cgal-discuss - Re: [cgal-discuss] Nearest neighbor query in a Delaunay triangulation
  • To:
  • Subject: Re: [cgal-discuss] Nearest neighbor query in a Delaunay triangulation
  • Date: Tue, 11 Feb 2014 16:47:27 +0100
Hello,
As a workaround, you may try the member function
instead of the global function.
http://doc.cgal.org/latest/Point_set_2/classCGAL_1_1Point__set__2.html
best,
andreas
On 11/02/2014 16:30, cdoucet wrote:
Hello,
I need to be able to find the nearest neighbor of a given point among the
vertices of a Delaunay triangulation.
My triangulation T is constructed from
Delaunay T(points.begin(),points.end())
where 'points' is a set of nodes.
I have seen in the documentation of CGAL that there exists a function
Dt::Vertex_handle CGAL::nearest_neighbor (const Dt &delau,
Dt::Vertex_handle v)
(see
http://doc.cgal.org/latest/Point_set_2/group__PkgPointSet2NeighborSearch.html)
However, I do not manage to use it.
My compiler claims that CGAL::nearest_neighbor does not exist.
I may do something wrong but I cannot find it.
Is there an header to be included?
Where can I find constructors of Dt::Vertex_handle?
Thank you very much for your help.
Best regards,
Cédric Doucet
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Nearest-neighbor-query-in-a-Delaunay-triangulation-tp4658803.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
