2767,2916
2916,2924,2886
2993,2997,2886
2997,3033,2886
2782,2744,2886
2739,2767,2886
2738,2732,2739
2738,2739,2744
2842,2848,2841
3221,3309,3170
3206,3214,3170
3206,3170,3162
3163,2997,2993
3040,3061,3033
3075,3163,2993
3061,3163,3081
3162,3163,3104
3163,3094,3104
3162,3104,3121
3163,3162,3170
3040,3163,3061
2997,3040,3033
3040,2997,3163
3359,3347,3320
3892,3368,3367
3892,3828,3368
3368,3342,3308
3368,3308,3307
3358,3368,3359
3368,3827,3359
3643,3359,3827
3827,3368,3828
3368,3358,3342
3284,3296,3338
3221,3214,3213
3274,3346,3368
3213,3274,3221
3151,3001,2890
3020,3154,3151
3154,3161,3002
3075,3155,3094
3075,3141,3155
3020,3151,2984
2984,3151,2890
3002,3001,3151
3274,3338,3346
3274,3284,3338
3020,3319,3169
3161,3020,3169
3319,3211,3169
3002,3169,3065
3161,3169,3002
3306,3319,3020
3232,3213,3212
3213,3284,3274
3307,3274,3368
3338,3296,3892
3212,3169,3211
3232,3212,3211
3155,3141,3205
3065,3205,3141
3169,3205,3065
3213,3169,3212
3213,3205,3169
3213,3155,3205
3065,3141,3075
1961,1796,1788
1815,1823,1606
2544,2580,2610
2767,2739,2544
2719,2767,2544
2560,2492,2458
2458,2465,2542
1974,1858,1675
1325,1667,1673
1673,1667,1648
1674,1673,1648
1291,1647,1325
1775,1788,1502
2021,1823,2011
1858,1989,2000
1989,1858,1974
2001,1823,1990
1858,1775,1674
1858,1674,1675
1673,1775,1325
1674,1775,1673
1279,1616,1647
1291,1279,1647
1325,1659,1667
1674,1648,1660
1667,1659,1648
1325,1647,1659
1635,1648,1647
1659,1647,1648
2136,2092,2127
1976,1977,1991
2542,2560,2458
2511,2580,2544
2560,2570,2511
2560,2511,2492
2580,2511,2570
2135,2419,2127
2000,2135,2127
2000,2127,2092
2000,2092,2048
2002,1991,1977
2145,2146,2092
2136,2145,2092
2146,2145,2162
2127,2419,2136
2162,2136,2419
2145,2136,2162
2511,2544,2297
2253,2162,2419
2285,2253,2419
2285,2419,2458
2162,2285,2146
2253,2285,2162
2298,2285,2297
2285,2511,2297
2492,2511,2285
2298,2146,2285
2297,2544,2298
2298,2544,2367
2357,2409,2420
2367,2357,2298
2409,2544,2420
2367,2544,2409
2367,2409,2357
2357,2420,2408
2732,2738,2420
1991,1990,1975
2021,2011,2002
1977,2146,2298
2002,1977,2298
2002,2001,1990
1975,1976,1991
2050,2034,2002
2034,2021,2002
2050,2002,2298
2002,1990,1991
1977,1960,2146
1961,1977,1976
1975,1961,1976
1977,1858,1960
1977,1961,1858
1858,2146,1960
1775,1502,1325
1990,1823,1815
1990,1815,1975
1961,1788,1775
1961,1775,1858
2049,1823,2050
1975,1815,1961
1961,1804,1796
1961,1815,1804
2050,1823,2034
2011,1823,2001
2034,1823,2021
2050,2073,2062
2062,2049,2050
1823,2049,2062
2073,2050,2084
2833,2834,2842
2050,2093,2084
2298,2357,2093
2298,2093,2050
1208,1221,1207
2093,2357,2112
2252,2213,2296
2694,2213,2186
2310,2309,2296
2155,2154,2112
2782,2886,2866
2782,2866,2862
3081,2956,3061
2956,2962,2885
3061,2956,2886
3061,2886,3033
2841,2833,2842
3174,3215,3216
2651,2744,2676
2651,2738,2744
2738,2651,2420
2885,2834,2878
2744,2690,2676
2972,3028,2848
2704,2705,2823
2873,2834,2870
2862,2866,2834
2834,2823,2694
2962,2834,2885
3432,3431,3442
2962,2966,2834
2782,2834,2744
2973,2972,2834
2973,2834,2966
2834,2972,2842
2870,2834,2866
2873,2878,2834
2841,2832,2833
2823,2833,2832
2842,2972,2848
2840,2841,2848
2823,2834,2833
2782,2862,2834
2840,2848,2847
3506,3493,3479
2697,2693,2698
2832,2840,2704
2699,2693,2694
2698,2705,2704
2744,2694,2690
2744,2834,2694
2651,2676,2694
2690,2694,2676
