cgal-discuss - Re: [cgal-discuss] Delaunay_d example fails
  • To:
  • Subject: Re: [cgal-discuss] Delaunay_d example fails
  • Date: Thu, 24 Apr 2014 22:43:07 -0700
Aha, thank you Sebastien!
Swapping out GMP fixes this.
On Thu, Apr 24, 2014 at 10:16 PM, Sebastien Loriot (GeometryFactory) <> wrote:
Note that you need to install leda if you want to use it.
Sebastien.
On 04/25/2014 05:27 AM, Adam Getchell wrote:
Hello all,
I have just installed CGAL 4.4, and I am playing with the example:
http://doc.cgal.org/latest/Convex_hull_d/classCGAL_1_1Delaunay__d.html
My code is:
https://github.com/acgetchell/CDT-plusplus/blob/Delaunay_d/dSimplex.cpp
However, I get errors with leda_integer:
https://gist.github.com/acgetchell/11276915
Any suggestions welcome.
Thank you.
Adam Getchell
On 6/4/13, 9:34 AM, "Guillaume Damiand" <.fr>
wrote:
Hi,
On 04/06/2013 17:36, acgetchell wrote:
Hello all,
The example listed here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Combinatorial_map/
Chapter_main.html#Subsection_27.6.3
Looks like it generates a tetrahedron.
What is the best way for generating 4-simplices and storing them?
You can use a 4D combinatorial map, and write a function that create a
4-simplex by creating 4 tetrahedron (thanks to the function
CGAL::make_combinatorial_tetrahedron<CMap>) and use 3-sew to glue them
correctly.
Thanks to this function you can create several 4-simplices and use 4-sew
operation to glue them.
Note that if you need geometry, you need to use a 4D linear cell complex
instead of a 4D combinatorial map.
Guillaume
Thanks for any pointers,
Adam
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Pointers-for-generating-4-dimens
ional-simplices-tp4657646.html
Guillaume DAMIAND
CNRS, LIRIS  UMR 5205
Université Claude Bernard
Bātiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Phone: +33 (0)4.72.43.26.62               Fax: +33 (0)4.72.43.15.36
Mail: .fr
Adam Getchell
"Invincibility is in oneself, vulnerability in the opponent." -- Sun Tzu
