cgal-discuss - Re: [cgal-discuss] Get the volume of a c2t3 object
  • To:
  • Subject: Re: [cgal-discuss] Get the volume of a c2t3 object
  • Date: Wed, 18 Dec 2013 21:58:58 +0100
Start from the infinite vertex, visit and mark all incident cells and their neighbors that don't have a facet on the surface. Collect the
neighbor cell sharing a facet on the surface and then reconstruct cells
in the volume. If you have holes and nested volume repeat the process.
Something similar is done in 2D here:
http://doc.cgal.org/latest/Triangulation_2/index.html#title29
Sebastien.
On 12/01/2013 05:41 PM, Ames wrote:
Hello,
I've been using the "3D Surface Mesh Generation Package" to create a surface
mesh using an implicit levelset function. My mesh is composed of several
connected components (the number of which varies according to the levelset
value). Since I have a Triangulation_3 embedded in a 2D complex, is it
possible to extract the volume of each component?
ps1: I use boost::graph to calculate the number of components
ps2: I also tried to create a c3t3 object using class
MeshComplexWithFeatures3 ,with the same implicit function and although i
have the volume mesh, i cannot iterate over the vertices or edges of the
complex and create an undirected graph with boost (zero components are
returned).
Thank you
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Get-the-volume-of-a-c2t3-object-tp4658497.html
