- To:
- Subject: Re: [cgal-discuss] Intersection of two CONVEX 3D polyhedrons
- Date: Tue, 22 Apr 2014 19:27:24 -0700 (PDT)
Hi, Olivier,
I have a question for using duality to solve this problem.
Considering there are two convex polyhedrons which are not intersect with
each other any all.
However, using duality, I can map the faces of both of the polyhedrons to
vertices, and the convex hull of the mapped vertices is always exists.
Is it saying that the intersection of the original polyhedrons exists?
I am confused about this problem.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Intersection-of-two-CONVEX-3D-polyhedrons-tp4564202p4659179.html
- Re: [cgal-discuss] Intersection of two CONVEX 3D polyhedrons, TL3SHI2, 04/23/2014
- <Possible follow-up(s)>
- Re: [cgal-discuss] Intersection of two CONVEX 3D polyhedrons, Olivier Devillers, 04/23/2014
- Re: [cgal-discuss] Intersection of two CONVEX 3D polyhedrons, Andreas Fabri, 04/23/2014
