[cgal-discuss] Multiple volumes: Bug converting Nef polyhedron to Polyhedron_3?
- To:
- Subject: [cgal-discuss] Multiple volumes: Bug converting Nef polyhedron to Polyhedron_3?
- Date: Thu, 2 Jan 2014 01:39:25 -0500
Hi all,
Consider the two attached objects (a cube and a smaller cube).
I want to subtract the smaller cube from the larger one and export to OFF.
For demonstration purposes, this can be done using the Polyhedron_3 demo
which ships with CGAL:
o Add each file, convert each object to Nef, subtract, convert back to
Polyhedron and finally save as OFF
The issue: The saved OFF file has the inside walls facing the wrong way: It
is saved as one positive cube inside another positive cube.
This issue was discovered in OpenSCAD, a 3D modeling tool using CGAL, and a
detailed discussion about why we think this may be a CGAL bug can be found
here:
https://github.com/openscad/openscad/issues/495
Any ideas?
Cheers,
-Marius
cube10.off
Description: Binary data
cube5.off
- [cgal-discuss] Multiple volumes: Bug converting Nef polyhedron to Polyhedron_3?, Marius Kintel, 01/02/2014
- Re: [cgal-discuss] Multiple volumes: Bug converting Nef polyhedron to Polyhedron_3?, Sebastien Loriot (GeometryFactory), 01/02/2014
- Re: [cgal-discuss] Multiple volumes: Bug converting Nef polyhedron to Polyhedron_3?, Marius Kintel, 01/02/2014
