- To:
- Subject: [cgal-discuss] error C10004: unexpected end-of-file found
- Date: Sun, 9 Mar 2014 00:31:19 -0800 (PST)
I successfully generated a Visual Studio 2012 solution for building CGAL 4.3,
using CMake 2.8.12.1. When building "ALL_BUILD" project, the following
error is present in CGAL-4.3/include/config.h
Error 1 error C1004: unexpected end-of-file found C:\Program
Files\CGAL-4.3\include\CGAL\config.h 152 1 CGAL
Line 152 corresponds to the line after the #endif
#ifndef CGAL_NO_DEPRECATED_CODE
#define CGAL_BEGIN_NAMESPACE namespace CGAL {
#define CGAL_END_NAMESPACE }
#endif
I do not see any issue with absence of closing parentheses, brace, or need
for semicolon on that line. Further, I have not made any edits to the
config.h file and its date of modification is prior to the date I installed
CGAL.
How do I resolve this issue?
Thanks
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/error-C10004-unexpected-end-of-file-found-tp4658931.html
- [cgal-discuss] error C10004: unexpected end-of-file found, djkrome, 03/09/2014
- Re: [cgal-discuss] error C10004: unexpected end-of-file found, Laurent Rineau (CGAL/GeometryFactory), 03/10/2014
- Re: [cgal-discuss] error C10004: unexpected end-of-file found, djkrome, 03/13/2014
