cgal-discuss - Re: [cgal-discuss] Undetected non-manifold vertex in poly3
  • To:
  • Subject: Re: [cgal-discuss] Undetected non-manifold vertex in poly3
  • Date: Mon, 16 Dec 2013 08:33:11 +0100
On 12/14/2013 11:26 AM, Zohar wrote:
Hi,
I have the mesh below, which I load with Polyhedron_3.exe demo. The
non-manifold vertex is not detected. Also, when I constructed this mesh
using Polyhedron_incremental_builder_3, the builder.test_facet() was
successful.
Hopefully incremental builder does not complain because in this case the
non-manifoldness can be resolved by adding another triangle.
Actually, I'm not even sure how can it detect that it's a bad
facet, without knowing if I'll add facets that would remedy the situation.
I suppose the answer is that the builder detects only non-manifold edges,
although the Polyhedron_3 can't cope with non-manifold vertices (e.g.
halfedge circulator around a vertex). Thus, I should use Nef.is_simple() to
detect non-manifold. But nef requires a slow build and gmp. I was wondering
if cgal offers a more efficient way (e.g. like MeshLab)?
Check the number of border edges incident to the vertex is more than 2.
Sebastien.
Thanks,
Zohar
OFF
14 16 0
-30.7325 -19.2431 -36.0255
-30.8645 -17.8773 -35.3618
-32.1125 -17.8012 -34.5874
-31.1675 -17.2117 -34.713
-31.808 -17.0522 -34.5372
-31.1318 -17.4698 -34.6007
-31.0541 -17.8668 -34.3054
-31.0108 -17.0475 -34.2369
-30.5593 -18.9909 -34.9694
-30.6328 -17.7648 -34.7113
-30.8158 -18.3803 -34.362
-30.6815 -16.8104 -35.0021
-30.9511 -17.0582 -34.4975
-30.6251 -17.2115 -34.2052
3 5 9 12
3 0 8 9
3 11 3 12
3 1 5 3
3 0 9 1
3 5 2 4
3 1 9 5
3 5 6 2
3 11 12 13
3 7 6 5
3 9 10 13
3 5 12 7
3 8 10 9
3 7 12 3
3 9 13 12
3 5 4 3
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Undetected-non-manifold-vertex-in-poly3-tp4658551.html
