- To:
- Subject: Re: [cgal-discuss] MPI and locality
- Date: Tue, 04 Feb 2014 16:15:35 +0100
On 01/24/2014 11:49 AM, Mel M wrote:
Hi,If I understand correctly, the stitching pb is not related to the
I'm developing a program which uses CGAL - specifically the Polyhedron_3
object and the remeshing and intersection algorithms. It also uses MPI. When
in parallel, the domain and the polyhedral surfaces are split up spatially
into cuboids based on the Cartesian co-ordinates. I then run various CGAL
algorithms on each bit, and stitch them back together afterwards.
My problem is with locality - obviously if the algorithms are not local my
results will be dependent on how the domain is split up. Especially I'm
having trouble with remeshing the polyhedral surface on each core and then
stitching it back together afterwards, when there may have been vertices
added or removed on one side.
Has anyone done work using CGAL and MPI? How did you get the two to work
together? (I've read Parallel Multi-Core Geometric Algorithms in CGAL, but
it's not quite what I'm trying to do).
parallel runs but to the cuboid decomposition since the region
near the border of the cubes are not guarantee to match
(and won't in general).
Did I miss your question?
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/MPI-and-locality-tp4658707.html
- Re: [cgal-discuss] MPI and locality, Sebastien Loriot (GeometryFactory), 02/04/2014
- Re: [cgal-discuss] MPI and locality, Mel M, 02/04/2014
