cgal-discuss - Re: [cgal-discuss] clang++ c++11 and stdlib libc++ on mac
  • To: "" <>
  • Subject: Re: [cgal-discuss] clang++ c++11 and stdlib libc++ on mac
  • Date: Thu, 24 Apr 2014 09:59:27 -0500
  • Accept-language: en-US
  • Acceptlanguage: en-US
Thank you, Marc and Laurent, very much for replying. I am attaching the
verbose build output.
>> That version of clang does not use -stdlib=libc++ by default. Instead,
>>it uses libstd++ (the STL from GNU/g++)Š
>> Probably the compilation of Boost using b2 has used the default stdlib
>>(libstdc++)...
True, but I specified stdlib=libc++ when building both boost and cgal.
Running oTool -L on the boost libraries (attached) shows that they are
built with libc++, and I am able to build a boost only program using them
with that argument (way down the email thread in the first email from me).
oTool -L /usr/local/lib/libboost_thread.dylib
/usr/local/lib/libboost_thread.dylib:
libboost_thread.dylib (compatibility version 0.0.0, current version
0.0.0)
libboost_system.dylib (compatibility version 0.0.0, current version
0.0.0)
/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version
65.1.0)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current
version
169.3.0)
There are other dependencies than boost for CGAL, of course. I installed
at least some of them using homebrew, which would use libstdc++ instead of
libc++ for my version of OsX 10.8 I understand. But if I check the dylibs
in ccmake, they were not built against libstdc++ directly. I suppose they
could have indirect dependencies, though.
oTool -L /usr/local/lib/libgmp.dylib
/usr/local/lib/libgmp.dylib:
/usr/local/opt/gmp/lib/libgmp.10.dylib (compatibility version 12.0.0,
current version 12.3.0)
version
169.3.0)
I wonder if upgrading to 10.9.x will solve some of these problems? I was
trying to avoid that if possible because I'm not very confident it will
help. It may make homebrew use libc++ when I install new packages though.
Thanks again!
Jared
On 4/24/14 4:39 AM, "Laurent Rineau (CGAL/GeometryFactory)"
wrote:
>Le Wednesday 23 April 2014 14:08:04 Becksfort, Jared a écrit :
>> Hello,
>> I have had some trouble getting programs using CGAL to run using c++11
>>on
>> a mac 10.8.5.
>> My clang++ version is
>> Apple LLVM version 4.2 (clang-425.0.28) (based on LLVM 3.2svn)
>> Target: x86_64-apple-darwin12.5.0
>> Thread model: posix
>That version of clang does not use -stdlib=libc++ by default. Instead, it
>uses
>libstd++ (the STL from GNU/g++).
>> The issue is very likely to be related to the stdlib argument, I think.
>> I
>> built boost using b2 and cgal using cmake with "-std=c++11
>> -stdlib=libc++"
>(libstdc++), and not the libc++ you have used to compile CGAL libraries.
>That
>way, you get libraries that are binary-incompatible. I suggest you either
>recompile Boost libraries with libc++, or recompile CGAL libraries with
>libstdc++.
>Laurent Rineau, PhD
>R&D Engineer at GeometryFactory http://www.geometryfactory.com/
>Release Manager of the CGAL Project http://www.cgal.org/
>You are currently subscribed to cgal-discuss.
>To unsubscribe or access the archives, go to
>https://sympa.inria.fr/sympa/info/cgal-discuss
Email Disclaimer: www.stjude.org/emaildisclaimer
Consultation Disclaimer: www.stjude.org/consultationdisclaimer
Thread model: posix
"/usr/bin/clang" -cc1 -triple x86_64-apple-macosx10.8.0 -emit-obj
-mrelax-all -disable-free -disable-llvm-verifier -main-file-name
scratch_cgal.cpp -pic-level 2 -mdisable-fp-elim -masm-verbose -munwind-tables
-target-cpu core2 -target-linker-version 136 -v -resource-dir
/usr/bin/../lib/clang/4.2 -fmodule-cache-path
/var/folders/rt/nynrzjhn151gb3cvm08cy1nc0000gp/T/clang-module-cache
-stdlib=libc++ -std=c++11 -fdeprecated-macro -fdebug-compilation-dir
/Users/jbecksfo/Documents/import_projects/cgal_test -ferror-limit 19
-fmessage-length 0 -stack-protector 1 -mstackrealign -fblocks
-fobjc-runtime=macosx-10.8.0 -fobjc-dispatch-method=mixed
-fobjc-default-synthesize-properties -fcxx-exceptions -fexceptions
-fdiagnostics-show-option -o
/var/folders/rt/nynrzjhn151gb3cvm08cy1nc0000gp/T/scratch_cgal-J4dfsL.o -x c++
scratch_cgal.cpp
clang -cc1 version 4.2 based upon LLVM 3.2svn default target
ignoring nonexistent directory "/usr/include/c++/v1"
#include "..." search starts here:
#include <...> search starts here:
/usr/bin/../lib/c++/v1
/usr/local/include
/usr/bin/../lib/clang/4.2/include
/usr/include
/System/Library/Frameworks (framework directory)
End of search list.
