cgal-discuss - Re: [cgal-discuss] Convex Hull 3D. ( Reposted)
  • To:
  • Subject: Re: [cgal-discuss] Convex Hull 3D. ( Reposted)
  • Date: Wed, 30 Oct 2013 13:08:49 -0400
On 2013-10-30, at 12:41 PM, KeithSloan52
wrote:
> But I am still a bit confused because OpenSCAD seems to be making the same
> call to Convex_hull, but when viewing its output the facets look to be
> mostly 4 sided.
Could it be that the 4-sided faces you see is an illusion due to CGAL
providing separate edge information, which we use to render edges?
See CGAL/Nef_polyhedron_3.h:561, CGAL/Nef_3/SCN_external_structure.h and
CGAL/Nef_3/SNC_simplify.h which could be responsible for this edge
construction. The code is really hard to read and as far as I can see not
documented, but perhaps someone here knows what's going on..
-Marius
