cgal-discuss - Re: [cgal-discuss] Assertion violation in Delaunay_triangulation_3.h
  • To:
  • Subject: Re: [cgal-discuss] Assertion violation in Delaunay_triangulation_3.h
  • Date: Mon, 31 Mar 2014 19:39:18 +0200
Hi
that test does the following:
for each finite cell c
for each adjacent cell n of c
is the 4th vertex of n outside the circumscribing sphere of c?
see
http://doc.cgal.org/latest/Triangulation_3/classCGAL_1_1Delaunay__triangulation__3.html#af5c0c915316ad748b7c04ff5a9184dfe
and
http://doc.cgal.org/latest/Triangulation_3/index.html#title0
Monique Teillaud
http://www.inria.fr/sophia/members/Monique.Teillaud/
INRIA Sophia Antipolis - Méditerranée
Institut National de Recherche en Informatique et Automatique
Le 28/03/14 23:03, gupta61 a écrit :
One more thing. So the place where the code is failing is
(Taken from Delaunay_triangulation_3.h, CGAL 4.1)
if ( ! Tr_Base::is_valid(c,verbose,level) ) {
if (verbose) {
std::cerr << "combinatorically invalid cell" ;
for (int i=0; i <= dimension(); i++ )
std::cerr << c->vertex(i)->point() << ", " ;
std::cerr << std::endl;
CGAL_triangulation_assertion(false);
return false;
switch ( dimension() ) {
case 3:
if ( ! is_infinite(c) ) {
is_valid_finite(c,verbose,level);
for (int i=0; i<4; i++ ) {
if (side_of_sphere(c,
c->vertex((c->neighbor(i))->index(c))->point())
== ON_BOUNDED_SIDE ) {
if (verbose)
std::cerr << "non-empty sphere " << std::endl;
return false;
break;
Now the triangulation is valid because it is checking that
"Tr_Base::is_valid(c,verbose,level)" through this call. It is the second
test which I don't understand in terms of what it is trying to check? Can
you let me know a little bit more details about what /property/ is it
checking by this call "side_of_sphere(c,
c->vertex((c->neighbor(i))->index(c))->point()) == ON_BOUNDED_SIDE" ?
Thanks.
Piyush Gupta
UIUC
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Assertion-violation-in-Delaunay-triangulation-3-h-tp4659027p4659031.html
