cgal-discuss - Re: [cgal-discuss] In-order traversal of Delaunay edges corresponding to unbounded Voronoi edges
  • To:
  • Subject: Re: [cgal-discuss] In-order traversal of Delaunay edges corresponding to unbounded Voronoi edges
  • Date: Fri, 15 Nov 2013 16:24:35 +0100
Le 11/15/13 4:14 PM, Martin Uhrin a écrit :
Thanks Monique.
I tried this approach. Or one that I think is equivalent:
delaunay.incident_edges(delaunay.infinite_vertex());
but as you said, this produces the convex hull of the triangulation. This
would give me edge 1-3, however I believe the dual of the ray that passes
through the label b is in fact edge 1-2 which is the one I want, followed by
edge 2-3.
The dual of b is not a ray but a finite Voronoi edge.
The fact that on your drawing you clip your Voronoi diagram
and the center of the circle circumscribnig triangle 123
is outside the screen does not mean it does not exist.
It exists, has been computed, and is finite.
