cgal-discuss - Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices
  • To:
  • Subject: Re: [cgal-discuss] Problem with Polyhedron_3 demo - intersection of objects with the same vertices
  • Date: Thu, 06 Mar 2014 21:37:18 +0100
On 03/06/2014 07:52 AM, swistak06 wrote:
Thanks for quick response.
The exampliar input files are here:
https://www.dropbox.com/s/nywdv80yzr0wpxp/henley_3D.off
https://www.dropbox.com/s/slxzfwhchpuix2p/henley_shift_3D.off
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-with-Polyhedron-3-demo-intersection-of-objects-with-the-same-vertices-tp4658911p4658913.html
First problem, your polyhedra are inconsistently oriented (which explain the checkerboard coloration when you open them in the demo.
Second problem you have non triangular facets which would not
be a problem for Nef if the vertices of the facets were coplanar
(which is not the case).
To fix this you can use the "Orient polygon soup" plugin and "Inside outside" plugin to fix the orientation.
The plugin "Triangulated facets" will help before creating nef polyhedra.
Sebastien.
