- To:
- Subject: Re: [cgal-discuss] Multi-level polyhedron
- Date: Fri, 28 Feb 2014 16:23:16 +0100
On 02/28/2014 04:09 PM, Zohar wrote:
Wow, the whole thing (halfedge_collapse) is changed. Are there still 5 cases
doing the same operations?
When there are no constrained edges it is the same. Otherwise, constrained edges cannot disappear.
you'll know what happen because you must have a container storing
I don't fully follow.
Record the neighborhood (a patch around the collapsed edge) before the
collapse, and upon undo I simply cut this neighborhood from the coarse mesh
and restore it to the way it was, sounds like a good idea.
The thing is that I have additional data on the edges which needs to be
updated if edges are collapsed (not related to the multi-resolution), so I
still need to follow what happens and update my own data in the coarse mesh.
pending simplices.
What do you mean by "modify halfedge_collapse", should I modify cgal sourcesModify the function halfedge_collapse so that the next/prev and
or write a template instantiation override?
incidence relationships are updated but do not remove any simplex.
The idea is to not remove any simplex so that handles are still valid.
What do you mean by "clean up the data structure from the pending
simplices"? I assume it's related to the first step that leaves the
simplicies, which are now actually deleted. But I don't see why the
cut/paste patch idea needs all this.
You will have simplices not used in the structure however, which is
why you need to clean things when the undo is no longer required.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Multi-level-polyhedron-tp4656471p4658889.html
- Re: [cgal-discuss] Multi-level polyhedron, (continued)
- Re: [cgal-discuss] Multi-level polyhedron, Zohar, 02/27/2014
- Re: [cgal-discuss] Multi-level polyhedron, Philipp Moeller, 02/27/2014
- Re: [cgal-discuss] Multi-level polyhedron, Sebastien Loriot (GeometryFactory), 02/28/2014
- Re: [cgal-discuss] Multi-level polyhedron, Zohar, 02/28/2014