2694,2408,2420
2651,2694,2420
2699,2698,2693
2705,2698,2699
2697,2698,2704
2823,2705,2699
2123,1921,2109
2123,1959,1921
1923,1895,1907
2693,2697,2213
2310,2213,2697
2310,2296,2213
2185,2225,2212
2213,2185,2186
2694,2186,2408
2252,2185,2213
2252,2225,2185
2154,2186,2185
2408,2186,2155
2252,2296,1908
2466,2134,2457
3297,3298,3234
3257,3234,3298
3347,3384,3255
3415,3359,3643
3384,3256,3255
3409,3431,3256
3429,3415,3428
3461,3450,3449
3520,3522,3506
3494,3507,3525
3441,3431,3429
3526,3480,3494
3455,3444,3445
3455,3469,3444
3191,3239,3190
3469,3470,3483
3229,3256,3246
3255,3256,3229
3432,3442,3443
3442,3441,3452
3442,3431,3441
3450,3428,3449
3481,3468,3466
3432,3443,3468
3439,3450,3461
3439,3461,3464
3479,3452,3464
3466,3452,3479
3450,3439,3428
3468,3452,3466
3453,3452,3468
3452,3453,3443
3442,3452,3443
3441,3429,3452
3449,3428,3766
3431,3409,3429
3415,3416,3347
3428,3673,3766
3643,3428,3415
3673,3428,3643
3429,3416,3415
3298,3297,3327
3362,3432,3371
3362,3327,3432
3349,3432,3327
3223,3237,3217
3359,3415,3347
3199,3217,3175
3275,3362,3371
3347,3416,3384
3228,3320,3347
3228,3309,3320
3246,3234,3229
3229,3222,3170
3228,3229,3170
3170,3215,3163
3416,3409,3256
3384,3416,3256
3255,3229,3228
3327,3297,3256
3327,3256,3349
3222,3215,3170
3222,3234,3215
3309,3228,3170
3298,3362,3275
3298,3327,3362
3207,3178,3164
2966,3148,2973
3237,3230,3235
3312,3236,3237
3207,3216,3235
3275,3237,3298
3257,3298,3235
3297,3234,3246
3237,3235,3298
3297,3246,3256
3178,3199,3175
3178,3217,3199
3178,3223,3217
2973,3178,3175
3164,3178,2973
3148,3164,2973
3257,3235,3216
3234,3216,3215
3257,3216,3234
3230,3237,3223
3223,3178,3230
3207,3230,3178
3216,3207,3164
3174,3216,3164
3144,3237,3152
2972,2973,3175
3163,3148,3081
2956,3148,2962
3163,3156,3148
3148,3174,3164
3148,3156,3174
2962,3148,2966
3255,3228,3347
3175,3128,3082
2972,3175,3082
2972,3082,3072
3144,3113,3122
3028,2972,3072
3072,3082,3113
3028,3072,3113
3122,3113,3082
3144,3217,3237
3482,3494,3480
3122,3128,3144
3144,3128,3175
3372,3172,3239
3237,3236,3152
3217,3144,3175
3152,3330,3191
3152,3312,3330
3191,3190,3152
3312,3237,3371
3275,3371,3237
3493,3494,3481
3329,3239,3191
3330,3329,3191
3481,3494,3484
3483,3484,3494
3329,3328,3239
3312,3152,3236
3371,3400,3330
3494,3482,3483
3494,3493,3507
3444,3410,3372
3444,3372,3373
3329,3330,3350
3329,3350,3328
3484,3468,3481
3526,3494,3527
3469,3482,3444
3483,3470,3484
3524,3543,3525
3525,3543,3527
3469,3483,3482
3493,3481,3479
3527,3543,3526
3543,3524,3522
3468,3470,3455
3330,3400,3455
3400,3371,3455
3455,3371,3432
3432,3468,3455
3350,3330,3455
3470,3469,3455
3477,3492,3479
3482,3480,3467
3467,3454,3482
3444,3482,3454
3477,3461,3449
3493,3506,3507
3524,3506,3522
3506,3525,3507
3525,3506,3524
3477,3520,3492
3477,3503,3520
3477,3449,3474
3477,3474,3503
3790,3814,3474
3474,3449,3766
3474,3780,3790
3766,3780,3474
3503,3500,3515
3533,3835,3566
3500,3814,3813
3500,3474,3814
3474,3500,3503
3812,3500,3813
3812,3811,3500
3500,3533,3553
3500,3811,3823
3500,3823,3533
3533,3823,3835
3620,3655,3623
3623,3605,3585
3884,3602,3856
3618,3620,3602
3623,3603,3620
3620,3603,3602
3655,3653,3695
3653,3651,3695
3618,3651,3653
3620,3653,3655
3386,3385,3370
3491,3462,3463
3523,3491,3463
3626,3606,3625
3741,3749,3742
3627,3626,3661
3629,3607,3628
3710,3716,3717
