- To: Martin Uhrin <>
- Cc:
- Subject: Re: [cgal-discuss] Delaunay triangulation crash in spatial sort
- Date: Tue, 19 Nov 2013 16:28:58 +0100
Martin Uhrin
writes:
> Dear CGAL communit,
> I get a crashes with certain sets of input points when calculating a
> Delaunay triangulation. This example can be used to reproduce my crash:
> http://doc.cgal.org/latest/Triangulation_2/Triangulation_2_2voronoi_8cpp-example.html
> when using this input file: voronoi.cin
> <http://cgal-discuss.949826.n4.nabble.com/file/n4658433/voronoi.cin> .
> The crash persists even if I use an exact construction kernel and originates
> from a comparison within the spatial sort when creating the triangulation.
> A backtrace can be found here: gdb.txt
> <http://cgal-discuss.949826.n4.nabble.com/file/n4658433/gdb.txt> .
What's your gcc version? Could it be related to this gcc bug
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58800 ?
> Any ideas on what could be causing this would be much appreciated.
- [cgal-discuss] Delaunay triangulation crash in spatial sort, Martin Uhrin, 11/19/2013
- Re: [cgal-discuss] Delaunay triangulation crash in spatial sort, Philipp Moeller, 11/19/2013
- Re: [cgal-discuss] Delaunay triangulation crash in spatial sort, Martin Uhrin, 11/19/2013
