- To:
- Subject: Re: [cgal-discuss] Convert 3D alpha shape to polyhedron
- Date: Mon, 24 Mar 2014 08:53:22 +0100
The main difficulty will be that the alpha shape
is potentially non-manifold.
andreas
On 24/03/2014 08:50, Sebastien Loriot (GeometryFactory) wrote:
On 03/23/2014 01:24 AM, Alvin Smith wrote:
Hi everybody,
1. Is there a way to convert from a 3D alpha shape to a polyhedron?
2. Is there a way to do this without using the incremental builder?
It seems like this is possible, given that an alpha shape is a surface,
and so is the polyhedron.
Thank you,
AS
I don't think there is something working out-of-the-box.
However, using the Polyhedron_incremental_builder for this
purpose should be rather easy:
http://doc.cgal.org/latest/Polyhedron/classCGAL_1_1Polyhedron__incremental__builder__3.html
Sebastien.
- [cgal-discuss] Convert 3D alpha shape to polyhedron, Alvin Smith, 03/23/2014
- Re: [cgal-discuss] Convert 3D alpha shape to polyhedron, Sebastien Loriot (GeometryFactory), 03/24/2014
- Re: [cgal-discuss] Convert 3D alpha shape to polyhedron, Andreas Fabri, 03/24/2014