3566,3605,3587
3585,3566,3565
3374,3375,3444
3856,3585,3565
3533,3566,3553
3846,3566,3834
3566,3835,3834
3566,3585,3605
3607,3588,3606
3606,3605,3625
3500,3553,3567
3515,3500,3567
3567,3503,3515
3520,3503,3567
3567,3553,3566
3520,3568,3569
3520,3567,3568
3588,3543,3571
3588,3608,3543
3375,3376,3444
3608,3588,3607
3607,3606,3627
3627,3606,3626
3606,3588,3567
3606,3566,3587
3567,3566,3606
3606,3587,3605
3628,3607,3627
3629,3628,3664
3625,3623,3655
3664,3628,3663
3625,3655,3659
3659,3655,3657
3626,3659,3661
3626,3625,3659
3663,3627,3661
3538,3523,3539
3610,3542,3526
3430,3404,3417
3628,3627,3663
3630,3629,3664
3609,3539,3610
3609,3558,3539
3630,3608,3607
3757,3663,3661
3758,3666,3759
3540,3526,3541
3541,3526,3542
3557,3538,3558
3608,3630,3543
3374,3373,3239
3522,3571,3543
3522,3520,3571
3588,3520,3570
3571,3520,3588
3467,3480,3417
3465,3451,3480
3480,3478,3465
3410,3454,3467
3373,3372,3239
3410,3417,3399
3350,3376,3328
3376,3239,3328
3444,3376,3445
3376,3350,3445
3375,3374,3239
3373,3374,3444
3403,3404,3430
3387,3410,3392
3410,3399,3392
3451,3539,3440
3523,3440,3539
3430,3417,3440
3440,3480,3451
3417,3480,3440
3521,3538,3537
3404,3399,3417
3421,3430,3463
3322,3421,3463
3462,3322,3463
3190,3165,3152
3067,3080,3071
2856,2848,3028
3372,3184,3172
2990,2994,2976
3171,3172,3176
3172,3180,3176
3179,3183,3238
3523,3521,3491
3071,3076,3070
3060,3059,3054
3066,3059,3067
2980,3171,3006
3192,3399,3404
2980,2977,3171
3059,3060,3067
2980,2990,2976
3399,3192,3392
3171,3165,3172
3176,3180,3179
3165,2925,2917
3372,3192,3184
3239,3165,3190
3172,3165,3239
3179,3060,3013
3179,3013,3171
2925,2980,2976
2925,2977,2980
3003,2990,3054
3003,2994,2990
3054,3013,3060
3392,3192,3387
3183,3192,3238
3013,3054,2990
3387,3192,3372
2980,3013,2990
2980,3006,3013
3171,2977,2925
3171,2925,3165
3179,3080,3067
3080,3179,3189
3176,3179,3171
3180,3183,3179
3060,3179,3067
3172,3184,3180
3184,3183,3180
3192,3183,3184
3311,3430,3322
3421,3322,3430
3192,3404,3276
3326,3322,3339
3361,3370,3369
3321,3322,3326
3537,3536,3519
3430,3311,3299
3403,3430,3299
3404,3403,3299
3276,3404,3299
3189,3179,3224
3238,3224,3179
3361,3322,3370
3321,3310,3311
3386,3370,3322
3310,3321,3360
3552,3408,3586
3438,3586,3408
3310,3299,3311
3238,3310,3224
3238,3299,3310
3027,3187,3136
3321,3311,3322
3339,3322,3343
3361,3369,3360
3361,3360,3348
3343,3348,3360
3343,3360,3339
3339,3360,3326
3360,3321,3326
3720,3719,3728
3652,3621,3622
3385,3369,3370
3516,3517,3534
3521,3537,3519
3385,3391,3408
3490,3501,3489
3632,3633,3668
3391,3475,3408
3490,3489,3476
3408,3475,3438
3518,3504,3505
3502,3501,3490
3491,3521,3505
3610,3526,3636
3391,3386,3398
3722,3721,3730
3572,3631,3555
3521,3523,3538
3756,3760,3761
3589,3573,3558
3539,3526,3540
3539,3480,3526
3480,3539,3478
3539,3465,3478
3539,3451,3465
3633,3609,3634
3622,3621,3584
3622,3584,3604
3491,3386,3322
3462,3491,3322
3369,3385,3408
3369,3408,3360
3386,3391,3385
3716,3725,3717
3488,3408,3552
3728,3719,3727
3518,3505,3519
3517,3535,3534
3437,3488,3552
3502,3516,3501
3398,3386,3476
3517,3516,3502
3504,3518,3517
3391,3476,3475
3391,3398,3476
3489,3475,3476
3556,3536,3537
3631,3572,3573
3504,3386,3491
3518,3535,3517
3504,3491,3505
3555,3536,3556
3536,3518,3519
3535,3518,3536
3490,3504,3502
3490,3476,3504
3504,3476,3386
