- To:
- Subject: [cgal-discuss] 3D mesh from cube with point-based layer boundaries
- Date: Mon, 3 Mar 2014 12:58:45 -0800 (PST)
Consider a geo model consisting of a cube with with irregular internal layer
boundaries defined by sets of 3D points. How would I go about generating a
3D tetrahedral mesh of such a model that maintains the layer boundaries in
the final mesh?
I believe this is the 3D constrained Delaunay triangulation mentioned in
another thread here as not yet officially available in CGAL. Is that
correct?
Thanks in advance
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-mesh-from-cube-with-point-based-layer-boundaries-tp4658895.html
- [cgal-discuss] 3D mesh from cube with point-based layer boundaries, fadecomic, 03/03/2014
- Re: [cgal-discuss] 3D mesh from cube with point-based layer boundaries, Sebastien Loriot (GeometryFactory), 03/04/2014
- Re: [cgal-discuss] 3D mesh from cube with point-based layer boundaries, Jack Stalnaker, 03/04/2014
- <Possible follow-up(s)>