"/usr/bin/ld" -demangle -dynamic -arch x86_64 -macosx_version_min 10.8.0 -o
sout -lCGAL -lboost_thread
/var/folders/rt/nynrzjhn151gb3cvm08cy1nc0000gp/T/scratch_cgal-J4dfsL.o -lc++
-lSystem /usr/bin/../lib/clang/4.2/lib/darwin/libclang_rt.osx.a
Undefined symbols for architecture x86_64:
"std::__1::basic_istream<char, std::__1::char_traits<char>
>::operator>>(std::__1::basic_istream<char, std::__1::char_traits<char> >&
(*)(std::__1::basic_istream<char, std::__1::char_traits<char> >&))",
referenced from:
CGAL::operator>>(std::__1::basic_istream<char,
std::__1::char_traits<char> >&, CGAL::File_header_extended_OFF&) in
libCGAL.a(all_files.cpp.o)
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see
invocation)
Archive : /usr/local/lib/libboost_atomic.a
/usr/local/lib/libboost_atomic.a(lockpool.o):
/usr/local/lib/libboost_atomic.dylib:
libboost_atomic.dylib (compatibility version 0.0.0, current version
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_chrono.a
/usr/local/lib/libboost_chrono.a(chrono.o):
/usr/local/lib/libboost_chrono.a(thread_clock.o):
/usr/local/lib/libboost_chrono.a(process_cpu_clocks.o):
/usr/local/lib/libboost_chrono.dylib:
libboost_chrono.dylib (compatibility version 0.0.0, current version
0.0.0)
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_context.a
/usr/local/lib/libboost_context.a(make_x86_64_sysv_macho_gas.o):
/usr/local/lib/libboost_context.a(jump_x86_64_sysv_macho_gas.o):
/usr/local/lib/libboost_context.dylib:
libboost_context.dylib (compatibility version 0.0.0, current version
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_coroutine.a
/usr/local/lib/libboost_coroutine.a(standard_stack_allocator_posix.o):
/usr/local/lib/libboost_coroutine.a(coroutine_context.o):
/usr/local/lib/libboost_coroutine.a(exceptions.o):
/usr/local/lib/libboost_coroutine.dylib:
libboost_coroutine.dylib (compatibility version 0.0.0, current
version 0.0.0)
0.0.0)
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_date_time.a
/usr/local/lib/libboost_date_time.a(greg_month.o):
/usr/local/lib/libboost_date_time.a(greg_weekday.o):
/usr/local/lib/libboost_date_time.a(date_generators.o):
/usr/local/lib/libboost_date_time.dylib:
libboost_date_time.dylib (compatibility version 0.0.0, current
version 0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_exception.a
/usr/local/lib/libboost_exception.a(clone_current_exception_non_intrusive.o):
Archive : /usr/local/lib/libboost_filesystem.a
/usr/local/lib/libboost_filesystem.a(codecvt_error_category.o):
/usr/local/lib/libboost_filesystem.a(operations.o):
/usr/local/lib/libboost_filesystem.a(path.o):
/usr/local/lib/libboost_filesystem.a(path_traits.o):
/usr/local/lib/libboost_filesystem.a(portability.o):
/usr/local/lib/libboost_filesystem.a(unique_path.o):
/usr/local/lib/libboost_filesystem.a(utf8_codecvt_facet.o):
/usr/local/lib/libboost_filesystem.a(windows_file_codecvt.o):
/usr/local/lib/libboost_filesystem.dylib:
libboost_filesystem.dylib (compatibility version 0.0.0, current
version 0.0.0)
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_graph.a
/usr/local/lib/libboost_graph.a(read_graphviz_new.o):
/usr/local/lib/libboost_graph.a(graphml.o):
/usr/local/lib/libboost_graph.dylib:
libboost_graph.dylib (compatibility version 0.0.0, current version
0.0.0)
libboost_regex.dylib (compatibility version 0.0.0, current version
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_iostreams.a
/usr/local/lib/libboost_iostreams.a(file_descriptor.o):
/usr/local/lib/libboost_iostreams.a(mapped_file.o):
/usr/local/lib/libboost_iostreams.a(bzip2.o):
/usr/local/lib/libboost_iostreams.a(gzip.o):
/usr/local/lib/libboost_iostreams.a(zlib.o):
/usr/local/lib/libboost_iostreams.dylib:
libboost_iostreams.dylib (compatibility version 0.0.0, current
