- To: "" <>
- Subject: Re: [cgal-discuss] Tetrahedral mesh viewer
- Date: Tue, 03 Dec 2013 19:56:53 +0100
Le mardi 03 décembre 2013 18:43:30 Yann Cobigo a écrit :
> Dear CGAL users and developers,
> Iwas wondering if some of you guys would have any suggestion for a
> tetrahedral meshviewer (file.mesh, or other format would work out). I use
> 'paraview' and 'medINRIA' but the rendering is not as good as 'medit'. The
> problem with 'medit' is that we have the binary and not the sources ...
> Today, the binary does not work anymore on my machines (fedora and ubuntu,
> both 64bit).
You just need to install the 32 bits version of libGL.so.1. I use medit with
Fedora 19 (64 bits), using the NVIDIA drivers, and it works.
Laurent Rineau, PhD
- [cgal-discuss] Tetrahedral mesh viewer, Yann Cobigo, 12/03/2013
- Re: [cgal-discuss] Tetrahedral mesh viewer, Laurent Rineau (CGAL/GeometryFactory), 12/03/2013
- Re: [cgal-discuss] Tetrahedral mesh viewer, Yann Cobigo, 12/04/2013
