Re: [cgal-discuss] CGAL 4.4 Released, Computational Geometry Algorithms Library
- To:
- Subject: Re: [cgal-discuss] CGAL 4.4 Released, Computational Geometry Algorithms Library
- Date: Sun, 06 Apr 2014 12:54:16 +0200
Hi,
On 04/04/2014 12:19 PM, Laurent Rineau (CGAL/GeometryFactory) wrote:
> The CGAL Open Source Project is pleased to announce the release 4.4
> of CGAL, the Computational Geometry Algorithms Library.
Debian packages for CGAL 4.4 are now available as well. Simply add
deb ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian wheezy main
deb-src ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian wheezy main
deb ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian jessie main
deb-src ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian jessie main
to /etc/apt/sources list (you only need the pair of lines corresponding to the
release you are using). For sid/unstable packages are available from the
official Debian repository. The packages are called libcgal10, libcgal-dev,
libcgal-qt4-10, libcgal-qt4-dev, libcgal-demo, and libcgal-ipelets.
In case you want to download the packages manually, have a look at
ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian/pool/main/c/cgal/
See also http://www.cgal.org/FAQ.html#debian_packages .
Joachim
- [cgal-discuss] CGAL 4.4 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 04/04/2014
- Re: [cgal-discuss] CGAL 4.4 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 04/04/2014
- Re: [cgal-discuss] CGAL 4.4 Released, Computational Geometry Algorithms Library, Joachim Reichel, 04/06/2014