3504,3517,3502
3660,3725,3658
3753,3754,3747
3535,3536,3555
3555,3556,3572
3557,3556,3537
3665,3666,3758
3753,3752,3758
3665,3662,3631
3734,3660,3662
3708,3656,3725
3658,3586,3624
3709,3708,3716
3743,3662,3751
3554,3535,3555
3534,3535,3554
3554,3660,3658
3734,3725,3660
3738,3745,3746
3700,3693,3699
3696,3702,3697
3554,3555,3662
3745,3752,3746
3554,3662,3660
3734,3662,3743
3624,3554,3658
3726,3727,3718
3710,3709,3716
3735,3727,3734
3727,3726,3734
3725,3726,3717
3692,3698,3693
3708,3725,3716
3744,3745,3737
3735,3728,3727
3735,3736,3728
3735,3743,3736
3735,3734,3743
3662,3555,3631
3725,3656,3658
3736,3743,3744
3744,3751,3745
3737,3745,3738
3610,3540,3541
3665,3758,3751
3752,3751,3758
3746,3752,3753
3759,3667,3760
3537,3538,3557
3610,3539,3540
3753,3747,3746
3634,3668,3633
3667,3632,3668
3633,3632,3609
3589,3609,3632
3668,3760,3667
3761,3760,3668
3632,3667,3666
3631,3632,3666
3539,3558,3538
3724,3723,3732
3572,3556,3557
3631,3573,3632
3557,3558,3573
3573,3589,3632
3732,3723,3731
3630,3526,3543
3630,3636,3526
3609,3589,3558
3724,3733,3742
3630,3664,3636
3762,3664,3663
3635,3610,3636
3609,3610,3635
3733,3724,3732
3636,3762,3668
3635,3636,3668
3762,3761,3668
3659,3750,3661
3634,3635,3668
3762,3636,3664
3759,3755,3754
3739,3746,3747
3755,3748,3754
3756,3750,3749
3748,3755,3749
3747,3748,3740
3722,3730,3731
3723,3722,3731
3733,3741,3742
3756,3755,3760
3759,3760,3755
3748,3749,3741
3740,3748,3741
3733,3740,3741
3750,3756,3757
3756,3761,3757
3757,3761,3762
3750,3757,3661
3747,3740,3739
3731,3739,3732
3739,3740,3732
3731,3738,3739
3738,3746,3739
3724,3715,3723
3721,3714,3720
3729,3721,3720
3729,3730,3721
3650,3690,3676
3685,3676,3690
3713,3712,3719
3718,3712,3711
3684,3683,3687
3687,3688,3684
3724,3701,3715
3701,3694,3715
3655,3695,3657
3695,3701,3659
3657,3695,3659
3701,3742,3659
3701,3695,3694
3687,3694,3688
3695,3689,3694
3695,3651,3689
3680,3683,3681
3683,3682,3687
3647,3676,3645
3691,3697,3692
3691,3685,3690
3694,3689,3688
3706,3711,3712
3709,3703,3708
3688,3689,3681
3688,3681,3684
3684,3681,3683
3648,3650,3676
3704,3703,3709
3710,3704,3709
3720,3713,3719
3720,3714,3713
3711,3717,3718
3698,3697,3702
3710,3717,3711
3501,3586,3489
3704,3699,3703
3699,3698,3703
3699,3693,3698
3698,3702,3703
3714,3707,3713
3712,3713,3707
3712,3707,3706
3687,3682,3707
3707,3682,3700
3706,3707,3700
3715,3707,3714
3715,3687,3707
3691,3686,3685
3718,3719,3712
3697,3691,3696
3696,3691,3690
3705,3706,3700
3705,3700,3704
3704,3700,3699
3711,3705,3710
3705,3704,3710
3705,3711,3706
3516,3586,3501
3692,3697,3698
3692,3686,3691
3686,3692,3693
3233,3244,3231
3604,3658,3656
3604,3586,3658
3438,3475,3586
3554,3624,3586
3586,3534,3554
3586,3516,3534
3652,3654,3690
3708,3696,3656
3551,3532,3584
3702,3696,3708
3656,3654,3622
3654,3656,3696
3654,3652,3622
3696,3690,3654
3652,3619,3621
3619,3584,3621
3604,3656,3622
3586,3604,3584
3650,3652,3690
3617,3619,3652
3617,3652,3650
3617,3650,3648
3528,3513,3514
3676,3644,3645
3595,3578,3598
3488,3437,3408
3580,3579,3562
3613,3614,3597
3649,3646,3681
3680,3682,3683
3680,3679,3682
3651,3618,3649
3678,3677,3682
3677,3693,3682
3677,3686,3693
3676,3686,3677
3678,3679,3676
3676,3681,3646
3680,3681,3676
3646,3649,3616
3600,3922,3616
3644,3676,3646
3676,3679,3680
3689,3651,3649
3689,3649,3681
3618,3600,3616