version 0.0.0)
/usr/lib/libz.1.dylib (compatibility version 1.0.0, current version
1.2.5)
/usr/lib/libbz2.1.0.dylib (compatibility version 1.0.0, current
version 1.0.5)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_locale.a
/usr/local/lib/libboost_locale.a(codepage.o):
/usr/local/lib/libboost_locale.a(date_time.o):
/usr/local/lib/libboost_locale.a(format.o):
/usr/local/lib/libboost_locale.a(formatting.o):
/usr/local/lib/libboost_locale.a(generator.o):
/usr/local/lib/libboost_locale.a(ids.o):
/usr/local/lib/libboost_locale.a(localization_backend.o):
/usr/local/lib/libboost_locale.a(message.o):
/usr/local/lib/libboost_locale.a(mo_lambda.o):
/usr/local/lib/libboost_locale.a(codecvt_converter.o):
/usr/local/lib/libboost_locale.a(default_locale.o):
/usr/local/lib/libboost_locale.a(info.o):
/usr/local/lib/libboost_locale.a(locale_data.o):
/usr/local/lib/libboost_locale.a(codecvt.o):
/usr/local/lib/libboost_locale.a(collate.o):
/usr/local/lib/libboost_locale.a(converter.o):
/usr/local/lib/libboost_locale.a(numeric.o):
/usr/local/lib/libboost_locale.a(posix_backend.o):
/usr/local/lib/libboost_locale.a(std_backend.o):
/usr/local/lib/libboost_locale.a(gregorian.o):
/usr/local/lib/libboost_locale.dylib:
libboost_locale.dylib (compatibility version 0.0.0, current version
0.0.0)
0.0.0)
/usr/lib/libiconv.2.dylib (compatibility version 7.0.0, current
version 7.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_log.a
/usr/local/lib/libboost_log.a(dump_ssse3.o):
/usr/local/lib/libboost_log.a(dump_avx2.o):
/usr/local/lib/libboost_log.a(attribute_name.o):
/usr/local/lib/libboost_log.a(attribute_set.o):
/usr/local/lib/libboost_log.a(attribute_value_set.o):
/usr/local/lib/libboost_log.a(code_conversion.o):
/usr/local/lib/libboost_log.a(core.o):
/usr/local/lib/libboost_log.a(record_ostream.o):
/usr/local/lib/libboost_log.a(severity_level.o):
/usr/local/lib/libboost_log.a(global_logger_storage.o):
/usr/local/lib/libboost_log.a(named_scope.o):
/usr/local/lib/libboost_log.a(process_name.o):
/usr/local/lib/libboost_log.a(process_id.o):
/usr/local/lib/libboost_log.a(thread_id.o):
/usr/local/lib/libboost_log.a(timer.o):
/usr/local/lib/libboost_log.a(exceptions.o):
/usr/local/lib/libboost_log.a(default_attribute_names.o):
/usr/local/lib/libboost_log.a(default_sink.o):
/usr/local/lib/libboost_log.a(text_ostream_backend.o):
/usr/local/lib/libboost_log.a(text_file_backend.o):
/usr/local/lib/libboost_log.a(syslog_backend.o):
/usr/local/lib/libboost_log.a(thread_specific.o):
/usr/local/lib/libboost_log.a(once_block.o):
/usr/local/lib/libboost_log.a(timestamp.o):
/usr/local/lib/libboost_log.a(threadsafe_queue.o):
/usr/local/lib/libboost_log.a(event.o):
/usr/local/lib/libboost_log.a(trivial.o):
/usr/local/lib/libboost_log.a(spirit_encoding.o):
/usr/local/lib/libboost_log.a(format_parser.o):
/usr/local/lib/libboost_log.a(date_time_format_parser.o):
/usr/local/lib/libboost_log.a(named_scope_format_parser.o):
/usr/local/lib/libboost_log.a(unhandled_exception_count.o):
/usr/local/lib/libboost_log.a(dump.o):
/usr/local/lib/libboost_log.dylib:
libboost_log.dylib (compatibility version 0.0.0, current version
0.0.0)
0.0.0)
version 0.0.0)
version 0.0.0)
0.0.0)
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_log_setup.a
/usr/local/lib/libboost_log_setup.a(parser_utils.o):
/usr/local/lib/libboost_log_setup.a(init_from_stream.o):
/usr/local/lib/libboost_log_setup.a(init_from_settings.o):
/usr/local/lib/libboost_log_setup.a(settings_parser.o):
/usr/local/lib/libboost_log_setup.a(filter_parser.o):
/usr/local/lib/libboost_log_setup.a(formatter_parser.o):
/usr/local/lib/libboost_log_setup.a(default_filter_factory.o):
/usr/local/lib/libboost_log_setup.a(matches_relation_factory.o):
