cgal-discuss - Re: [cgal-discuss] Error while using make_surface_mesh
  • To:
  • Subject: Re: [cgal-discuss] Error while using make_surface_mesh
  • Date: Mon, 31 Mar 2014 15:51:28 +0200
Le Friday 21 March 2014 15:26:48 gupta61 a écrit :
> Hi,
> I am getting this error while trying to use make_surface_mesh function
> terminate called after throwing an instance of
> 'CGAL::Precondition_exception'
> what(): CGAL ERROR: precondition violation!
> Expr: ! k.is_degenerate_3_object()(t)
> >From what I understand, this is possible when I have a degenerate segment.
> But I checked all the points I am inserting for the surface and there are no
> degenerate segments. I was wondering if you can shed some light on this
> matter and other cases where it is possible to get this error. Thanks.
You report is very sparse. In which file, and which line do you see the
precondition error? Can you please also post the piece of code that you have
used to produce the exception, if it is not long?
Laurent Rineau, PhD