3618,3616,3649
3437,3586,3460
3437,3552,3586
3616,3614,3646
3646,3614,3644
3614,3613,3644
3437,3360,3408
3586,3473,3460
3615,3645,3644
3530,3531,3550
3586,3532,3473
3531,3532,3550
3551,3564,3563
3619,3617,3601
3586,3584,3532
3564,3582,3563
3564,3551,3584
3581,3549,3582
3550,3551,3563
3532,3551,3550
3619,3583,3564
3584,3619,3564
3617,3647,3645
3617,3645,3615
3530,3563,3549
3530,3550,3563
3564,3583,3582
3619,3582,3583
3619,3601,3582
3512,3562,3548
3549,3563,3582
3617,3581,3601
3614,3935,3597
3580,3562,3581
3514,3530,3529
3498,3499,3514
3487,3532,3499
3253,3325,3244
3498,3487,3499
3397,3448,3396
3549,3581,3528
3499,3531,3530
3460,3448,3436
3513,3472,3498
3407,3436,3273
3513,3497,3486
3265,3273,3272
3413,3420,3427
3434,3413,3427
3407,3402,3460
3407,3460,3436
3459,3448,3487
3532,3487,3448
3448,3473,3532
3448,3460,3473
3396,3427,3420
3402,3407,3273
3244,3245,3253
3253,3245,3254
3254,3265,3264
3548,3562,3561
3921,3560,3901
3548,3921,3883
3548,3560,3921
3528,3581,3562
3579,3578,3560
3561,3560,3548
3901,3560,3578
3615,3595,3598
3580,3599,3579
3644,3595,3615
3613,3595,3644
3561,3579,3560
3617,3615,3599
3581,3599,3580
3581,3617,3599
3595,3613,3596
3599,3615,3579
3579,3615,3578
3598,3578,3615
3616,3936,3614
3936,3935,3614
3613,3597,3596
3901,3578,3935
3935,3578,3595
3935,3595,3596
3935,3596,3597
3188,3080,3224
3496,3511,3495
3496,3495,3485
3485,3871,3855
3512,3513,3528
3434,3446,3426
3471,3446,3434
3434,3472,3471
3447,3472,3434
3405,3419,3641
3426,3822,3419
3446,3458,3485
3842,3832,3433
3395,3420,3413
3395,3414,3420
3413,3426,3406
3832,3426,3433
3832,3822,3426
3426,3405,3406
3426,3419,3405
3382,3395,3547
3405,3395,3406
3395,3413,3406
3497,3496,3486
3496,3446,3471
3496,3458,3446
3426,3413,3434
3427,3435,3447
3433,3426,3446
3855,3446,3485
3842,3433,3446
3842,3446,3843
3446,3855,3843
3528,3562,3512
3486,3471,3472
3459,3447,3435
3427,3447,3434
3420,3414,3396
3448,3459,3435
3396,3448,3435
3396,3435,3427
3472,3487,3498
3459,3487,3472
3459,3472,3447
3436,3397,3273
3496,3485,3458
3497,3512,3496
3497,3513,3512
3496,3512,3511
3548,3883,3510
3485,3495,3871
3872,3871,3495
3883,3495,3510
3883,3872,3495
3511,3510,3495
3389,3390,3396
3366,3283,3389
3272,3264,3265
3283,3325,3272
3264,3325,3253
3272,3273,3283
3272,3325,3264
3254,3264,3253
3396,3390,3397
3283,3397,3390
3273,3397,3283
3389,3396,3366
3325,3283,3357
3341,3414,3395
3356,3341,3383
3341,3395,3383
3325,3366,3396
3325,3396,3341
3325,3357,3366
3355,3356,3383
3382,3383,3395
3198,3160,3187
2954,2953,2947
2946,2953,3022
2947,2953,2946
2953,2954,3187
3437,3402,3273
3437,3273,3188
3233,3231,3227
3244,3233,3245
3231,3325,3252
3244,3325,3231
3210,3231,3252
3231,3210,3160
3227,3231,3198
3198,3231,3160
3360,3188,3310
3187,3188,3227
1906,1863,1921
2800,2540,2541
3022,3187,3027
3022,2953,3187
3188,3076,3080
3188,3070,3076
2954,3070,3188
3187,3160,3136
3198,3187,3227
3224,3310,3188
3227,3188,3233
3233,3188,3245
3245,3188,3254
3254,3188,3265
3189,3224,3080
2947,3070,2954
2947,2907,3070
2812,2947,2811
2800,2812,2540
2811,2540,2812
2907,3066,3070
2452,2379,2453
2379,2474,2453
2193,2452,2489
2193,2489,2211
2211,2275,1894
2275,2211,2489
1905,1959,1958
2452,2200,2356
2200,2452,2193
2193,1894,1819
1810,2193,1819
2211,1894,2193
1810,1792,2193
2123,2151,1959
2159,1959,2151
