- To:
- Subject: [cgal-discuss] Get polygons with holes from Alpha_shape_2 result edges
- Date: Sun, 23 Feb 2014 23:28:50 +0900
Hi list,
I am trying to get polygons with holes from Alpha_shape_2 result edges,
but, is there the best way to get it?
I tried the following 2 ways((1), (2)), but I am not sure whether (1)
is valid way, and (2) way is really slow.
So, if the best way exists, I want to use it.
(1) Trace next segment which source point equals current segment's end point.
(If multiple segments' source points equal current segument's end
point, use most right side one to avoid switching inner <=> outer.)
(2) Join non-overlapped triangles by CGAL::join function.
The example code and test data are here.
https://gist.github.com/sanak/9156747
Regards,
Ko Nagase (長瀬 興)
Georepublic Japan
mail:
web: http://georepublic.co.jp
- [cgal-discuss] Get polygons with holes from Alpha_shape_2 result edges, Ko Nagase, 02/23/2014
