- To:
- Subject: Re: [cgal-discuss] Unable to read .off files
- Date: Sat, 19 Apr 2014 20:38:32 +0100
I think the problem is in your file:
it should be:
OFF 4 2 0 -3.628 9.5893 -1.5654 -3.628 -0.2361 2.66 4.2771 -1.3605 -1.5654 4.2771 4.3454 2.66 3 0 1 3 3 1 2 3
i.e. 3 0 1 3, not 3 0 1 2
Forgive me if I am wrong.
Regards,
Giles
On 19 April 2014 20:08, dg <> wrote:
Hi all,
I am trying to read a .off file using the stream operator ( >> ) directly
into the polyhedron class
CGAL::Polyhedron_3<Exact_predicates_exact_constructions_kernel> but it not
reading the .off file.
Although, when I try to read standard .off files from internet they work
fine.
We are creating our own .off file according to its format. Here is the
sample file.
t1.off <http://cgal-discuss.949826.n4.nabble.com/file/n4659156/t1.off>
Thanks.
dg
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Unable-to-read-off-files-tp4659156.html
- [cgal-discuss] Unable to read .off files, dg, 04/19/2014
- Re: [cgal-discuss] Unable to read .off files, Giles Bathgate, 04/19/2014
- Re: [cgal-discuss] Unable to read .off files, dg, 04/19/2014
- Re: [cgal-discuss] Unable to read .off files, Giles Bathgate, 04/20/2014
- Message not available
- Re: [cgal-discuss] Unable to read .off files, dg, 04/20/2014
