cgal-discuss - [cgal-discuss] Construct Triangulation_2 from existing one
  • To:
  • Subject: [cgal-discuss] Construct Triangulation_2 from existing one
  • Date: Tue, 1 Apr 2014 08:53:29 -0700 (PDT)
Hi,
This question was asked before several times, and the answer is surprisingly
not possible. I wanted to verify that.
Let's say I have an existing triangulation (e.g. .off), and I want to load
it into Triangulation_2. My objective is to take advantage of the methods in
Triangulation_2, such as point location (which can be done with AABB tree as
well).
There is an overloaded operator>>, which reads only points, as far as I can
see, and ignores the connectivity.
So the only way, I can see, is to construct a constrained triangulation
(constraining the desired connectivity), and deleting redundant faces.
Is this correct? If it is, please consider making the Triangulation_2
construction more versatile.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Construct-Triangulation-2-from-existing-one-tp4659047.html