/usr/local/lib/libboost_log_setup.a(default_formatter_factory.o):
/usr/local/lib/libboost_log_setup.dylib:
libboost_log_setup.dylib (compatibility version 0.0.0, current
version 0.0.0)
0.0.0)
0.0.0)
version 0.0.0)
version 0.0.0)
0.0.0)
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_math_c99.a
/usr/local/lib/libboost_math_c99.a(acosh.o):
/usr/local/lib/libboost_math_c99.a(asinh.o):
/usr/local/lib/libboost_math_c99.a(atanh.o):
/usr/local/lib/libboost_math_c99.a(cbrt.o):
/usr/local/lib/libboost_math_c99.a(copysign.o):
/usr/local/lib/libboost_math_c99.a(erfc.o):
/usr/local/lib/libboost_math_c99.a(erf.o):
/usr/local/lib/libboost_math_c99.a(expm1.o):
/usr/local/lib/libboost_math_c99.a(fmax.o):
/usr/local/lib/libboost_math_c99.a(fmin.o):
/usr/local/lib/libboost_math_c99.a(fpclassify.o):
/usr/local/lib/libboost_math_c99.a(hypot.o):
/usr/local/lib/libboost_math_c99.a(lgamma.o):
/usr/local/lib/libboost_math_c99.a(llround.o):
/usr/local/lib/libboost_math_c99.a(log1p.o):
/usr/local/lib/libboost_math_c99.a(lround.o):
/usr/local/lib/libboost_math_c99.a(nextafter.o):
/usr/local/lib/libboost_math_c99.a(nexttoward.o):
/usr/local/lib/libboost_math_c99.a(round.o):
/usr/local/lib/libboost_math_c99.a(tgamma.o):
/usr/local/lib/libboost_math_c99.a(trunc.o):
/usr/local/lib/libboost_math_c99.dylib:
libboost_math_c99.dylib (compatibility version 0.0.0, current version
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_math_c99f.a
/usr/local/lib/libboost_math_c99f.a(acoshf.o):
/usr/local/lib/libboost_math_c99f.a(asinhf.o):
/usr/local/lib/libboost_math_c99f.a(atanhf.o):
/usr/local/lib/libboost_math_c99f.a(cbrtf.o):
/usr/local/lib/libboost_math_c99f.a(copysignf.o):
/usr/local/lib/libboost_math_c99f.a(erfcf.o):
/usr/local/lib/libboost_math_c99f.a(erff.o):
/usr/local/lib/libboost_math_c99f.a(expm1f.o):
/usr/local/lib/libboost_math_c99f.a(fmaxf.o):
/usr/local/lib/libboost_math_c99f.a(fminf.o):
/usr/local/lib/libboost_math_c99f.a(fpclassifyf.o):
/usr/local/lib/libboost_math_c99f.a(hypotf.o):
/usr/local/lib/libboost_math_c99f.a(lgammaf.o):
/usr/local/lib/libboost_math_c99f.a(llroundf.o):
/usr/local/lib/libboost_math_c99f.a(log1pf.o):
/usr/local/lib/libboost_math_c99f.a(lroundf.o):
/usr/local/lib/libboost_math_c99f.a(nextafterf.o):
/usr/local/lib/libboost_math_c99f.a(nexttowardf.o):
/usr/local/lib/libboost_math_c99f.a(roundf.o):
/usr/local/lib/libboost_math_c99f.a(tgammaf.o):
/usr/local/lib/libboost_math_c99f.a(truncf.o):
/usr/local/lib/libboost_math_c99f.dylib:
libboost_math_c99f.dylib (compatibility version 0.0.0, current
version 0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_math_c99l.a
/usr/local/lib/libboost_math_c99l.a(acoshl.o):
/usr/local/lib/libboost_math_c99l.a(asinhl.o):
/usr/local/lib/libboost_math_c99l.a(atanhl.o):
/usr/local/lib/libboost_math_c99l.a(cbrtl.o):
/usr/local/lib/libboost_math_c99l.a(copysignl.o):
/usr/local/lib/libboost_math_c99l.a(erfcl.o):
/usr/local/lib/libboost_math_c99l.a(erfl.o):
/usr/local/lib/libboost_math_c99l.a(expm1l.o):
/usr/local/lib/libboost_math_c99l.a(fmaxl.o):
/usr/local/lib/libboost_math_c99l.a(fminl.o):
/usr/local/lib/libboost_math_c99l.a(fpclassifyl.o):
/usr/local/lib/libboost_math_c99l.a(hypotl.o):
/usr/local/lib/libboost_math_c99l.a(lgammal.o):
/usr/local/lib/libboost_math_c99l.a(llroundl.o):
/usr/local/lib/libboost_math_c99l.a(log1pl.o):
/usr/local/lib/libboost_math_c99l.a(lroundl.o):
/usr/local/lib/libboost_math_c99l.a(nextafterl.o):
/usr/local/lib/libboost_math_c99l.a(nexttowardl.o):
/usr/local/lib/libboost_math_c99l.a(roundl.o):
/usr/local/lib/libboost_math_c99l.a(tgammal.o):
/usr/local/lib/libboost_math_c99l.a(truncl.o):
/usr/local/lib/libboost_math_c99l.dylib:
libboost_math_c99l.dylib (compatibility version 0.0.0, current
