- To:
- Subject: Re: [cgal-discuss] CGAL 4.3 : intersection(Triangle_2, Triangle_2)
- Date: Wed, 27 Nov 2013 13:17:10 +0100
Le Wednesday 27 November 2013 12:14:22 Hugo Mercier a écrit :
> Hi,
> I found something strange with the last CGAL 4.3. The following file
> fails to compile. No good template deduction can be found. It only fails
> for Triangle_2 x Triangle_2 (Triangle_3 is ok)
> Apparently
> CGAL/Intersections_2/Triangle_2_Triangle_2_intersection_impl.h is
> correctly included, but something prevents it from being considered for
> candidate templates. I can't manage to see what is the problem.
> #include <CGAL/Exact_predicates_exact_constructions_kernel.h>
> #include <CGAL/intersections.h>
> typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
> int main() {
> CGAL::Triangle_2<Kernel> tri1, tri2;
> intersection( tri1, tri2 );
There must be a bug. What if you include <CGAL/intersections.h> before the
header of the kernel?
Which compiler have you used?
Laurent Rineau, PhD
- [cgal-discuss] CGAL 4.3 : intersection(Triangle_2, Triangle_2), Hugo Mercier, 11/27/2013
- Re: [cgal-discuss] CGAL 4.3 : intersection(Triangle_2, Triangle_2), Laurent Rineau (CGAL/GeometryFactory), 11/27/2013
- Re: [cgal-discuss] CGAL 4.3 : intersection(Triangle_2, Triangle_2), Hugo Mercier, 11/27/2013
- Re: [cgal-discuss] CGAL 4.3 : intersection(Triangle_2, Triangle_2), Andreas Fabri, 11/27/2013
