Re: [cgal-discuss] Nearest neighbor query time increases as epsilon increases?!
- To:
- Subject: Re: [cgal-discuss] Nearest neighbor query time increases as epsilon increases?!
- Date: Wed, 04 Dec 2013 22:19:47 +0100
On 12/02/2013 05:13 PM, Samaras wrote:
Could you provide a minimal example showing the issue?
Sorry for taking me too long to answer, but I was trying to find a way to
minimize the code completely. I think I can't do nothing better than a .zip
file, which I provide in this link
<https://www.dropbox.com/s/z3ujtdm19fnt017/minimal.zip> from dropbox
In this .zip, I read from a file that contains 2^17 points in 17 dimensions,
with coordinates at {-1, 1}, into an std::vector.
Then I insert them into the tree and then I use the first 1000 points of the
vector as queries.
Here are the average time measurements I got: (for epsilon from 0.0 to 0.2)
NN for 0.0 0.000212090 seconds.
NN for 0.1 0.000376698 seconds.
NN for 0.15 0.004152510 seconds.
NN for 0.2 0.009170970 seconds.
I am really eager to hear from you! As you see, as the epsilon increases,
the time increases too! :/
What you use as distance can be negative which makes that you visit more
nodes of the tree when epsilon increases.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Nearest-neighbor-query-time-increases-as-epsilon-increases-tp4658494p4658503.html
- Re: [cgal-discuss] Nearest neighbor query time increases as epsilon increases?!, Samaras, 12/01/2013
- Re: [cgal-discuss] Nearest neighbor query time increases as epsilon increases?!, Sebastien Loriot (GeometryFactory), 12/02/2013
- Re: [cgal-discuss] Nearest neighbor query time increases as epsilon increases?!, Samaras, 12/02/2013
- Re: [cgal-discuss] Nearest neighbor query time increases as epsilon increases?!, Sebastien Loriot (GeometryFactory), 12/04/2013
- Re: [cgal-discuss] Nearest neighbor query time increases as epsilon increases?!, Samaras, 12/04/2013
