- To:
- Subject: Re: [cgal-discuss] Building issue with CGAL 4.4 on win32
- Date: Mon, 14 Apr 2014 11:24:20 +0200
Well, GMP_NUMB_BITS is 64 on my 64bit windows while building Win32 configuration in Visual C++. I'll investigate further.
2014-04-14 11:11 GMT+02:00 Marc Glisse <>:
On Mon, 14 Apr 2014, Olivier BARTHELEMY wrote:Hello,
I am getting compilation errors in my project with CGAL 4.4 when building a
windows 32bit executable in MSVC 2010. In that configuration, it seems
_BitScanForward64 and _BitScanReverse64, used in mpzf.h are not available
(as seen here :
http://msdn.microsoft.com/en-us/library/wfd9z0bb(v=vs.100).aspx, the 64bit
versions are not available on x86). Building with CGAL_DO_NOT_USE_MPZF macro
seems to solve the compilation problem, but i think #ifdef checks in that
header could be tweaked to avoid using it when the intrinsic is not
available
the file already checks:
GMP_NUMB_BITS == 64
(defined in gmp.h)
how did you end up with that in a 32 bit build?
Marc Glisse
Olivier BARTHELEMY Software development engineer Geovariances, 49bis avenue Franklin Roosevelt - 77215 AVON CEDEX - FRANCE | www.geovariances.com |
- [cgal-discuss] Building issue with CGAL 4.4 on win32, Olivier BARTHELEMY, 04/14/2014
- Re: [cgal-discuss] Building issue with CGAL 4.4 on win32, Marc Glisse, 04/14/2014
- Re: [cgal-discuss] Building issue with CGAL 4.4 on win32, Olivier BARTHELEMY, 04/14/2014