2133,2144,2143
2017,2009,2030
2250,2202,2194
2179,2183,2172
2858,2751,2856
2179,2172,2173
2856,2751,2847
2200,2250,2356
2200,2193,2250
2250,2379,2452
2356,2250,2452
2380,2379,2250
2193,1792,2043
1959,2043,1958
2143,2132,2133
2152,2160,2151
1605,1958,1701
1701,1958,1734
1958,2043,1734
1906,1921,1959
1905,1906,1959
1582,1905,1605
1582,1855,1905
1605,1905,1958
2296,2309,1987
2030,2045,2029
1987,1864,1908
1987,1972,1864
2134,2153,2144
2134,2144,2133
2110,2109,2045
1863,2109,1921
1863,2029,2109
2124,2117,2118
2045,2109,2029
1582,1856,1855
2125,2124,2118
2117,2110,2118
2117,2109,2110
2184,2183,2179
2183,2194,2202
2159,2183,2202
2151,2160,2183
2159,2151,2183
2751,2901,2759
2858,2901,2751
2117,2123,2109
2152,2161,2160
2123,2124,2132
2117,2124,2123
2153,2173,2161
2153,2161,2152
2160,2172,2183
2151,2123,2132
2143,2151,2132
2152,2151,2143
1959,2178,2043
2159,2178,1959
2193,2202,2250
2178,2159,2193
2202,2193,2159
2160,2161,2172
2172,2161,2173
2194,2183,2184
2490,2743,2541
2743,2800,2541
3059,3066,2907
3054,3059,2907
3003,3054,2907
2743,2907,2812
2907,2743,2731
2310,2543,2446
2581,2466,2457
2823,2832,2704
2925,2718,2703
2847,2848,2856
2856,3028,3113
2892,2856,3113
2759,2589,2581
2774,2759,2917
2901,2917,2759
2745,2310,2697
2704,2840,2847
2751,2704,2847
2745,2704,2751
2892,3113,2902
2783,2774,2917
2901,2856,2902
2901,2858,2856
2856,2892,2902
2902,2918,2901
2901,2918,2917
3165,2917,2918
3165,2918,2902
3165,2902,3152
3152,2902,3144
3144,2902,3113
2994,2925,2976
2994,2718,2925
2703,2774,2783
2703,2759,2774
2581,2589,2184
2783,2917,2703
2925,2703,2917
2250,2703,2380
2703,2718,2731
3003,2731,2994
3003,2907,2731
2994,2731,2718
2379,2380,2703
2250,2194,2703
2490,2474,2703
2703,2731,2743
2743,2490,2703
2194,2184,2589
2194,2589,2703
2589,2759,2703
2446,2134,2111
2184,2173,2581
2153,2466,2581
2173,2153,2581
2466,2153,2134
2457,2446,2581
2457,2134,2446
2310,2446,2309
2745,2543,2310
2581,2751,2759
2543,2745,2751
1895,1879,1830
1863,2017,2029
2017,2030,2029
2030,2009,2111
2045,2030,2111
1987,2009,1971
2009,1987,2446
1935,1971,1923
1923,1879,1895
1830,1908,1864
1830,1896,1908
1987,2309,2446
2296,1987,1908
1972,1830,1864
1972,1907,1830
1923,1907,1935
1971,1935,1946
1946,1987,1971
1972,1987,1946
1935,1907,1946
1907,1972,1946
1772,1785,1784
1907,1895,1830
1758,1691,1624
1614,1830,1744
1758,1614,1744
1624,1614,1758
1222,1208,1173
1186,1222,1173
1794,1795,1803
1830,1772,1758
1785,1830,1795
1879,1795,1830
1795,1971,1822
1795,1923,1971
1772,1830,1785
1744,1830,1758
1691,1758,1703
1803,1822,1813
1822,1803,1795
1784,1794,1813
1785,1794,1784
1794,1803,1813
1795,1794,1785
1784,1813,1829
1855,1856,1906
1856,1863,1906
1829,1712,1758
1829,1758,1784
1758,1712,1703
1170,1183,1160
1572,1162,1397
1572,1171,1162
1521,1572,1397
1093,1160,1183
1160,1142,1154
1142,1160,1127
1160,1154,1162
1170,1160,1162
1143,1154,1142
1143,1162,1154
1127,1114,1128
1128,1142,1127
1143,1142,1128
1101,1114,1127
1128,1114,1094
1040,1114,1101
1040,1094,1114
1101,1127,1040
839,961,953
839,954,961
961,1031,1020
961,1040,1031
1397,1162,1143
745,632,612
745,612,729
794,781,795
812,824,796
1040,961,1207
1572,1170,1171
1572,1184,1170
1572,1183,1184
1572,1195,1183
1572,1521,1533
1533,1573,1572
1573,1583,1572
1585,1599,1583
1573,1562,1585
1573,1585,1583
1397,1040,1207
1397,1094,1040
