cgal-discuss - Re: [cgal-discuss] Data structure similar to Arrangement_2 for 3D
  • To:
  • Subject: Re: [cgal-discuss] Data structure similar to Arrangement_2 for 3D
  • Date: Mon, 21 Apr 2014 19:01:34 +0300
Hi dg,
Unfortunately, such a data structure is not available neither in CGAL nor anywhere else to best of my knowledge.
As you can imagine, developing such a data structure is far from trivial.
Check out the Linear Cell Complex of CGAL. This is perhaps as close as it gets.
Efi
   ____  _        ____             _
  /_____/_) o    /__________  __  //
 (____ (   (    (    (_/ (_/-(-'_(/
                         _/
On Sun, Apr 20, 2014 at 1:21 AM, dg <> wrote:
Hello all,
I am trying to use a data structure which is similar to Arrangement_2 but in
3D.
Specifically, I need support for adding faces, planes, edges so that the
resulting arrangement is taken care of.
For example, if I add a face it should divide the polyhedron into two
volumes and create the corresponding half edges and faces.
Also, I need the volume iterator similar to face iterator available in
Arrangement_2.
Thanks in advance.
dg.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Data-structure-similar-to-Arrangement-2-for-3D-tp4659160.html
