[cgal-discuss] Merging/Combining two Polyhedron_3 with shared vertices and edges
- To:
- Subject: [cgal-discuss] Merging/Combining two Polyhedron_3 with shared vertices and edges
- Date: Wed, 13 Nov 2013 18:50:27 -0800 (PST)
I have a requirement to merge two Polyhedron_3 objects, one is closed
geometry and the other is a surface. There are common vertices and edges
between them. I have written a routine based on
Polyhedron_incremental_builder_3, I am able to successfully combine the
Polyhedron_3 objects (as checked by outputting results into OFF file),
however assertion errors due to shared halfedges unfortunately inhibit the
method. I am not even sure whether the approach I have taken works, I would
be very grateful for any help/advice or a solution to my problem?
Ideally, I would get to a point where I am able to combine the geometries
by:
CGAL::poly_merge<Polyhedron, HalfedgeDS> modifier(P1,P2);
P3.delegate(modifier);
or,
P2.delegate(modifier);
(I have checked orientation of surface but no effect + please note the code
below has worked well so far for combining geometry but due to the sorting
method there are exceptions!)
int compare_Point_3(const Point_3* p, const Point_3* q)
if ((fabs((*p)[0] - (*q)[0]) < GEOM_TOL) && (fabs((*p)[1] - (*q)[1]) <
GEOM_TOL) && (fabs((*p)[2] - (*q)[2]) < GEOM_TOL))
return 0;
} else {
double delta = ((*p)[0] * (*p)[0] + (*p)[1] * (*p)[1] + (*p)[2] *
(*p)[2]) - ((*q)[0] * (*q)[0] + (*q)[1] * (*q)[1] + (*q)[2] * (*q)[2]);
if (delta < 0) {
return -1;
} else {
return 1;
bool compare_lessthan(const Point_3* p, const Point_3* q)
return compare_Point_3(p, q) == -1;
namespace CGAL {
template <class Poly, class HDS>
class poly_merge : public Modifier_base<HDS> {
public:
typedef Poly Polyhedron;
typedef HDS Halfedge_data_structure;
poly_merge(const Polyhedron& poly_1, const Polyhedron& poly_2) :
input_1(poly_1), input_2(poly_2) {}
void operator()(HDS& output);
protected:
const Poly& input_1;
const Poly& input_2;
void poly_merge<Poly,HDS>:: operator()(HDS& output) {
typedef typename Poly::Vertex_const_iterator Vertex_const_iterator;
typedef typename Poly::Facet_const_iterator Facet_const_iterator;
typedef typename HDS::Vertex::Point Point;
typedef typename Poly::Point_3 Point_3;
typedef typename std::vector<const Point_3*> pPoints_3;
typename std::vector<const Point_3*>::iterator p_it;
typedef typename std::map<const Point_3*, int> Point_map;
pPoints_3 vert_input_1;
for (Vertex_const_iterator vi = input_1.vertices_begin(); vi !=
input_1.vertices_end(); ++vi) vert_input_1.push_back(&(vi->point()));
std::sort(vert_input_1.begin(), vert_input_1.end(),
compare_lessthan);
pPoints_3 vert_input_2;
for (Vertex_const_iterator vi = input_2.vertices_begin(); vi !=
input_2.vertices_end(); ++vi) vert_input_2.push_back(&(vi->point()));
std::sort(vert_input_2.begin(), vert_input_2.end(),
compare_lessthan);
Point_map pm;
pPoints_3 vert_input_2_diff, input_intersection;
int i = 0, j = 0;
while (i < vert_input_1.size() && j < vert_input_2.size()) {
std::cout << "i: " << i << "; j: " << j << std::endl;
int c = compare_Point_3(vert_input_1[i], vert_input_2[j]);
std::cout << "c: " << c << std::endl;
if (c == -1) {
++i;
} else if (c == 1) {
vert_input_2_diff.push_back(vert_input_2[j]);
++j;
} else if (c == 0) {
input_intersection.push_back(vert_input_1[i]);