1572,1614,1624
1040,1093,1075
1572,1583,1614
1583,1599,1614
1533,1547,1573
1417,1521,1397
1397,1128,1094
1397,1143,1128
1521,1417,1533
1533,1417,1534
1533,1534,1547
634,796,576
1207,1197,1208
1324,1306,1236
1324,1417,1397
1324,1357,1417
1197,1207,1185
1562,1417,1357
1547,1417,1562
1236,1306,1397
1221,1236,1397
1207,1221,1397
1324,1397,1306
1222,1221,1208
731,493,476
839,1185,954
1237,1222,1186
1222,1278,1324
1222,1324,1236
1222,1236,1221
1278,1222,1237
1207,961,1185
1185,961,954
1208,1197,1173
1173,1197,1185
1173,1185,1163
1163,1081,1173
2225,2252,1773
1908,1773,2252
1786,1773,1830
1562,1773,1585
1773,2212,2225
1599,1773,1614
1599,1585,1773
1773,1786,1614
2093,2154,1773
2093,2112,2154
1759,2093,1773
1773,1908,1896
1830,1773,1896
2185,2212,1773
2154,2185,1773
1417,1547,1534
1493,1238,1186
1759,1493,1745
1773,1493,1759
1773,1562,1493
1278,1493,1324
1324,1562,1357
1324,1493,1562
1493,1278,1237
1493,1237,1238
1823,2062,1493
2084,1493,2073
2084,2093,1493
2093,1745,1493
1187,1493,1186
1173,1081,1186
1081,746,1070
1070,1076,1081
1187,1186,1081
1081,1493,1187
1081,1481,1493
1081,1082,1481
1081,1076,1082
870,785,1279
757,856,740
757,870,856
757,785,870
740,856,731
870,1279,1129
1129,1082,870
1076,870,1082
1070,870,1076
1129,1291,1082
1325,1082,1291
1291,1129,1279
1606,1481,1082
1606,1082,1502
1606,1502,1815
1804,1815,1502
1788,1796,1502
2073,1493,2062
1082,1325,1502
1276,1572,1624
1834,1856,1500
1856,1834,1829
1813,1822,1856
1829,1813,1856
1856,1822,2009
1863,1856,2009
1500,1856,1582
1218,1195,1572
1276,1265,1572
1218,1572,1265
1218,1183,1195
1093,1139,1125
1265,1093,1218
1127,1160,1093
1093,1183,1218
1031,1075,1020
781,782,795
1040,1075,1031
811,918,908
952,972,960
1251,1829,1834
1288,1251,1834
951,959,950
930,850,917
951,952,960
1276,1093,1265
1703,1712,1139
1373,1251,1288
1373,1355,1251
1093,952,918
1073,1067,1125
1125,1217,1073
1125,1139,1217
931,924,918
782,811,795
764,781,763
940,951,950
763,794,727
763,727,719
908,821,762
950,959,970
908,762,727
918,952,941
930,950,850
952,951,941
1125,952,1093
1125,972,952
931,941,940
908,917,837
908,837,821
917,918,924
917,908,918
924,931,930
951,960,959
971,983,982
972,1067,983
959,960,971
971,960,972
879,950,970
970,971,982
879,970,1066
970,1067,1066
970,982,1067
972,1125,1067
1479,1288,1492
1500,1492,1288
1500,1288,1321
1479,1373,1288
1139,1712,1251
552,544,561
552,537,544
794,908,727
782,1093,811
782,1075,1093
811,1093,918
794,795,908
908,795,811
781,794,763
781,764,782
710,752,763
839,953,730
710,763,719
953,961,730
682,681,671
681,682,692
1020,730,961
839,692,682
839,730,692
692,730,745
1075,730,1020
1075,782,730
632,745,678
745,710,678
745,752,710
764,752,745
730,782,745
764,745,782
410,514,391
410,515,514
659,658,649
671,658,672
650,659,649
681,692,745
681,561,544
681,552,561
681,570,552
570,681,585
672,658,659
839,672,659
812,825,824
824,825,839
682,671,672
379,464,506
410,379,506
650,649,642
796,824,650
590,586,642
576,642,586
650,642,576
419,421,418
413,419,412
591,606,601
359,328,354
324,307,234
324,351,354
452,449,465
470,586,590
465,470,464
470,590,642
385,410,392
470,465,576
465,456,452
465,464,456
576,465,449
576,449,562
355,464,356
355,456,464
443,452,456
329,324,312
355,443,456
318,307,324
354,356,379
356,354,355
356,464,379
118,85,96
