- To:
- Subject: Re: [cgal-discuss] Question about CGAL example: mesh_implicit_domains
- Date: Fri, 11 Apr 2014 15:23:16 +0200
Le Wednesday 09 April 2014 15:28:05 tang a écrit :
> Hi Sebastien,
> Thank you very much for your kindly reply. Is there any good method to pass
> double data to this kind of function?
No, you cannot. But you could use a functor, that is a class with operator(),
instead of a function.
class Cube_functor {
public:
Cube_functor(double x0,double y0,double z0,double r0);
double operator()(double x, double y, double z) const;
Then you can create a functor object with the right parameters:
Cube_functor my_cube(0.5, 0.5, 0.5, 0.5);
and use it as a function. Mesh_3 implicit domains can deal with a functor.
- [cgal-discuss] Question about CGAL example: mesh_implicit_domains, tang, 04/06/2014
- Re: [cgal-discuss] Question about CGAL example: mesh_implicit_domains, tang, 04/06/2014
- Re: [cgal-discuss] Question about CGAL example: mesh_implicit_domains, Laurent Rineau (CGAL/GeometryFactory), 04/07/2014
- Re: [cgal-discuss] Question about CGAL example: mesh_implicit_domains, tang, 04/10/2014
- Re: [cgal-discuss] Question about CGAL example: mesh_implicit_domains, Laurent Rineau (CGAL/GeometryFactory), 04/11/2014