version 0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_math_tr1.a
/usr/local/lib/libboost_math_tr1.a(assoc_laguerre.o):
/usr/local/lib/libboost_math_tr1.a(assoc_legendre.o):
/usr/local/lib/libboost_math_tr1.a(beta.o):
/usr/local/lib/libboost_math_tr1.a(comp_ellint_1.o):
/usr/local/lib/libboost_math_tr1.a(comp_ellint_2.o):
/usr/local/lib/libboost_math_tr1.a(comp_ellint_3.o):
/usr/local/lib/libboost_math_tr1.a(cyl_bessel_i.o):
/usr/local/lib/libboost_math_tr1.a(cyl_bessel_j.o):
/usr/local/lib/libboost_math_tr1.a(cyl_bessel_k.o):
/usr/local/lib/libboost_math_tr1.a(cyl_neumann.o):
/usr/local/lib/libboost_math_tr1.a(ellint_1.o):
/usr/local/lib/libboost_math_tr1.a(ellint_2.o):
/usr/local/lib/libboost_math_tr1.a(ellint_3.o):
/usr/local/lib/libboost_math_tr1.a(expint.o):
/usr/local/lib/libboost_math_tr1.a(hermite.o):
/usr/local/lib/libboost_math_tr1.a(laguerre.o):
/usr/local/lib/libboost_math_tr1.a(legendre.o):
/usr/local/lib/libboost_math_tr1.a(riemann_zeta.o):
/usr/local/lib/libboost_math_tr1.a(sph_bessel.o):
/usr/local/lib/libboost_math_tr1.a(sph_legendre.o):
/usr/local/lib/libboost_math_tr1.a(sph_neumann.o):
/usr/local/lib/libboost_math_tr1.dylib:
libboost_math_tr1.dylib (compatibility version 0.0.0, current version
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_math_tr1f.a
/usr/local/lib/libboost_math_tr1f.a(assoc_laguerref.o):
/usr/local/lib/libboost_math_tr1f.a(assoc_legendref.o):
/usr/local/lib/libboost_math_tr1f.a(betaf.o):
/usr/local/lib/libboost_math_tr1f.a(comp_ellint_1f.o):
/usr/local/lib/libboost_math_tr1f.a(comp_ellint_2f.o):
/usr/local/lib/libboost_math_tr1f.a(comp_ellint_3f.o):
/usr/local/lib/libboost_math_tr1f.a(cyl_bessel_if.o):
/usr/local/lib/libboost_math_tr1f.a(cyl_bessel_jf.o):
/usr/local/lib/libboost_math_tr1f.a(cyl_bessel_kf.o):
/usr/local/lib/libboost_math_tr1f.a(cyl_neumannf.o):
/usr/local/lib/libboost_math_tr1f.a(ellint_1f.o):
/usr/local/lib/libboost_math_tr1f.a(ellint_2f.o):
/usr/local/lib/libboost_math_tr1f.a(ellint_3f.o):
/usr/local/lib/libboost_math_tr1f.a(expintf.o):
/usr/local/lib/libboost_math_tr1f.a(hermitef.o):
/usr/local/lib/libboost_math_tr1f.a(laguerref.o):
/usr/local/lib/libboost_math_tr1f.a(legendref.o):
/usr/local/lib/libboost_math_tr1f.a(riemann_zetaf.o):
/usr/local/lib/libboost_math_tr1f.a(sph_besself.o):
/usr/local/lib/libboost_math_tr1f.a(sph_legendref.o):
/usr/local/lib/libboost_math_tr1f.a(sph_neumannf.o):
/usr/local/lib/libboost_math_tr1f.dylib:
libboost_math_tr1f.dylib (compatibility version 0.0.0, current
version 0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_math_tr1l.a
/usr/local/lib/libboost_math_tr1l.a(assoc_laguerrel.o):
/usr/local/lib/libboost_math_tr1l.a(assoc_legendrel.o):
/usr/local/lib/libboost_math_tr1l.a(betal.o):
/usr/local/lib/libboost_math_tr1l.a(comp_ellint_1l.o):
/usr/local/lib/libboost_math_tr1l.a(comp_ellint_2l.o):
/usr/local/lib/libboost_math_tr1l.a(comp_ellint_3l.o):
/usr/local/lib/libboost_math_tr1l.a(cyl_bessel_il.o):
/usr/local/lib/libboost_math_tr1l.a(cyl_bessel_jl.o):
/usr/local/lib/libboost_math_tr1l.a(cyl_bessel_kl.o):
/usr/local/lib/libboost_math_tr1l.a(cyl_neumannl.o):
/usr/local/lib/libboost_math_tr1l.a(ellint_1l.o):
/usr/local/lib/libboost_math_tr1l.a(ellint_2l.o):
/usr/local/lib/libboost_math_tr1l.a(ellint_3l.o):
/usr/local/lib/libboost_math_tr1l.a(expintl.o):
/usr/local/lib/libboost_math_tr1l.a(hermitel.o):
/usr/local/lib/libboost_math_tr1l.a(laguerrel.o):
/usr/local/lib/libboost_math_tr1l.a(legendrel.o):
/usr/local/lib/libboost_math_tr1l.a(riemann_zetal.o):
/usr/local/lib/libboost_math_tr1l.a(sph_bessell.o):
/usr/local/lib/libboost_math_tr1l.a(sph_legendrel.o):
/usr/local/lib/libboost_math_tr1l.a(sph_neumannl.o):
/usr/local/lib/libboost_math_tr1l.dylib:
libboost_math_tr1l.dylib (compatibility version 0.0.0, current