pm[vert_input_2[j]] = i;
// std::cout << "Intersection: " << i << std::endl;
++i; ++j;
if (vert_input_2_diff.size() != vert_input_2.size())
vert_input_2_diff.push_back(vert_input_2[vert_input_2.size() - 1]);
std::cout << "Input 1 verts: " << vert_input_1.size() << "\n";
for (p_it = vert_input_1.begin(); p_it != vert_input_1.end();
++p_it) std::cout << *(*p_it) << std::endl;
std::cout << std::endl << std::endl;
std::cout << "Input 2 verts: " << vert_input_2.size() << "\n";
for (p_it = vert_input_2.begin(); p_it != vert_input_2.end();
std::cout << "Intersect points: " << input_intersection.size() <<
"\n";
for (p_it = input_intersection.begin(); p_it !=
input_intersection.end(); ++p_it) std::cout << *(*p_it) << std::endl;
std::cout << "Input 2 diff: " << vert_input_2_diff.size() << "\n";
for (p_it = vert_input_2_diff.begin(); p_it !=
vert_input_2_diff.end(); ++p_it) std::cout << *(*p_it) << std::endl;
std::cout << "intersection map\n"
"Printing point and position from original vector through pointer"
<< std::endl;
for (auto it = pm.begin(); it != pm.end(); ++it) {
std::cout << "Position: " << it->second << std::endl;
const Point_3* p = it->first;
std::cout << *p << std::endl;
Polyhedron_incremental_builder_3<HDS> B(output, true);
B.begin_surface(vert_input_1.size() + vert_input_2_diff.size(),
input_1.size_of_facets() + input_2.size_of_facets());
//std::cout << "OFF" << std::endl;
//std::cout << (vert_input_1.size() + vert_input_2_diff.size()) << "
" << (input_1.size_of_facets() + input_2.size_of_facets()) << " 0" <<
std::endl;
std::cout << std::endl;
for (i = 0; i < vert_input_1.size(); ++i)
B.add_vertex(Point_3(*(vert_input_1[i])));
pm[vert_input_1[i]] = i;
//std::cout << *(vert_input_1[i]) << std::endl;
//std::cout << "Index 1: " << pm[vert_input_1[i]] << std::endl;
for (j = 0; j < vert_input_2_diff.size(); ++j, ++i)
B.add_vertex(Point_3(*(vert_input_2_diff[j])));
pm[vert_input_2_diff[j]] = i;
//std::cout << *(vert_input_2_diff[j]) << std::endl;
//std::cout << "Index 1: " << pm[vert_input_2_diff[j]] <<
std::endl;
for (Facet_const_iterator fi = input_1.facets_begin(); fi !=
input_1.facets_end(); ++fi)
//std::cout << "3 ";
B.begin_facet();
typedef typename Poly::Halfedge_around_facet_const_circulator
Halfedge_around_facet_const_circulator;
Halfedge_around_facet_const_circulator hc = fi->facet_begin();
Halfedge_around_facet_const_circulator hc_end = hc;
CGAL_assertion( hc != NULL);
do {
B.add_vertex_to_facet(pm[&(hc->vertex()->point())]);
//std::cout << "Point around face 1: " <<
hc->vertex()->point() << std::endl;
//std::cout << pm[&(hc->vertex()->point())] << " ";
++hc;
} while( hc != hc_end);
B.end_facet();
//std::cout << std::endl;
for (Facet_const_iterator fi = input_2.facets_begin(); fi !=
input_2.facets_end(); ++fi)
B.begin_facet();
do {
//std::cout << "Point around face 2: " <<
++hc;
B.end_facet();
B.end_surface();
output.normalize_border();
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Merging-Combining-two-Polyhedron-3-with-shared-vertices-and-edges-tp4658412.html
- [cgal-discuss] Merging/Combining two Polyhedron_3 with shared vertices and edges, costantinos, 11/14/2013
- Re: [cgal-discuss] Merging/Combining two Polyhedron_3 with shared vertices and edges, Sebastien Loriot (GeometryFactory), 11/15/2013