470,576,586
642,464,470
522,464,642
544,522,681
671,681,522
649,522,642
438,396,514
438,514,505
506,464,522
658,522,649
522,658,671
396,391,514
340,334,312
359,273,266
522,410,506
522,515,410
537,522,544
537,515,522
372,273,359
354,372,359
354,379,372
276,273,391
385,392,391
379,391,372
379,385,391
463,514,511
463,505,514
392,410,391
106,85,118
514,543,511
417,396,442
417,400,396
391,396,276
400,339,396
463,425,446
463,469,425
446,442,463
417,442,446
417,446,425
438,505,442
463,442,505
469,463,511
514,515,537
77,76,71
198,96,92
198,92,147
147,77,133
220,221,229
124,96,198
198,234,200
307,200,234
328,200,318
328,266,200
318,200,307
146,141,200
200,124,198
141,124,200
146,200,273
200,266,273
132,78,104
132,97,78
42,78,97
42,97,93
41,70,42
71,106,70
76,106,71
70,107,75
70,106,107
70,75,78
84,78,75
107,84,75
59,70,56
72,77,60
59,60,77
59,77,71
71,70,59
56,70,41
59,56,60
35,40,21
56,41,36
41,40,36
40,35,36
148,147,133
133,77,121
121,77,72
60,121,72
22,36,35
22,35,21
60,57,22
56,36,22
56,22,57
18,17,23
22,21,18
23,22,18
60,22,23
60,23,121
17,64,23
64,68,23
158,157,149
151,159,271
150,151,271
150,271,274
86,90,145
88,245,171
88,153,245
171,87,88
370,731,386
171,170,87
95,87,170
211,170,177
177,170,171
216,215,211
370,349,450
731,476,386
169,151,144
370,386,402
169,215,271
224,216,177
370,480,486
228,223,224
548,731,370
563,731,548
370,486,491
548,370,491
144,165,169
152,165,144
169,165,215
223,228,370
223,215,216
224,223,216
224,177,178
349,370,228
224,178,228
349,245,249
349,178,245
349,228,178
170,211,95
165,211,215
145,91,95
145,152,144
211,165,95
145,95,165
386,476,402
370,402,401
401,406,405
271,223,370
413,412,405
406,401,402
413,406,402
405,406,413
419,413,402
476,419,402
299,184,296
418,421,440
419,418,412
419,440,421
405,271,401
274,271,405
529,492,855
493,855,492
856,855,493
419,493,492
419,476,493
554,607,577
602,607,547
554,547,607
419,492,529
440,419,529
547,440,529
855,602,547
529,855,547
746,607,1070
607,855,870
602,855,607
1070,607,870
440,547,554
607,606,591
576,562,601
576,601,617
617,613,618
607,591,577
591,554,577
440,591,467
440,554,591
617,601,613
613,601,606
607,618,606
607,746,618
746,626,618
618,626,617
746,634,626
738,634,746
576,617,634
617,626,634
746,796,738
738,796,634
812,796,746
839,650,824
839,659,650
1163,825,1081
825,746,1081
825,812,746
591,443,467
562,449,443
449,452,443
601,443,591
601,562,443
329,351,324
334,329,312
334,340,351
328,324,354
328,318,324
329,334,351
121,184,133
175,184,121
284,303,290
220,133,184
324,229,312
324,234,229
148,220,147
229,147,220
147,229,198
229,234,198
282,300,296
271,370,401
150,68,64
144,150,64
303,284,184
221,220,184
220,148,133
326,355,351
326,351,340
295,312,229
184,295,221
184,290,295
221,295,229
303,295,290
158,176,168
150,149,23
284,290,184
443,355,326
326,340,312
440,467,443
326,440,443
158,164,157
158,168,164
164,168,167
149,121,23
167,168,176
149,157,121
223,271,215
159,169,271
158,184,176
184,175,176
151,150,144
150,23,68
440,326,313
412,274,405
412,282,274
313,326,303
312,295,303
326,312,303
304,299,300
304,418,440
313,304,440
313,303,304
303,184,299
296,184,285
418,304,300
282,296,285
304,303,299
296,300,299
300,412,418
300,282,412
176,175,167
167,175,121
167,157,164
282,150,274
150,282,158
158,282,285
158,285,184