version 0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_prg_exec_monitor.a
/usr/local/lib/libboost_prg_exec_monitor.a(debug.o):
/usr/local/lib/libboost_prg_exec_monitor.a(execution_monitor.o):
/usr/local/lib/libboost_prg_exec_monitor.a(cpp_main.o):
/usr/local/lib/libboost_prg_exec_monitor.dylib:
libboost_prg_exec_monitor.dylib (compatibility version 0.0.0, current
version 0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_program_options.a
/usr/local/lib/libboost_program_options.a(cmdline.o):
/usr/local/lib/libboost_program_options.a(config_file.o):
/usr/local/lib/libboost_program_options.a(options_description.o):
/usr/local/lib/libboost_program_options.a(parsers.o):
/usr/local/lib/libboost_program_options.a(variables_map.o):
/usr/local/lib/libboost_program_options.a(value_semantic.o):
/usr/local/lib/libboost_program_options.a(positional_options.o):
/usr/local/lib/libboost_program_options.a(utf8_codecvt_facet.o):
/usr/local/lib/libboost_program_options.a(convert.o):
/usr/local/lib/libboost_program_options.a(winmain.o):
/usr/local/lib/libboost_program_options.a(split.o):
/usr/local/lib/libboost_program_options.dylib:
libboost_program_options.dylib (compatibility version 0.0.0, current
version 0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_python.a
/usr/local/lib/libboost_python.a(numeric.o):
/usr/local/lib/libboost_python.a(list.o):
/usr/local/lib/libboost_python.a(long.o):
/usr/local/lib/libboost_python.a(dict.o):
/usr/local/lib/libboost_python.a(tuple.o):
/usr/local/lib/libboost_python.a(str.o):
/usr/local/lib/libboost_python.a(slice.o):
/usr/local/lib/libboost_python.a(from_python.o):
/usr/local/lib/libboost_python.a(registry.o):
/usr/local/lib/libboost_python.a(type_id.o):
/usr/local/lib/libboost_python.a(enum.o):
/usr/local/lib/libboost_python.a(class.o):
/usr/local/lib/libboost_python.a(function.o):
/usr/local/lib/libboost_python.a(inheritance.o):
/usr/local/lib/libboost_python.a(life_support.o):
/usr/local/lib/libboost_python.a(pickle_support.o):
/usr/local/lib/libboost_python.a(errors.o):
/usr/local/lib/libboost_python.a(module.o):
/usr/local/lib/libboost_python.a(builtin_converters.o):
/usr/local/lib/libboost_python.a(arg_to_python_base.o):
/usr/local/lib/libboost_python.a(iterator.o):
/usr/local/lib/libboost_python.a(stl_iterator.o):
/usr/local/lib/libboost_python.a(object_protocol.o):
/usr/local/lib/libboost_python.a(object_operators.o):
/usr/local/lib/libboost_python.a(wrapper.o):
/usr/local/lib/libboost_python.a(import.o):
/usr/local/lib/libboost_python.a(exec.o):
/usr/local/lib/libboost_python.a(function_doc_signature.o):
/usr/local/lib/libboost_python.dylib:
libboost_python.dylib (compatibility version 0.0.0, current version
0.0.0)
/System/Library/Frameworks/Python.framework/Versions/2.7/Python
(compatibility version 2.7.0, current version 2.7.2)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_random.a
/usr/local/lib/libboost_random.a(random_device.o):
/usr/local/lib/libboost_random.dylib:
libboost_random.dylib (compatibility version 0.0.0, current version
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_regex.a
/usr/local/lib/libboost_regex.a(c_regex_traits.o):
/usr/local/lib/libboost_regex.a(cpp_regex_traits.o):
/usr/local/lib/libboost_regex.a(cregex.o):
/usr/local/lib/libboost_regex.a(fileiter.o):
/usr/local/lib/libboost_regex.a(icu.o):
/usr/local/lib/libboost_regex.a(instances.o):
/usr/local/lib/libboost_regex.a(posix_api.o):
/usr/local/lib/libboost_regex.a(regex.o):
/usr/local/lib/libboost_regex.a(regex_debug.o):
/usr/local/lib/libboost_regex.a(regex_raw_buffer.o):
/usr/local/lib/libboost_regex.a(regex_traits_defaults.o):
/usr/local/lib/libboost_regex.a(static_mutex.o):
/usr/local/lib/libboost_regex.a(w32_regex_traits.o):
