cgal-discuss - Re: [cgal-discuss] cant run configure on qt4
  • To:
  • Subject: Re: [cgal-discuss] cant run configure on qt4
  • Date: Mon, 17 Feb 2014 07:26:28 +0100
On 02/14/2014 04:50 PM, yarinkos wrote:
Hi,
I'm trying for days to install CGAL,
I tried to use the installation guide(X64),
and cant run to configure.exe in the command prompt of VS2010.
" There is no installer for the 64-bit version of QT4. You need to
download the sources of the open-source version and to compile them.
I download qt-everywhere-opensource-src-4.8.2.tar.gz
Extract it
I extract it to c:\dev. The directory
c:\dev\qt-everywhere-opensource-src-4.8.2 has been created
Open the Visual Studio Command Prompt
Go to the QT directory, configure and compile. If you build only the
libraries and the tools (without the examples), it should not take too much
time.
cd c:\dev\qt-everywhere-opensource-src-4.8.2
configure.exe
nmake sub-src
nmake sub-tools
i downloaded and extract the file C:\dev\qt-everywhere-opensource-src-5.2.1
CGAL is not compatible with Qt5, you need to use Qt4.
Sebastien.
but when open the command prompt and run configure.exe(after cd dev\qt-...
I get that configure.exe is unrecognized.
there is no file like that.
should i downland the zip version?
or there is installer for 64 version?
I'm really confused and stuck for a days with on and off work on it.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/cant-run-configure-on-qt4-tp4658826.html
