cgal-discuss - Re: [cgal-discuss] Meshing of polyhedron persistently fails
  • To:
  • Subject: Re: [cgal-discuss] Meshing of polyhedron persistently fails
  • Date: Mon, 04 Nov 2013 09:39:29 +0100
Le 31/10/2013 23:40, Phil Weir a écrit :
On 30/10/13 17:28, Phil Weir wrote:
On 10/17/2013 05:57 PM, Garth N. Wells wrote:
What I'm doing is surface meshing a sphere, converting the surface mesh to a polyhedron, and trying to generate a volume mesh of the polyhedron (the motivation is to add/subtract polyhedra to create more complicated domains). The code that reproduces the error (using CGAL 4.2 and GCC 4.8) is attached. The code is basically a concatenation of the demos in sections 48.3.1 and 51.3.2. Any suggestions to get this working?
Garth
Actually, I have just had a very similar problem the last couple of days, same abort message - I rebuilt CGAL 4.2, with identical source to the working version, and it appeared. The old binary still runs fine. CGAL 4.2 and 4.3 show the same thing with the mesh_polyhedral_domain demo. A fresh compile of CGAL 4.3 on an Ubuntu 12.04 virtual box has no problems. As such, I suspect there may be something with library versions.
A related problem with the same code turned out to be this bug in the version of the STL libraries http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58800 that is now default on Ubuntu 13.10. I have not confirmed whether the underlying cause is related to the problem above too, but this particular one was occurring during conversion of a polyhedron to a Nef polyhedron - K3 tree calls std::nth_element, which in turn calls an introselect routine.
This routine runs past the iterator end in a small percentage of cases where it picks out a (critically) bad pivot. As K3 tree hits this routine a lot of times for a large polyhedron, it seems to fairly consistently kill my code for non-trivial tests - the comparison operator dereferences the iter and CGAL::assign fails to cast it. The upshot is a segfault below K3_tree.h:116-8 when trying to pull out the point value of a vertex for comparison - if anybody else sees this, that may be why.
I don't know if anybody else is currently trying CGAL on Ubuntu 13.10, but I could imagine that causing non-obvious bugs in other geometry-building places too.
I tried, and observed similar problems (segfault or memory problems) in triangulation_3 package.
It seems to work with gcc 4.7 also provided in ubuntu 13.10 but I did only few tests...
Best
Guillaume
Best,
PTW
Guillaume DAMIAND
CNRS - LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Tél: +33 (0)4.72.43.26.62 Fax: +33 (0)4.72.43.15.36
Mail:
Web: http://liris.cnrs.fr/guillaume.damiand/
Attachment: smime.p7s
Description: Signature cryptographique S/MIME
  • Re: [cgal-discuss] Meshing of polyhedron persistently fails, Guillaume Damiand, 11/04/2013