/usr/local/lib/libboost_regex.a(wc_regex_traits.o):
/usr/local/lib/libboost_regex.a(wide_posix_api.o):
/usr/local/lib/libboost_regex.a(winstances.o):
/usr/local/lib/libboost_regex.a(usinstances.o):
/usr/local/lib/libboost_regex.dylib:
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_serialization.a
/usr/local/lib/libboost_serialization.a(basic_archive.o):
/usr/local/lib/libboost_serialization.a(basic_iarchive.o):
/usr/local/lib/libboost_serialization.a(basic_iserializer.o):
/usr/local/lib/libboost_serialization.a(basic_oarchive.o):
/usr/local/lib/libboost_serialization.a(basic_oserializer.o):
/usr/local/lib/libboost_serialization.a(basic_pointer_iserializer.o):
/usr/local/lib/libboost_serialization.a(basic_pointer_oserializer.o):
/usr/local/lib/libboost_serialization.a(basic_serializer_map.o):
/usr/local/lib/libboost_serialization.a(basic_text_iprimitive.o):
/usr/local/lib/libboost_serialization.a(basic_text_oprimitive.o):
/usr/local/lib/libboost_serialization.a(basic_xml_archive.o):
/usr/local/lib/libboost_serialization.a(binary_iarchive.o):
/usr/local/lib/libboost_serialization.a(binary_oarchive.o):
/usr/local/lib/libboost_serialization.a(extended_type_info.o):
/usr/local/lib/libboost_serialization.a(extended_type_info_typeid.o):
/usr/local/lib/libboost_serialization.a(extended_type_info_no_rtti.o):
/usr/local/lib/libboost_serialization.a(polymorphic_iarchive.o):
/usr/local/lib/libboost_serialization.a(polymorphic_oarchive.o):
/usr/local/lib/libboost_serialization.a(stl_port.o):
/usr/local/lib/libboost_serialization.a(text_iarchive.o):
/usr/local/lib/libboost_serialization.a(text_oarchive.o):
/usr/local/lib/libboost_serialization.a(void_cast.o):
/usr/local/lib/libboost_serialization.a(archive_exception.o):
/usr/local/lib/libboost_serialization.a(xml_grammar.o):
/usr/local/lib/libboost_serialization.a(xml_iarchive.o):
/usr/local/lib/libboost_serialization.a(xml_oarchive.o):
/usr/local/lib/libboost_serialization.a(xml_archive_exception.o):
/usr/local/lib/libboost_serialization.a(shared_ptr_helper.o):
/usr/local/lib/libboost_serialization.dylib:
libboost_serialization.dylib (compatibility version 0.0.0, current
version 0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_signals.a
/usr/local/lib/libboost_signals.a(trackable.o):
/usr/local/lib/libboost_signals.a(connection.o):
/usr/local/lib/libboost_signals.a(named_slot_map.o):
/usr/local/lib/libboost_signals.a(signal_base.o):
/usr/local/lib/libboost_signals.a(slot.o):
/usr/local/lib/libboost_signals.dylib:
libboost_signals.dylib (compatibility version 0.0.0, current version
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_system.a
/usr/local/lib/libboost_system.a(error_code.o):
/usr/local/lib/libboost_system.dylib:
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_test_exec_monitor.a
/usr/local/lib/libboost_test_exec_monitor.a(compiler_log_formatter.o):
/usr/local/lib/libboost_test_exec_monitor.a(debug.o):
/usr/local/lib/libboost_test_exec_monitor.a(execution_monitor.o):
/usr/local/lib/libboost_test_exec_monitor.a(framework.o):
/usr/local/lib/libboost_test_exec_monitor.a(plain_report_formatter.o):
/usr/local/lib/libboost_test_exec_monitor.a(progress_monitor.o):
/usr/local/lib/libboost_test_exec_monitor.a(results_collector.o):
/usr/local/lib/libboost_test_exec_monitor.a(results_reporter.o):
/usr/local/lib/libboost_test_exec_monitor.a(test_main.o):
/usr/local/lib/libboost_test_exec_monitor.a(test_tools.o):
/usr/local/lib/libboost_test_exec_monitor.a(unit_test_log.o):
/usr/local/lib/libboost_test_exec_monitor.a(unit_test_main.o):
/usr/local/lib/libboost_test_exec_monitor.a(unit_test_monitor.o):
/usr/local/lib/libboost_test_exec_monitor.a(unit_test_parameters.o):
/usr/local/lib/libboost_test_exec_monitor.a(unit_test_suite.o):
