- To:
- Subject: Re: [cgal-discuss] error in using bykat function of convex hull
- Date: Mon, 31 Mar 2014 16:27:45 +0530
I am using 'Exact_predicates_inexact_constructions_kernel"
On 3/30/14, Stefan Schirra
wrote:
> On 03/29/2014 03:54 PM, Ranjana Shevkar wrote:
>> hello,
>> I am using CGAL4.2_beta1 on Win XP. I am trying to calculate points on
>> convex hull using bykat, akl_toussaint and jarvis algorithms. for
>> bykat while executing for Random circular distribution 8192 points,
>> following run time error is there
>> CGAL error: postcondition violation!
>> Expression : is_ccw_strongly_convex_2(
>> res.output_so_far_begin(),res.output_so_far_end(),ch_traits)
>> File : C:\Program
>> Files\CGAL-4.2-beta1\include\CGAL/Convex_hull_2/ch_bykat_impl.h
>> Line : 109
>> Explanation:
>> Refer to the bug-reporting instructions at
>> http://www.cgal.org/bug_report.html
>> for jarvis , same error is given for all points.
>> for akl_toussaint there is an error : compatibility between input and
>> output iterator to forwarditerator.
> Which kernel do you use?
> Regards,
> Stefan
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] error in using bykat function of convex hull, Ranjana Shevkar, 03/29/2014
- Re: [cgal-discuss] error in using bykat function of convex hull, Stefan Schirra, 03/29/2014
- Re: [cgal-discuss] error in using bykat function of convex hull, Ranjana Shevkar, 03/31/2014
