cgal-discuss - [cgal-discuss] Updating code based on CGAL
  • To:
  • Subject: [cgal-discuss] Updating code based on CGAL
  • Date: Sat, 2 Nov 2013 21:00:49 -0700 (PDT)
Hi,
I have old code based on CGAL 3.0. I would like to update this code to use
latest version of CGAL (4.3). The old code is using these typedef
typedef CGAL::Filtered_exact<double, CGAL::MP_Float> NT;
typedef CGAL::Cartesian<NT> Rep;
Filtered_exact<> is deprecated. The documentation suggests to replace it by
Filtered_kernel
http://www.cgal.org/Manual/3.2/doc_html/cgal_manual/NumberTypeSupport_ref/Class_Filtered_exact.html#Cross_link_anchor_1137
In my code I change these two typedef by
typedef CGAL::Simple_cartesian<CGAL::MP_Float> Rep;
typedef CGAL::Filtered_kernel<Rep> NT;
In my old code (CGAL v3.0) I have something like that
std::vector<NT> mdists;
mdists.resize( triang.number_of_vertices(), NT(0) );
At compilation step I receive this error
<function-style-cast>' : cannot convert from 'int' to 'NT'
Are my type def are correct?
Is is the rest of the code that need to be changed?
thank you
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Updating-code-based-on-CGAL-tp4658361.html
