- To:
- Subject: [cgal-discuss] CGAL in parallel (MPI)
- Date: Wed, 5 Feb 2014 02:09:36 -0800 (PST)
Has anyone done work using CGAL and MPI? How did you get the two to work
together? I've read Parallel Multi-Core Geometric Algorithms in CGAL, but
we're looking for a solution that will work without needing shared memory.
Specifically we're doing work with the Polyhedron_3 object, including
intersection calculation, remeshing etc.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-in-parallel-MPI-tp4658777.html
- [cgal-discuss] CGAL in parallel (MPI), Mel M, 02/05/2014