/usr/local/lib/libboost_test_exec_monitor.a(xml_log_formatter.o):
/usr/local/lib/libboost_test_exec_monitor.a(xml_report_formatter.o):
Archive : /usr/local/lib/libboost_thread.a
/usr/local/lib/libboost_thread.a(thread.o):
/usr/local/lib/libboost_thread.a(once.o):
/usr/local/lib/libboost_thread.a(future.o):
0.0.0)
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_timer.a
/usr/local/lib/libboost_timer.a(auto_timers_construction.o):
/usr/local/lib/libboost_timer.a(cpu_timer.o):
/usr/local/lib/libboost_timer.dylib:
libboost_timer.dylib (compatibility version 0.0.0, current version
0.0.0)
0.0.0)
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_unit_test_framework.a
/usr/local/lib/libboost_unit_test_framework.a(compiler_log_formatter.o):
/usr/local/lib/libboost_unit_test_framework.a(debug.o):
/usr/local/lib/libboost_unit_test_framework.a(execution_monitor.o):
/usr/local/lib/libboost_unit_test_framework.a(framework.o):
/usr/local/lib/libboost_unit_test_framework.a(plain_report_formatter.o):
/usr/local/lib/libboost_unit_test_framework.a(progress_monitor.o):
/usr/local/lib/libboost_unit_test_framework.a(results_collector.o):
/usr/local/lib/libboost_unit_test_framework.a(results_reporter.o):
/usr/local/lib/libboost_unit_test_framework.a(test_tools.o):
/usr/local/lib/libboost_unit_test_framework.a(unit_test_log.o):
/usr/local/lib/libboost_unit_test_framework.a(unit_test_main.o):
/usr/local/lib/libboost_unit_test_framework.a(unit_test_monitor.o):
/usr/local/lib/libboost_unit_test_framework.a(unit_test_parameters.o):
/usr/local/lib/libboost_unit_test_framework.a(unit_test_suite.o):
/usr/local/lib/libboost_unit_test_framework.a(xml_log_formatter.o):
/usr/local/lib/libboost_unit_test_framework.a(xml_report_formatter.o):
/usr/local/lib/libboost_unit_test_framework.a(exception_safety.o):
/usr/local/lib/libboost_unit_test_framework.a(interaction_based.o):
/usr/local/lib/libboost_unit_test_framework.a(logged_expectations.o):
/usr/local/lib/libboost_unit_test_framework.dylib:
libboost_unit_test_framework.dylib (compatibility version 0.0.0,
current version 0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_wave.a
/usr/local/lib/libboost_wave.a(instantiate_cpp_exprgrammar.o):
/usr/local/lib/libboost_wave.a(instantiate_cpp_grammar.o):
/usr/local/lib/libboost_wave.a(instantiate_cpp_literalgrs.o):
/usr/local/lib/libboost_wave.a(instantiate_defined_grammar.o):
/usr/local/lib/libboost_wave.a(instantiate_predef_macros.o):
/usr/local/lib/libboost_wave.a(instantiate_re2c_lexer.o):
/usr/local/lib/libboost_wave.a(instantiate_re2c_lexer_str.o):
/usr/local/lib/libboost_wave.a(token_ids.o):
/usr/local/lib/libboost_wave.a(wave_config_constant.o):
/usr/local/lib/libboost_wave.a(aq.o):
/usr/local/lib/libboost_wave.a(cpp_re.o):
/usr/local/lib/libboost_wave.dylib:
libboost_wave.dylib (compatibility version 0.0.0, current version
0.0.0)
0.0.0)
version 0.0.0)
version 0.0.0)
0.0.0)
0.0.0)
65.1.0)
version 169.3.0)
Archive : /usr/local/lib/libboost_wserialization.a
/usr/local/lib/libboost_wserialization.a(basic_text_wiprimitive.o):
/usr/local/lib/libboost_wserialization.a(basic_text_woprimitive.o):
/usr/local/lib/libboost_wserialization.a(text_wiarchive.o):
/usr/local/lib/libboost_wserialization.a(text_woarchive.o):
/usr/local/lib/libboost_wserialization.a(utf8_codecvt_facet.o):
/usr/local/lib/libboost_wserialization.a(xml_wgrammar.o):
/usr/local/lib/libboost_wserialization.a(xml_wiarchive.o):
/usr/local/lib/libboost_wserialization.a(xml_woarchive.o):
/usr/local/lib/libboost_wserialization.a(codecvt_null.o):
/usr/local/lib/libboost_wserialization.dylib:
libboost_wserialization.dylib (compatibility version 0.0.0, current
version 0.0.0)
version 0.0.0)
65.1.0)
version 169.3.0)
