cgal-discuss - Re: [cgal-discuss] Bug of 'join_vertex' in CGAL?
  • To:
  • Subject: Re: [cgal-discuss] Bug of 'join_vertex' in CGAL?
  • Date: Mon, 27 Jan 2014 07:50:14 +0100
Add a break instruction after "if(found==0)found=1;" (you have no guarantee that obj->halfedges_begin() is still valid.
Sebastien.
On 01/26/2014 12:59 AM, tang wrote:
Hi Sebastien,
Thank you very much for your kindly remind, I got it.
However, I used the following code (by ), it still crashed. Is there any
problem in the code?
Thanks.
double minimum_edge_length = edgelengthmin*edgelengthmin; // squared
double len;
while(1)
int found=0;
Halfedge_iterator eb0=obj->halfedges_begin() ;
for( Polyhedron::Halfedge_iterator eb =
obj->halfedges_begin() ; eb !=
obj->halfedges_end() ; ++ eb )
len=get_edge_length<Polyhedron>(eb);
if(len<minimum_edge_length)
//remove_edge&lt;Polyhedron>(*obj, eb);
SMS::halfedge_collapse(eb,*obj);
eb=eb0 ;
else
eb0=eb;
if(found==0)break;
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-of-join-vertex-in-CGAL-tp4658645p4658709.html
