- To:
- Subject: Re: [cgal-discuss] Questions about the undocumented polyhedron_cut_plane_3
- Date: Sat, 15 Mar 2014 18:33:32 -0700 (PDT)
Dear Sebastien,
Can this function work my problem?
I need to split triangle surface of a polyhedron by a given plane. The
result is that all triangles which are intersected with the plane are split
by the plane.
If it can work, how to use this function? or any other better functions can
solve my problem?
Thanks
Tang Laoya
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Questions-about-the-undocumented-polyhedron-cut-plane-3-tp3759412p4658965.html
- Re: [cgal-discuss] Questions about the undocumented polyhedron_cut_plane_3, tang, 03/16/2014
- Re: [cgal-discuss] Questions about the undocumented polyhedron_cut_plane_3, Zohar, 03/23/2014
